I was just curious - in F90, and in particular, for CVF, if I have a routine that accesses a derived-type variable many times during the course of a simulation, is it any more advantageous to store that derived type variable as a local variable as opposed to just using it directly. In other words, is it significantly faster to access a variable ala
var1 = data%var1
DO i = 1, 10000
var2 = var1
ENDDO
or would it make no difference in terms of execution speed to just do
DO i = 1, 10000
var2 = data%var1
ENDDO
If not, would it also hold true for multiply embedded derived types, ala
var2 = data%var1(1)%var3%var4
Chris
var1 = data%var1
DO i = 1, 10000
var2 = var1
ENDDO
DO i = 1, 10000
var2 = data%var1
ENDDO
Chris
In current versions of CVF, it should make no difference. My general recommendation is to write code in a way that makes sense to you, and not spend time worrying up front about which programming paradigm is "fastest". (You should try to be aware of significant performance divots, such as vector subscripts.)
Steve
Steve
