Software Archive
Read-only legacy content
17061 Discussions
Adapting modern tools to bioinformatic research results.
mcgama88
by Mark McGary
Lets take a look at the demands of software execution on large volume protein residue. The nature of the protein residue is the nomenclature of protein. Adequate translation and volume of data are problematic to sorting and path.
The building blocks of genetic material and cellular pathways are certainly under a variety of assay and sorting scruntiny. I have a fondness for Dr. Selkov and the larger teams, ANL, and his work published in support and mission therein. This comes in part because I adapted to those tools and began a research path that has led to findings of certain cell division anchor positions. While a number of years in full basic development, the impact of understanding gene data remains complex and variable when looking a single type of finding.
Identified in a species of spyrochete, an unusual problem is to now develop adequate software to provide translation mechanics and basic challenge to other species. Because this sorting and assay is a departure from available toolbars, it would complement eXpasy and EMBl, many many fine sites of future good.
Taken in light of the growing antibiotic drug resistance seen across the globe, probable targets in cell division mechanism is worthy of a best effort in software anyalisis. This challenge has become one of adaptation and use of tools
suited even to the desktop. A larger genetic assay might wait but design and sorting aspects demand resource and craftmanship. A design path perhaps critical in understanding intersections of disease and host.
I'd like to talk about a design that incorporates parallel tools from the beginning.
Lets take a look at current thought and method in protein assay, with a deep and certain understanding that software developments are catching up to the needs of research. Understanding the development of one path may shed light on problems in many research and scientific means, including cost of development.
Problem one: adapting the protein soup. It may interest the observer to understand a good alphabet for protein exists. Called fasta, this nomenclature has come to represent amino residues. Based on the english alphabet, it departs by excluding j,o, and x.
An excell page has proven of value to retain this nomenclature.
Many protein tools can examine certain aspects of this comparative nomenclature and can include other information such as mole weight and acid base, polar non polar data.
The fundamental resource of modern protein assay lies in the comparative view.
Comparing one organism's gene patterns to another. This seems straight forward until the sheer volume of sorting is found. A single bacteria is equipped with several hundreds of thousands or even millions of base pairings to so equip life process. Then comes the fact that gene mechanics are adaptive process.
Things go wrong or right and varations of species happen. The end researcher is left to grapple with comparative regions that exibit slight change.
Many modern process of sorting handle a comparative view one gene to another or set of others at a time. In a too brief way....think of a bell curve with the top most tip of bell results....and away to print a set of most alike.
Where this could in my opinion be improved is a new stratagy of comparative view of cell division anchor. With this as a start point, software to assay across species would demonstrate wider patterns. Think of two endpoints with flexible ends. While not static, the concept of interior region seems of merit.
In fact, this type of result is seen in the spyrochete and at least two more species.
Many more remain to be examined.
It remains a goal to examine protein. Lets examine how parallel tools might impact results.
It would be rather useful to see work deployable to the fine products now close to production. This software design ....and hence....production, then, demands an undertaking of design that maximizes research by speed and adaptive use of
parallel universe.
Language selection.
In the view of wide deployment, visual studio with parallel tools seems fit. adapt .NET?
That is to say the tools would be found on many near future products. However, how about C++. Dr. W. Kim, (Intel), talks about condition variables. This exact public method seems radily adaptable to the mechanics of wide string endpoint sorting.
Let us consider the advantages of parallelism in multiple genetic sorts. The sort needs to get to a characterization that might be useful in the semaphore. Dr. Kim points out the thinking.C. A. R. Hoare and Per Brinch Hansen developed the idea of monitors around 1972, based on earlier ideas of their own and of E. W. Dijkstra. [7] Brinch Hansen was the first to implement monitors. Hoare developed the theoretical framework and demonstrated their equivalence to semaphores
The protein sorting....and endpoint selection in species might get to here:
Whenever a thread leaves the monitor (by returning or waiting) the assertions of all waiting threads are evaluated until one is found to be true. In such a system, condition variables are not needed, but the assertions must be explicitly coded. The contract for wait is Cell division anchor positions in genetic residues of spyrochetae.
CAn the concept of true in the semaphore be shaped to include a cell division anchor set?
Enumeration of one gene and it's residue.....seem a likely challenge for past practice. By design, parallel thought should be able to provide sort executions of a level beyond existing means.
The evidence of a finished sort is where a default sort
{ {default sort: mol weight 131}}where mol weight 131 isoleucine, letter I in fasta, is interior to
*for example Ubiquitin A-32 residual ribosomal protein fusion product 1
Homo sapiens........ as opposed to the larger spyrochete findings of the form glutaminexxxxxxxxxxxxxxxglutamine. This was cell division anchor finding, cira 2000 (WIT). Now to propose other species sorting. But how to get there. ? Is the condition varaible idea the best sort. Is the C== form the best underlying structure to build upon?
remembering every protein chemical defined by the order of their amino acid residues, their primary structure.
now takes up sort as previous to thread.
previous to semaphore..
. I promise to resume my talk on where event id in protein needs to fall in thread . I know I seem to leave questions, but I hopethey are interesting questions. In finding a weight to put as conceptual in this developmental thinking, consider resistance mutations and how to catagorize that mechanism as a variable.
It is rather, I hope interesting to take aim at the middle.I've been watching the parallel universe talks....and deeply considering how to get the sorting routines into parallel. That is to say, design the best fit.
Mark M.
Washington state.
*References : Dr. W. Kim
Selkov, et al. WIT, ANL
*see Susan Napier
Dan Weirreb
Wiki page: in production
Assay of cell division anchor positions in the spyrochete and gram posiitive, negative pathogen
Similar thesis topic.
I.
