Software Archive
Read-only legacy content
17060 Discussions
Adding vectors with MIC
Anwar_Ludin
Is the following code sample for adding vectors correct? Can I make it even faster using vectorized operations?
void vectorAdd(float*a, float*b, float* r,int size)
   #pragma offload target(mic) in(a:length(size)) in(b:length(size)) inout(r:length(size))
   #pragmaopenmp parallel for shared(a,b,r) private(i)
   for(inti=0; i<size; ++i)
      r = a+b;
TimP
You probably need float * restrict a, float * restrict b, float *restrict r   (or one of the ivdep pragmas) to get auto-vectorization.  Alignment would help if you make all the OpenMP chunks a multiple of 32.
A single offloaded vector operation like this would spend a majority of the time on data transfer.
