Software Archive
Read-only legacy content
17061 Discusiones
After update to 3900 intel xdk not starting [Ubuntu]
Eneko_R_
Principiante
1.243 Vistas
I've upgraded my intel xdk to the new version and I can't open the program. I tried to reinstall, with and without sudo, launching it from .sh file, formating ubuntu, and it is imposible. How can I open the program or debug this action?
Please this issue is very important for us.
0 kudos
8 Respuestas
PaulF_IntelCorp
Empleados
1.243 Vistas
Which version of Ubuntu are you using? Are you using Ubuntu 64-bit or 32-bit? Which XDK did you download and install? 32-bit or 64-bit? Did you install the XDK as a "local user"? A local install should end up in your home directory.
Eneko_R_
Principiante
1.243 Vistas
I'm using Ubuntu 16.04 LTS 64-bit. I downloaded 64-bit. I installed it "local user" (home directory) and I tried as root too (/opt directory).
Thanks for your reply
PaulF_IntelCorp
Empleados
1.243 Vistas
Please provide a video or series of screenshots that show precisely what is happening (or not happening).
Eneko_R_
Principiante
1.243 Vistas
Nothing is happening. No errors, no warnings, nothing. I can send video or screenshots, but...
I have been tried to launch it from icon and it seems to start, but, finally, the icon disappear and program keep been closed. I tried to open it from the shell too, and nothing happened.
I have to say that i'm working over intel xdk for 1'5 years.
Exists any execution log?
PaulF_IntelCorp
Empleados
1.243 Vistas
Yes, there is an "xdk.log" file that is created each time the XDK starts. It should be located underneath the ~/.config/XDK folder. The precise location moved as a result of this upgrade, so you might find two copies (old version and new version). That file will only be created if the XDK proper actually started. If the shell script is failing, it's not likely to show up in that file.
PaulF_IntelCorp
Empleados
1.243 Vistas
I just performed an upgrade on my Ubuntu 16.04 64-bit image and it installed and ran without issue.
Here's what ps reports as the command for a "local" install:
  • ~/intel/XDK/bin/nw ~/intel/XDK/xdk --enable-logging
If you use that at the command-line it should start (assuming a similar installation).
Otherwise, after it started, I locked the launch to the start bar, and this is what it generated:
[Desktop Entry]
Exec=/home/ubuntu/intel/XDK/xdk.sh
Icon=intel-xdk
Type=Application
Terminal=false
Name=Intel XDK
GenericName=Intel XDK
Categoreis=Development:Intel XDK
Where "ubuntu" is this machines home folder, which you'll have to change to match your system. That file is named "intel-xdk-app.desktop" and is located in the "~/.local/share/applications" folder and has "rwx" permissions for the user, only (i.e., chmod 700).
Hope that helps, I'll get further clarification from the appropriate engineer when I can track him down. :)
PaulF_IntelCorp
Empleados
1.243 Vistas
I just confirmed that the "xdk.sh" script is what you should be using the start the XDK (the one referenced in the desktop file is the script you should be using the start the XDK). Is that the one you are attempting to use to start the XDK?
Alternatively, if you try something like this does it work?
$ ~/intel/XDK/bin/nw ~/intel/XDK/xdk --enable-logging &
Elias_B_
Principiante
1.243 Vistas
I had the same problem. I used
And looked that libgconf-2.so.4 isn't installed. apt-get install libgconf-2-4 and all is done (for me)!
Thanks! :-)
Responder
