Software Archive
Read-only legacy content
17060 Discussions
Allocate and deallocate problem
Deleted_U_Intel
We currently have MS Fortran Powerstation 4.0. We are experiencing an important problem regarding the deallocation of pointers. We would like to know if this problem still persists in Compaq Visual Fortran.
Louis
C#######################################################################
C
C     This test has been performed with MS Fortran Power Station 4.0
C
C     This program creates a linked list of "item".
C     It test the speed of allocation and speed of deallocation
C
C     We found that the deallocation is made from the last item to
C     the first is adequate.
C
C     But the deallocation becomes very slow when it is made from the first item
C     to the last. It can be more than 100 times slower!!!
C
C     If additionnal independent linked lists are defined, the deallocation speed
C     decreases exponentially when made from the first item to the last.
C
C     Can you tell me if this problem still occurs in the new version
C     of Compaq Visual Fortran 6.5.
C
C     To test this program all you need to do is to create a console application
C     and change the value of KORDER as follows
C
C        KORDER = 1 ! 1 = Deallocate from first to last
C        KORDER = 2 ! 2 = Deallocate from last to first
C
C
        Program Test
C
        TYPE item
         integer      KVAL
         integer      KOTHER
C
         TYPE (item),POINTER  previous_item
         TYPE (item),POINTER  next_item
        END TYPE item
C
        INTEGER KORDER,II,KTOT
C
        TYPE (item),POINTER  first_item
        TYPE (item),POINTER  last_item
C
C------------------
        type(item), POINTER  parent_item
        type(item), POINTER  current_item
C------------------
C
C
C       Initialization
        KTOT = 0
        NULLIFY(first_item)
        NULLIFY(last_item)
C
C       Add 50000 Items
        DO II = 1,50000
          allocate(current_item)
          nullify(current_item%next_item)
C
          IF (KTOT.LE.0) THEN
            first_item=>current_item
            nullify(current_item%previous_item)
            KTOT = 1
          ELSE
            parent_item=>last_item
            parent_item%next_item=>current_item
            current_item%previous_item=>parent_item
            KTOT = KTOT + 1
          END IF
          current_item%KVAL = II
          last_item=>current_item
        END DO
C
        IF (KORDER.EQ.1) THEN
C       SLOW deallocation
          current_item=>first_item
          DO II=1,KTOT
            parent_item=>current_item%next_item
            if (associated(current_item)) deallocate(current_item)
           current_item=>parent_item
          END DO
        ELSE
C         QUICK deallocation
          current_item=>last_item
          DO II=1,KTOT
            parent_item=>current_item%previous_item
          END DO
        END IF
C
        END
C
You also sent this to us at vf-support. My response was as follows:
Compaq Visual Fortran's compiler and language libraries are our own and not
derived from Microsoft's. Visual Fortran 6.5 executes your test program very
quickly, using either value of KORDER.
Steve
