Software Archive
Read-only legacy content
17060 Discussions
An error occurred while building the application. Verify your build assets are correct and try again.[iOS]
Jure_C_
I have HTML5 + CORDOVA + Ionics project, INTEL XDK version is 1995.
Project name is IonTest. I tryed to build application under the name: SOLINTERRA #1, SOLINTERRA, IonTest.
I can build my application without a problem for Android. But when I try to build it for iPhone I get An error occurred while building the application. Verify your build assets are correct and try again.
I have added p12,provisionig profile...
When in test, I could build a .ipa file.
PaulF_IntelCorp
Try to limit your use of the intel.xdk APIs, they are going away and are based on very old implementations of PhoneGap. The equivalent Cordova APIs are a better choice, including use of the "deviceready" event instead of that "intel.xdk.device.ready" event to detect initialization of the Cordova subsystem.
Use the Cordova "StatusBar" plugin (last plugin in the leftmost column of plugins in the Plugins section of the Projects tab) instead of intel.xdk.device.hideStatusBar().
I have never seen this network alert, you may need to do some further debugging to determine where that is coming from.
Amrita_C_Intel
Can you please provide with your build log?
Jure_C_
where can I find build log? I have the same screen as the person that created this thread: https://software.intel.com/en-us/forums/topic/558489
PaulF_IntelCorp
Are you using a dev or production provisioning file? You need to use an ad-hoc provisioning file for testing.
Amrita_C_Intel
Are you using the classic (legacy) build or the Cordova build or iOS?
Amrita_C_Intel
You can see the error log just below the build failed message if you are using Cordova build.
Jure_C_
@Paul Fischer
I tried both dev and production profiles.
@Amrita C.
I am using Cordova build. And there is no error log.
I tried another build so that I could make a screenshot for Amrita about the build log and now application was build. I hope that I will have enough time to try it today and that it will work without problems. I will replay if there will be more problems, but thank you for your help.
Jure_C_
I have to problems with my app. If I should  open a new thread, please tell me.
First problem is that on iPhone 4, iOS 7.1.1 I can't hide status bar. For that purpose I use this code in index.html
<script>
    var onDeviceReady=function(){
        //alert("device ready");
                //----------- Set device orientation -----------------------
                intel.xdk.device.setRotateOrientation("landscape");
                intel.xdk.device.setAutoRotate(false);
                //----------- Hide status bar ------------------------------
                intel.xdk.device.hideStatusBar();
document.addEventListener("intel.xdk.device.ready",onDeviceReady,false);
    </script> -->
Second problem have been encountered on both Android and iOS, when you load the application for the first time, it will fire alert that it you should check internet connection. This alert gets fired if app doesn't retrive data from web api in 5 secconds. If you close the app and run it again, it works fine.Second problem have been encountered on both Android and iOS, when you load the application for the first time, it will fire alert that it you should check internet connection. This alert gets fired if app doesn't retrieve data from web api in 5 seconds. If you close the app and run it again, it works fine.
PaulF_IntelCorp
Jure_C_
That alert is alert that I display, when trigger for connection timeout is triggered.
I will change intel.xdkAPIs with Cordova APIs.
EDIT: Now that I changed APIs, status bar is hidden, like it should be. But still I don't know why I get that connection alert.
Thank you.
Matthew_S_8
I too got the same error. this is my build log
Calling plugman.fetch on plugin ".../cachedPlugins.vnGEFJ.tmp/cache.WA1LX5.pl/cordova-plugin-statusbar"
Copying plugin ".../cachedPlugins.vnGEFJ.tmp/cache.WA1LX5.pl/cordova-plugin-statusbar" => ".../GlobalApp/plugins/cordova-plugin-statusbar"
Calling plugman.install on plugin ".../GlobalApp/plugins/cordova-plugin-statusbar" for platform "ios" with options "{"cli_variables":{},"browserify":false,"link":false,"pluginInfoProvider":{"_cache":{".../cachedPlugins.vnGEFJ.tmp/cache.WA1LX5.pl/cordova-plugin-statusbar":{"filepath":".../cachedPlugins.vnGEFJ.tmp/cache.WA1LX5.pl/cordova-plugin-statusbar/plugin.xml","dir":".../cachedPlugins.vnGEFJ.tmp/cache.WA1LX5.pl/cordova-plugin-statusbar","_et":{"_root":{"_id":27,"tag":"plugin","attrib":{"xmlns":"http://apache.org/cordova/ns/plugins/1.0","xmlns:rim":"http://www.blackberry.com/ns/widgets","xmlns:android":"http://schemas.android.com/apk/res/android","id":"cordova-plugin-statusbar","version":"1.0.0"},"text":"\n    ","tail":null,"_children":[{"_id":28,"tag":"name","attrib":{},"text":"StatusBar","tail":"\n    ","_children":[]},{"_id":29,"tag":"description","attrib":{},"text":"Cordova StatusBar Plugin","tail":"\n    ","_children":[]},{"_id":30,"tag":"license","attrib":{},"text":"Apache 2.0","tail":"\n    ","_children":[]},{"_id":31,"tag":"keywords","attrib":{},"text":"cordova,statusbar","tail":"\n\n    ","_children":[]},{"_id":32,"tag":"engines","attrib":{},"text":"\n            ","tail":"\n\n    ","_children":[{"_id":33,"tag":"engine","attrib":{"name":"cordova","version":">=3.0.0"},"text":"","tail":"\n    ","_children":[]}]},{"_id":34,"tag":"js-module","attrib":{"src":"www/statusbar.js","name":"statusbar"},"text":"\n        ","tail":"\n\n    ","_children":[{"_id":35,"tag":"clobbers","attrib":{"target":"window.StatusBar"},"text":"","tail":"\n    ","_children":[]}]},{"_id":36,"tag":"platform","attrib":{"name":"android"},"text":"\n        ","tail":"\n\n    \n    ","_children":[{"_id":37,"tag":"source-file","attrib":{"src":"src/android/StatusBar.java","target-dir":"src/org/apache/cordova/statusbar"},"text":"","tail":"\n\n        ","_children":[]},{"_id":38,"tag":"config-file","attrib":{"target":"res/xml/config.xml","parent":"/*"},"text":"\n            ","tail":"\n    ","_children":[{"_id":39,"tag":"feature","attrib":{"name":"StatusBar"},"text":"\n                ","tail":"\n        ","_children":[{"_id":40,"tag":"param","attrib":{"name":"android-package","value":"org.apache.cordova.statusbar.StatusBar"},"text":"","tail":"\n                ","_children":[]},{"_id":41,"tag":"param","attrib":{"name":"onload","value":"true"},"text":"","tail":"\n            ","_children":[]}]}]}]},{"_id":42,"tag":"platform","attrib":{"name":"ios"},"text":"\n\n        ","tail":"\n\n    \n    ","_children":[{"_id":43,"tag":"config-file","attrib":{"target":"config.xml","parent":"/*"},"text":"\n            ","tail":"\n\n        ","_children":[{"_id":44,"tag":"feature","attrib":{"name":"StatusBar"},"text":"\n                ","tail":"\n            ","_children":[{"_id":45,"tag":"param","attrib":{"name":"ios-package","value":"CDVStatusBar"},"text":"","tail":"\n                ","_children":[]},{"_id":46,"tag":"param","attrib":{"name":"onload","value":"true"},"text":"","tail":"\n            ","_children":[]}]},{"_id":47,"tag":"preference","attrib":{"name":"StatusBarOverlaysWebView","value":"true"},"text":"","tail":"\n            ","_children":[]},{"_id":48,"tag":"preference","attrib":{"name":"StatusBarStyle","value":"lightcontent"},"text":"","tail":"\n        ","_children":[]}]},{"_id":49,"tag":"header-file","attrib":{"src":"src/ios/CDVStatusBar.h"},"text":"","tail":"\n        ","_children":[]},{"_id":50,"tag":"source-file","attrib":{"src":"src/ios/CDVStatusBar.m"},"text":"","tail":"\n\n    ","_children":[]}]},{"_id":51,"tag":"platform","attrib":{"name":"wp7"},"text":"\n        ","tail":"\n\n    \n    ","_children":[{"_id":52,"tag":"config-file","attrib":{"target":"config.xml","parent":"/*"},"text":"\n            ","tail":"\n        ","_children":[{"_id":53,"tag":"feature","attrib":{"name":"StatusBar"},"text":"\n                ","tail":"\n        ","_children":[{"_id":54,"tag":"param","attrib":{"name":"wp-package","value":"StatusBar"},"text":"","tail":"\n            ","_children":[]}]}]},{"_id":55,"tag":"source-file","attrib":{"src":"src/wp/StatusBar.cs"},"text":"","tail":"\n    ","_children":[]}]},{"_id":56,"tag":"platform","attrib":{"name":"wp8"},"text":"\n        ","tail":"\n\n    \n    ","_children":[{"_id":57,"tag":"config-file","attrib":{"target":"config.xml","parent":"/*"},"text":"\n            ","tail":"\n        ","_children":[{"_id":58,"tag":"feature","attrib":{"name":"StatusBar"},"text":"\n                ","tail":"\n        ","_children":[{"_id":59,"tag":"param","attrib":{"name":"wp-package","value":"StatusBar"},"text":"","tail":"\n            ","_children":[]}]}]},{"_id":60,"tag":"source-file","attrib":{"src":"src/wp/StatusBar.cs"},"text":"","tail":"\n    ","_children":[]}]},{"_id":61,"tag":"platform","attrib":{"name":"windows"},"text":"\n        ","tail":"\n","_children":[{"_id":62,"tag":"js-module","attrib":{"src":"src/windows/StatusBarProxy.js","name":"StatusBarProxy"},"text":"\n            ","tail":"\n    ","_children":[{"_id":63,"tag":"runs","attrib":{},"text":"","tail":"\n        ","_children":[]}]}]}]}},"id":"cordova-plugin-statusbar","version":"1.0.0","name":"StatusBar","description":"Cordova StatusBar Plugin","license":"Apache 2.0","keywords":["cordova","statusbar"]},".../GlobalApp/plugins/cordova-plugin-statusbar":{"filepath":".../GlobalApp/plugins/cordova-plugin-statusbar/plugin.xml","dir":".../GlobalApp/plugins/cordova-plugin-statusbar","_et":{"_root":{"_id":64,"tag":"plugin","attrib":{"xmlns":"http://apache.org/cordova/ns/plugins/1.0","xmlns:rim":"http://www.blackberry.com/ns/widgets","xmlns:android":"http://schemas.android.com/apk/res/android","id":"cordova-plugin-statusbar","version":"1.0.0"},"text":"\n    ","tail":null,"_children":[{"_id":65,"tag":"name","attrib":{},"text":"StatusBar","tail":"\n    ","_children":[]},{"_id":66,"tag":"description","attrib":{},"text":"Cordova StatusBar Plugin","tail":"\n    ","_children":[]},{"_id":67,"tag":"license","attrib":{},"text":"Apache 2.0","tail":"\n    ","_children":[]},{"_id":68,"tag":"keywords","attrib":{},"text":"cordova,statusbar","tail":"\n\n    ","_children":[]},{"_id":69,"tag":"engines","attrib":{},"text":"\n            ","tail":"\n\n    ","_children":[{"_id":70,"tag":"engine","attrib":{"name":"cordova","version":">=3.0.0"},"text":"","tail":"\n    ","_children":[]}]},{"_id":71,"tag":"js-module","attrib":{"src":"www/statusbar.js","name":"statusbar"},"text":"\n        ","tail":"\n\n    ","_children":[{"_id":72,"tag":"clobbers","attrib":{"target":"window.StatusBar"},"text":"","tail":"\n    ","_children":[]}]},{"_id":73,"tag":"platform","attrib":{"name":"android"},"text":"\n        ","tail":"\n\n    \n    ","_children":[{"_id":74,"tag":"source-file","attrib":{"src":"src/android/StatusBar.java","target-dir":"src/org/apache/cordova/statusbar"},"text":"","tail":"\n\n        ","_children":[]},{"_id":75,"tag":"config-file","attrib":{"target":"res/xml/config.xml","parent":"/*"},"text":"\n            ","tail":"\n    ","_children":[{"_id":76,"tag":"feature","attrib":{"name":"StatusBar"},"text":"\n                ","tail":"\n        ","_children":[{"_id":77,"tag":"param","attrib":{"name":"android-package","value":"org.apache.cordova.statusbar.StatusBar"},"text":"","tail":"\n                ","_children":[]},{"_id":78,"tag":"param","attrib":{"name":"onload","value":"true"},"text":"","tail":"\n            ","_children":[]}]}]}]},{"_id":79,"tag":"platform","attrib":{"name":"ios"},"text":"\n\n        ","tail":"\n\n    \n    ","_children":[{"_id":80,"tag":"config-file","attrib":{"target":"config.xml","parent":"/*"},"text":"\n            ","tail":"\n\n        ","_children":[{"_id":81,"tag":"feature","attrib":{"name":"StatusBar"},"text":"\n                ","tail":"\n            ","_children":[{"_id":82,"tag":"param","attrib":{"name":"ios-package","value":"CDVStatusBar"},"text":"","tail":"\n                ","_children":[]},{"_id":83,"tag":"param","attrib":{"name":"onload","value":"true"},"text":"","tail":"\n            ","_children":[]}]},{"_id":84,"tag":"preference","attrib":{"name":"StatusBarOverlaysWebView","value":"true"},"text":"","tail":"\n            ","_children":[]},{"_id":85,"tag":"preference","attrib":{"name":"StatusBarStyle","value":"lightcontent"},"text":"","tail":"\n        ","_children":[]}]},{"_id":86,"tag":"header-file","attrib":{"src":"src/ios/CDVStatusBar.h"},"text":"","tail":"\n        ","_children":[]},{"_id":87,"tag":"source-file","attrib":{"src":"src/ios/CDVStatusBar.m"},"text":"","tail":"\n\n    ","_children":[]}]},{"_id":88,"tag":"platform","attrib":{"name":"wp7"},"text":"\n        ","tail":"\n\n    \n    ","_children":[{"_id":89,"tag":"config-file","attrib":{"target":"config.xml","parent":"/*"},"text":"\n            ","tail":"\n        ","_children":[{"_id":90,"tag":"feature","attrib":{"name":"StatusBar"},"text":"\n                ","tail":"\n        ","_children":[{"_id":91,"tag":"param","attrib":{"name":"wp-package","value":"StatusBar"},"text":"","tail":"\n            ","_children":[]}]}]},{"_id":92,"tag":"source-file","attrib":{"src":"src/wp/StatusBar.cs"},"text":"","tail":"\n    ","_children":[]}]},{"_id":93,"tag":"platform","attrib":{"name":"wp8"},"text":"\n        ","tail":"\n\n    \n    ","_children":[{"_id":94,"tag":"config-file","attrib":{"target":"config.xml","parent":"/*"},"text":"\n            ","tail":"\n        ","_children":[{"_id":95,"tag":"feature","attrib":{"name":"StatusBar"},"text":"\n                ","tail":"\n        ","_children":[{"_id":96,"tag":"param","attrib":{"name":"wp-package","value":"StatusBar"},"text":"","tail":"\n            ","_children":[]}]}]},{"_id":97,"tag":"source-file","attrib":{"src":"src/wp/StatusBar.cs"},"text":"","tail":"\n    ","_children":[]}]},{"_id":98,"tag":"platform","attrib":{"name":"windows"},"text":"\n        ","tail":"\n","_children":[{"_id":99,"tag":"js-module","attrib":{"src":"src/windows/StatusBarProxy.js","name":"StatusBarProxy"},"text":"\n            ","tail":"\n    ","_children":[{"_id":100,"tag":"runs","attrib":{},"text":"","tail":"\n        ","_children":[]}]}]}]}},"id":"cordova-plugin-statusbar","version":"1.0.0","name":"StatusBar","description":"Cordova StatusBar Plugin","license":"Apache 2.0","keywords":["cordova","statusbar"]}},"_getAllCache":{}},"nohooks":["."]}"
Installing "cordova-plugin-statusbar" for ios
Running command: .../GlobalApp/platforms/ios/cordova/version
Command finished with error code 0: .../GlobalApp/platforms/ios/cordova/version
Install start for "cordova-plugin-statusbar" on ios.
Beginning processing of action stack for ios project...
Parsing ios project files...
Action stack processing complete.
Writing out ios project files...
Preparing ios project
Processing configuration changes for plugins.
Iterating over installed plugins: [ 'cordova-plugin-statusbar' ]
Writing out cordova_plugins.js...
Install complete for cordova-plugin-statusbar on ios.
Calling plugman.fetch on plugin ".../cachedPlugins.vnGEFJ.tmp/cache.zXrZxx.pl/cordova-plugin-device"
Copying plugin ".../cachedPlugins.vnGEFJ.tmp/cache.zXrZxx.pl/cordova-plugin-device" => ".../GlobalApp/plugins/cordova-plugin-device"
Calling plugman.install on plugin ".../GlobalApp/plugins/cordova-plugin-device" for platform "ios" with options "{"cli_variables":{},"browserify":false,"link":false,"pluginInfoProvider":{"_cache":{".../cachedPlugins.vnGEFJ.tmp/cache.zXrZxx.pl/cordova-plugin-device":{"filepath":".../cachedPlugins.vnGEFJ.tmp/cache.zXrZxx.pl/cordova-plugin-device/plugin.xml","dir":".../cachedPlugins.vnGEFJ.tmp/cache.zXrZxx.pl/cordova-plugin-device","_et":{"_root":{"_id":27,"tag":"plugin","attrib":{"xmlns":"http://apache.org/cordova/ns/plugins/1.0","xmlns:rim":"http://www.blackberry.com/ns/widgets","xmlns:android":"http://schemas.android.com/apk/res/android","id":"cordova-plugin-device","version":"1.0.1"},"text":"\n    ","tail":null,"_children":[{"_id":28,"tag":"name","attrib":{},"text":"Device","tail":"\n    ","_children":[]},{"_id":29,"tag":"description","attrib":{},"text":"Cordova Device Plugin","tail":"\n    ","_children":[]},{"_id":30,"tag":"license","attrib":{},"text":"Apache 2.0","tail":"\n    ","_children":[]},{"_id":31,"tag":"keywords","attrib":{},"text":"cordova,device","tail":"\n    ","_children":[]},{"_id":32,"tag":"repo","attrib":{},"text":"https://git-wip-us.apache.org/repos/asf/cordova-plugin-device.git","tail":"\n    ","_children":[]},{"_id":33,"tag":"issue","attrib":{},"text":"https://issues.apache.org/jira/browse/CB/component/12320648","tail":"\n\n    ","_children":[]},{"_id":34,"tag":"js-module","attrib":{"src":"www/device.js","name":"device"},"text":"\n        ","tail":"\n\n    \n    ","_children":[{"_id":35,"tag":"clobbers","attrib":{"target":"device"},"text":"","tail":"\n    ","_children":[]}]},{"_id":36,"tag":"platform","attrib":{"name":"firefoxos"},"text":"\n        ","tail":"\n\n    \n    ","_children":[{"_id":37,"tag":"config-file","attrib":{"target":"config.xml","parent":"/*"},"text":"\n            ","tail":"\n\n        ","_children":[{"_id":38,"tag":"feature","attrib":{"name":"Device"},"text":"\n                ","tail":"\n        ","_children":[{"_id":39,"tag":"param","attrib":{"name":"firefoxos-package","value":"Device"},"text":"","tail":"\n            ","_children":[]}]}]},{"_id":40,"tag":"js-module","attrib":{"src":"src/firefoxos/DeviceProxy.js","name":"DeviceProxy"},"text":"\n            ","tail":"\n    ","_children":[{"_id":41,"tag":"runs","attrib":{},"text":"","tail":"\n        ","_children":[]}]}]},{"_id":42,"tag":"platform","attrib":{"name":"tizen"},"text":"\n        ","tail":"\n\n    \n    ","_children":[{"_id":43,"tag":"js-module","attrib":{"src":"src/tizen/DeviceProxy.js","name":"DeviceProxy"},"text":"\n            ","tail":"\n    ","_children":[{"_id":44,"tag":"runs","attrib":{},"text":"","tail":"\n        ","_children":[]}]}]},{"_id":45,"tag":"platform","attrib":{"name":"android"},"text":"\n        ","tail":"\n\n    \n    ","_children":[{"_id":46,"tag":"config-file","attrib":{"target":"res/xml/config.xml","parent":"/*"},"text":"\n            ","tail":"\n\n        ","_children":[{"_id":47,"tag":"feature","attrib":{"name":"Device"},"text":"\n                ","tail":"\n        ","_children":[{"_id":48,"tag":"param","attrib":{"name":"android-package","value":"org.apache.cordova.device.Device"},"text":"","tail":"\n            ","_children":[]}]}]},{"_id":49,"tag":"source-file","attrib":{"src":"src/android/Device.java","target-dir":"src/org/apache/cordova/device"},"text":"","tail":"\n    ","_children":[]}]},{"_id":50,"tag":"platform","attrib":{"name":"amazon-fireos"},"text":"\n        ","tail":"\n    \n    \n    ","_children":[{"_id":51,"tag":"config-file","attrib":{"target":"res/xml/config.xml","parent":"/*"},"text":"\n            ","tail":"\n\n        ","_children":[{"_id":52,"tag":"feature","attrib":{"name":"Device"},"text":"\n                ","tail":"\n        ","_children":[{"_id":53,"tag":"param","attrib":{"name":"android-package","value":"org.apache.cordova.device.Device"},"text":"","tail":"\n            ","_children":[]}]}]},{"_id":54,"tag":"source-file","attrib":{"src":"src/android/Device.java","target-dir":"src/org/apache/cordova/device"},"text":"","tail":"\n    ","_children":[]}]},{"_id":55,"tag":"platform","attrib":{"name":"ubuntu"},"text":"\n        ","tail":"\n\n    \n    ","_children":[{"_id":56,"tag":"header-file","attrib":{"src":"src/ubuntu/device.h"},"text":"","tail":"\n        ","_children":[]},{"_id":57,"tag":"source-file","attrib":{"src":"src/ubuntu/device.cpp"},"text":"","tail":"\n        ","_children":[]},{"_id":58,"tag":"js-module","attrib":{"src":"src/ubuntu/device.js","name":"DeviceProxy"},"text":"\n            ","tail":"\n    ","_children":[{"_id":59,"tag":"merges","attrib":{"target":"device"},"text":"","tail":"\n        ","_children":[]}]}]},{"_id":60,"tag":"platform","attrib":{"name":"ios"},"text":"\n        ","tail":"\n\n    \n    ","_children":[{"_id":61,"tag":"config-file","attrib":{"target":"config.xml","parent":"/*"},"text":"\n            ","tail":"\n\n        ","_children":[{"_id":62,"tag":"feature","attrib":{"name":"Device"},"text":"\n                ","tail":"\n        ","_children":[{"_id":63,"tag":"param","attrib":{"name":"ios-package","value":"CDVDevice"},"text":"","tail":"\n            ","_children":[]}]}]},{"_id":64,"tag":"header-file","attrib":{"src":"src/ios/CDVDevice.h"},"text":"","tail":"\n        ","_children":[]},{"_id":65,"tag":"source-file","attrib":{"src":"src/ios/CDVDevice.m"},"text":"","tail":"\n    ","_children":[]}]},{"_id":66,"tag":"platform","attrib":{"name":"blackberry10"},"text":"\n        ","tail":"\n\n    \n    ","_children":[{"_id":67,"tag":"source-file","attrib":{"src":"src/blackberry10/index.js","target-dir":"Device"},"text":"","tail":"\n        ","_children":[]},{"_id":68,"tag":"config-file","attrib":{"target":"www/config.xml","parent":"/widget"},"text":"\n            ","tail":"\n        ","_children":[{"_id":69,"tag":"feature","attrib":{"name":"Device","value":"Device"},"text":"","tail":"\n        ","_children":[]}]},{"_id":70,"tag":"config-file","attrib":{"target":"www/config.xml","parent":"/widget/rim:permissions"},"text":"\n            ","tail":"\n    ","_children":[{"_id":71,"tag":"rim:permit","attrib":{},"text":"read_device_identifying_information","tail":"\n        ","_children":[]}]}]},{"_id":72,"tag":"platform","attrib":{"name":"wp7"},"text":"\n        ","tail":"\n\n    \n    ","_children":[{"_id":73,"tag":"config-file","attrib":{"target":"config.xml","parent":"/*"},"text":"\n            ","tail":"\n\n        ","_children":[{"_id":74,"tag":"feature","attrib":{"name":"Device"},"text":"\n                ","tail":"\n        ","_children":[{"_id":75,"tag":"param","attrib":{"name":"wp-package","value":"Device"},"text":"","tail":"\n            ","_children":[]}]}]},{"_id":76,"tag":"config-file","attrib":{"target":"Properties/WMAppManifest.xml","parent":"/Deployment/App/Capabilities"},"text":"\n            ","tail":"\n\n        ","_children":[{"_id":77,"tag":"Capability","attrib":{"Name":"ID_CAP_IDENTITY_DEVICE"},"text":"","tail":"\n        ","_children":[]}]},{"_id":78,"tag":"source-file","attrib":{"src":"src/wp/Device.cs"},"text":"","tail":"\n    ","_children":[]}]},{"_id":79,"tag":"platform","attrib":{"name":"wp8"},"text":"\n        ","tail":"\n\n    \n    ","_children":[{"_id":80,"tag":"config-file","attrib":{"target":"config.xml","parent":"/*"},"text":"\n            ","tail":"\n\n        ","_children":[{"_id":81,"tag":"feature","attrib":{"name":"Device"},"text":"\n                ","tail":"\n        ","_children":[{"_id":82,"tag":"param","attrib":{"name":"wp-package","value":"Device"},"text":"","tail":"\n            ","_children":[]}]}]},{"_id":83,"tag":"config-file","attrib":{"target":"Properties/WMAppManifest.xml","parent":"/Deployment/App/Capabilities"},"text":"\n            ","tail":"\n\n        ","_children":[{"_id":84,"tag":"Capability","attrib":{"Name":"ID_CAP_IDENTITY_DEVICE"},"text":"","tail":"\n        ","_children":[]}]},{"_id":85,"tag":"source-file","attrib":{"src":"src/wp/Device.cs"},"text":"","tail":"\n    ","_children":[]}]},{"_id":86,"tag":"platform","attrib":{"name":"windows"},"text":"\n        ","tail":"\n\n    \n    ","_children":[{"_id":87,"tag":"js-module","attrib":{"src":"src/windows/DeviceProxy.js","name":"DeviceProxy"},"text":"\n            ","tail":"\n    ","_children":[{"_id":88,"tag":"merges","attrib":{"target":""},"text":"","tail":"\n        ","_children":[]}]}]},{"_id":89,"tag":"platform","attrib":{"name":"browser"},"text":"\n        ","tail":"\n\n","_children":[{"_id":90,"tag":"config-file","attrib":{"target":"config.xml","parent":"/*"},"text":"\n            ","tail":"\n\n        ","_children":[{"_id":91,"tag":"feature","attrib":{"name":"Device"},"text":"\n                ","tail":"\n        ","_children":[{"_id":92,"tag":"param","attrib":{"name":"browser-package","value":"Device"},"text":"","tail":"\n            ","_children":[]}]}]},{"_id":93,"tag":"js-module","attrib":{"src":"src/browser/DeviceProxy.js","name":"DeviceProxy"},"text":"\n            ","tail":"\n    ","_children":[{"_id":94,"tag":"runs","attrib":{},"text":"","tail":"\n        ","_children":[]}]}]}]}},"id":"cordova-plugin-device","version":"1.0.1","name":"Device","description":"Cordova Device Plugin","license":"Apache 2.0","repo":"https://git-wip-us.apache.org/repos/asf/cordova-plugin-device.git","issue":"https://issues.apache.org/jira/browse/CB/component/12320648","keywords":["cordova","device"]},".../GlobalApp/plugins/cordova-plugin-device":{"filepath":".../GlobalApp/plugins/cordova-plugin-device/plugin.xml","dir":".../GlobalApp/plugins/cordova-plugin-device","_et":{"_root":{"_id":95,"tag":"plugin","attrib":{"xmlns":"http://apache.org/cordova/ns/plugins/1.0","xmlns:rim":"http://www.blackberry.com/ns/widgets","xmlns:android":"http://schemas.android.com/apk/res/android","id":"cordova-plugin-device","version":"1.0.1"},"text":"\n    ","tail":null,"_children":[{"_id":96,"tag":"name","attrib":{},"text":"Device","tail":"\n    ","_children":[]},{"_id":97,"tag":"description","attrib":{},"text":"Cordova Device Plugin","tail":"\n    ","_children":[]},{"_id":98,"tag":"license","attrib":{},"text":"Apache 2.0","tail":"\n    ","_children":[]},{"_id":99,"tag":"keywords","attrib":{},"text":"cordova,device","tail":"\n    ","_children":[]},{"_id":100,"tag":"repo","attrib":{},"text":"https://git-wip-us.apache.org/repos/asf/cordova-plugin-device.git","tail":"\n    ","_children":[]},{"_id":101,"tag":"issue","attrib":{},"text":"https://issues.apache.org/jira/browse/CB/component/12320648","tail":"\n\n    ","_children":[]},{"_id":102,"tag":"js-module","attrib":{"src":"www/device.js","name":"device"},"text":"\n        ","tail":"\n\n    \n    ","_children":[{"_id":103,"tag":"clobbers","attrib":{"target":"device"},"text":"","tail":"\n    ","_children":[]}]},{"_id":104,"tag":"platform","attrib":{"name":"firefoxos"},"text":"\n        ","tail":"\n\n    \n    ","_children":[{"_id":105,"tag":"config-file","attrib":{"target":"config.xml","parent":"/*"},"text":"\n            ","tail":"\n\n        ","_children":[{"_id":106,"tag":"feature","attrib":{"name":"Device"},"text":"\n                ","tail":"\n        ","_children":[{"_id":107,"tag":"param","attrib":{"name":"firefoxos-package","value":"Device"},"text":"","tail":"\n            ","_children":[]}]}]},{"_id":108,"tag":"js-module","attrib":{"src":"src/firefoxos/DeviceProxy.js","name":"DeviceProxy"},"text":"\n            ","tail":"\n    ","_children":[{"_id":109,"tag":"runs","attrib":{},"text":"","tail":"\n        ","_children":[]}]}]},{"_id":110,"tag":"platform","attrib":{"name":"tizen"},"text":"\n        ","tail":"\n\n    \n    ","_children":[{"_id":111,"tag":"js-module","attrib":{"src":"src/tizen/DeviceProxy.js","name":"DeviceProxy"},"text":"\n            ","tail":"\n    ","_children":[{"_id":112,"tag":"runs","attrib":{},"text":"","tail":"\n        ","_children":[]}]}]},{"_id":113,"tag":"platform","attrib":{"name":"android"},"text":"\n        ","tail":"\n\n    \n    ","_children":[{"_id":114,"tag":"config-file","attrib":{"target":"res/xml/config.xml","parent":"/*"},"text":"\n            ","tail":"\n\n        ","_children":[{"_id":115,"tag":"feature","attrib":{"name":"Device"},"text":"\n                ","tail":"\n        ","_children":[{"_id":116,"tag":"param","attrib":{"name":"android-package","value":"org.apache.cordova.device.Device"},"text":"","tail":"\n            ","_children":[]}]}]},{"_id":117,"tag":"source-file","attrib":{"src":"src/android/Device.java","target-dir":"src/org/apache/cordova/device"},"text":"","tail":"\n    ","_children":[]}]},{"_id":118,"tag":"platform","attrib":{"name":"amazon-fireos"},"text":"\n        ","tail":"\n    \n    \n    ","_children":[{"_id":119,"tag":"config-file","attrib":{"target":"res/xml/config.xml","parent":"/*"},"text":"\n            ","tail":"\n\n        ","_children":[{"_id":120,"tag":"feature","attrib":{"name":"Device"},"text":"\n                ","tail":"\n        ","_children":[{"_id":121,"tag":"param","attrib":{"name":"android-package","value":"org.apache.cordova.device.Device"},"text":"","tail":"\n            ","_children":[]}]}]},{"_id":122,"tag":"source-file","attrib":{"src":"src/android/Device.java","target-dir":"src/org/apache/cordova/device"},"text":"","tail":"\n    ","_children":[]}]},{"_id":123,"tag":"platform","attrib":{"name":"ubuntu"},"text":"\n        ","tail":"\n\n    \n    ","_children":[{"_id":124,"tag":"header-file","attrib":{"src":"src/ubuntu/device.h"},"text":"","tail":"\n        ","_children":[]},{"_id":125,"tag":"source-file","attrib":{"src":"src/ubuntu/device.cpp"},"text":"","tail":"\n        ","_children":[]},{"_id":126,"tag":"js-module","attrib":{"src":"src/ubuntu/device.js","name":"DeviceProxy"},"text":"\n            ","tail":"\n    ","_children":[{"_id":127,"tag":"merges","attrib":{"target":"device"},"text":"","tail":"\n        ","_children":[]}]}]},{"_id":128,"tag":"platform","attrib":{"name":"ios"},"text":"\n        ","tail":"\n\n    \n    ","_children":[{"_id":129,"tag":"config-file","attrib":{"target":"config.xml","parent":"/*"},"text":"\n            ","tail":"\n\n        ","_children":[{"_id":130,"tag":"feature","attrib":{"name":"Device"},"text":"\n                ","tail":"\n        ","_children":[{"_id":131,"tag":"param","attrib":{"name":"ios-package","value":"CDVDevice"},"text":"","tail":"\n            ","_children":[]}]}]},{"_id":132,"tag":"header-file","attrib":{"src":"src/ios/CDVDevice.h"},"text":"","tail":"\n        ","_children":[]},{"_id":133,"tag":"source-file","attrib":{"src":"src/ios/CDVDevice.m"},"text":"","tail":"\n    ","_children":[]}]},{"_id":134,"tag":"platform","attrib":{"name":"blackberry10"},"text":"\n        ","tail":"\n\n    \n    ","_children":[{"_id":135,"tag":"source-file","attrib":{"src":"src/blackberry10/index.js","target-dir":"Device"},"text":"","tail":"\n        ","_children":[]},{"_id":136,"tag":"config-file","attrib":{"target":"www/config.xml","parent":"/widget"},"text":"\n            ","tail":"\n        ","_children":[{"_id":137,"tag":"feature","attrib":{"name":"Device","value":"Device"},"text":"","tail":"\n        ","_children":[]}]},{"_id":138,"tag":"config-file","attrib":{"target":"www/config.xml","parent":"/widget/rim:permissions"},"text":"\n            ","tail":"\n    ","_children":[{"_id":139,"tag":"rim:permit","attrib":{},"text":"read_device_identifying_information","tail":"\n        ","_children":[]}]}]},{"_id":140,"tag":"platform","attrib":{"name":"wp7"},"text":"\n        ","tail":"\n\n    \n    ","_children":[{"_id":141,"tag":"config-file","attrib":{"target":"config.xml","parent":"/*"},"text":"\n            ","tail":"\n\n        ","_children":[{"_id":142,"tag":"feature","attrib":{"name":"Device"},"text":"\n                ","tail":"\n        ","_children":[{"_id":143,"tag":"param","attrib":{"name":"wp-package","value":"Device"},"text":"","tail":"\n            ","_children":[]}]}]},{"_id":144,"tag":"config-file","attrib":{"target":"Properties/WMAppManifest.xml","parent":"/Deployment/App/Capabilities"},"text":"\n            ","tail":"\n\n        ","_children":[{"_id":145,"tag":"Capability","attrib":{"Name":"ID_CAP_IDENTITY_DEVICE"},"text":"","tail":"\n        ","_children":[]}]},{"_id":146,"tag":"source-file","attrib":{"src":"src/wp/Device.cs"},"text":"","tail":"\n    ","_children":[]}]},{"_id":147,"tag":"platform","attrib":{"name":"wp8"},"text":"\n        ","tail":"\n\n    \n    ","_children":[{"_id":148,"tag":"config-file","attrib":{"target":"config.xml","parent":"/*"},"text":"\n            ","tail":"\n\n        ","_children":[{"_id":149,"tag":"feature","attrib":{"name":"Device"},"text":"\n                ","tail":"\n        ","_children":[{"_id":150,"tag":"param","attrib":{"name":"wp-package","value":"Device"},"text":"","tail":"\n            ","_children":[]}]}]},{"_id":151,"tag":"config-file","attrib":{"target":"Properties/WMAppManifest.xml","parent":"/Deployment/App/Capabilities"},"text":"\n            ","tail":"\n\n        ","_children":[{"_id":152,"tag":"Capability","attrib":{"Name":"ID_CAP_IDENTITY_DEVICE"},"text":"","tail":"\n        ","_children":[]}]},{"_id":153,"tag":"source-file","attrib":{"src":"src/wp/Device.cs"},"text":"","tail":"\n    ","_children":[]}]},{"_id":154,"tag":"platform","attrib":{"name":"windows"},"text":"\n        ","tail":"\n\n    \n    ","_children":[{"_id":155,"tag":"js-module","attrib":{"src":"src/windows/DeviceProxy.js","name":"DeviceProxy"},"text":"\n            ","tail":"\n    ","_children":[{"_id":156,"tag":"merges","attrib":{"target":""},"text":"","tail":"\n        ","_children":[]}]}]},{"_id":157,"tag":"platform","attrib":{"name":"browser"},"text":"\n        ","tail":"\n\n","_children":[{"_id":158,"tag":"config-file","attrib":{"target":"config.xml","parent":"/*"},"text":"\n            ","tail":"\n\n        ","_children":[{"_id":159,"tag":"feature","attrib":{"name":"Device"},"text":"\n                ","tail":"\n        ","_children":[{"_id":160,"tag":"param","attrib":{"name":"browser-package","value":"Device"},"text":"","tail":"\n            ","_children":[]}]}]},{"_id":161,"tag":"js-module","attrib":{"src":"src/browser/DeviceProxy.js","name":"DeviceProxy"},"text":"\n            ","tail":"\n    ","_children":[{"_id":162,"tag":"runs","attrib":{},"text":"","tail":"\n        ","_children":[]}]}]}]}},"id":"cordova-plugin-device","version":"1.0.1","name":"Device","description":"Cordova Device Plugin","license":"Apache 2.0","repo":"https://git-wip-us.apache.org/repos/asf/cordova-plugin-device.git","issue":"https://issues.apache.org/jira/browse/CB/component/12320648","keywords":["cordova","device"]}},"_getAllCache":{}},"nohooks":["."]}"
Installing "cordova-plugin-device" for ios
Install start for "cordova-plugin-device" on ios.
Iterating over installed plugins: [ 'cordova-plugin-statusbar', 'cordova-plugin-device' ]
Install complete for cordova-plugin-device on ios.
Calling plugman.fetch on plugin ".../cachedPlugins.vnGEFJ.tmp/cache.KLWeaG.pl/cordova-plugin-splashscreen"
Copying plugin ".../cachedPlugins.vnGEFJ.tmp/cache.KLWeaG.pl/cordova-plugin-splashscreen" => ".../GlobalApp/plugins/cordova-plugin-splashscreen"
Calling plugman.install on plugin ".../GlobalApp/plugins/cordova-plugin-splashscreen" for platform "ios" with options "{"cli_variables":{},"browserify":false,"link":false,"pluginInfoProvider":{"_cache":{".../cachedPlugins.vnGEFJ.tmp/cache.KLWeaG.pl/cordova-plugin-splashscreen":{"filepath":".../cachedPlugins.vnGEFJ.tmp/cache.KLWeaG.pl/cordova-plugin-splashscreen/plugin.xml","dir":".../cachedPlugins.vnGEFJ.tmp/cache.KLWeaG.pl/cordova-plugin-splashscreen","_et":{"_root":{"_id":27,"tag":"plugin","attrib":{"xmlns":"http://apache.org/cordova/ns/plugins/1.0","id":"cordova-plugin-splashscreen","version":"2.1.0"},"text":"\n    ","tail":null,"_children":[{"_id":28,"tag":"name","attrib":{},"text":"Splashscreen","tail":"\n    ","_children":[]},{"_id":29,"tag":"description","attrib":{},"text":"Cordova Splashscreen Plugin","tail":"\n    ","_children":[]},{"_id":30,"tag":"license","attrib":{},"text":"Apache 2.0","tail":"\n    ","_children":[]},{"_id":31,"tag":"keywords","attrib":{},"text":"cordova,splashscreen","tail":"\n    ","_children":[]},{"_id":32,"tag":"repo","attrib":{},"text":"https://git-wip-us.apache.org/repos/asf/cordova-plugin-splashscreen.git","tail":"\n    ","_children":[]},{"_id":33,"tag":"issue","attrib":{},"text":"https://issues.apache.org/jira/browse/CB/component/12320653","tail":"\n\n    ","_children":[]},{"_id":34,"tag":"engines","attrib":{},"text":"\n        ","tail":"\n\n    ","_children":[{"_id":35,"tag":"engine","attrib":{"name":"cordova-android","version":">=3.6.0"},"text":"","tail":"\n    ","_children":[]}]},{"_id":36,"tag":"js-module","attrib":{"src":"www/splashscreen.js","name":"SplashScreen"},"text":"\n        ","tail":"\n\n    \n    ","_children":[{"_id":37,"tag":"clobbers","attrib":{"target":"navigator.splashscreen"},"text":"","tail":"\n    ","_children":[]}]},{"_id":38,"tag":"platform","attrib":{"name":"android"},"text":"\n        ","tail":"\n\n    \n    ","_children":[{"_id":39,"tag":"config-file","attrib":{"target":"res/xml/config.xml","parent":"/*"},"text":"\n            ","tail":"\n\n        ","_children":[{"_id":40,"tag":"feature","attrib":{"name":"SplashScreen"},"text":"\n                ","tail":"\n        ","_children":[{"_id":41,"tag":"param","attrib":{"name":"android-package","value":"org.apache.cordova.splashscreen.SplashScreen"},"text":"","tail":"\n                ","_children":[]},{"_id":42,"tag":"param","attrib":{"name":"onload","value":"true"},"text":"","tail":"\n            ","_children":[]}]}]},{"_id":43,"tag":"source-file","attrib":{"src":"src/android/SplashScreen.java","target-dir":"src/org/apache/cordova/splashscreen"},"text":"","tail":"\n    ","_children":[]}]},{"_id":44,"tag":"platform","attrib":{"name":"amazon-fireos"},"text":"\n        ","tail":"\n\n    \n    ","_children":[{"_id":45,"tag":"config-file","attrib":{"target":"res/xml/config.xml","parent":"/*"},"text":"\n            ","tail":"\n\n        ","_children":[{"_id":46,"tag":"feature","attrib":{"name":"SplashScreen"},"text":"\n            ","tail":"\n        ","_children":[{"_id":47,"tag":"param","attrib":{"name":"android-package","value":"org.apache.cordova.splashscreen.SplashScreen"},"text":"","tail":"\n            ","_children":[]}]}]},{"_id":48,"tag":"source-file","attrib":{"src":"src/android/SplashScreen.java","target-dir":"src/org/apache/cordova/splashscreen"},"text":"","tail":"\n    ","_children":[]}]},{"_id":49,"tag":"platform","attrib":{"name":"ubuntu"},"text":"\n        ","tail":"\n\n    \n    ","_children":[{"_id":50,"tag":"header-file","attrib":{"src":"src/ubuntu/splashscreen.h"},"text":"","tail":"\n        ","_children":[]},{"_id":51,"tag":"source-file","attrib":{"src":"src/ubuntu/splashscreen.cpp"},"text":"","tail":"\n    ","_children":[]}]},{"_id":52,"tag":"platform","attrib":{"name":"ios"},"text":"\n        ","tail":"\n\n    \n    ","_children":[{"_id":53,"tag":"config-file","attrib":{"target":"config.xml","parent":"/*"},"text":"\n\t\t    ","tail":"\n\n        ","_children":[{"_id":54,"tag":"feature","attrib":{"name":"SplashScreen"},"text":"\n\t\t\t    ","tail":"\n        ","_children":[{"_id":55,"tag":"param","attrib":{"name":"ios-package","value":"CDVSplashScreen"},"text":"","tail":"\n\t\t\t    ","_children":[]},{"_id":56,"tag":"param","attrib":{"name":"onload","value":"true"},"text":"","tail":"\n\t\t    ","_children":[]}]}]},{"_id":57,"tag":"header-file","attrib":{"src":"src/ios/CDVSplashScreen.h"},"text":"","tail":"\n        ","_children":[]},{"_id":58,"tag":"source-file","attrib":{"src":"src/ios/CDVSplashScreen.m"},"text":"","tail":"\n        ","_children":[]},{"_id":59,"tag":"header-file","attrib":{"src":"src/ios/CDVViewController+SplashScreen.h"},"text":"","tail":"\n        ","_children":[]},{"_id":60,"tag":"source-file","attrib":{"src":"src/ios/CDVViewController+SplashScreen.m"},"text":"","tail":"\n\n\t    ","_children":[]},{"_id":61,"tag":"framework","attrib":{"src":"CoreGraphics.framework"},"text":"","tail":"\n    ","_children":[]}]},{"_id":62,"tag":"platform","attrib":{"name":"blackberry10"},"text":"\n        ","tail":"\n\n    \n    ","_children":[{"_id":63,"tag":"source-file","attrib":{"src":"src/blackberry10/index.js","target-dir":"SplashScreen"},"text":"","tail":"\n        ","_children":[]},{"_id":64,"tag":"config-file","attrib":{"target":"www/config.xml","parent":"/widget"},"text":"\n            ","tail":"\n    ","_children":[{"_id":65,"tag":"feature","attrib":{"name":"SplashScreen","value":"SplashScreen"},"text":"","tail":"\n        ","_children":[]}]}]},{"_id":66,"tag":"platform","attrib":{"name":"wp8"},"text":"\n        ","tail":"\n\n    \n    ","_children":[{"_id":67,"tag":"config-file","attrib":{"target":"config.xml","parent":"/*"},"text":"\n            ","tail":"\n\n        ","_children":[{"_id":68,"tag":"feature","attrib":{"name":"SplashScreen"},"text":"\n                ","tail":"\n        ","_children":[{"_id":69,"tag":"param","attrib":{"name":"wp-package","value":"SplashScreen"},"text":"","tail":"\n                ","_children":[]},{"_id":70,"tag":"param","attrib":{"name":"onload","value":"true"},"text":"","tail":"\n            ","_children":[]}]}]},{"_id":71,"tag":"source-file","attrib":{"src":"src/wp/SplashScreen.cs"},"text":"","tail":"\n        ","_children":[]},{"_id":72,"tag":"source-file","attrib":{"src":"src/wp/ResolutionHelper.cs"},"text":"","tail":"\n\n    ","_children":[]}]},{"_id":73,"tag":"platform","attrib":{"name":"windows8"},"text":"\n        ","tail":"\n\n    \n    ","_children":[{"_id":74,"tag":"js-module","attrib":{"src":"www/windows/SplashScreenProxy.js","name":"SplashScreenProxy"},"text":"\n            ","tail":"\n    ","_children":[{"_id":75,"tag":"merges","attrib":{"target":""},"text":"","tail":"\n        ","_children":[]}]}]},{"_id":76,"tag":"platform","attrib":{"name":"windows"},"text":"\n        ","tail":"\n\n    \n    ","_children":[{"_id":77,"tag":"js-module","attrib":{"src":"www/windows/SplashScreenProxy.js","name":"SplashScreenProxy"},"text":"\n            ","tail":"\n    ","_children":[{"_id":78,"tag":"merges","attrib":{"target":""},"text":"","tail":"\n        ","_children":[]}]}]},{"_id":79,"tag":"platform","attrib":{"name":"tizen"},"text":"\n        ","tail":"\n\n    \n    ","_children":[{"_id":80,"tag":"js-module","attrib":{"src":"src/tizen/SplashScreenProxy.js","name":"SplashScreenProxy"},"text":"\n            ","tail":"\n    ","_children":[{"_id":81,"tag":"runs","attrib":{},"text":"","tail":"\n        ","_children":[]}]}]},{"_id":82,"tag":"platform","attrib":{"name":"browser"},"text":"\n        ","tail":"\n","_children":[{"_id":83,"tag":"js-module","attrib":{"src":"src/browser/SplashScreenProxy.js","name":"SplashScreenProxy"},"text":"\n            ","tail":"\n    ","_children":[{"_id":84,"tag":"runs","attrib":{},"text":"","tail":"\n        ","_children":[]}]}]}]}},"id":"cordova-plugin-splashscreen","version":"2.1.0","name":"Splashscreen","description":"Cordova Splashscreen Plugin","license":"Apache 2.0","repo":"https://git-wip-us.apache.org/repos/asf/cordova-plugin-splashscreen.git","issue":"https://issues.apache.org/jira/browse/CB/component/12320653","keywords":["cordova","splashscreen"]},".../GlobalApp/plugins/cordova-plugin-splashscreen":{"filepath":".../GlobalApp/plugins/cordova-plugin-splashscreen/plugin.xml","dir":".../GlobalApp/plugins/cordova-plugin-splashscreen","_et":{"_root":{"_id":85,"tag":"plugin","attrib":{"xmlns":"http://apache.org/cordova/ns/plugins/1.0","id":"cordova-plugin-splashscreen","version":"2.1.0"},"text":"\n    ","tail":null,"_children":[{"_id":86,"tag":"name","attrib":{},"text":"Splashscreen","tail":"\n    ","_children":[]},{"_id":87,"tag":"description","attrib":{},"text":"Cordova Splashscreen Plugin","tail":"\n    ","_children":[]},{"_id":88,"tag":"license","attrib":{},"text":"Apache 2.0","tail":"\n    ","_children":[]},{"_id":89,"tag":"keywords","attrib":{},"text":"cordova,splashscreen","tail":"\n    ","_children":[]},{"_id":90,"tag":"repo","attrib":{},"text":"https://git-wip-us.apache.org/repos/asf/cordova-plugin-splashscreen.git","tail":"\n    ","_children":[]},{"_id":91,"tag":"issue","attrib":{},"text":"https://issues.apache.org/jira/browse/CB/component/12320653","tail":"\n\n    ","_children":[]},{"_id":92,"tag":"engines","attrib":{},"text":"\n        ","tail":"\n\n    ","_children":[{"_id":93,"tag":"engine","attrib":{"name":"cordova-android","version":">=3.6.0"},"text":"","tail":"\n    ","_children":[]}]},{"_id":94,"tag":"js-module","attrib":{"src":"www/splashscreen.js","name":"SplashScreen"},"text":"\n        ","tail":"\n\n    \n    ","_children":[{"_id":95,"tag":"clobbers","attrib":{"target":"navigator.splashscreen"},"text":"","tail":"\n    ","_children":[]}]},{"_id":96,"tag":"platform","attrib":{"name":"android"},"text":"\n        ","tail":"\n\n    \n    ","_children":[{"_id":97,"tag":"config-file","attrib":{"target":"res/xml/config.xml","parent":"/*"},"text":"\n            ","tail":"\n\n        ","_children":[{"_id":98,"tag":"feature","attrib":{"name":"SplashScreen"},"text":"\n                ","tail":"\n        ","_children":[{"_id":99,"tag":"param","attrib":{"name":"android-package","value":"org.apache.cordova.splashscreen.SplashScreen"},"text":"","tail":"\n                ","_children":[]},{"_id":100,"tag":"param","attrib":{"name":"onload","value":"true"},"text":"","tail":"\n            ","_children":[]}]}]},{"_id":101,"tag":"source-file","attrib":{"src":"src/android/SplashScreen.java","target-dir":"src/org/apache/cordova/splashscreen"},"text":"","tail":"\n    ","_children":[]}]},{"_id":102,"tag":"platform","attrib":{"name":"amazon-fireos"},"text":"\n        ","tail":"\n\n    \n    ","_children":[{"_id":103,"tag":"config-file","attrib":{"target":"res/xml/config.xml","parent":"/*"},"text":"\n            ","tail":"\n\n        ","_children":[{"_id":104,"tag":"feature","attrib":{"name":"SplashScreen"},"text":"\n            ","tail":"\n        ","_children":[{"_id":105,"tag":"param","attrib":{"name":"android-package","value":"org.apache.cordova.splashscreen.SplashScreen"},"text":"","tail":"\n            ","_children":[]}]}]},{"_id":106,"tag":"source-file","attrib":{"src":"src/android/SplashScreen.java","target-dir":"src/org/apache/cordova/splashscreen"},"text":"","tail":"\n    ","_children":[]}]},{"_id":107,"tag":"platform","attrib":{"name":"ubuntu"},"text":"\n        ","tail":"\n\n    \n    ","_children":[{"_id":108,"tag":"header-file","attrib":{"src":"src/ubuntu/splashscreen.h"},"text":"","tail":"\n        ","_children":[]},{"_id":109,"tag":"source-file","attrib":{"src":"src/ubuntu/splashscreen.cpp"},"text":"","tail":"\n    ","_children":[]}]},{"_id":110,"tag":"platform","attrib":{"name":"ios"},"text":"\n        ","tail":"\n\n    \n    ","_children":[{"_id":111,"tag":"config-file","attrib":{"target":"config.xml","parent":"/*"},"text":"\n\t\t    ","tail":"\n\n        ","_children":[{"_id":112,"tag":"feature","attrib":{"name":"SplashScreen"},"text":"\n\t\t\t    ","tail":"\n        ","_children":[{"_id":113,"tag":"param","attrib":{"name":"ios-package","value":"CDVSplashScreen"},"text":"","tail":"\n\t\t\t    ","_children":[]},{"_id":114,"tag":"param","attrib":{"name":"onload","value":"true"},"text":"","tail":"\n\t\t    ","_children":[]}]}]},{"_id":115,"tag":"header-file","attrib":{"src":"src/ios/CDVSplashScreen.h"},"text":"","tail":"\n        ","_children":[]},{"_id":116,"tag":"source-file","attrib":{"src":"src/ios/CDVSplashScreen.m"},"text":"","tail":"\n        ","_children":[]},{"_id":117,"tag":"header-file","attrib":{"src":"src/ios/CDVViewController+SplashScreen.h"},"text":"","tail":"\n        ","_children":[]},{"_id":118,"tag":"source-file","attrib":{"src":"src/ios/CDVViewController+SplashScreen.m"},"text":"","tail":"\n\n\t    ","_children":[]},{"_id":119,"tag":"framework","attrib":{"src":"CoreGraphics.framework"},"text":"","tail":"\n    ","_children":[]}]},{"_id":120,"tag":"platform","attrib":{"name":"blackberry10"},"text":"\n        ","tail":"\n\n    \n    ","_children":[{"_id":121,"tag":"source-file","attrib":{"src":"src/blackberry10/index.js","target-dir":"SplashScreen"},"text":"","tail":"\n        ","_children":[]},{"_id":122,"tag":"config-file","attrib":{"target":"www/config.xml","parent":"/widget"},"text":"\n            ","tail":"\n    ","_children":[{"_id":123,"tag":"feature","attrib":{"name":"SplashScreen","value":"SplashScreen"},"text":"","tail":"\n        ","_children":[]}]}]},{"_id":124,"tag":"platform","attrib":{"name":"wp8"},"text":"\n        ","tail":"\n\n    \n    ","_children":[{"_id":125,"tag":"config-file","attrib":{"target":"config.xml","parent":"/*"},"text":"\n            ","tail":"\n\n        ","_children":[{"_id":126,"tag":"feature","attrib":{"name":"SplashScreen"},"text":"\n                ","tail":"\n        ","_children":[{"_id":127,"tag":"param","attrib":{"name":"wp-package","value":"SplashScreen"},"text":"","tail":"\n                ","_children":[]},{"_id":128,"tag":"param","attrib":{"name":"onload","value":"true"},"text":"","tail":"\n            ","_children":[]}]}]},{"_id":129,"tag":"source-file","attrib":{"src":"src/wp/SplashScreen.cs"},"text":"","tail":"\n        ","_children":[]},{"_id":130,"tag":"source-file","attrib":{"src":"src/wp/ResolutionHelper.cs"},"text":"","tail":"\n\n    ","_children":[]}]},{"_id":131,"tag":"platform","attrib":{"name":"windows8"},"text":"\n        ","tail":"\n\n    \n    ","_children":[{"_id":132,"tag":"js-module","attrib":{"src":"www/windows/SplashScreenProxy.js","name":"SplashScreenProxy"},"text":"\n            ","tail":"\n    ","_children":[{"_id":133,"tag":"merges","attrib":{"target":""},"text":"","tail":"\n        ","_children":[]}]}]},{"_id":134,"tag":"platform","attrib":{"name":"windows"},"text":"\n        ","tail":"\n\n    \n    ","_children":[{"_id":135,"tag":"js-module","attrib":{"src":"www/windows/SplashScreenProxy.js","name":"SplashScreenProxy"},"text":"\n            ","tail":"\n    ","_children":[{"_id":136,"tag":"merges","attrib":{"target":""},"text":"","tail":"\n        ","_children":[]}]}]},{"_id":137,"tag":"platform","attrib":{"name":"tizen"},"text":"\n        ","tail":"\n\n    \n    ","_children":[{"_id":138,"tag":"js-module","attrib":{"src":"src/tizen/SplashScreenProxy.js","name":"SplashScreenProxy"},"text":"\n            ","tail":"\n    ","_children":[{"_id":139,"tag":"runs","attrib":{},"text":"","tail":"\n        ","_children":[]}]}]},{"_id":140,"tag":"platform","attrib":{"name":"browser"},"text":"\n        ","tail":"\n","_children":[{"_id":141,"tag":"js-module","attrib":{"src":"src/browser/SplashScreenProxy.js","name":"SplashScreenProxy"},"text":"\n            ","tail":"\n    ","_children":[{"_id":142,"tag":"runs","attrib":{},"text":"","tail":"\n        ","_children":[]}]}]}]}},"id":"cordova-plugin-splashscreen","version":"2.1.0","name":"Splashscreen","description":"Cordova Splashscreen Plugin","license":"Apache 2.0","repo":"https://git-wip-us.apache.org/repos/asf/cordova-plugin-splashscreen.git","issue":"https://issues.apache.org/jira/browse/CB/component/12320653","keywords":["cordova","splashscreen"]}},"_getAllCache":{}},"nohooks":["."]}"
Installing "cordova-plugin-splashscreen" for ios
Install start for "cordova-plugin-splashscreen" on ios.
  'cordova-plugin-device',
  'cordova-plugin-splashscreen' ]
Install complete for cordova-plugin-splashscreen on ios.
Generating config.xml from defaults for platform "ios"
Calling plugman.prepare for platform "ios"
Wrote out iOS Bundle Identifier to "namo.global.app.sridhar"
Wrote out iOS Bundle Version to "0.0.1"
iOS Product Name has not changed (still "GlobalApp")
************* Processing the main config.xml file (after_prepare)  *****************
App Directory = [.../GlobalApp]
Will process and update the following config files:
    Config.xml = [.../GlobalApp/config.xml]
Namespaces:
    prefix/uri ''/'http://www.w3.org/ns/widgets'
    prefix/uri 'intelxdk'/'http://xdk.intel.com/ns/v1'
Name of the app is [GlobalApp]
Updating full app name to [GlobalApp]
Processing preference permissions
Updating the versionName
Setting [CFBundleShortVersionString] to 0.0.1
Processing debuggable
Processing config file values
Saving config.xml to [.../GlobalApp/config.xml]
Saving info.plist to [.../GlobalApp/platforms/ios/GlobalApp/GlobalApp-Info.plist]
************* Completed processing the main config.xml file (after_prepare)  *****************
Running command: .../GlobalApp/platforms/ios/cordova/build --release --device
Building project  : .../GlobalApp/platforms/ios/GlobalApp.xcodeproj
	Configuration : Release
	Platform      : device
Build settings from command line:
    ARCHS = armv7 armv7s arm64
    CONFIGURATION_BUILD_DIR = .../GlobalApp/platforms/ios/build/device
    SDKROOT = iphoneos8.0
    SHARED_PRECOMPS_DIR = .../GlobalApp/platforms/ios/build/sharedpch
    VALID_ARCHS = armv7 armv7s arm64
Build settings from configuration file '.../GlobalApp/platforms/ios/cordova/build-release.xcconfig':
    CODE_SIGN_IDENTITY = iPhone Distribution
    IPHONEOS_DEPLOYMENT_TARGET = 5.1.1
    PROVISIONING_PROFILE = 55dfc0c1-840f-44bb-aa44-dda3f0042994
=== BUILD TARGET CordovaLib OF PROJECT CordovaLib WITH CONFIGURATION Release ===
Check dependencies
Write auxiliary files
/bin/mkdir -p .../GlobalApp/platforms/ios/CordovaLib/build/CordovaLib.build/Release-iphoneos/CordovaLib.build
write-file .../GlobalApp/platforms/ios/CordovaLib/build/CordovaLib.build/Release-iphoneos/CordovaLib.build/Cordova-all-non-framework-target-headers.hmap
write-file .../GlobalApp/platforms/ios/CordovaLib/build/CordovaLib.build/Release-iphoneos/CordovaLib.build/Cordova-own-target-headers.hmap
write-file .../GlobalApp/platforms/ios/CordovaLib/build/CordovaLib.build/Release-iphoneos/CordovaLib.build/Cordova-project-headers.hmap
write-file .../GlobalApp/platforms/ios/CordovaLib/build/CordovaLib.build/Release-iphoneos/CordovaLib.build/Cordova-all-target-headers.hmap
/bin/mkdir -p .../GlobalApp/platforms/ios/build/sharedpch/CordovaLib_Prefix-fivrigwvgybezearyxkqepphqwui
write-file .../GlobalApp/platforms/ios/build/sharedpch/CordovaLib_Prefix-fivrigwvgybezearyxkqepphqwui/CordovaLib_Prefix.pch.pch.hash-criteria
/bin/mkdir -p .../GlobalApp/platforms/ios/build/sharedpch/CordovaLib_Prefix-ewmbvtliszxykhdqazocuxzlgdis
write-file .../GlobalApp/platforms/ios/build/sharedpch/CordovaLib_Prefix-ewmbvtliszxykhdqazocuxzlgdis/CordovaLib_Prefix.pch.pch.hash-criteria
/bin/mkdir -p .../GlobalApp/platforms/ios/build/sharedpch/CordovaLib_Prefix-efvxvmjhiwhimmbjxfdnmvsssihe
write-file .../GlobalApp/platforms/ios/build/sharedpch/CordovaLib_Prefix-efvxvmjhiwhimmbjxfdnmvsssihe/CordovaLib_Prefix.pch.pch.hash-criteria
write-file .../GlobalApp/platforms/ios/CordovaLib/build/CordovaLib.build/Release-iphoneos/CordovaLib.build/Cordova.hmap
/bin/mkdir -p .../GlobalApp/platforms/ios/CordovaLib/build/CordovaLib.build/Release-iphoneos/CordovaLib.build/Objects-normal/armv7s
write-file .../GlobalApp/platforms/ios/CordovaLib/build/CordovaLib.build/Release-iphoneos/CordovaLib.build/Objects-normal/armv7s/Cordova.LinkFileList
write-file .../GlobalApp/platforms/ios/CordovaLib/build/CordovaLib.build/Release-iphoneos/CordovaLib.build/Cordova-generated-files.hmap
write-file .../GlobalApp/platforms/ios/CordovaLib/build/CordovaLib.build/Release-iphoneos/CordovaLib.build/Objects-normal/armv7/Cordova.LinkFileList
/bin/mkdir -p .../GlobalApp/platforms/ios/CordovaLib/build/CordovaLib.build/Release-iphoneos/CordovaLib.build/Objects-normal/arm64
write-file .../GlobalApp/platforms/ios/CordovaLib/build/CordovaLib.build/Release-iphoneos/CordovaLib.build/Objects-normal/arm64/Cordova.LinkFileList
CpHeader Classes/CDVInvokedUrlCommand.h .../GlobalApp/platforms/ios/build/device/include/Cordova/CDVInvokedUrlCommand.h
    cd .../GlobalApp/platforms/ios/CordovaLib
    export PATH="/Applications/Xcode.app/Contents/Developer/Platforms/iPhoneOS.platform/Developer/usr/bin:/Applications/Xcode.app/Contents/Developer/usr/bin:/usr/bin:/bin:/usr/sbin:/sbin:/usr/local/bin:/usr/local/git/bin:/Developer/android-sdk-macosx/tools:/usr/local/ant/bin"
    builtin-copy -exclude .DS_Store -exclude CVS -exclude .svn -exclude .git -exclude .hg -strip-debug-symbols -strip-tool /Applications/Xcode.app/Contents/Developer/Toolchains/XcodeDefault.xctoolchain/usr/bin/strip -resolve-src-symlinks .../GlobalApp/platforms/ios/CordovaLib/Classes/CDVInvokedUrlCommand.h .../GlobalApp/platforms/ios/build/device/include/Cordova
CpHeader Classes/NSMutableArray+QueueAdditions.h .../GlobalApp/platforms/ios/build/device/include/Cordova/NSMutableArray+QueueAdditions.h
    builtin-copy -exclude .DS_Store -exclude CVS -exclude .svn -exclude .git -exclude .hg -strip-debug-symbols -strip-tool /Applications/Xcode.app/Contents/Developer/Toolchains/XcodeDefault.xctoolchain/usr/bin/strip -resolve-src-symlinks .../GlobalApp/platforms/ios/CordovaLib/Classes/NSMutableArray+QueueAdditions.h .../GlobalApp/platforms/ios/build/device/include/Cordova
CpHeader Classes/CDVPlugin.h .../GlobalApp/platforms/ios/build/device/include/Cordova/CDVPlugin.h
    builtin-copy -exclude .DS_Store -exclude CVS -exclude .svn -exclude .git -exclude .hg -strip-debug-symbols -strip-tool /Applications/Xcode.app/Contents/Developer/Toolchains/XcodeDefault.xctoolchain/usr/bin/strip -resolve-src-symlinks .../GlobalApp/platforms/ios/CordovaLib/Classes/CDVPlugin.h .../GlobalApp/platforms/ios/build/device/include/Cordova
CpHeader Classes/CDVDebug.h .../GlobalApp/platforms/ios/build/device/include/Cordova/CDVDebug.h
    builtin-copy -exclude .DS_Store -exclude CVS -exclude .svn -exclude .git -exclude .hg -strip-debug-symbols -strip-tool /Applications/Xcode.app/Contents/Developer/Toolchains/XcodeDefault.xctoolchain/usr/bin/strip -resolve-src-symlinks .../GlobalApp/platforms/ios/CordovaLib/Classes/CDVDebug.h .../GlobalApp/platforms/ios/build/device/include/Cordova
CpHeader Classes/NSData+Base64.h .../GlobalApp/platforms/ios/build/device/include/Cordova/NSData+Base64.h
    builtin-copy -exclude .DS_Store -exclude CVS -exclude .svn -exclude .git -exclude .hg -strip-debug-symbols -strip-tool /Applications/Xcode.app/Contents/Developer/Toolchains/XcodeDefault.xctoolchain/usr/bin/strip -resolve-src-symlinks .../GlobalApp/platforms/ios/CordovaLib/Classes/NSData+Base64.h .../GlobalApp/platforms/ios/build/device/include/Cordova
CpHeader Classes/NSDictionary+Extensions.h .../GlobalApp/platforms/ios/build/device/include/Cordova/NSDictionary+Extensions.h
    builtin-copy -exclude .DS_Store -exclude CVS -exclude .svn -exclude .git -exclude .hg -strip-debug-symbols -strip-tool /Applications/Xcode.app/Contents/Developer/Toolchains/XcodeDefault.xctoolchain/usr/bin/strip -resolve-src-symlinks .../GlobalApp/platforms/ios/CordovaLib/Classes/NSDictionary+Extensions.h .../GlobalApp/platforms/ios/build/device/include/Cordova
CpHeader Classes/CDVPluginResult.h .../GlobalApp/platforms/ios/build/device/include/Cordova/CDVPluginResult.h
    builtin-copy -exclude .DS_Store -exclude CVS -exclude .svn -exclude .git -exclude .hg -strip-debug-symbols -strip-tool /Applications/Xcode.app/Contents/Developer/Toolchains/XcodeDefault.xctoolchain/usr/bin/strip -resolve-src-symlinks .../GlobalApp/platforms/ios/CordovaLib/Classes/CDVPluginResult.h .../GlobalApp/platforms/ios/build/device/include/Cordova
CpHeader Classes/CDVWhitelist.h .../GlobalApp/platforms/ios/build/device/include/Cordova/CDVWhitelist.h
    builtin-copy -exclude .DS_Store -exclude CVS -exclude .svn -exclude .git -exclude .hg -strip-debug-symbols -strip-tool /Applications/Xcode.app/Contents/Developer/Toolchains/XcodeDefault.xctoolchain/usr/bin/strip -resolve-src-symlinks .../GlobalApp/platforms/ios/CordovaLib/Classes/CDVWhitelist.h .../GlobalApp/platforms/ios/build/device/include/Cordova
CpHeader Classes/CDVURLProtocol.h .../GlobalApp/platforms/ios/build/device/include/Cordova/CDVURLProtocol.h
    builtin-copy -exclude .DS_Store -exclude CVS -exclude .svn -exclude .git -exclude .hg -strip-debug-symbols -strip-tool /Applications/Xcode.app/Contents/Developer/Toolchains/XcodeDefault.xctoolchain/usr/bin/strip -resolve-src-symlinks .../GlobalApp/platforms/ios/CordovaLib/Classes/CDVURLProtocol.h .../GlobalApp/platforms/ios/build/device/include/Cordova
CpHeader Classes/CDVViewController.h .../GlobalApp/platforms/ios/build/device/include/Cordova/CDVViewController.h
    builtin-copy -exclude .DS_Store -exclude CVS -exclude .svn -exclude .git -exclude .hg -strip-debug-symbols -strip-tool /Applications/Xcode.app/Contents/Developer/Toolchains/XcodeDefault.xctoolchain/usr/bin/strip -resolve-src-symlinks .../GlobalApp/platforms/ios/CordovaLib/Classes/CDVViewController.h .../GlobalApp/platforms/ios/build/device/include/Cordova
CpHeader Classes/CDVCommandDelegate.h .../GlobalApp/platforms/ios/build/device/include/Cordova/CDVCommandDelegate.h
    builtin-copy -exclude .DS_Store -exclude CVS -exclude .svn -exclude .git -exclude .hg -strip-debug-symbols -strip-tool /Applications/Xcode.app/Contents/Developer/Toolchains/XcodeDefault.xctoolchain/usr/bin/strip -resolve-src-symlinks .../GlobalApp/platforms/ios/CordovaLib/Classes/CDVCommandDelegate.h .../GlobalApp/platforms/ios/build/device/include/Cordova
CpHeader Classes/CDV.h .../GlobalApp/platforms/ios/build/device/include/Cordova/CDV.h
    builtin-copy -exclude .DS_Store -exclude CVS -exclude .svn -exclude .git -exclude .hg -strip-debug-symbols -strip-tool /Applications/Xcode.app/Contents/Developer/Toolchains/XcodeDefault.xctoolchain/usr/bin/strip -resolve-src-symlinks .../GlobalApp/platforms/ios/CordovaLib/Classes/CDV.h .../GlobalApp/platforms/ios/build/device/include/Cordova
CpHeader Classes/CDVAvailability.h .../GlobalApp/platforms/ios/build/device/include/Cordova/CDVAvailability.h
    builtin-copy -exclude .DS_Store -exclude CVS -exclude .svn -exclude .git -exclude .hg -strip-debug-symbols -strip-tool /Applications/Xcode.app/Contents/Developer/Toolchains/XcodeDefault.xctoolchain/usr/bin/strip -resolve-src-symlinks .../GlobalApp/platforms/ios/CordovaLib/Classes/CDVAvailability.h .../GlobalApp/platforms/ios/build/device/include/Cordova
CpHeader Classes/CDVAvailabilityDeprecated.h .../GlobalApp/platforms/ios/build/device/include/Cordova/CDVAvailabilityDeprecated.h
    builtin-copy -exclude .DS_Store -exclude CVS -exclude .svn -exclude .git -exclude .hg -strip-debug-symbols -strip-tool /Applications/Xcode.app/Contents/Developer/Toolchains/XcodeDefault.xctoolchain/usr/bin/strip -resolve-src-symlinks .../GlobalApp/platforms/ios/CordovaLib/Classes/CDVAvailabilityDeprecated.h .../GlobalApp/platforms/ios/build/device/include/Cordova
CpHeader Classes/UIDevice+Extensions.h .../GlobalApp/platforms/ios/build/device/include/Cordova/UIDevice+Extensions.h
    builtin-copy -exclude .DS_Store -exclude CVS -exclude .svn -exclude .git -exclude .hg -strip-debug-symbols -strip-tool /Applications/Xcode.app/Contents/Developer/Toolchains/XcodeDefault.xctoolchain/usr/bin/strip -resolve-src-symlinks .../GlobalApp/platforms/ios/CordovaLib/Classes/UIDevice+Extensions.h .../GlobalApp/platforms/ios/build/device/include/Cordova
CpHeader Classes/CDVLocalStorage.h .../GlobalApp/platforms/ios/build/device/include/Cordova/CDVLocalStorage.h
    builtin-copy -exclude .DS_Store -exclude CVS -exclude .svn -exclude .git -exclude .hg -strip-debug-symbols -strip-tool /Applications/Xcode.app/Contents/Developer/Toolchains/XcodeDefault.xctoolchain/usr/bin/strip -resolve-src-symlinks .../GlobalApp/platforms/ios/CordovaLib/Classes/CDVLocalStorage.h .../GlobalApp/platforms/ios/build/device/include/Cordova
CpHeader Classes/NSArray+Comparisons.h .../GlobalApp/platforms/ios/build/device/include/Cordova/NSArray+Comparisons.h
    builtin-copy -exclude .DS_Store -exclude CVS -exclude .svn -exclude .git -exclude .hg -strip-debug-symbols -strip-tool /Applications/Xcode.app/Contents/Developer/Toolchains/XcodeDefault.xctoolchain/usr/bin/strip -resolve-src-symlinks .../GlobalApp/platforms/ios/CordovaLib/Classes/NSArray+Comparisons.h .../GlobalApp/platforms/ios/build/device/include/Cordova
CpHeader Classes/CDVCommandQueue.h .../GlobalApp/platforms/ios/build/device/include/Cordova/CDVCommandQueue.h
    builtin-copy -exclude .DS_Store -exclude CVS -exclude .svn -exclude .git -exclude .hg -strip-debug-symbols -strip-tool /Applications/Xcode.app/Contents/Developer/Toolchains/XcodeDefault.xctoolchain/usr/bin/strip -resolve-src-symlinks .../GlobalApp/platforms/ios/CordovaLib/Classes/CDVCommandQueue.h .../GlobalApp/platforms/ios/build/device/include/Cordova
CpHeader Classes/CDVShared.h .../GlobalApp/platforms/ios/build/device/include/Cordova/CDVShared.h
    builtin-copy -exclude .DS_Store -exclude CVS -exclude .svn -exclude .git -exclude .hg -strip-debug-symbols -strip-tool /Applications/Xcode.app/Contents/Developer/Toolchains/XcodeDefault.xctoolchain/usr/bin/strip -resolve-src-symlinks .../GlobalApp/platforms/ios/CordovaLib/Classes/CDVShared.h .../GlobalApp/platforms/ios/build/device/include/Cordova
CpHeader Classes/CDVCommandDelegateImpl.h .../GlobalApp/platforms/ios/build/device/include/Cordova/CDVCommandDelegateImpl.h
    builtin-copy -exclude .DS_Store -exclude CVS -exclude .svn -exclude .git -exclude .hg -strip-debug-symbols -strip-tool /Applications/Xcode.app/Contents/Developer/Toolchains/XcodeDefault.xctoolchain/usr/bin/strip -resolve-src-symlinks .../GlobalApp/platforms/ios/CordovaLib/Classes/CDVCommandDelegateImpl.h .../GlobalApp/platforms/ios/build/device/include/Cordova
CpHeader Classes/CDVScreenOrientationDelegate.h .../GlobalApp/platforms/ios/build/device/include/Cordova/CDVScreenOrientationDelegate.h
    builtin-copy -exclude .DS_Store -exclude CVS -exclude .svn -exclude .git -exclude .hg -strip-debug-symbols -strip-tool /Applications/Xcode.app/Contents/Developer/Toolchains/XcodeDefault.xctoolchain/usr/bin/strip -resolve-src-symlinks .../GlobalApp/platforms/ios/CordovaLib/Classes/CDVScreenOrientationDelegate.h .../GlobalApp/platforms/ios/build/device/include/Cordova
CpHeader Classes/CDVConfigParser.h .../GlobalApp/platforms/ios/build/device/include/Cordova/CDVConfigParser.h
PaulF_IntelCorp
@Matthew -- please do not paste those build logs into your post, they are extremely difficult to scan when you do that, making it very difficult to help you. Please attach the detailed build log using the "attach media" button. That insures we get the original file with no modifications. Please try again.
