Help !
Logs:
Calling plugman.fetch on plugin ".../cachedPlugins.nPmgM8.tmp/cache.JcpX7r.pl/org.apache.cordova.camera" Copying plugin ".../cachedPlugins.nPmgM8.tmp/cache.JcpX7r.pl/org.apache.cordova.camera" => ".../AstermDepo/plugins/org.apache.cordova.camera" Calling plugman.install on plugin ".../AstermDepo/plugins/org.apache.cordova.camera" for platform "android" with options "{"cli_variables":{},"browserify":false,"nohooks":["."]}" Installing "org.apache.cordova.camera" for android Install start for "org.apache.cordova.camera" on android. path does not exist: .../AstermDepo/platforms/android/src/org/apache/cordova/camera path does not exist: .../AstermDepo/platforms/android/src/org/apache/cordova/camera path does not exist: .../AstermDepo/platforms/android/src/org/apache/cordova/camera Beginning processing of action stack for android project... Parsing android project files... Action stack processing complete. Running command: .../AstermDepo/platforms/android/cordova/version Command finished with error code 0: .../AstermDepo/platforms/android/cordova/version Writing out android project files... Preparing android project Processing configuration changes for plugins. Iterating over installed plugins: [ 'org.apache.cordova.camera' ] Writing out cordova_plugins.js... Install complete for org.apache.cordova.camera on android. Calling plugman.fetch on plugin ".../cachedPlugins.nPmgM8.tmp/cache.mGnKze.pl/org.apache.cordova.device" Copying plugin ".../cachedPlugins.nPmgM8.tmp/cache.mGnKze.pl/org.apache.cordova.device" => ".../AstermDepo/plugins/org.apache.cordova.device" Calling plugman.install on plugin ".../AstermDepo/plugins/org.apache.cordova.device" for platform "android" with options "{"cli_variables":{},"browserify":false,"nohooks":["."]}" Installing "org.apache.cordova.device" for android Install start for "org.apache.cordova.device" on android. path does not exist: .../AstermDepo/platforms/android/src/org/apache/cordova/device Beginning processing of action stack for android project... Parsing android project files... Action stack processing complete. Running command: .../AstermDepo/platforms/android/cordova/version Command finished with error code 0: .../AstermDepo/platforms/android/cordova/version Writing out android project files... Preparing android project Processing configuration changes for plugins. Iterating over installed plugins: [ 'org.apache.cordova.camera', 'org.apache.cordova.device' ] Writing out cordova_plugins.js... Install complete for org.apache.cordova.device on android. Calling plugman.fetch on plugin ".../cachedPlugins.nPmgM8.tmp/cache.BymvdD.pl/org.apache.cordova.inappbrowser" Copying plugin ".../cachedPlugins.nPmgM8.tmp/cache.BymvdD.pl/org.apache.cordova.inappbrowser" => ".../AstermDepo/plugins/org.apache.cordova.inappbrowser" Calling plugman.install on plugin ".../AstermDepo/plugins/org.apache.cordova.inappbrowser" for platform "android" with options "{"cli_variables":{},"browserify":false,"nohooks":["."]}" Installing "org.apache.cordova.inappbrowser" for android Install start for "org.apache.cordova.inappbrowser" on android. path does not exist: .../AstermDepo/platforms/android/src/org/apache/cordova/inappbrowser path does not exist: .../AstermDepo/platforms/android/src/org/apache/cordova/inappbrowser path does not exist: .../AstermDepo/platforms/android/src/org/apache/cordova/inappbrowser path does not exist: .../AstermDepo/platforms/android/res/drawable-hdpi/ic_action_next_item.png path does not exist: .../AstermDepo/platforms/android/res/drawable-mdpi/ic_action_next_item.png path does not exist: .../AstermDepo/platforms/android/res/drawable-xhdpi/ic_action_next_item.png path does not exist: .../AstermDepo/platforms/android/res/drawable-xxhdpi/ic_action_next_item.png path does not exist: .../AstermDepo/platforms/android/res/drawable-hdpi/ic_action_previous_item.png path does not exist: .../AstermDepo/platforms/android/res/drawable-mdpi/ic_action_previous_item.png path does not exist: .../AstermDepo/platforms/android/res/drawable-xhdpi/ic_action_previous_item.png path does not exist: .../AstermDepo/platforms/android/res/drawable-xxhdpi/ic_action_previous_item.png path does not exist: .../AstermDepo/platforms/android/res/drawable-hdpi/ic_action_remove.png path does not exist: .../AstermDepo/platforms/android/res/drawable-mdpi/ic_action_remove.png path does not exist: .../AstermDepo/platforms/android/res/drawable-xhdpi/ic_action_remove.png path does not exist: .../AstermDepo/platforms/android/res/drawable-xxhdpi/ic_action_remove.png Beginning processing of action stack for android project... Parsing android project files... Copying resource file src/android/res/drawable-hdpi/ic_action_next_item.png to res/drawable-hdpi/ic_action_next_item.png Copying resource file src/android/res/drawable-mdpi/ic_action_next_item.png to res/drawable-mdpi/ic_action_next_item.png Copying resource file src/android/res/drawable-xhdpi/ic_action_next_item.png to res/drawable-xhdpi/ic_action_next_item.png Copying resource file src/android/res/drawable-xxhdpi/ic_action_next_item.png to res/drawable-xxhdpi/ic_action_next_item.png Copying resource file src/android/res/drawable-hdpi/ic_action_previous_item.png to res/drawable-hdpi/ic_action_previous_item.png Copying resource file src/android/res/drawable-mdpi/ic_action_previous_item.png to res/drawable-mdpi/ic_action_previous_item.png Copying resource file src/android/res/drawable-xhdpi/ic_action_previous_item.png to res/drawable-xhdpi/ic_action_previous_item.png Copying resource file src/android/res/drawable-xxhdpi/ic_action_previous_item.png to res/drawable-xxhdpi/ic_action_previous_item.png Copying resource file src/android/res/drawable-hdpi/ic_action_remove.png to res/drawable-hdpi/ic_action_remove.png Copying resource file src/android/res/drawable-mdpi/ic_action_remove.png to res/drawable-mdpi/ic_action_remove.png Copying resource file src/android/res/drawable-xhdpi/ic_action_remove.png to res/drawable-xhdpi/ic_action_remove.png Copying resource file src/android/res/drawable-xxhdpi/ic_action_remove.png to res/drawable-xxhdpi/ic_action_remove.png Action stack processing complete. Running command: .../AstermDepo/platforms/android/cordova/version Command finished with error code 0: .../AstermDepo/platforms/android/cordova/version Writing out android project files... Preparing android project Processing configuration changes for plugins. Iterating over installed plugins: [ 'org.apache.cordova.camera', 'org.apache.cordova.device', 'org.apache.cordova.inappbrowser' ] Writing out cordova_plugins.js... Install complete for org.apache.cordova.inappbrowser on android. Calling plugman.fetch on plugin ".../cachedPlugins.nPmgM8.tmp/cache.LOhyrT.pl/org.apache.cordova.dialogs" Copying plugin ".../cachedPlugins.nPmgM8.tmp/cache.LOhyrT.pl/org.apache.cordova.dialogs" => ".../AstermDepo/plugins/org.apache.cordova.dialogs" Calling plugman.install on plugin ".../AstermDepo/plugins/org.apache.cordova.dialogs" for platform "android" with options "{"cli_variables":{},"browserify":false,"nohooks":["."]}" Installing "org.apache.cordova.dialogs" for android Install start for "org.apache.cordova.dialogs" on android. path does not exist: .../AstermDepo/platforms/android/src/org/apache/cordova/dialogs Beginning processing of action stack for android project... Parsing android project files... Action stack processing complete. Running command: .../AstermDepo/platforms/android/cordova/version Command finished with error code 0: .../AstermDepo/platforms/android/cordova/version Writing out android project files... Preparing android project Processing configuration changes for plugins. Iterating over installed plugins: [ 'org.apache.cordova.camera', 'org.apache.cordova.device', 'org.apache.cordova.inappbrowser', 'org.apache.cordova.dialogs' ] Writing out cordova_plugins.js... Install complete for org.apache.cordova.dialogs on android. Calling plugman.fetch on plugin ".../cachedPlugins.nPmgM8.tmp/cache.aWa1At.pl/org.apache.cordova.splashscreen" Copying plugin ".../cachedPlugins.nPmgM8.tmp/cache.aWa1At.pl/org.apache.cordova.splashscreen" => ".../AstermDepo/plugins/org.apache.cordova.splashscreen" Calling plugman.install on plugin ".../AstermDepo/plugins/org.apache.cordova.splashscreen" for platform "android" with options "{"cli_variables":{},"browserify":false,"nohooks":["."]}" Installing "org.apache.cordova.splashscreen" for android Install start for "org.apache.cordova.splashscreen" on android. path does not exist: .../AstermDepo/platforms/android/src/org/apache/cordova/splashscreen Beginning processing of action stack for android project... Parsing android project files... Action stack processing complete. Running command: .../AstermDepo/platforms/android/cordova/version Command finished with error code 0: .../AstermDepo/platforms/android/cordova/version Writing out android project files... Preparing android project Processing configuration changes for plugins. Iterating over installed plugins: [ 'org.apache.cordova.camera', 'org.apache.cordova.device', 'org.apache.cordova.inappbrowser', 'org.apache.cordova.dialogs', 'org.apache.cordova.splashscreen' ] Writing out cordova_plugins.js... Install complete for org.apache.cordova.splashscreen on android. Calling plugman.fetch on plugin ".../cachedPlugins.nPmgM8.tmp/cache.lfLkW8.pl/org.apache.cordova.statusbar" Copying plugin ".../cachedPlugins.nPmgM8.tmp/cache.lfLkW8.pl/org.apache.cordova.statusbar" => ".../AstermDepo/plugins/org.apache.cordova.statusbar" Calling plugman.install on plugin ".../AstermDepo/plugins/org.apache.cordova.statusbar" for platform "android" with options "{"cli_variables":{},"browserify":false,"nohooks":["."]}" Installing "org.apache.cordova.statusbar" for android Install start for "org.apache.cordova.statusbar" on android. path does not exist: .../AstermDepo/platforms/android/src/org/apache/cordova/statusbar Beginning processing of action stack for android project... Parsing android project files... Action stack processing complete. Running command: .../AstermDepo/platforms/android/cordova/version Command finished with error code 0: .../AstermDepo/platforms/android/cordova/version Writing out android project files... Preparing android project Processing configuration changes for plugins. Iterating over installed plugins: [ 'org.apache.cordova.camera', 'org.apache.cordova.device', 'org.apache.cordova.inappbrowser', 'org.apache.cordova.dialogs', 'org.apache.cordova.splashscreen', 'org.apache.cordova.statusbar' ] Writing out cordova_plugins.js... Install complete for org.apache.cordova.statusbar on android. Calling plugman.fetch on plugin ".../cachedPlugins.nPmgM8.tmp/cache.kxS6AP.pl/org.apache.cordova.battery-status" Copying plugin ".../cachedPlugins.nPmgM8.tmp/cache.kxS6AP.pl/org.apache.cordova.battery-status" => ".../AstermDepo/plugins/org.apache.cordova.battery-status" Calling plugman.install on plugin ".../AstermDepo/plugins/org.apache.cordova.battery-status" for platform "android" with options "{"cli_variables":{},"browserify":false,"nohooks":["."]}" Installing "org.apache.cordova.battery-status" for android Install start for "org.apache.cordova.battery-status" on android. path does not exist: .../AstermDepo/platforms/android/src/org/apache/cordova/batterystatus Beginning processing of action stack for android project... Parsing android project files... Action stack processing complete. Running command: .../AstermDepo/platforms/android/cordova/version Command finished with error code 0: .../AstermDepo/platforms/android/cordova/version Writing out android project files... Preparing android project Processing configuration changes for plugins. Iterating over installed plugins: [ 'org.apache.cordova.camera', 'org.apache.cordova.device', 'org.apache.cordova.inappbrowser', 'org.apache.cordova.dialogs', 'org.apache.cordova.splashscreen', 'org.apache.cordova.statusbar', 'org.apache.cordova.battery-status' ] Writing out cordova_plugins.js... Install complete for org.apache.cordova.battery-status on android. Calling plugman.fetch on plugin ".../cachedPlugins.nPmgM8.tmp/cache.hArx16.pl/org.apache.cordova.device-motion" Copying plugin ".../cachedPlugins.nPmgM8.tmp/cache.hArx16.pl/org.apache.cordova.device-motion" => ".../AstermDepo/plugins/org.apache.cordova.device-motion" Calling plugman.install on plugin ".../AstermDepo/plugins/org.apache.cordova.device-motion" for platform "android" with options "{"cli_variables":{},"browserify":false,"nohooks":["."]}" Installing "org.apache.cordova.device-motion" for android Install start for "org.apache.cordova.device-motion" on android. path does not exist: .../AstermDepo/platforms/android/src/org/apache/cordova/devicemotion Beginning processing of action stack for android project... Parsing android project files... Action stack processing complete. Running command: .../AstermDepo/platforms/android/cordova/version Command finished with error code 0: .../AstermDepo/platforms/android/cordova/version Writing out android project files... Preparing android project Processing configuration changes for plugins. Iterating over installed plugins: [ 'org.apache.cordova.camera', 'org.apache.cordova.device', 'org.apache.cordova.inappbrowser', 'org.apache.cordova.dialogs', 'org.apache.cordova.splashscreen', 'org.apache.cordova.statusbar', 'org.apache.cordova.battery-status', 'org.apache.cordova.device-motion' ] Writing out cordova_plugins.js... Install complete for org.apache.cordova.device-motion on android. Calling plugman.fetch on plugin ".../cachedPlugins.nPmgM8.tmp/cache.IUpVlq.pl/org.apache.cordova.network-information" Copying plugin ".../cachedPlugins.nPmgM8.tmp/cache.IUpVlq.pl/org.apache.cordova.network-information" => ".../AstermDepo/plugins/org.apache.cordova.network-information" Calling plugman.install on plugin ".../AstermDepo/plugins/org.apache.cordova.network-information" for platform "android" with options "{"cli_variables":{},"browserify":false,"nohooks":["."]}" Installing "org.apache.cordova.network-information" for android Install start for "org.apache.cordova.network-information" on android. path does not exist: .../AstermDepo/platforms/android/src/org/apache/cordova/networkinformation Beginning processing of action stack for android project... Parsing android project files... Action stack processing complete. Running command: .../AstermDepo/platforms/android/cordova/version Command finished with error code 0: .../AstermDepo/platforms/android/cordova/version Writing out android project files... Preparing android project Processing configuration changes for plugins. Iterating over installed plugins: [ 'org.apache.cordova.camera', 'org.apache.cordova.device', 'org.apache.cordova.inappbrowser', 'org.apache.cordova.dialogs', 'org.apache.cordova.splashscreen', 'org.apache.cordova.statusbar', 'org.apache.cordova.battery-status', 'org.apache.cordova.device-motion', 'org.apache.cordova.network-information' ] Writing out cordova_plugins.js... Install complete for org.apache.cordova.network-information on android. Calling plugman.fetch on plugin ".../cachedPlugins.nPmgM8.tmp/cache.OIrgjO.pl/org.apache.cordova.geolocation" Copying plugin ".../cachedPlugins.nPmgM8.tmp/cache.OIrgjO.pl/org.apache.cordova.geolocation" => ".../AstermDepo/plugins/org.apache.cordova.geolocation" Calling plugman.install on plugin ".../AstermDepo/plugins/org.apache.cordova.geolocation" for platform "android" with options "{"cli_variables":{},"browserify":false,"nohooks":["."]}" Installing "org.apache.cordova.geolocation" for android Install start for "org.apache.cordova.geolocation" on android. Beginning processing of action stack for android project... Parsing android project files... Action stack processing complete. Running command: .../AstermDepo/platforms/android/cordova/version Command finished with error code 0: .../AstermDepo/platforms/android/cordova/version Writing out android project files... Preparing android project Processing configuration changes for plugins. Iterating over installed plugins: [ 'org.apache.cordova.camera', 'org.apache.cordova.device', 'org.apache.cordova.inappbrowser', 'org.apache.cordova.dialogs', 'org.apache.cordova.splashscreen', 'org.apache.cordova.statusbar', 'org.apache.cordova.battery-status', 'org.apache.cordova.device-motion', 'org.apache.cordova.network-information', 'org.apache.cordova.geolocation' ] Writing out cordova_plugins.js... Install complete for org.apache.cordova.geolocation on android. Calling plugman.fetch on plugin ".../cachedPlugins.nPmgM8.tmp/cache.cO2nvH.pl/org.apache.cordova.globalization" Copying plugin ".../cachedPlugins.nPmgM8.tmp/cache.cO2nvH.pl/org.apache.cordova.globalization" => ".../AstermDepo/plugins/org.apache.cordova.globalization" Calling plugman.install on plugin ".../AstermDepo/plugins/org.apache.cordova.globalization" for platform "android" with options "{"cli_variables":{},"browserify":false,"nohooks":["."]}" Installing "org.apache.cordova.globalization" for android Install start for "org.apache.cordova.globalization" on android. path does not exist: .../AstermDepo/platforms/android/src/org/apache/cordova/globalization path does not exist: .../AstermDepo/platforms/android/src/org/apache/cordova/globalization Beginning processing of action stack for android project... Parsing android project files... Action stack processing complete. Running command: .../AstermDepo/platforms/android/cordova/version Command finished with error code 0: .../AstermDepo/platforms/android/cordova/version Writing out android project files... Preparing android project Processing configuration changes for plugins. Iterating over installed plugins: [ 'org.apache.cordova.camera', 'org.apache.cordova.device', 'org.apache.cordova.inappbrowser', 'org.apache.cordova.dialogs', 'org.apache.cordova.splashscreen', 'org.apache.cordova.statusbar', 'org.apache.cordova.battery-status', 'org.apache.cordova.device-motion', 'org.apache.cordova.network-information', 'org.apache.cordova.geolocation', 'org.apache.cordova.globalization' ] Writing out cordova_plugins.js... Install complete for org.apache.cordova.globalization on android. Calling plugman.fetch on plugin ".../cachedPlugins.nPmgM8.tmp/cache.BNYujE.pl/org.apache.cordova.file" Copying plugin ".../cachedPlugins.nPmgM8.tmp/cache.BNYujE.pl/org.apache.cordova.file" => ".../AstermDepo/plugins/org.apache.cordova.file" Calling plugman.install on plugin ".../AstermDepo/plugins/org.apache.cordova.file" for platform "android" with options "{"cli_variables":{},"browserify":false,"nohooks":["."]}" Installing "org.apache.cordova.file" for android Install start for "org.apache.cordova.file" on android. path does not exist: .../AstermDepo/platforms/android/src/org/apache/cordova/file path does not exist: .../AstermDepo/platforms/android/src/org/apache/cordova/file path does not exist: .../AstermDepo/platforms/android/src/org/apache/cordova/file path does not exist: .../AstermDepo/platforms/android/src/org/apache/cordova/file path does not exist: .../AstermDepo/platforms/android/src/org/apache/cordova/file path does not exist: .../AstermDepo/platforms/android/src/org/apache/cordova/file path does not exist: .../AstermDepo/platforms/android/src/org/apache/cordova/file path does not exist: .../AstermDepo/platforms/android/src/org/apache/cordova/file Beginning processing of action stack for android project... Parsing android project files... Action stack processing complete. Running command: .../AstermDepo/platforms/android/cordova/version Command finished with error code 0: .../AstermDepo/platforms/android/cordova/version Writing out android project files... Preparing android project Processing configuration changes for plugins. Iterating over installed plugins: [ 'org.apache.cordova.camera', 'org.apache.cordova.device', 'org.apache.cordova.inappbrowser', 'org.apache.cordova.dialogs', 'org.apache.cordova.splashscreen', 'org.apache.cordova.statusbar', 'org.apache.cordova.battery-status', 'org.apache.cordova.device-motion', 'org.apache.cordova.network-information', 'org.apache.cordova.geolocation', 'org.apache.cordova.globalization', 'org.apache.cordova.file' ] Writing out cordova_plugins.js... Install complete for org.apache.cordova.file on android. Calling plugman.fetch on plugin ".../cachedPlugins.nPmgM8.tmp/cache.bytEXk.pl/org.apache.cordova.media" Copying plugin ".../cachedPlugins.nPmgM8.tmp/cache.bytEXk.pl/org.apache.cordova.media" => ".../AstermDepo/plugins/org.apache.cordova.media" Calling plugman.install on plugin ".../AstermDepo/plugins/org.apache.cordova.media" for platform "android" with options "{"cli_variables":{},"browserify":false,"nohooks":["."]}" Installing "org.apache.cordova.media" for android Dependencies detected, iterating through them... Dependent plugin "org.apache.cordova.file" already fetched, using that version. Dependent plugin "org.apache.cordova.file" already installed on android. Install start for "org.apache.cordova.media" on android. path does not exist: .../AstermDepo/platforms/android/src/org/apache/cordova/media path does not exist: .../AstermDepo/platforms/android/src/org/apache/cordova/media path does not exist: .../AstermDepo/platforms/android/src/org/apache/cordova/media Beginning processing of action stack for android project... Parsing android project files... Action stack processing complete. Running command: .../AstermDepo/platforms/android/cordova/version Command finished with error code 0: .../AstermDepo/platforms/android/cordova/version Writing out android project files... Preparing android project Processing configuration changes for plugins. Iterating over installed plugins: [ 'org.apache.cordova.camera', 'org.apache.cordova.device', 'org.apache.cordova.inappbrowser', 'org.apache.cordova.dialogs', 'org.apache.cordova.splashscreen', 'org.apache.cordova.statusbar', 'org.apache.cordova.battery-status', 'org.apache.cordova.device-motion', 'org.apache.cordova.network-information', 'org.apache.cordova.geolocation', 'org.apache.cordova.globalization', 'org.apache.cordova.file', 'org.apache.cordova.media' ] Writing out cordova_plugins.js... Install complete for org.apache.cordova.media on android. Calling plugman.fetch on plugin ".../cachedPlugins.nPmgM8.tmp/cache.LtUjnI.pl/com.intel.xdk.accelerometer" Copying plugin ".../cachedPlugins.nPmgM8.tmp/cache.LtUjnI.pl/com.intel.xdk.accelerometer" => ".../AstermDepo/plugins/com.intel.xdk.accelerometer" Calling plugman.install on plugin ".../AstermDepo/plugins/com.intel.xdk.accelerometer" for platform "android" with options "{"cli_variables":{},"browserify":false,"nohooks":["."]}" Installing "com.intel.xdk.accelerometer" for android Install start for "com.intel.xdk.accelerometer" on android. path does not exist: .../AstermDepo/platforms/android/src/com/intel/xdk/accelerometer Beginning processing of action stack for android project... Parsing android project files... Action stack processing complete. Running command: .../AstermDepo/platforms/android/cordova/version Command finished with error code 0: .../AstermDepo/platforms/android/cordova/version Writing out android project files... Preparing android project Processing configuration changes for plugins. Iterating over installed plugins: [ 'org.apache.cordova.camera', 'org.apache.cordova.device', 'org.apache.cordova.inappbrowser', 'org.apache.cordova.dialogs', 'org.apache.cordova.splashscreen', 'org.apache.cordova.statusbar', 'org.apache.cordova.battery-status', 'org.apache.cordova.device-motion', 'org.apache.cordova.network-information', 'org.apache.cordova.geolocation', 'org.apache.cordova.globalization', 'org.apache.cordova.file', 'org.apache.cordova.media', 'com.intel.xdk.accelerometer' ] Writing out cordova_plugins.js... Install complete for com.intel.xdk.accelerometer on android. Calling plugman.fetch on plugin ".../cachedPlugins.nPmgM8.tmp/cache.3r01Vr.pl/com.intel.xdk.base" Copying plugin ".../cachedPlugins.nPmgM8.tmp/cache.3r01Vr.pl/com.intel.xdk.base" => ".../AstermDepo/plugins/com.intel.xdk.base" Calling plugman.install on plugin ".../AstermDepo/plugins/com.intel.xdk.base" for platform "android" with options "{"cli_variables":{},"browserify":false,"nohooks":["."]}" Installing "com.intel.xdk.base" for android Install start for "com.intel.xdk.base" on android. path does not exist: .../AstermDepo/platforms/android/src/com/intel/xdk/base path does not exist: .../AstermDepo/platforms/android/res/layout path does not exist: .../AstermDepo/platforms/android/res/layout path does not exist: .../AstermDepo/platforms/android/res/layout path does not exist: .../AstermDepo/platforms/android/res/layout Beginning processing of action stack for android project... Parsing android project files... Action stack processing complete. Running command: .../AstermDepo/platforms/android/cordova/version Command finished with error code 0: .../AstermDepo/platforms/android/cordova/version Writing out android project files... Preparing android project Processing configuration changes for plugins. Iterating over installed plugins: [ 'org.apache.cordova.camera', 'org.apache.cordova.device', 'org.apache.cordova.inappbrowser', 'org.apache.cordova.dialogs', 'org.apache.cordova.splashscreen', 'org.apache.cordova.statusbar', 'org.apache.cordova.battery-status', 'org.apache.cordova.device-motion', 'org.apache.cordova.network-information', 'org.apache.cordova.geolocation', 'org.apache.cordova.globalization', 'org.apache.cordova.file', 'org.apache.cordova.media', 'com.intel.xdk.accelerometer', 'com.intel.xdk.base' ] path does not exist: .../AstermDepo/platforms/android/intelxdk.js path does not exist: .../AstermDepo/platforms/android/xhr.js Writing out cordova_plugins.js... Install complete for com.intel.xdk.base on android. Calling plugman.fetch on plugin ".../cachedPlugins.nPmgM8.tmp/cache.mo0qH5.pl/com.intel.xdk.cache" Copying plugin ".../cachedPlugins.nPmgM8.tmp/cache.mo0qH5.pl/com.intel.xdk.cache" => ".../AstermDepo/plugins/com.intel.xdk.cache" Calling plugman.install on plugin ".../AstermDepo/plugins/com.intel.xdk.cache" for platform "android" with options "{"cli_variables":{},"browserify":false,"nohooks":["."]}" Installing "com.intel.xdk.cache" for android Install start for "com.intel.xdk.cache" on android. path does not exist: .../AstermDepo/platforms/android/src/com/intel/xdk/cache Beginning processing of action stack for android project... Parsing android project files... Action stack processing complete. Running command: .../AstermDepo/platforms/android/cordova/version Command finished with error code 0: .../AstermDepo/platforms/android/cordova/version Writing out android project files... Preparing android project Processing configuration changes for plugins. Iterating over installed plugins: [ 'org.apache.cordova.camera', 'org.apache.cordova.device', 'org.apache.cordova.inappbrowser', 'org.apache.cordova.dialogs', 'org.apache.cordova.splashscreen', 'org.apache.cordova.statusbar', 'org.apache.cordova.battery-status', 'org.apache.cordova.device-motion', 'org.apache.cordova.network-information', 'org.apache.cordova.geolocation', 'org.apache.cordova.globalization', 'org.apache.cordova.file', 'org.apache.cordova.media', 'com.intel.xdk.accelerometer', 'com.intel.xdk.base', 'com.intel.xdk.cache' ] path does not exist: .../AstermDepo/platforms/android/intelxdk.js path does not exist: .../AstermDepo/platforms/android/xhr.js Writing out cordova_plugins.js... Install complete for com.intel.xdk.cache on android. Calling plugman.fetch on plugin ".../cachedPlugins.nPmgM8.tmp/cache.lkv4Aa.pl/com.intel.xdk.camera" Copying plugin ".../cachedPlugins.nPmgM8.tmp/cache.lkv4Aa.pl/com.intel.xdk.camera" => ".../AstermDepo/plugins/com.intel.xdk.camera" Calling plugman.install on plugin ".../AstermDepo/plugins/com.intel.xdk.camera" for platform "android" with options "{"cli_variables":{},"browserify":false,"nohooks":["."]}" Installing "com.intel.xdk.camera" for android Install start for "com.intel.xdk.camera" on android. path does not exist: .../AstermDepo/platforms/android/src/com/intel/xdk/camera Beginning processing of action stack for android project... Parsing android project files... Action stack processing complete. Running command: .../AstermDepo/platforms/android/cordova/version Command finished with error code 0: .../AstermDepo/platforms/android/cordova/version Writing out android project files... Preparing android project Processing configuration changes for plugins. Iterating over installed plugins: [ 'org.apache.cordova.camera', 'org.apache.cordova.device', 'org.apache.cordova.inappbrowser', 'org.apache.cordova.dialogs', 'org.apache.cordova.splashscreen', 'org.apache.cordova.statusbar', 'org.apache.cordova.battery-status', 'org.apache.cordova.device-motion', 'org.apache.cordova.network-information', 'org.apache.cordova.geolocation', 'org.apache.cordova.globalization', 'org.apache.cordova.file', 'org.apache.cordova.media', 'com.intel.xdk.accelerometer', 'com.intel.xdk.base', 'com.intel.xdk.cache', 'com.intel.xdk.camera' ] path does not exist: .../AstermDepo/platforms/android/intelxdk.js path does not exist: .../AstermDepo/platforms/android/xhr.js Writing out cordova_plugins.js... Install complete for com.intel.xdk.camera on android. Calling plugman.fetch on plugin ".../cachedPlugins.nPmgM8.tmp/cache.RnAoQa.pl/com.intel.xdk.device" Copying plugin ".../cachedPlugins.nPmgM8.tmp/cache.RnAoQa.pl/com.intel.xdk.device" => ".../AstermDepo/plugins/com.intel.xdk.device" Calling plugman.install on plugin ".../AstermDepo/plugins/com.intel.xdk.device" for platform "android" with options "{"cli_variables":{},"browserify":false,"nohooks":["."]}" Installing "com.intel.xdk.device" for android Install start for "com.intel.xdk.device" on android. path does not exist: .../AstermDepo/platforms/android/src/com/intel/xdk/device path does not exist: .../AstermDepo/platforms/android/src/com/phonegap/plugins/barcodescanner path does not exist: .../AstermDepo/platforms/android/res/layout-land path does not exist: .../AstermDepo/platforms/android/res/layout-land path does not exist: .../AstermDepo/platforms/android/res/layout-ldpi path does not exist: .../AstermDepo/platforms/android/res/menu path does not exist: .../AstermDepo/platforms/android/res/menu path does not exist: .../AstermDepo/platforms/android/res/menu path does not exist: .../AstermDepo/platforms/android/res/raw Beginning processing of action stack for android project... Parsing android project files... Action stack processing complete. Running command: .../AstermDepo/platforms/android/cordova/version Command finished with error code 0: .../AstermDepo/platforms/android/cordova/version Writing out android project files... Preparing android project Processing configuration changes for plugins. Iterating over installed plugins: [ 'org.apache.cordova.camera', 'org.apache.cordova.device', 'org.apache.cordova.inappbrowser', 'org.apache.cordova.dialogs', 'org.apache.cordova.splashscreen', 'org.apache.cordova.statusbar', 'org.apache.cordova.battery-status', 'org.apache.cordova.device-motion', 'org.apache.cordova.network-information', 'org.apache.cordova.geolocation', 'org.apache.cordova.globalization', 'org.apache.cordova.file', 'org.apache.cordova.media', 'com.intel.xdk.accelerometer', 'com.intel.xdk.base', 'com.intel.xdk.cache', 'com.intel.xdk.camera', 'com.intel.xdk.device' ] path does not exist: .../AstermDepo/platforms/android/intelxdk.js path does not exist: .../AstermDepo/platforms/android/xhr.js Writing out cordova_plugins.js... Install complete for com.intel.xdk.device on android. Calling plugman.fetch on plugin ".../cachedPlugins.nPmgM8.tmp/cache.4yc19G.pl/com.intel.xdk.display" Copying plugin ".../cachedPlugins.nPmgM8.tmp/cache.4yc19G.pl/com.intel.xdk.display" => ".../AstermDepo/plugins/com.intel.xdk.display" Calling plugman.install on plugin ".../AstermDepo/plugins/com.intel.xdk.display" for platform "android" with options "{"cli_variables":{},"browserify":false,"nohooks":["."]}" Installing "com.intel.xdk.display" for android Install start for "com.intel.xdk.display" on android. path does not exist: .../AstermDepo/platforms/android/src/com/intel/xdk/display path does not exist: .../AstermDepo/platforms/android/src/com/intel/xdk/display Beginning processing of action stack for android project... Parsing android project files... Action stack processing complete. Running command: .../AstermDepo/platforms/android/cordova/version Command finished with error code 0: .../AstermDepo/platforms/android/cordova/version Writing out android project files... Preparing android project Processing configuration changes for plugins. Iterating over installed plugins: [ 'org.apache.cordova.camera', 'org.apache.cordova.device', 'org.apache.cordova.inappbrowser', 'org.apache.cordova.dialogs', 'org.apache.cordova.splashscreen', 'org.apache.cordova.statusbar', 'org.apache.cordova.battery-status', 'org.apache.cordova.device-motion', 'org.apache.cordova.network-information', 'org.apache.cordova.geolocation', 'org.apache.cordova.globalization', 'org.apache.cordova.file', 'org.apache.cordova.media', 'com.intel.xdk.accelerometer', 'com.intel.xdk.base', 'com.intel.xdk.cache', 'com.intel.xdk.camera', 'com.intel.xdk.device', 'com.intel.xdk.display' ] path does not exist: .../AstermDepo/platforms/android/intelxdk.js path does not exist: .../AstermDepo/platforms/android/xhr.js Writing out cordova_plugins.js... Install complete for com.intel.xdk.display on android. Calling plugman.fetch on plugin ".../cachedPlugins.nPmgM8.tmp/cache.J8_wcm.pl/com.intel.xdk.notification" Copying plugin ".../cachedPlugins.nPmgM8.tmp/cache.J8_wcm.pl/com.intel.xdk.notification" => ".../AstermDepo/plugins/com.intel.xdk.notification" Calling plugman.install on plugin ".../AstermDepo/plugins/com.intel.xdk.notification" for platform "android" with options "{"cli_variables":{},"browserify":false,"nohooks":["."]}" Installing "com.intel.xdk.notification" for android Install start for "com.intel.xdk.notification" on android. path does not exist: .../AstermDepo/platforms/android/src/com/intel/xdk/notification Beginning processing of action stack for android project... Parsing android project files... Action stack processing complete. Running command: .../AstermDepo/platforms/android/cordova/version Command finished with error code 0: .../AstermDepo/platforms/android/cordova/version Writing out android project files... Preparing android project Processing configuration changes for plugins. Iterating over installed plugins: [ 'org.apache.cordova.camera', 'org.apache.cordova.device', 'org.apache.cordova.inappbrowser', 'org.apache.cordova.dialogs', 'org.apache.cordova.splashscreen', 'org.apache.cordova.statusbar', 'org.apache.cordova.battery-status', 'org.apache.cordova.device-motion', 'org.apache.cordova.network-information', 'org.apache.cordova.geolocation', 'org.apache.cordova.globalization', 'org.apache.cordova.file', 'org.apache.cordova.media', 'com.intel.xdk.accelerometer', 'com.intel.xdk.base', 'com.intel.xdk.cache', 'com.intel.xdk.camera', 'com.intel.xdk.device', 'com.intel.xdk.display', 'com.intel.xdk.notification' ] path does not exist: .../AstermDepo/platforms/android/intelxdk.js path does not exist: .../AstermDepo/platforms/android/xhr.js Writing out cordova_plugins.js... Install complete for com.intel.xdk.notification on android. Generating config.xml from defaults for platform "android" Calling plugman.prepare for platform "android" Preparing android project Processing configuration changes for plugins. Iterating over installed plugins: [ 'org.apache.cordova.camera', 'org.apache.cordova.device', 'org.apache.cordova.inappbrowser', 'org.apache.cordova.dialogs', 'org.apache.cordova.splashscreen', 'org.apache.cordova.statusbar', 'org.apache.cordova.battery-status', 'org.apache.cordova.device-motion', 'org.apache.cordova.network-information', 'org.apache.cordova.geolocation', 'org.apache.cordova.globalization', 'org.apache.cordova.file', 'org.apache.cordova.media', 'com.intel.xdk.accelerometer', 'com.intel.xdk.base', 'com.intel.xdk.cache', 'com.intel.xdk.camera', 'com.intel.xdk.device', 'com.intel.xdk.display', 'com.intel.xdk.notification' ] path does not exist: .../AstermDepo/platforms/android/intelxdk.js path does not exist: .../AstermDepo/platforms/android/xhr.js Writing out cordova_plugins.js... undefined
- Tags:
- HTML5
- Intel® XDK
Auto Added andoid.confix.xml
<preference name="android-permission" value="<preference"/>
<preference name="android-permission" value="name="android-windowSoftInputMode""/>
<preference name="android-permission" value="value="adjustResize"/>"/>
When adding those extra Android permissions, you need to add them by simply providing the name as shown on this page: http://developer.android.com/reference/android/Manifest.permission.html -- I'll update the doc page to remove some of that confusion.
Do you need all of those plugins? Generally, most apps do not need every plugin in the list of available plugins. Including plugins your app does not need can cause conflicts and problem. I recommend you only select those plugins that correspond to APIs your app is actually using.
