Software Archive
Read-only legacy content
17060 Discussions
Android Back Button Exiting Apps Instead Of Running Its New Code
Muhammad_H_
I am making an app for Android using HTML-JavaScript on Intel-XDK. I'm overriding the Android Back Button function and Android Menu Button using the following code.
<script src="cordova.js" type="text/javascript"></script>
<script type="text/javascript">
/* Android Back Button
function backButtonPressed() {
    isPaused = true; // To Pause
document.addEventListener("backbutton", backButtonPressed, false);
/* Android Menu Button
function menuButtonPressed() {
    isPaused = false; // To false
document.addEventListener("menubutton", menuButtonPressed, false);
</script>
Both are working perfectly in Intel-XDK Emulate. But when I am running them in an android device, the menu button code is working but back button code is not working and it's exiting the app. What to do to stop this behavior (ie, exiting the app) and start running my own code?
Note: I also tried code from https://software.intel.com/en-us/node/493108 but still not working in Mobile and is working in Emulator.
Dale_S_Intel
How are you running it on the device?  If you're using App Preview or the debug tab, there may be a problem causing it to not work (cf. http://stackoverflow.com/questions/34511358/android-back-button-exiting-apps-instead-of-running-its-new-code). ; If you haven't tried building the app and running it on a device, give that a try and let us know.
Muhammad_H_
Yes, Your answer is Right. Debug and Apps Preview are not showing the final results.
But me got another problem. Yes, I was trying in "Test Tab, Debug Tab, Apps Preview" till now and there my BackButton is not working and MenuButton was working but now I build it on "Crosswalk for Android" then run the APK on my mobile and now BackButton is working but MenuButton stopped working. Now what to do...???
