Software Archive
Read-only legacy content
17060 Discussions
Android Build Error
Christopher_G_1
Intel XDK version 3400
Had 1 successful build and made minor changes and cannot seem to get successful build. I was getting this error before and I just retried a few times before the 1 successful build.
Any help is appreciated.
Error message which is in attachment:
:preDexArmv7Release
:dexArmv7Release
UNEXPECTED TOP-LEVEL EXCEPTION:
com.android.dex.DexException: Multiple dex files define Landroid/support/v4/accessibilityservice/AccessibilityServiceInfoCompatIcs;
	at com.android.dx.merge.DexMerger.readSortableTypes(DexMerger.java:596)
	at com.android.dx.merge.DexMerger.getSortedTypes(DexMerger.java:554)
	at com.android.dx.merge.DexMerger.mergeClassDefs(DexMerger.java:535)
	at com.android.dx.merge.DexMerger.mergeDexes(DexMerger.java:171)
	at com.android.dx.merge.DexMerger.merge(DexMerger.java:189)
	at com.android.dx.command.dexer.Main.mergeLibraryDexBuffers(Main.java:454)
	at com.android.dx.command.dexer.Main.runMonoDex(Main.java:303)
	at com.android.dx.command.dexer.Main.run(Main.java:246)
	at com.android.dx.command.dexer.Main.main(Main.java:215)
	at com.android.dx.command.Main.main(Main.java:106)
 FAILED
FAILURE: Build failed with an exception.
* What went wrong:
Execution failed for task ':dexArmv7Release'.
> com.android.ide.common.internal.LoggedErrorException: Failed to run command:
  	.../android-sdk/build-tools/21.1.2/dx --dex --output .../cordova_project/platforms/android/build/intermediates/dex/armv7/release --input-list=.../cordova_project/platforms/android/build/intermediates/tmp/dex/armv7/release/inputList.txt
  Error Code:
  	2
  Output:
* Try:
Run with --stacktrace option to get the stack trace. Run with --info or --debug option to get more log output.
BUILD FAILED
Pamela_H_Intel
Christopher,
There are a few things you can try:
  • I know you had a successful build, but I don't know when. So try building the sample "Hello Cordova". If it doesn't build, we might have an issue on our end.
  • If it doesn't build, tell us. If it does:
    • I also don't know which version of CLI you are using nor which plugins (those show in the build summary, not the build log)
    • The error says there is a conflict with files. So, if you are using CLI 5.1.1, try switching to 5.4.1.
    • If you still get the same build error with 5.4.1, remove your plugins, one at a time, to see which one causes the conflict
Pamela
Christopher_G_1
Thank you Pam. I will try that. I am using plugins for vibration, facebook, twitter. I am using a Unity ads plugin for reward ads and admob with mediation for Chartboost, AdColony, and MillenialMedia. I should have mentioned that my build works when I use the same files for an iOS build. Will let you know my results. (Also, I am using CLI 5.4.1) Again, thank you.
