Software Archive
Read-only legacy content
17060 Discussions
Android Build error in version 3491
Michael_O_2
Dear Intel Engineers,
I have a published app that I recently updated, but I can't create a new build with XDK 3491.
Please see the attached log.
PaulF_IntelCorp
I think this is an issue with one of your plugins, most likely the analytics, in-app-billing, or push plugins. I would remove one plugin and rebuild to see if it fixes the build problem. Keep doing this until you find the plugin that's causing the problem. From there you can focus on that plugin.
Also, try all three CLI build versions to see if there are any differences in build results.
Michael_O_2
I was able to build the app when I removed the analytics plugin.
