Software Archive
Read-only legacy content
17060 Discussions
How can i use R200 set 3DScan without texture ?
kkeye
I don't wanna scan model with texture, what can i do ?
samontab
Valued Contributor II
Just don't scan it then...
If you mean that you want to scan a model that does not have texture, then that's why the R200 has an IR projector. It puts IR dots in the object, even if it is a white wall, the points will appear in different locations on each IR camera, so it will be able to get depth through stereo.
kkeye
hi samontab! thanks for u help. maybe i didn't say it clearly. i wanna scaning process with out texture like below image (green area)
jb455
Could you create the model with texture mode on, then replace the texture file with a solid colour?
Or maybe load up the obj file and replace all the colours in it with the same number (or an average of the R, G and B values of each vertex so you get some shading)? Look at how the sample converts the model into Javascript data for the HTML viewer for ideas of how you might go about doing this.
