Software Archive
Read-only legacy content
17060 Discussions
Appodeal on Intel XDK
Javier_del_A_
Can somebody help me?
I'm having a lot of problems for the integration of Appodeal (ads) through Construct2 and then compile it into Intel XDK. I not know what I'm doing wrong, but I'm going crazy: S.
When I fix an error another and so on.
Now I've gotten intel compilrlo XDK allows me all successfully. But a new problem is missing.
When I get the XDK Intel apk and open it on my mobile device, in two seconds crashes and an error that says: The app has stopped. Automatically closes.
Here is a little guide with the steps that follow.
Someone who is working with Appodeal in Construct2 please help me?
If I continue like this I'll lose my head.
499036
PaulF_IntelCorp
Javier -- in your second step image there is a note about plugins being included in your intelxdk.config.additions.xml file. Did you remove the references in that file? This must be done, in addition to adding the plugins via the plugin manager. Leaving the plugin references in the intelxdk.config.additions.xml file will cause problems.
I'm confused by your step 3 -- which change cause the build failure? Changing the target API level to 23 or changing the CW version to 16?
Have you tried using CLI 5.1.1 instead of CLI 5.4.1?
PaulF_IntelCorp
Tobiasz -- thank you very much for those two posts! I'll add links to them to our FAQs.
