Software Archive
Read-only legacy content
17060 Discussions
Appropriate meshing for RealSense data
Thomas_5207
I was using the RealSense SDK for meshing and thought the results were good. For technical reasons I have had to switch to librealsense and wish to implement a similar type of meshing. Does anyone know which type of meshing the SDK uses? I was trying poisson meshing before but the SDK does not produce a watertight mesh so I suspect it does not use this type.
Eli_E_
There's many suitable open-source implementations to look at. One of the most accessible projects is InfiniTAM: https://github.com/victorprad/InfiniTAM
There's a pull request on the project that brings librealsense compatibility: https://github.com/victorprad/InfiniTAM/pull/39
Here's a few others
https://github.com/qianyizh/ElasticReconstruction
https://github.com/mp3guy/ElasticFusion
https://github.com/mp3guy/Kintinuous
https://github.com/personalrobotics/OpenChisel - need pose estimation for this
https://github.com/tum-vision/fastfusion - again requires pose estimation
samontab
Valued Contributor II
VTK and PCL provide different meshing algorithms
