Software Archive
Read-only legacy content
17060 Discussions
XDK won't open for me
Matthew_M_3
Hi, have just downloaded latest version of XDK. Have a shortcut in my taskbar etc but when I double-click it does nothing - the progress spinwheel goes round a few times and then nothing.
Am working on a Toshiba laptop, 64-bit, running Windows 7. Have downloaded and used Androind SDK before (albeit very slowly), so not sure that it's anything about the hardware or OS.
Any simply-explained help appreciated!
Elroy_A_Intel
Are you able to launch Intel XDK via your programs listing instead of the taskbar?
Matthew_M_3
No, it won't work that way either.
PaulF_IntelCorp
Did you install the XDK into a custom location or did you allow it to install in the default location? Can you attach a copy of the xdk.log file that is generated each time you attempt to start the XDK? On Windows machines it is normally located here >  %LocalAppData%\XDK which you can get to on the command line by typing "cd %LocalAppData%\XDK" or by entering it into the address bar of the Windows file explorer. See the image below for what I mean:
