Software Archive
Read-only legacy content
17061 Discussions
Are multiple cameras supported yet?
Granger_L_
Débutant
3 272 Visites
I wish to use two cameras simultaneously for a project, but I saw from posts on this forum about a year ago that multiple cameras weren't supported at that time. Is that still the case?
UPDATE: I finally got multicamera streaming working! As mentioned librealsense is the solution. Something to be noted is that I was only able to get it working with Visual Studio 2013 Professional. It didn't not work with Visual Studio 2015 Community Edition for me.
0 Compliments
18 Réponses
Colleen_C_Intel
Employé
3 272 Visites
Simultaneous use of multiple cameras is not supported by the RS SDK - but raw streams can be done.
0 Compliments
Granger_L_
Débutant
3 272 Visites
Hi Colleen,
Thanks for the reply. Would you mind elaborating on that? Does this mean that I could use senseManager->AquireFrame for two cameras at the same time?
Granger
0 Compliments
samontab
Précieux contributeur II
3 272 Visites
I think I read somewhere that you need to have one copy of senseManager per camera.
0 Compliments
mikkel_t_
Débutant
3 272 Visites
I too would like to know more about this, could you elaborate Colleen? :-)
Mikkel
0 Compliments
AndreCarlucci
Débutant
3 272 Visites
Btw, if you have two cameras connected, how the RS SDK decides which one to use?
0 Compliments
samontab
3 272 Visites
There are some methods that you can use to filter out different devices. Actually the SDK can even work with a normal webcam as well.
0 Compliments
samontab
3 273 Visites
Now it is supported (in another library):
https://github.com/IntelRealSense/librealsense
0 Compliments
Thomas_5207
Nouveau contributeur I
3 273 Visites
Hi there, it would be helpful if you could expand on what you mean. I would like to use multiple cameras but only to get the streams and do some basic processing. I do not need to use the SDK to do much else apart from  computing the mapping between colour and depth as well as calculating the projection from depth to world coordinates.
Or is that not possible at all with the SDK and would need to all be managed ourselves from the raw streams as in the library that was posted above?
Many thanks,
Thomas
0 Compliments
samontab
3 273 Visites
The Intel RealSense SDK only supports one camera at a time and Windows. This is the SDK that contains all the computer vision stuff, face detection, tracking, etc.
The librealsense library supports multiple cameras and OSs, but only provides raw access to the camera. There are no computer vision algorithms provided here.
0 Compliments
CLi37
Débutant
3 273 Visites
Without SDK enabled how can I convert raw data from depth camera to distance?
0 Compliments
samontab
3 273 Visites
Well, one of the formats for depth is in mm. Just ask the camera for it very nicely, and it will respond.
You don't need to use the SDK, just use the library.
0 Compliments
Granger_L_
Débutant
3 273 Visites
So is it possible for me to write a program that creates two sensemanagers -- one for one camera, another for a second camera, then grab raw stream data from both cameras?
0 Compliments
samontab
3 273 Visites
Granger, for multiple camera support you should use librealsense instead of the RealSense SDK. It has a different interface.
0 Compliments
Granger_L_
Débutant
3 273 Visites
Thank samontab, I'll check that out. Have you used this library before?
0 Compliments
Granger_L_
Débutant
3 273 Visites
This is something I am wondering as well.
0 Compliments
Colleen_C_Intel
Employé
3 273 Visites
Please see the code provided by the librealsense project:
https://github.com/IntelRealSense/librealsense/blob/master/examples/cpp-multicam.cpp
0 Compliments
samontab
3 273 Visites
Granger L. wrote:
Yeah, I've tested it and it works perfectly fine for my needs, which are just raw capture from the cameras from multiple OSs.
0 Compliments
mikkel_t_
Débutant
3 273 Visites
Thanks @ samontab!
Great info! :-)
Just for reference, these are the possibilities of the librealsense:
  1. Native streams: depth, color, infrared
  2. Synthetic streams: rectified images, depth aligned to color and vice versa, etc.
  3. Intrinsic/extrinsic calibration information
  4. Majority of hardware-specific functionality for individual camera generations (UVC XU controls)
  5. Multi-camera capture across heterogeneous camera architectures (e.g. mix R200 and F200 in same application)
(Copy/paste from the librealsense readme)
These should be more than sufficient to calculate all 3D point clouds etc.
0 Compliments
Répondre
