Software Archive
Read-only legacy content
17060 Discussions
Arithmetic operations with KNC intrinsics
Pritchard__Ben
I'm working on some simple examples of using the Xeon Phi with intrinsics. Is something like the following supported? Or am I missing something really obvious?
#include "immintrin.h"
int main(int argc, char ** argv)
    double arr[8] = {1.0, 2.0, 3.0, 4.0, 5.0, 6.0, 7.0, 8.0};
    __m512d d1 = _mm512_load_pd(arr);
    __m512d d2 = _mm512_load_pd(arr);
    __m512d d3 = d1 * d2;
    return 0;
I get the following error with Intel 16.0.2 (and earlier versions):
[user@host mictest]$ icc -mmic -Wall test.c
test.c(9): error: operation not supported for these simd operands
compilation aborted for test.c (code 2)
jimdempseyatthecove
__m512d d3 = _mm512_mul_pd(d1, d2);
Look for the Intrinsics guide
Jim Dempsey
Pritchard__Ben
Jim Dempsey
Ah maybe I should have been more specific. Yes, I was aware of the various intrinsics. However, I'm porting code that uses AVX __m256d intrinsics with the usual math operators, which works. It would be nice to just have to change the types and leave the rest of the math as is (since it would require lots of messy nested function calls, and the code is quite extensive).
CFR
New Contributor II
I vaguely remember from the Intel compiler Beta webinar May 2015 that the use of arithmetic operators (and the class libraries) were not consistent/supported across all the data types.  At that time I believe on 128 and 256 bit types were supported for arithmetic ops.  Class libraries for 64 (ivec) and 128 (dvec) were supported, but I didn't get an answer as to when 256 (qvec) and 512 (not just micvec) would be updated.  This applied to the 2016 Beta and at least the first release of the 2016 tools, so I'm not sure if the latest and greatest updates has fixed things.
