Software Archive
Read-only legacy content
17060 Discussions
Array Notation : passing array to function
sheliak
Dear all,
recently I started to use the Array Notation in the new compiler 12.1.0, which is amazing, and I am glad to finally have (dynamic) multi-dimensional array support in C++ too :).
Unfortunately documentationis still a bit rare, so I am confused about following code (here an example)
#include
#include
typedef std::complex cmplxd;
typedef cmplxd(*A2c)[];
int Nx, Ny, NxLlD, NyLlD;
void goCilk(cmplxd A[NxLlD,Nx][NyLlD,Ny])
for(int x = NxLlD; x <= NxLlD+Nx-1; x++) { for(int y = NyLlD; y <= NyLlD+Ny-1; y++) {
std::cout << x << " " << y << " " << A << std::endl;
int main()
NxLlD = 1; Nx = 4;
NyLlD = 1; Ny = 3;
cmplxd *A = new cmplxd[Nx*Ny];
for(int x = 0; x < Nx*Ny; x++) A = 1.;
A[0]=2.;
goCilk((A2c) A);
The code compiles and runs without error. Now concerning the "cmplxd goCilk(cmplxd A[NxLlD,Nx][NyLlD,Ny])" functions, I tought that A[NxLlD, Nx] defines the starting value, and the length of this dimension. Similar like fortran has with A(NxLlD:NxLlD+Nx-1), but it seems that even tough the code compiles, the NxLlD value has no meaning as I checked with using some random numbers for NxLlD/NyLlD.
Could you please point me to the documentation, where I can find out the correct syntax ?
And is it actually possible todefine an offset to an array (only in notation like in Fortran), e.g. right now A[0][0] points to the first value, but I would like thatA[NxLlD][NyLlD] to point to the lowest value (it makes life far more simpler for MPI (domain decomposition) programs).
Thanks a lot and best wishes,
Paul
Balaji_I_Intel
Hello Paul,
I am not sure if you are aware but this website has the entire Cilk Plus language specification: http://software.intel.com/en-us/articles/intel-cilk-plus-specification/
The Array-triplets are representedusing the following sytax
Array [ ]
For example, Array[0:5:2] implies we are going to touch A[0], A[2], A[4], A[6], A[8]
I hope this helps!
Balaji V. Iyer.
sheliak
Dear Balaji,
thanks a lot for your quick reply. Yes, I know about the specifictation, I looked through it and couldn't find
anything related. So what confused me,is that
WORKS : void goCilk(cmplxd A[NxLlD,Nx][NyLlD,Ny]) (<--- note the comma NxLLD, Nx
behaviour is not documented, and seems not be a valid feature, yet the compiler accepts it without warning.
Is this a bug or am I missing somehting ?
sheliak
also, it has a pretty different behavirout compared to Fortran,
Assuming I pass an array in Fortran, I define the index position of this array. E.g.
subroutine (A)
double precison :: A(Start_X:End_X, Start_Y:End_Y)
in the function deklaration. While cilk plus seems to always assume that my index starts from A[0].
Is there a way to tell cilk where to start counting ?
E.g.
double (int Start_X, int Length_X, A[Start_X, Length_X])
calling Start_X=5, and Length_X=10, then A[5] refers to the zeroth element (A'[0] in the previous view).
In Fortran it is pretty easy, in Cilk I hope this feature exists, or may be included ?
