Software Archive
Read-only legacy content
Asset Submission not working for IOS
Nick_F_2
New Contributor III
I'm having build issues with IOS but the following issue is a real pain. I'm using version 1826
I have set up the assets such as icons and splash screens and they are uploaded fine.
If I change tabs then go back to the assets and check them they have changed to a previous version of the asset.
In the example movie attached you will see I select a new icon. The original icon you will see has shaded with shadow the new icon is flat. In the example I change the 60x60 and 120x120 icons to the new version but they revert to the old.
I have attached a movie of the process.
Swati_S_Intel1
Hello Nick,
From the video you sent I could figure that you are using Legacy iOS build. Legacy build is going to be deprecated soon. So, please use Cordova iOS build (top row in build page). For that you have to set up your project details and assets on Projects page under Build Settings and Launch Icons and Splash Screen. Make sure to select iOS tab in that.
I also saw your other post where you were having issues with iOS build. It could be the same reason. Please try Cordova build for that project as well.
Swati
Nick_F_2
New Contributor III
Hi Swati
Will this apply to non Cordova content builds mine is just plain HTML5.
Nick
Swati_S_Intel1
The Cordova build uses Cordova build container to build for specific platforms like iOS, Android etc. It has no bearing on whether your app uses any Cordova Plugins or not. Cordova Build is going to be the de facto for XDK going forward. So, I encourage you to use that.
Swati
