Software Archive
Read-only legacy content
17060 Discussions
Assets
Michelle_A_
 I keep getting this error ,  ( Verify your build assets are correct and try again ) this is really bugging me, PLEASE HELP.
Cheers
Michelle
John_H_Intel2
What kind of build are you attempting?
Did you setup the info required info in the Project Settings tab?
Elroy_A_Intel
Can you share a copy of your Build Log?
Nathan_D_
Hi Im having the same problem. I exported my app from construct 2. It contains Admob plugin.
I get this error when I try build
The build failed.
An error occurred while building the application. Verify your build assets are correct and try again.
Build Log:
  • The App ID is "com.runosaurus.dino"
  • The App Name is "Runosaur"
  • Crosswalk Version: 14.43.343.24
  • Plugin "com.cranberrygame.phonegap.plugin.ad.admob" (1.0.39) installed.
  • Plugin "com.google.playservices" (19.0.0) installed.
  • Plugin "org.apache.cordova.inappbrowser" (0.6.0) installed.
PaulF_IntelCorp
Switch to CLI 5.1.1 and try again.
