i installed version 15.4.3 von windows vista 32-bit on my 945GM, and it causes screen flickers.
i even deinstalled it and installed the previous version (15.4) which worked just fine before. but it still flickers, seems like the 15.4.3 destroyed something, i hope its not the card!
how can intel release that driver and MS give a WHQL certificate? thats a shame.
i have a dell inspiron 640m laptop.
- « Previous
- 1
- 2
- Next »
15.4.3 is the latest for 945GM.
I personally download the .zip version, extract it, then run setup.exe from the extracted directory, but that's because I hack the .INF file. For a normal user, downloading the .exe version and running it should be fine.
my idee would be, download exe files unzip the exe with winrar, and install the drivers by using the device manager...
play with it, try drivers... reinstall, deinstall.. just play around and you'll find your own best solution :)
btw: what is the gma950 tool good for? I get this little blue icon on the system tray that takes over the display properties. Do I need that for anything, I prefer the standard windows display properties.
New driver up that resolves the issue, 15.4.4.
2448724 |
Blank HDMI if plugged in during resume (S3 -> S0) transition. |
SoftBIOS |
Intel 945GM Express Chipset |
Any idea what "SoftBIOS" refers to? Does the driver also update the firmware/bios of the 945GM?
I don't know which solution is better, but I had the same problem as what you describe here, and know my problem is solved:
Follow this instruction:
- Click on the Start button (pearl? ball? orb?).
- Type "Task Scheduler" and hit Enter.
- On the left-hand side, click "Task Scheduler Local" (you should already be there, but just in case).
- Expand "Task Scheduler Library," then "Microsoft," then "Windows," then click "MobilePC."
- Up top, you'll see a task called "TMM." Click it, and on the right-hand side, click "Disable."
- You're done.
Source:
http://forum.notebookreview.com/showthread.php?t=153286
![](/skins/images/B7BA37F9CE4B52FF7CAE1FB0388839C8/responsive_peak/images/icon_anonymous_message.png)
- « Previous
- 1
- 2
- Next »
