Software Archive
Read-only legacy content
17061 Discussions
Audio No Work for me, No Sound
jaime_m_
Hi, I'm begginers, so
i just add plugin intel xdk player in my project xdk + cordoba but no work what is wrong ? thx
this is my code
<!DOCTYPE html>
<html>
    <head>
        <link rel="stylesheet" type="text/css" href="app_framework/3.0/af.ui.css" data-ver="2">
        <link rel="stylesheet" type="text/css" href="app_framework/3.0/icons.min.css">
        <meta charset="UTF-8">
        <title>Blank App Designer Cordova Web App Project Template</title>
        <meta http-equiv="Content-type" content="text/html; charset=utf-8">
        <!-- <meta name="viewport" content="width=device-width, minimum-scale=1, initial-scale=1"> -->
        <meta name="viewport" content="width=device-width, minimum-scale=1, initial-scale=1, user-scalable=no">
        <!-- <meta name="viewport" content="width=device-width, initial-scale=1, user-scalable=yes, minimum-scale=1, maximum-scale=2"> -->
        <style>
            @-ms-viewport { width: 100vw ; min-zoom: 100% ; zoom: 100% ; }          @viewport { width: 100vw ; min-zoom: 100% zoom: 100% ; }
            @-ms-viewport { user-zoom: fixed ; min-zoom: 100% ; }                   @viewport { user-zoom: fixed ; min-zoom: 100% ; }
            /*@-ms-viewport { user-zoom: zoom ; min-zoom: 100% ; max-zoom: 200% ; }   @viewport { user-zoom: zoom ; min-zoom: 100% ; max-zoom: 200% ; }*/
        </style>
        <link rel="stylesheet" href="css/app.css">
        <link rel="stylesheet" type="text/css" href="css/index_main.less.css" class="main-less">
        <script src="cordova.js" id="xdkJScordova_">
        </script>
        <script src="js/app.js"></script>
        <!-- for your event code, see README and file comments for details -->
        <script src="js/init-app.js"></script>
        <!-- for your init code, see README and file comments for details -->
        <script src="xdk/init-dev.js"></script>
        <!-- normalizes device and document ready events, see file for details -->
        <script>
             function playSound()
            //Parameters:
            //1. File path relative to the WWW directory
            //2. Loop or not.
              intel.xdk.player.playPodcast("http://labs.qnimate.com/sound.mp3");
        document.addEventListener("intel.xdk.player.audio.start", function(){
            //started playing audio in background
        }, false);
        document.addEventListener("intel.xdk.player.audio.stop", function(){
            //Playing audio finished. Its also fired when intel.xdk.player.stopAudio() is called.
        }, false);
        document.addEventListener("intel.xdk.player.audio.busy", function(){
            //intel.xdk.player.startAudio is already playing an another audio file
        }, false);
        document.addEventListener("intel.xdk.player.audio.error", function(){
            //an error occured so audio cannot be played
        }, false);
        </script>
        <script type="application/javascript">
            $.afui.autoLaunch = false; //By default, it is set to true and you're app will run right away.  We set it to false to show a splashscreen
            /* This function runs when the content is loaded.*/
            $.afui.useOSThemes=false;
             $(document).ready(function(){
                setTimeout(function(){
                    $.afui.launch();
                },1500);
        </script>
            You may substitute jQuery for the App Framework selector library.
            See http://app-framework-software.intel.com/documentation.php#afui/afui_jquery
        <script type="application/javascript" src="lib/jquery.min.js"></script>
        <script type="application/javascript" src="app_framework/3.0/appframework.ui.min.js"></script>
    </head>
    <body id="afui" class="v2">
        <div class="upage vertical-col left view" id="mainpage" data-header="none" data-footer="none">
            <div class="pages">
                <div class="upage-content vertical-col left panel ac0" id="uib_page_1">
                    <div class="grid grid-pad urow uib_row_1 row-height-1" data-uib="layout/row" data-ver="0">
                        <div class="col uib_col_1 col-0_12-12" data-uib="layout/col" data-ver="0">
                            <div class="widget-container content-area vertical-col">
                                <a class="button widget uib_w_1 d-margins" data-uib="app_framework/button" data-ver="2" onclick="playMusic();">Button</a><span class="uib_shim"></span>
                            </div>
                        </div>
                    </div>
                </div>
            </div>
        </div>
    </body>
</html>
