Software Archive
Read-only legacy content
17060 Discussions
Audio Not Playing in the App but playing in the Emulator
Joseph_R_2
I am facing the issue of the audio not being played from the installed App in the Mobile.
I am able to play the audio in the XDK Emulator but not in the Mobile.
The Error in the App Mobile App is code : 1 message : undefined
Here is the code
  <script type="text/javascript" charset="utf-8" src="cordova.js"></script>
        <script type="text/javascript" charset="utf-8">
        document.addEventListener("deviceready", onDeviceReady, false);
        var my_media = null;
        function playAudio(src) {
            my_media = new Media(src, onSuccess, onError);
            my_media.play();
        function onSuccess() {
            console.log("playAudio():Audio Success");
        function onError(error) {
            alert('code: '    + error.code    + '\n' +
                  'message: ' + error.message + '\n');
        </script>
      </head>
      <body>
          <h3>Luger</h3>
     <button onclick="playAudio('www/Shot.ogg');"> <img src="Luger.jpg" width="500" height="200"> </button
I used both Wav and Ogg, both are playing fine in the Emulator not in the Installed App
Please Help if possible, Thanks in Advance
Amrita_C_Intel
Which plugin are you using?
Emulator is just a simulator. There are some limitations just check out this link: https://software.intel.com/en-us/xdk/docs/dev-emulator
Try to build with crosswalk and use either build or debug tab to see the actual behavior of the app.
Amrita_C_Intel
First of all you can take look of one of our sample to understand how it works.
Here is the link: https://github.com/gomobile/sample-audio-player
.wav and .ogg files are the only ones compatible with the emulator. However, you can use .mp3 files without issues except that you should test on a built app or app preview.
Joseph_R_2
Hi Amrita,
Thanks for your Example, but I think I figured out the problem here.
The issue is happening if the Sound File is present Locally in the www folder, If I give a Sound File URL to be played instead, it is getting played flawlessly in the App .
In your given example, the Cordova API Function has an URL for its playback, so its getting played both in the Emulator and the App.
I think the issue is with the Asset Compression in Android and the MP3 did not get compressed correctly.
I am adding the changed code
  <body>
          <h3>Luger</h3>
     <button onclick="playAudio('http://www.wolfensteingoodies.com/archives/olddoom/sounds/dspistol.wav');"> <img src="Luger.jpg" width="500" height="200">
Thanks for your time again.
Amrita_C_Intel
Great! I am glad it is working
