Software Archive
Read-only legacy content
17060 Discussions
iOS build failes for new app
BerndB
480749
Hi Intel team,
my build for a new iOS App failed, while for other (old) apps it works fine for iOS. Build fo new app for Android works fine too..
The error from the log file:
shell.js: internal error
Error: EINVAL, invalid argument '.../voktra/platforms/ios/voktra.xcodeproj'
    at Object.fs.renameSync (fs.js:543:18)
    at /Developer/cordova/5.1.1/node_modules/cordova/node_modules/cordova-lib/node_modules/shelljs/src/mv.js:77:8
    at Array.forEach (native)
    at Object._mv (/Developer/cordova/5.1.1/node_modules/cordova/node_modules/cordova-lib/node_modules/shelljs/src/mv.js:53:11)
    at Object.mv (/Developer/cordova/5.1.1/node_modules/cordova/node_modules/cordova-lib/node_modules/shelljs/src/common.js:186:23)
    at pbxProject.<anonymous> (/Developer/cordova/5.1.1/node_modules/cordova/node_modules/cordova-lib/src/cordova/metadata/ios_parser.js:198:23)
    at pbxProject.EventEmitter.emit (events.js:98:17)
    at pbxProject.<anonymous> (/Developer/cordova/5.1.1/node_modules/cordova/node_modules/cordova-lib/node_modules/xcode/lib/pbxProject.js:30:18)
    at ChildProcess.EventEmitter.emit (events.js:98:17)
    at handleMessage (child_process.js:322:10)
Thank you for you support
Cheers Bernd
John_H_Intel2
I remember seeing something similar to this a while back. It appears to be a to be a core Cordova bug. The fix is to not have the same project name and App Name and you should be good.
John_H_Intel2
I see you have a bunch of builds attempted this morning, but only 3 have succeeded. Are you changing anything with the ones that have succeeded?
BerndB
Hi John,
thx for your reply.
The ones that succeeded i've set the "App Name" to lower letters like in the "App ID".
When  i use a different setting in the "App Name" (i.e. all Uppercase or Mixed), the build faills for iOS. On Android i can use whatever "App Name". It looks like to be an old issue of naming/renaming !?
Other apps i did for iOS are not affected ! Sounds crazy to me that only the new App doesn't work.
John_H_Intel2
John_H_Intel2
Its an underlying issue with ios cordova. If you built using the CLI on your own computer, you would have the same issue :(
