Software Archive
Read-only legacy content
Azure Table Storage
Terrence_S_
Does anyone know of any software to help post data to Azure Table Storage from Edison / Arduino? Thanks.
NagaVenkat_K_Intel
Hi Terrence,
As of now there is no support for Windows Azure for Edison. I do see it is currently supported for Galileo boards.
If you think you can use a Galileo board instead, please go through this article http://msdn.microsoft.com/en-us/magazine/dn574801.aspx
However I would recommend you to use the IoT Developer Kit https://software.intel.com/en-us/iot/downloads and IoT Cloud-based Analytics system https://software.intel.com/en-us/intel-iot-developer-kit-cloud-based-analytics-user-guide.
Raghu Kona
Ivan_K_2
If you want to post data to Table Storage using Galileo and C++ in Windows, you can use Windows Azure Storage libraries for C++ (https://github.com/Azure/azure-storage-cpp) . It's still in CTP stage (version 0.4.0) and if you use it with Galileo you will come across some problems. But, with some small modifications, it works OK. I describe it hot to do that in my blog http://kardum.net/iot/intel-galileo-windows-application-azure-storage/
If you try my approach and find any problems or have any questions, please let me know.
Ivan
Vinoth_R_
you can go through this blog to access azure storage services from Galileo on windows for IoT.
http://vinoth-vinothblog.blogspot.in/2015/02/windows-iot-on-galileo-sensors-to-server.html
Vinoth
Vidyasagar_MSC
Innovator
MSDN blog by Laurelle is an awesome collection of posts which will guide and help you connect your IoT device or software to cloud (Azure)
http://blogs.msdn.com/b/laurelle/ ;
Vidyasagar_MSC
Innovator
