Software Archive
Read-only legacy content
17061 Discussions
BUG - Data Service how to - update display of parameters
Geoff_at_CFM
When editing the parameters in the JSON file, I have found that I need to close the XDK and re-open it in order to get the display of the parameters to update in the services testing window - the one with "Try it" and "Debug it" buttons on it.
Is there a better way to update this window?
Also, If I create/use a data service in an app, then create a new app - the data service still appears in the new app, even though it ain't there!
I have to exit XDK and restart it.
PaulF_IntelCorp
Your first item is a known issue and there is no better workaround than exiting and restarting the XDK. :(
The second item you describe is not a known issue. I'll be filing a bug against it.
