Software Archive
Read-only legacy content
17060 Discussions
Bad image resize with Android using crosswalk Runtime 19 Embedded
mattias_c_
I'm using the accepted answer from this stackoverflow question http://stackoverflow.com/questions/19262141/resize-image-with-javascript-canvas-smoothly.
It works perfectly everywhere i try it. Except for Android crosswalk when images are resized from large images to canvas(3000+ pixel image down to 500 pixel canvas). When building with crosswalk the edges get jaggy and looks bad. I know this might be hard to get around but I fgured maybe somebody had any input on why the downscaling when using crosswalk is worse then when not using crosswalk. If so, is there anything I can change to downscale better?
(It works good in Android when not using crosswalk, incase i was unclear)
Any help or input is highly appreciated, thanks!
EDIT: Just noticed that big images looks bad in crosswalk overall(not that i try to use this big images, just want to scale them down, but the problem might be related).
Steps to reproduce,
1. get a big image, like 4000x4000 pixels for instance.
2. Set as image src to an image tag
3. Compare crosswalk with default browser/runtime
PaulF_IntelCorp
You might also try different versions of Crosswalk, that might make a difference.
mattias_c_
Ye, tried them all between version 14-19. I Guess that there's not much i can do or do you have any suggestions? Is it possible to give the crosswalk team feedback somehow or something? kinda stuck, Thanks
PaulF_IntelCorp
You can provide feedback directly to the Crosswalk team. There is a Jira database, but I think you need to request permission to add to it > https://crosswalk-project.org/jira/ <
