Software Archive
Read-only legacy content
17060 Discussions
Best way to handle selection in thousands of options
Diego_Calp
Valued Contributor I
I'm looking for suggestions about how to handle a select of around 1800 driver's names.
My app will have several select dropdown controls populated from tables, only one with such a lot of records. It will be great a control that performs a search based on part of the name.
Looking forward to your comments, thanks a lot.
Diego
Chris_P_Intel
https://css-tricks.com/dynamic-dropdowns/
http://stackoverflow.com/questions/5036277/dealing-with-huge-data-in-select-boxes
You are definitely going to need an "autocomplete" solution. The links above will help get you started. This means you'll probably have to write some server-side code too.
Chris_P_Intel
Diego_Calp
Thank you very much Chris,
Chosen seems a very good option, I didn't know it, I will give it a try.
In the meantime I was looking at Framework7, it has a search bar that works nice with lists. I hope Intel update the F7 version in XDK, besides the list, it has a lot of goodies.
Diego
