Software Archive
Read-only legacy content
Bootstrap
Rudy_F_
Does the Bootstrap 3 option generate a Bootstrap page?  When I try it I do not see any Bootstrap controls or script tags.
I am using XDK version 3240 on a Mac
Rakshith_K_Intel
The Bootstrap script tag and css will be added to code after you drag and drop the first component in the app designer tool.
Switch to 'design' mode and then drag a button, and then switch to 'code' mode, you will see the bootstrap script tags
Rudy_F_
Ah, so it doesn't pull in pure Boottrap3 markup!
ok, thanks
