Software Archive
Read-only legacy content
17060 Discussions
Error Incomplete Crosswalk Project Service
Maina_W_
Hi, i have been working on a project using Intel XDK and it was working fine, even on my phone until the latest build which threw the error on my phone, Error Incomplete Crosswalk Project Service: Please repackage Elimu Asilia, tried a couple of time but the error persist on my phone, it works well on the emulator, the only significant things i did between the successful build and none successful build were:
  1. Tried to remove intel.xdk.cache plugin unsuccessfully
  2. Tried to upgrade from 5.1.1 to 5.4.1 but it refused to build so i reverted back
  3. Made some changes on my code (CSS, JS and HTML
​2943db75-2655-4a9b-b049-6b4205f52f4e.png)
PaulF_IntelCorp
It sounds like your plugins directory is corrupted. Simplest thing to try is to delete the entire plugins directory inside your project (exit the Intel XDK first). When you restart the XDK and open your app you may be presented with a dialog that says your plugins are out of sync, if you get that message, choose the list of plugins that are in the project file. You project should then reinstall the plugins.
The other problem may be that you have plugins specified in your intelxdk.config.additions.xml, which you should remove.
PaulF_IntelCorp
Maina_W_
My problem came up when i update my Cordova CLI version from 5.1.1 to 5.4.1, i updated CLI and Plugins, when i did this, it refused to build the application, which has led me to believe that is due to corrupted plugins as Paul F from intel explains above. So i downgraded back from 5.4.1 to 5.1.1 and forgot to update the plugins and CLI, so it threw the above error, the solution was simple, upgrade again and upgrade both CLI and plugins then downgrade back and update the CLI and Plugins, so that it loads the old plugins which worked before, hope this helps you
ghani_g_
The same here my problem not fixit
Pamela_H_Intel
@Vitali - you are getting the same error message, after upgrading CLI? Have you been able to re-sync your plugins?
@Ghani - what are your symptoms? The same error message? Which CLI are you using? Have you tried syncing your plugins?
ghani_g_
@Pamela H. incomplete crosswalk project. How can I update plugins ? I am using 3240
ghani_g_
although i tried another project the same problem still existed and emulator not running
Pamela_H_Intel
@Ghani - to update your plugins, do as Paul says above . . . close XDK and delete the contents of the plugin folder for a project. Restart XDK, open that project, and add the plugins back in. Also, (as Paul says) check your intelxdk.config.additions.xml file. There may be "extra" plugins in there.
