Software Archive
Read-only legacy content
17060 Discussions
Brackets node process failed to launch Error: spawn ENOENT
Hugo_A_
I have a problem to start Intel XDK. Have reinstalled, deleted user Local folders and installed in other folders. However, the problem persists. Below is the LOG: ============================================== xdk:client (1425549492578): Intel XDK: 1816 xdk:client (1425549492578): Platform: win32-ia32 (6.1.7601) xdk:client (1425549493780): Starting client process initialization xdk:server (1425549495164): Starting server process initialization xdk:server (1425549496781): Http server started on the standard port 58889 xdk:server (1425549497034): Component "core:assert" starting import xdk:server (1425549497035): Component "core:assert" finished initialization xdk:server (1425549497035): Component "core:component-error" starting import xdk:server (1425549497035): Component "core:component-error" finished initialization xdk:server (1425549497035): Component "core:command-line-options" starting import xdk:server (1425549497035): Component "core:command-line-options" finished initialization xdk:server (1425549497035): Component "core:service-error" starting import xdk:server (1425549497036): Component "core:service-error" finished initialization xdk:server (1425549497036): Component "core:buffer" starting import xdk:server (1425549497036): Component "core:buffer" finished initialization xdk:server (1425549497036): Component "core:signaler" starting import xdk:server (1425549497078): Component "core:signaler" finished initialization xdk:server (1425549497078): Component "core:signaler-group" starting import xdk:server (1425549497196): Component "core:signaler-group" finished initialization xdk:server (1425549497196): Component "core:logger" starting import xdk:server (1425549497500): Component "core:logger" finished initialization xdk:server (1425549497500): Component "core:http-request" starting import xdk:server (1425549497506): Component "core:http-request" finished initialization xdk:server (1425549497507): Component "core:database" starting import xdk:server (1425549497509): Component "core:database" finished initialization xdk:server (1425549497509): Component "core:version" starting import xdk:server (1425549497509): Component "core:version" finished initialization xdk:server (1425549497509): Component "core:userfs-name-converter" starting import xdk:server (1425549497512): Component "core:userfs-name-converter" finished initialization xdk:server (1425549497512): Component "core:crash-handler" starting import xdk:server (1425549497515): Component "core:crash-handler" finished initialization xdk:server (1425549497515): Component "core:i18n-support" starting import xdk:server (1425549497515): Component "core:i18n-support" finished initialization xdk:server (1425549497516): Component "core:theme" starting import xdk:server (1425549498160): Component "core:theme" finished initialization xdk:server (1425549498162): Component "server:userfs" starting import xdk:server (1425549498208): Component "server:userfs" calling init() xdk:server (1425549498474): Component "server:userfs" finished initialization xdk:server (1425549498474): Component "server:user-profile" starting import xdk:server (1425549498480): Component "server:user-profile" calling init() xdk:server (1425549498481): Component "server:user-profile" finished initialization xdk:server (1425549498481): Component "server:projectInfo" starting import xdk:server (1425549498501): Component "server:projectInfo" calling init() xdk:server (1425549498502): Component "server:projectInfo" finished initialization xdk:server (1425549498502): Component "server:ui-builder" starting import xdk:server (1425549499226): Component "server:ui-builder" calling init() xdk:server (1425549499228): Component "server:ui-builder" finished initialization xdk:server (1425549499228): Component "server:emulator-notification" starting import xdk:server (1425549499267): Component "server:emulator-notification" calling init() xdk:server (1425549499268): Component "server:emulator-notification" finished initialization xdk:server (1425549499268): Component "server:emulator-webserver" starting import xdk:server (1425549499302): Component "server:emulator-webserver" calling init() xdk:server (1425549499304): Component "server:emulator-webserver" finished initialization xdk:server (1425549499304): Component "server:new-project-creator" starting import xdk:server (1425549499337): Component "server:new-project-creator" calling init() xdk:server (1425549499337): Component "server:new-project-creator" finished initialization xdk:server (1425549499337): Component "server:zip-util" starting import xdk:server (1425549499380): Component "server:zip-util" calling init() xdk:server (1425549499380): Component "server:zip-util" finished initialization xdk:server (1425549499380): Component "server:uuid-server" starting import xdk:server (1425549499387): Component "server:uuid-server" calling init() xdk:server (1425549499387): Component "server:uuid-server" finished initialization xdk:server (1425549499387): Component "server:app-starter" starting import xdk:server (1425549499424): Component "server:app-starter" calling init() xdk:server (1425549499427): Component "server:app-starter" finished initialization xdk:server (1425549499427): Component "server:force-download" starting import xdk:server (1425549499451): Component "server:force-download" calling init() xdk:server (1425549499451): Component "server:force-download" finished initialization xdk:server (1425549499451): Component "server:updater" starting import xdk:server (1425549499485): Component "server:updater" calling init() server:updater (1425549499485): config.base-auto server:updater (1425549499485): url=https://download.xdk.intel.com/xdk/ xdk:server (1425549499486): Component "server:updater" finished initialization xdk:server (1425549499486): Component "server:editor-node" starting import xdk:server (1425549499760): Component "server:editor-node" calling init() xdk:server (1425549499791): Component "server:editor-node" waiting for delayed initialization xdk:server (1425549499792): Component "server:cordova-lib" starting import xdk:server (1425549500389): Component "server:cordova-lib" calling init() xdk:server (1425549501647): Component "server:cordova-lib" finished initialization xdk:server (1425549501647): Component "server:api-explorer" starting import xdk:server (1425549501685): Component "server:api-explorer" calling init() xdk:server (1425549501964): Component "server:api-explorer" finished initialization xdk:server (1425549501965): Component "server:plugin-listener" starting import xdk:server (1425549502003): Component "server:plugin-listener" calling init() xdk:server (1425549502004): Component "server:plugin-listener" finished initialization server:editor-node (1425549502504): Starting Brackets node process "d:\Programas\Intel XDK\bin\node" "d:\xxx\Intel XDK\bin\node-core" server:editor-node (1425549502520): Brackets node process failed to launch Error: spawn ENOENT xdk:server (1425549502520): Unexpected exception while initializing "editor-node" (maybe crash): Failed to spawn Brackets node. xdk:server (1425549502520): Error in common initialization xdk:server (1425549502520): Writing an error to the server data file: [object Object] server:editor-node (1425549502520): Received close from Brackets node stdout. xdk:server (1425549502520): Wrote server data to "c:\Users\xxxx\AppData\Local\XDK\server-data.txt" xdk:client (1425549502614): Server data file has an error description [Log closed from xdk:client] ==============================================
John_H_Intel2
What OS are you running?
Hugo_A_
Windows 7 64 bits
Swati_S_Intel1
We are working on this issue, a fix will be available soon. Meanwhile you can go back to the previous release. https://software.intel.com/en-us/forums/topic/542074
