Software Archive
Read-only legacy content
17061 Discussions
Porting cordova app from Android to Windows8
K12345
Hi ,
I have a cordova app that uses Intel Framework SDK and currently running on Android Platform.
I am trying to port it on Windows8 and facing some issues e.g. I am not able to type into the text input controls.
I see a file "appframeworkod-min.js" in my project and I see in this file there is an attribute:os.android=true;
I am suspecting this as the culprit but not sure regarding this.
I have few questions:
1) Is there anything that I need to change for porting my cordova app(using Intel Framework) from Android to Windows?
2) Do I need different set of app framework files or set some attributes to windows in any of these files ?
Any suggestions would be really appreciated.
Swati_S_Intel1
You do not need to change anything to deploy for another platform. But looks like your app is using android theme. You can disable use of the theme by :
$.ui.useOSThemes = false;
