Software Archive
Read-only legacy content
17060 Discussions
Broken Splash Screen link
Matt_H_1
I changed something and then I noticed that my splash screens were no longer accessible. I cannot change them or remove them to attach new ones. I really don't know what to do here. Has anyone else had this issue?
Ad
New Contributor III
The only way I could solve this problem was by editing the YOURPROJECT.XDK file, located in the root of your project directory, manually.
Important: Before your start, make a backup of this file!
1. Close XDK.
2. Open YOURPROJECT.XDK and delete in this file the branch "splashes_": [ ..... ]
Do this for each build (android, crosswalk etc..)!
3. Save it and start XDK again
Ad
New Contributor III
1. Close XDK.
Hamilton_Tenório_da_
Valued Contributor I
For safe, make a copy before...
Matt_H_1
Thank you very much. It worked perfectly.
Uitlegentekst
Thanks. Had the same problem. Worked for me as well!
Kenyon_B_1
Not working for me. Still showing up broken.
Anyone using Dropbox personal with business on the same computer? It changes the directory from "Dropbox" to "Dropbox (personal)".
I am wondering if the parentheses are causing problems.
John_H_Intel2
Try creating another project not in dropbox and add the splash screens back in. Does it work then?
Adri_v_
Good tip - thanks.
Had the same problem and I found that I could correct the filenames in this file and then restart the XDK.
The images showed up again :-)
