Software Archive
Read-only legacy content
17061 Discusiones
Broken Splash Screen link
Matt_H_1
Principiante
1.093 Vistas
I changed something and then I noticed that my splash screens were no longer accessible. I cannot change them or remove them to attach new ones. I really don't know what to do here. Has anyone else had this issue?
0 kudos
1 Solución
Ad
Nuevo Colaborador III
1.093 Vistas
The only way I could solve this problem was by editing the YOURPROJECT.XDK file, located in the root of your project directory, manually.
Important: Before your start, make a backup of this file!
1. Close XDK.
2. Open YOURPROJECT.XDK and delete in this file the branch "splashes_": [ ..... ]
Do this for each build (android, crosswalk etc..)!
3. Save it and start XDK again
Ver la solución en mensaje original publicado
7 Respuestas
Ad
1.094 Vistas
1. Close XDK.
Hamilton_Tenório_da_
Colaborador Valioso I
1.093 Vistas
For safe, make a copy before...
Matt_H_1
Principiante
1.093 Vistas
Thank you very much. It worked perfectly.
Uitlegentekst
Principiante
1.093 Vistas
Thanks. Had the same problem. Worked for me as well!
Kenyon_B_1
Principiante
1.093 Vistas
Not working for me. Still showing up broken.
Anyone using Dropbox personal with business on the same computer? It changes the directory from "Dropbox" to "Dropbox (personal)".
I am wondering if the parentheses are causing problems.
John_H_Intel2
Empleados
1.093 Vistas
Try creating another project not in dropbox and add the splash screens back in. Does it work then?
Adri_v_
Principiante
1.093 Vistas
Good tip - thanks.
Had the same problem and I found that I could correct the filenames in this file and then restart the XDK.
The images showed up again :-)
Responder
