Software Archive
Read-only legacy content
17060 Discussions
Bug? Cannot open Login windows
Helcio_R__Macedo_Pan
Anyone have the solution to my problem?
We have 4 PCs (1 Fedora KDE/3 Ubuntu), one of this Ubuntu PCs can't open the login window.. if i click on the "Log in" link on the start page, i've got an endless Loading icon
Best Regards.
- Helcio
Amrita_C_Intel
Can you  provide some screen shots?
Just to feedback..
I've tryied to install a new SO (Fedora @ Gnome Environment) and it works fine.. We still using it without other problems.
(Just a symbolic link to oa library who whe need to change when install or update the XDK and it makes appear an error dialog, but it dont crash the system.. i will talk about it in another topic)
Thanks Amrita for the answer and all for read! :D
Rogério_Q_
Unfortunately it is not running the 3088 version in Fedora 23 64-bit, even after modifying the symbolic link ....
Any idea?
Enough to be "ridiculous" an IDE like that only run on ubuntu, thus cutting many who would like to make use of intelXDK.
Yeah.. i've updated my XDK to 3088 and the program has crashed too
Fedora 23 x86_64
xdk:client:[2016-03-31T10:59:49.206Z]: (1459421989207): memlim: 1535115264
xdk:client:[2016-03-31T10:59:49.210Z]: (1459421989210): Setting NW crash dump to: /root/.config/XDK
xdk:client:[2016-03-31T10:59:49.374Z]: (1459421989374): Intel XDK: 3088
xdk:client:[2016-03-31T10:59:49.374Z]: (1459421989374): Platform: linux-x64 (4.4.6-300.fc23.x86_64)
xdk:client:[2016-03-31T10:59:49.374Z]: (1459421989374): System Info:  CPU: 4 X Intel(R) Core(TM) i7-4510U CPU @ 2.00GHz Physical Memory: 8272400384
xdk:client:[2016-03-31T10:59:49.374Z]: (1459421989374): NW: 0.11.7-rc10-dev
xdk:client:[2016-03-31T10:59:49.432Z]: (1459421989432): Created new theme: base
xdk:client:[2016-03-31T10:59:49.432Z]: (1459421989432): Registered new theme: base
xdk:client:[2016-03-31T10:59:49.434Z]: (1459421989434): Current theme is now: base
xdk:client:[2016-03-31T10:59:49.434Z]: (1459421989434): Loading theme from: ../../public/themes/xdk.json
xdk:client:[2016-03-31T10:59:49.434Z]: (1459421989434): Created new theme: base
xdk:client:[2016-03-31T10:59:49.434Z]: (1459421989434): Registered new theme: xdk
xdk:client:[2016-03-31T10:59:49.435Z]: (1459421989435): Current theme is now: xdk
xdk:client:[2016-03-31T10:59:49.579Z]: (1459421989579): Starting client process initialization
xdk:client:[2016-03-31T10:59:49.597Z]: (1459421989597): OS version: "Fedora release 23 (Twenty Three)"
xdk:client:[2016-03-31T10:59:49.610Z]: (1459421989610): NW Cache is up-to-date.
xdk:server:[2016-03-31T10:59:50.046Z]: (1459421990047): memlim: 1535115264
xdk:server:[2016-03-31T10:59:50.049Z]: (1459421990049): Setting NW crash dump to: /root/.config/XDK
xdk:server:[2016-03-31T10:59:50.197Z]: (1459421990197): Starting server process initialization
xdk:server:[2016-03-31T10:59:50.260Z]: (1459421990260): Http server started on the standard port 58889
xdk:server:[2016-03-31T10:59:50.277Z]: (1459421990277): NW Cache is up-to-date.
xdk:server:[2016-03-31T10:59:50.634Z]: (1459421990634): Component "core:assert" starting import
xdk:server:[2016-03-31T10:59:50.634Z]: (1459421990634): Component "core:assert" finished initialization
xdk:server:[2016-03-31T10:59:50.634Z]: (1459421990634): Component "core:component-error" starting import
xdk:server:[2016-03-31T10:59:50.635Z]: (1459421990635): Component "core:component-error" finished initialization
xdk:server:[2016-03-31T10:59:50.635Z]: (1459421990635): Component "core:command-line-options" starting import
xdk:server:[2016-03-31T10:59:50.635Z]: (1459421990635): Component "core:command-line-options" finished initialization
xdk:server:[2016-03-31T10:59:50.635Z]: (1459421990635): Component "core:service-error" starting import
xdk:server:[2016-03-31T10:59:50.635Z]: (1459421990635): Component "core:service-error" finished initialization
xdk:server:[2016-03-31T10:59:50.635Z]: (1459421990635): Component "core:buffer" starting import
xdk:server:[2016-03-31T10:59:50.635Z]: (1459421990635): Component "core:buffer" finished initialization
xdk:server:[2016-03-31T10:59:50.635Z]: (1459421990635): Component "core:signaler" starting import
xdk:server:[2016-03-31T10:59:50.636Z]: (1459421990636): Component "core:signaler" finished initialization
xdk:server:[2016-03-31T10:59:50.636Z]: (1459421990636): Component "core:signaler-group" starting import
xdk:server:[2016-03-31T10:59:50.638Z]: (1459421990638): Component "core:signaler-group" finished initialization
xdk:server:[2016-03-31T10:59:50.638Z]: (1459421990638): Component "core:logger" starting import
xdk:server:[2016-03-31T10:59:50.638Z]: (1459421990638): Component "core:logger" finished initialization
xdk:server:[2016-03-31T10:59:50.638Z]: (1459421990638): Component "core:http-request" starting import
xdk:server:[2016-03-31T10:59:50.639Z]: (1459421990639): Component "core:http-request" finished initialization
xdk:server:[2016-03-31T10:59:50.639Z]: (1459421990639): Component "core:database" starting import
xdk:server:[2016-03-31T10:59:50.640Z]: (1459421990640): Component "core:database" finished initialization
xdk:server:[2016-03-31T10:59:50.640Z]: (1459421990640): Component "core:version" starting import
xdk:server:[2016-03-31T10:59:50.640Z]: (1459421990640): Component "core:version" finished initialization
xdk:server:[2016-03-31T10:59:50.640Z]: (1459421990640): Component "core:userfs-name-converter" starting import
xdk:server:[2016-03-31T10:59:50.640Z]: (1459421990640): Component "core:userfs-name-converter" finished initialization
xdk:server:[2016-03-31T10:59:50.640Z]: (1459421990640): Component "core:crash-handler" starting import
xdk:server:[2016-03-31T10:59:50.641Z]: (1459421990641): Component "core:crash-handler" finished initialization
xdk:server:[2016-03-31T10:59:50.641Z]: (1459421990641): Component "core:i18n-support" starting import
xdk:server:[2016-03-31T10:59:50.641Z]: (1459421990641): Component "core:i18n-support" finished initialization
xdk:server:[2016-03-31T10:59:50.641Z]: (1459421990641): Component "core:theme" starting import
xdk:server:[2016-03-31T10:59:50.685Z]: (1459421990685): Component "core:theme" finished initialization
xdk:server:[2016-03-31T10:59:50.686Z]: (1459421990686): Component "server:userfs" starting import
xdk:server:[2016-03-31T10:59:50.689Z]: (1459421990689): Component "server:userfs" calling init()
xdk:server:[2016-03-31T10:59:50.711Z]: (1459421990711): Component "server:userfs" finished initialization
xdk:server:[2016-03-31T10:59:50.711Z]: (1459421990711): Component "server:user-profile" starting import
xdk:server:[2016-03-31T10:59:50.713Z]: (1459421990713): Component "server:user-profile" calling init()
xdk:server:[2016-03-31T10:59:50.713Z]: (1459421990713): Component "server:user-profile" finished initialization
xdk:server:[2016-03-31T10:59:50.714Z]: (1459421990714): Component "server:ui-builder" starting import
xdk:server:[2016-03-31T10:59:50.754Z]: (1459421990754): Component "server:ui-builder" calling init()
xdk:server:[2016-03-31T10:59:50.756Z]: (1459421990756): Component "server:ui-builder" finished initialization
xdk:server:[2016-03-31T10:59:50.756Z]: (1459421990756): Component "server:emulator-notification" starting import
xdk:server:[2016-03-31T10:59:50.759Z]: (1459421990759): Component "server:emulator-notification" calling init()
xdk:server:[2016-03-31T10:59:50.759Z]: (1459421990759): Component "server:emulator-notification" finished initialization
xdk:server:[2016-03-31T10:59:50.759Z]: (1459421990759): Component "server:emulator-webserver" starting import
xdk:server:[2016-03-31T10:59:50.760Z]: (1459421990760): Component "server:emulator-webserver" calling init()
xdk:server:[2016-03-31T10:59:50.761Z]: (1459421990761): Component "server:emulator-webserver" finished initialization
xdk:server:[2016-03-31T10:59:50.761Z]: (1459421990761): Component "server:zip-util" starting import
xdk:server:[2016-03-31T10:59:50.763Z]: (1459421990763): Component "server:zip-util" calling init()
xdk:server:[2016-03-31T10:59:50.763Z]: (1459421990763): Component "server:zip-util" finished initialization
xdk:server:[2016-03-31T10:59:50.764Z]: (1459421990764): Component "server:uuid-server" starting import
xdk:server:[2016-03-31T10:59:50.765Z]: (1459421990765): Component "server:uuid-server" calling init()
xdk:server:[2016-03-31T10:59:50.766Z]: (1459421990766): Component "server:uuid-server" finished initialization
xdk:server:[2016-03-31T10:59:50.766Z]: (1459421990766): Component "server:force-download" starting import
xdk:server:[2016-03-31T10:59:50.768Z]: (1459421990768): Component "server:force-download" calling init()
xdk:server:[2016-03-31T10:59:50.769Z]: (1459421990769): Component "server:force-download" finished initialization
xdk:server:[2016-03-31T10:59:50.769Z]: (1459421990769): Component "server:updater" starting import
xdk:server:[2016-03-31T10:59:50.781Z]: (1459421990781): Component "server:updater" calling init()
server:updater:[2016-03-31T10:59:50.782Z]: (1459421990782): config.base-auto
server:updater:[2016-03-31T10:59:50.782Z]: (1459421990782): url=auto
xdk:server:[2016-03-31T10:59:50.782Z]: (1459421990782): Component "server:updater" finished initialization
xdk:server:[2016-03-31T10:59:50.782Z]: (1459421990782): Component "server:editor-node" starting import
xdk:server:[2016-03-31T10:59:50.800Z]: (1459421990800): Component "server:editor-node" calling init()
xdk:server:[2016-03-31T10:59:50.800Z]: (1459421990800): Component "server:editor-node" waiting for delayed initialization
xdk:server:[2016-03-31T10:59:50.800Z]: (1459421990800): Component "server:cordova-lib" starting import
xdk:server:[2016-03-31T10:59:51.019Z]: (1459421991019): Component "server:cordova-lib" calling init()
xdk:server:[2016-03-31T10:59:51.115Z]: (1459421991115): Component "server:cordova-lib" finished initialization
xdk:server:[2016-03-31T10:59:51.115Z]: (1459421991115): Component "server:api-explorer" starting import
xdk:server:[2016-03-31T10:59:51.117Z]: (1459421991117): Component "server:api-explorer" calling init()
xdk:server:[2016-03-31T10:59:51.145Z]: (1459421991145): Component "server:api-explorer" finished initialization
xdk:server:[2016-03-31T10:59:51.145Z]: (1459421991145): Component "server:plugin-listener" starting import
xdk:server:[2016-03-31T10:59:51.146Z]: (1459421991146): Component "server:plugin-listener" calling init()
xdk:server:[2016-03-31T10:59:51.146Z]: (1459421991146): Component "server:plugin-listener" finished initialization
xdk:server:[2016-03-31T10:59:51.146Z]: (1459421991146): Component "server:git-runner" starting import
xdk:server:[2016-03-31T10:59:51.147Z]: (1459421991147): Component "server:git-runner" calling init()
xdk:server:[2016-03-31T10:59:51.148Z]: (1459421991148): Component "server:git-runner" finished initialization
server:editor-node:[2016-03-31T10:59:51.149Z]: (1459421991149): Starting Brackets node process /home/hpandelo/Softwares/intel/XDK/bin/xdk-node /home/hpandelo/Softwares/intel/XDK/bin/node-core
server:editor-node:[2016-03-31T10:59:51.222Z]: (1459421991222): Brackets node is running on port 42071
xdk:server:[2016-03-31T10:59:51.223Z]: (1459421991223): Component "server:editor-node" finished delayed initialization
xdk:server:[2016-03-31T10:59:51.224Z]: (1459421991224): Component "server:ui-builder" calling start()
xdk:server:[2016-03-31T10:59:51.227Z]: (1459421991227): Component "server:ui-builder" finished start()
xdk:server:[2016-03-31T10:59:51.227Z]: (1459421991227): Component "server:emulator-webserver" calling start()
xdk:server:[2016-03-31T10:59:51.227Z]: (1459421991227): Component "server:emulator-webserver" finished start()
xdk:server:[2016-03-31T10:59:51.227Z]: (1459421991227): Component "server:editor-node" calling start()
xdk:server:[2016-03-31T10:59:51.227Z]: (1459421991227): Component "server:editor-node" finished start()
xdk:server:[2016-03-31T10:59:51.229Z]: (1459421991229): Intel XDK is initialized now
xdk:server:[2016-03-31T10:59:51.230Z]: (1459421991230): Writing to the server data file
xdk:server:[2016-03-31T10:59:51.232Z]: (1459421991232): Wrote server data to "/root/.config/XDK/server-data.txt"
xdk:client:[2016-03-31T10:59:51.362Z]: (1459421991362): Successfully read server data file
xdk:client:[2016-03-31T10:59:51.541Z]: (1459421991541): Component "core:assert" starting import
xdk:client:[2016-03-31T10:59:51.541Z]: (1459421991541): Component "core:assert" finished initialization
xdk:client:[2016-03-31T10:59:51.541Z]: (1459421991541): Component "core:component-error" starting import
xdk:client:[2016-03-31T10:59:51.541Z]: (1459421991541): Component "core:component-error" finished initialization
xdk:client:[2016-03-31T10:59:51.541Z]: (1459421991541): Component "core:command-line-options" starting import
xdk:client:[2016-03-31T10:59:51.541Z]: (1459421991541): Component "core:command-line-options" finished initialization
xdk:client:[2016-03-31T10:59:51.541Z]: (1459421991541): Component "core:service-error" starting import
xdk:client:[2016-03-31T10:59:51.541Z]: (1459421991541): Component "core:service-error" finished initialization
xdk:client:[2016-03-31T10:59:51.541Z]: (1459421991541): Component "core:buffer" starting import
xdk:client:[2016-03-31T10:59:51.542Z]: (1459421991542): Component "core:buffer" finished initialization
xdk:client:[2016-03-31T10:59:51.542Z]: (1459421991542): Component "core:signaler" starting import
xdk:client:[2016-03-31T10:59:51.542Z]: (1459421991542): Component "core:signaler" finished initialization
xdk:client:[2016-03-31T10:59:51.542Z]: (1459421991542): Component "core:signaler-group" starting import
xdk:client:[2016-03-31T10:59:51.543Z]: (1459421991543): Component "core:signaler-group" finished initialization
xdk:client:[2016-03-31T10:59:51.543Z]: (1459421991543): Component "core:logger" starting import
xdk:client:[2016-03-31T10:59:51.544Z]: (1459421991544): Component "core:logger" finished initialization
xdk:client:[2016-03-31T10:59:51.544Z]: (1459421991544): Component "core:http-request" starting import
xdk:client:[2016-03-31T10:59:51.545Z]: (1459421991545): Component "core:http-request" finished initialization
xdk:client:[2016-03-31T10:59:51.545Z]: (1459421991545): Component "core:version" starting import
xdk:client:[2016-03-31T10:59:51.545Z]: (1459421991545): Component "core:version" finished initialization
xdk:client:[2016-03-31T10:59:51.545Z]: (1459421991545): Component "core:exit-notifier" starting import
xdk:client:[2016-03-31T10:59:51.545Z]: (1459421991545): Component "core:exit-notifier" finished initialization
xdk:client:[2016-03-31T10:59:51.545Z]: (1459421991545): Component "core:userfs-name-converter" starting import
xdk:client:[2016-03-31T10:59:51.545Z]: (1459421991545): Component "core:userfs-name-converter" finished initialization
xdk:client:[2016-03-31T10:59:51.545Z]: (1459421991545): Component "core:crash-handler" starting import
xdk:client:[2016-03-31T10:59:51.546Z]: (1459421991546): Component "core:crash-handler" finished initialization
xdk:client:[2016-03-31T10:59:51.546Z]: (1459421991546): Component "core:analytics" starting import
xdk:client:[2016-03-31T10:59:51.546Z]: (1459421991546): Component "core:analytics" finished initialization
xdk:client:[2016-03-31T10:59:51.546Z]: (1459421991546): Component "core:i18n-support" starting import
xdk:client:[2016-03-31T10:59:51.546Z]: (1459421991546): Component "core:i18n-support" finished initialization
xdk:client:[2016-03-31T10:59:51.546Z]: (1459421991546): Component "core:theme" starting import
xdk:client:[2016-03-31T10:59:51.546Z]: (1459421991546): Component "core:theme" finished initialization
xdk:client:[2016-03-31T10:59:51.553Z]: (1459421991554): Analytics ID: 347a3685-e4bd-469b-a957-c41639b84a61
xdk:client:[2016-03-31T10:59:51.555Z]: (1459421991555): onExit listener 0:
    at Object.exports.onExit (/home/hpandelo/Softwares/intel/XDK/xdk/core-modules/public/exit-notifier.js:17:2339)
    at setupDefaultAnalytics (/home/hpandelo/Softwares/intel/XDK/xdk/core-modules/public/analytics.js:17:1438)
    at /home/hpandelo/Softwares/intel/XDK/xdk/core-modules/public/analytics.js:17:6219
    at /home/hpandelo/Softwares/intel/XDK/xdk/node_modules/q/q.js:1229:26
    at _fulfilled (/home/hpandelo/Softwares/intel/XDK/xdk/node_modules/q/q.js:834:54)
    at self.promiseDispatch.done (/home/hpandelo/Softwares/intel/XDK/xdk/node_modules/q/q.js:863:30)
    at Promise.promise.promiseDispatch (/home/hpandelo/Softwares/intel/XDK/xdk/node_modules/q/q.js:796:13)
    at /home/hpandelo/Softwares/intel/XDK/xdk/node_modules/q/q.js:604:44
    at runSingle (/home/hpandelo/Softwares/intel/XDK/xdk/node_modules/q/q.js:137:13)
xdk:client:[2016-03-31T10:59:51.588Z]: (1459421991588): Component "client:app" starting import
xdk:client:[2016-03-31T10:59:51.589Z]: (1459421991589): Component "client:help-helper" starting import
xdk:client:[2016-03-31T10:59:51.589Z]: (1459421991589): Component "client:nativefs" starting import
xdk:client:[2016-03-31T10:59:51.589Z]: (1459421991589): Component "client:document-manager" starting import
xdk:client:[2016-03-31T10:59:51.589Z]: (1459421991589): Component "client:project-manager" starting import
xdk:client:[2016-03-31T10:59:51.589Z]: (1459421991589): Component "client:aa-controller" starting import
xdk:client:[2016-03-31T10:59:51.589Z]: (1459421991589): Component "client:build-validator" starting import
xdk:client:[2016-03-31T10:59:51.589Z]: (1459421991589): Component "client:projects-renderers" starting import
xdk:client:[2016-03-31T10:59:51.589Z]: (1459421991589): Component "client:projects-renderers-jsapp" starting import
xdk:client:[2016-03-31T10:59:51.589Z]: (1459421991589): Component "client:projects-renderers-webapp" starting import
xdk:client:[2016-03-31T10:59:51.589Z]: (1459421991589): Component "client:projects-renderers-iotapp" starting import
xdk:client:[2016-03-31T10:59:51.589Z]: (1459421991589): Component "client:active-sync" starting import
xdk:client:[2016-03-31T10:59:51.589Z]: (1459421991589): Component "client:apk-installer" starting import
xdk:client:[2016-03-31T10:59:51.589Z]: (1459421991589): Component "client:appcenter-options" starting import
xdk:client:[2016-03-31T10:59:51.589Z]: (1459421991589): Component "client:resource-manager" starting import
xdk:client:[2016-03-31T10:59:51.589Z]: (1459421991589): Component "client:resource-cocos2d" starting import
xdk:client:[2016-03-31T10:59:51.590Z]: (1459421991590): Component "client:resource-cocos2djs" starting import
xdk:client:[2016-03-31T10:59:51.590Z]: (1459421991590): Component "client:resource-phaser" starting import
xdk:client:[2016-03-31T10:59:51.590Z]: (1459421991590): Component "client:resource-pixi" starting import
xdk:client:[2016-03-31T10:59:51.590Z]: (1459421991590): Component "client:resource-easeljs" starting import
xdk:client:[2016-03-31T10:59:51.590Z]: (1459421991590): Component "client:resource-plain" starting import
xdk:client:[2016-03-31T10:59:51.590Z]: (1459421991590): Component "client:resource-render-frame" starting import
xdk:client:[2016-03-31T10:59:51.590Z]: (1459421991590): Component "client:resource-util" starting import
xdk:client:[2016-03-31T10:59:51.590Z]: (1459421991590): Component "client:bower-package-manager" starting import
xdk:client:[2016-03-31T10:59:51.590Z]: (1459421991590): Component "client:services-tab" starting import
xdk:client:[2016-03-31T10:59:51.590Z]: (1459421991590): Component "client:editor" starting import
xdk:client:[2016-03-31T10:59:51.590Z]: (1459421991590): Component "client:live-preview" starting import
xdk:client:[2016-03-31T10:59:51.590Z]: (1459421991590): Component "client:backend-services" starting import
xdk:client:[2016-03-31T10:59:51.590Z]: (1459421991590): Component "client:backend-feeds" starting import
xdk:client:[2016-03-31T10:59:51.590Z]: (1459421991590): Component "client:merged-feed" starting import
xdk:client:[2016-03-31T10:59:51.590Z]: (1459421991590): Component "client:backend-services-ext" starting import
xdk:client:[2016-03-31T10:59:51.591Z]: (1459421991591): Component "client:backend-service-utils" starting import
xdk:client:[2016-03-31T10:59:51.591Z]: (1459421991591): Component "client:cert-manager" starting import
xdk:client:[2016-03-31T10:59:51.591Z]: (1459421991591): Component "client:account-settings" starting import
xdk:client:[2016-03-31T10:59:51.591Z]: (1459421991591): Component "client:ui-builder-client" starting import
xdk:client:[2016-03-31T10:59:51.591Z]: (1459421991591): Component "client:project-meta" starting import
xdk:client:[2016-03-31T10:59:51.591Z]: (1459421991591): Component "client:contenttype-registry" starting import
xdk:client:[2016-03-31T10:59:51.591Z]: (1459421991591): Component "client:editor-registry" starting import
xdk:client:[2016-03-31T10:59:51.591Z]: (1459421991591): Component "client:platform-registry" starting import
xdk:client:[2016-03-31T10:59:51.591Z]: (1459421991591): Component "client:projecttype-registry" starting import
xdk:client:[2016-03-31T10:59:51.591Z]: (1459421991591): Component "client:library-registry" starting import
xdk:client:[2016-03-31T10:59:51.591Z]: (1459421991591): Component "client:cordova-registry" starting import
xdk:client:[2016-03-31T10:59:51.591Z]: (1459421991591): Component "client:service-method" starting import
xdk:client:[2016-03-31T10:59:51.591Z]: (1459421991591): Component "client:settings-db" starting import
xdk:client:[2016-03-31T10:59:51.591Z]: (1459421991591): Component "client:adb" starting import
xdk:client:[2016-03-31T10:59:51.591Z]: (1459421991591): Component "client:iosdb" starting import
xdk:client:[2016-03-31T10:59:51.591Z]: (1459421991591): Component "client:device" starting import
xdk:client:[2016-03-31T10:59:51.591Z]: (1459421991591): Component "client:device-discovery" starting import
xdk:client:[2016-03-31T10:59:51.591Z]: (1459421991591): Component "client:dialog-box" starting import
xdk:client:[2016-03-31T10:59:51.591Z]: (1459421991591): Component "client:test-local-server" starting import
xdk:client:[2016-03-31T10:59:51.591Z]: (1459421991591): Component "client:quick-tour" starting import
xdk:client:[2016-03-31T10:59:51.591Z]: (1459421991591): Component "client:hot-keys" starting import
xdk:client:[2016-03-31T10:59:51.591Z]: (1459421991591): Component "client:persistance" starting import
xdk:client:[2016-03-31T10:59:51.591Z]: (1459421991591): Component "client:tabs" starting import
xdk:client:[2016-03-31T10:59:51.592Z]: (1459421991592): Component "client:hash-utils" starting import
xdk:client:[2016-03-31T10:59:51.592Z]: (1459421991592): Component "client:file-watcher" starting import
xdk:client:[2016-03-31T10:59:51.592Z]: (1459421991592): Component "client:tool-tip" starting import
xdk:client:[2016-03-31T10:59:51.592Z]: (1459421991592): Component "client:cordova" starting import
xdk:client:[2016-03-31T10:59:51.592Z]: (1459421991592): Component "client:settings-ui" starting import
xdk:client:[2016-03-31T10:59:51.592Z]: (1459421991592): Component "client:external-links" starting import
xdk:client:[2016-03-31T10:59:51.592Z]: (1459421991592): Component "client:external-editors-runner" starting import
xdk:client:[2016-03-31T10:59:51.592Z]: (1459421991592): Component "client:project-list-load" starting import
xdk:client:[2016-03-31T10:59:51.592Z]: (1459421991592): Component "client:upload-manager" starting import
xdk:client:[2016-03-31T10:59:51.592Z]: (1459421991592): Component "client:git-manager" starting import
xdk:client:[2016-03-31T10:59:51.592Z]: (1459421991592): Component "client:new-project-creator" starting import
xdk:client:[2016-03-31T10:59:51.621Z]: (1459421991621): Component "client:help-helper" finished initialization
xdk:client:[2016-03-31T10:59:51.622Z]: (1459421991622): Component "client:nativefs" finished initialization
xdk:client:[2016-03-31T10:59:51.636Z]: (1459421991636): Component "client:active-sync" calling init()
xdk:client:[2016-03-31T10:59:51.636Z]: (1459421991636): Component "client:active-sync" finished initialization
xdk:client:[2016-03-31T10:59:51.637Z]: (1459421991637): Component "client:apk-installer" calling init()
xdk:client:[2016-03-31T10:59:51.637Z]: (1459421991637): Component "client:apk-installer" finished initialization
xdk:client:[2016-03-31T10:59:51.648Z]: (1459421991648): Component "client:resource-render-frame" calling init()
xdk:client:[2016-03-31T10:59:51.649Z]: (1459421991649): Component "client:resource-render-frame" waiting for delayed initialization
xdk:client:[2016-03-31T10:59:51.649Z]: (1459421991649): Component "client:resource-util" calling init()
xdk:client:[2016-03-31T10:59:51.649Z]: (1459421991649): Component "client:resource-util" finished initialization
xdk:client:[2016-03-31T10:59:51.652Z]: (1459421991652): Component "client:resource-render-frame" finished delayed initialization
xdk:client:[2016-03-31T10:59:51.658Z]: (1459421991658): Component "client:build-validator" finished initialization
xdk:client:[2016-03-31T10:59:51.665Z]: (1459421991665): Component "client:backend-services" calling init()
xdk:client:[2016-03-31T10:59:51.666Z]: (1459421991666): Component "client:backend-services" finished initialization
xdk:client:[2016-03-31T10:59:51.667Z]: (1459421991667): Component "client:backend-feeds" calling init()
xdk:client:[2016-03-31T10:59:51.667Z]: (1459421991667): Component "client:backend-feeds" finished initialization
xdk:client:[2016-03-31T10:59:51.669Z]: (1459421991669): Component "client:merged-feed" finished initialization
xdk:client:[2016-03-31T10:59:51.670Z]: (1459421991670): Component "client:backend-services-ext" calling init()
xdk:client:[2016-03-31T10:59:51.670Z]: (1459421991670): Component "client:backend-services-ext" finished initialization
xdk:client:[2016-03-31T10:59:51.670Z]: (1459421991670): Component "client:backend-service-utils" finished initialization
xdk:client:[2016-03-31T10:59:51.675Z]: (1459421991675): Component "client:project-meta" calling init()
xdk:client:[2016-03-31T10:59:51.675Z]: (1459421991675): Component "client:project-meta" finished initialization
xdk:client:[2016-03-31T10:59:51.681Z]: (1459421991681): Component "client:service-method" finished initialization
xdk:client:[2016-03-31T10:59:51.683Z]: (1459421991683): Component "client:settings-db" calling init()
xdk:client:[2016-03-31T10:59:51.683Z]: (1459421991683): Component "client:settings-db" waiting for delayed initialization
xdk:client:[2016-03-31T10:59:51.684Z]: (1459421991684): Component "client:adb" calling init()
xdk:client:[2016-03-31T10:59:51.689Z]: (1459421991689): Component "client:adb" waiting for delayed initialization
xdk:client:[2016-03-31T10:59:51.690Z]: (1459421991691): Component "client:iosdb" calling init()
xdk:client:[2016-03-31T10:59:51.691Z]: (1459421991691): Component "client:iosdb" finished initialization
xdk:client:[2016-03-31T10:59:51.701Z]: (1459421991701): Component "client:persistance" calling init()
xdk:client:[2016-03-31T10:59:51.702Z]: (1459421991702): Component "client:persistance" waiting for delayed initialization
xdk:client:[2016-03-31T10:59:51.705Z]: (1459421991705): Component "client:file-watcher" calling init()
xdk:client:[2016-03-31T10:59:51.705Z]: (1459421991705): Component "client:file-watcher" finished initialization
xdk:client:[2016-03-31T10:59:51.708Z]: (1459421991708): Component "client:external-links" finished initialization
xdk:client:[2016-03-31T10:59:51.709Z]: (1459421991709): Component "client:external-editors-runner" calling init()
xdk:client:[2016-03-31T10:59:51.710Z]: (1459421991710): Component "client:external-editors-runner" finished initialization
xdk:client:[2016-03-31T10:59:51.710Z]: (1459421991710): Component "client:project-list-load" calling init()
xdk:client:[2016-03-31T10:59:51.710Z]: (1459421991710): Component "client:project-list-load" waiting for delayed initialization
xdk:client:[2016-03-31T10:59:51.714Z]: (1459421991714): Component "client:upload-manager" calling init()
xdk:client:[2016-03-31T10:59:51.714Z]: (1459421991714): Component "client:upload-manager" finished initialization
xdk:client:[2016-03-31T10:59:51.715Z]: (1459421991715): Component "client:git-manager" calling init()
client:git-manager:[2016-03-31T10:59:51.715Z]: (1459421991715): git path =  /usr/bin/git
xdk:client:[2016-03-31T10:59:51.715Z]: (1459421991715): Component "client:git-manager" waiting for delayed initialization
xdk:client:[2016-03-31T10:59:51.717Z]: (1459421991717): Component "client:new-project-creator" calling init()
xdk:client:[2016-03-31T10:59:51.717Z]: (1459421991717): Component "client:new-project-creator" finished initialization
xdk:client:[2016-03-31T10:59:51.728Z]: (1459421991728): Component "client:hot-keys" calling init()
xdk:client:[2016-03-31T10:59:51.728Z]: (1459421991728): Component "client:hot-keys" finished initialization
xdk:client:[2016-03-31T10:59:51.731Z]: (1459421991731): Component "client:document-manager" calling init()
xdk:client:[2016-03-31T10:59:51.732Z]: (1459421991732): Component "client:document-manager" finished initialization
xdk:client:[2016-03-31T10:59:51.752Z]: (1459421991752): Component "client:aa-controller" calling init()
xdk:client:[2016-03-31T10:59:51.752Z]: (1459421991752): Component "client:aa-controller" finished initialization
xdk:client:[2016-03-31T10:59:51.800Z]: (1459421991800): Component "client:ui-builder-client" calling init()
xdk:client:[2016-03-31T10:59:51.800Z]: (1459421991800): Component "client:ui-builder-client" finished initialization
xdk:client:[2016-03-31T10:59:51.803Z]: (1459421991803): Component "client:dialog-box" finished initialization
xdk:client:[2016-03-31T10:59:51.808Z]: (1459421991808): Component "client:tool-tip" finished initialization
xdk:client:[2016-03-31T10:59:51.810Z]: (1459421991810): Component "client:settings-ui" finished initialization
xdk:client:[2016-03-31T10:59:51.828Z]: (1459421991828): Component "client:resource-manager" calling init()
xdk:client:[2016-03-31T10:59:51.829Z]: (1459421991829): Component "client:resource-manager" waiting for delayed initialization
xdk:client:[2016-03-31T10:59:51.839Z]: (1459421991839): Component "client:resource-cocos2djs" calling init()
xdk:client:[2016-03-31T10:59:51.839Z]: (1459421991839): Component "client:resource-cocos2djs" finished initialization
xdk:client:[2016-03-31T10:59:51.866Z]: (1459421991866): Component "client:appcenter-options" calling init()
xdk:client:[2016-03-31T10:59:51.866Z]: (1459421991866): Component "client:appcenter-options" waiting for delayed initialization
xdk:client:[2016-03-31T10:59:51.868Z]: (1459421991868): Component "client:test-local-server" calling init()
xdk:client:[2016-03-31T10:59:51.893Z]: (1459421991893): Component "client:test-local-server" finished initialization
xdk:client:[2016-03-31T10:59:51.894Z]: (1459421991894): Component "client:tabs" finished initialization
xdk:client:[2016-03-31T10:59:51.972Z]: (1459421991972): Component "client:cert-manager" finished initialization
xdk:client:[2016-03-31T10:59:51.978Z]: (1459421991978): Component "client:app" calling init()
xdk:client:[2016-03-31T10:59:51.993Z]: (1459421991993): Component "client:app" finished initialization
xdk:client:[2016-03-31T10:59:51.998Z]: (1459421991998): Component "client:services-tab" calling init()
xdk:client:[2016-03-31T10:59:51.998Z]: (1459421991998): Component "client:services-tab" finished initialization
xdk:client:[2016-03-31T10:59:52.005Z]: (1459421992005): Component "client:contenttype-registry" calling init()
xdk:client:[2016-03-31T10:59:52.006Z]: (1459421992006): Component "client:contenttype-registry" finished initialization
xdk:client:[2016-03-31T10:59:52.007Z]: (1459421992007): Component "client:editor-registry" finished initialization
xdk:client:[2016-03-31T10:59:52.013Z]: (1459421992013): Component "client:library-registry" calling init()
xdk:client:[2016-03-31T10:59:52.013Z]: (1459421992013): Component "client:library-registry" finished initialization
xdk:client:[2016-03-31T10:59:52.023Z]: (1459421992023): Component "client:device-discovery" calling init()
xdk:client:[2016-03-31T10:59:52.023Z]: (1459421992023): Component "client:device-discovery" waiting for delayed initialization
xdk:client:[2016-03-31T10:59:52.025Z]: (1459421992025): Component "client:hash-utils" finished initialization
xdk:client:[2016-03-31T10:59:52.074Z]: (1459421992074): Component "client:cordova" calling init()
xdk:client:[2016-03-31T10:59:52.075Z]: (1459421992075): Component "client:cordova" waiting for delayed initialization
xdk:client:[2016-03-31T10:59:52.088Z]: (1459421992088): Component "client:project-manager" calling init()
xdk:client:[2016-03-31T10:59:52.088Z]: (1459421992089): Component "client:project-manager" waiting for delayed initialization
xdk:client:[2016-03-31T10:59:52.094Z]: (1459421992095): Component "client:projects-renderers" calling init()
xdk:client:[2016-03-31T10:59:52.095Z]: (1459421992095): Component "client:projects-renderers" waiting for delayed initialization
xdk:client:[2016-03-31T10:59:52.096Z]: (1459421992096): Component "client:projects-renderers-iotapp" calling init()
xdk:client:[2016-03-31T10:59:52.096Z]: (1459421992096): Component "client:projects-renderers-iotapp" finished initialization
xdk:client:[2016-03-31T10:59:52.108Z]: (1459421992108): Component "client:resource-cocos2d" calling init()
xdk:client:[2016-03-31T10:59:52.108Z]: (1459421992108): Component "client:resource-cocos2d" waiting for delayed initialization
xdk:client:[2016-03-31T10:59:52.110Z]: (1459421992110): Component "client:navbar" starting import
xdk:client:[2016-03-31T10:59:52.110Z]: (1459421992110): Component "client:tweets" starting import
xdk:client:[2016-03-31T10:59:52.111Z]: (1459421992111): Component "client:projects-tab" starting import
xdk:client:[2016-03-31T10:59:52.111Z]: (1459421992111): Component "client:test-tab" starting import
xdk:client:[2016-03-31T10:59:52.111Z]: (1459421992111): Component "client:profilingTab" starting import
xdk:client:[2016-03-31T10:59:52.111Z]: (1459421992111): Component "client:emulator" starting import
xdk:client:[2016-03-31T10:59:52.111Z]: (1459421992111): Component "client:remote-tab" starting import
xdk:client:[2016-03-31T10:59:52.111Z]: (1459421992111): Component "client:build-tab" starting import
xdk:client:[2016-03-31T10:59:52.111Z]: (1459421992111): Component "client:build-service" starting import
xdk:client:[2016-03-31T10:59:52.111Z]: (1459421992111): Component "client:bower-client" starting import
xdk:client:[2016-03-31T10:59:52.111Z]: (1459421992111): Component "client:editor-tab" starting import
xdk:client:[2016-03-31T10:59:52.111Z]: (1459421992111): Component "client:account" starting import
xdk:client:[2016-03-31T10:59:52.111Z]: (1459421992111): Component "client:project-selector" starting import
xdk:client:[2016-03-31T10:59:52.111Z]: (1459421992111): Component "client:publish-tab" starting import
xdk:client:[2016-03-31T10:59:52.116Z]: (1459421992116): Component "client:resource-cocos2d" finished delayed initialization
xdk:client:[2016-03-31T10:59:52.124Z]: (1459421992124): Component "client:resource-phaser" calling init()
xdk:client:[2016-03-31T10:59:52.124Z]: (1459421992124): Component "client:resource-phaser" finished initialization
xdk:client:[2016-03-31T10:59:52.127Z]: (1459421992127): Component "client:resource-pixi" calling init()
xdk:client:[2016-03-31T10:59:52.127Z]: (1459421992127): Component "client:resource-pixi" finished initialization
xdk:client:[2016-03-31T10:59:52.128Z]: (1459421992128): Component "client:resource-easeljs" calling init()
xdk:client:[2016-03-31T10:59:52.128Z]: (1459421992128): Component "client:resource-easeljs" finished initialization
xdk:client:[2016-03-31T10:59:52.129Z]: (1459421992129): Component "client:resource-plain" calling init()
xdk:client:[2016-03-31T10:59:52.129Z]: (1459421992129): Component "client:resource-plain" finished initialization
xdk:client:[2016-03-31T10:59:52.134Z]: (1459421992134): Component "client:cordova-registry" calling init()
xdk:client:[2016-03-31T10:59:52.134Z]: (1459421992134): Component "client:cordova-registry" waiting for delayed initialization
xdk:client:[2016-03-31T10:59:52.149Z]: (1459421992149): Component "client:quick-tour" calling init()
xdk:client:[2016-03-31T10:59:52.149Z]: (1459421992149): Component "client:quick-tour" finished initialization
xdk:client:[2016-03-31T10:59:52.159Z]: (1459421992159): Component "client:account-settings" calling init()
xdk:client:[2016-03-31T10:59:52.159Z]: (1459421992159): Component "client:account-settings" finished initialization
xdk:client:[2016-03-31T10:59:52.163Z]: (1459421992163): Component "client:platform-registry" calling init()
xdk:client:[2016-03-31T10:59:52.164Z]: (1459421992164): Component "client:platform-registry" finished initialization
xdk:client:[2016-03-31T10:59:52.166Z]: (1459421992166): Component "client:projecttype-registry" calling init()
xdk:client:[2016-03-31T10:59:52.167Z]: (1459421992167): Component "client:projecttype-registry" finished initialization
xdk:client:[2016-03-31T10:59:52.172Z]: (1459421992172): Component "client:device" calling init()
ios-device:[2016-03-31T10:59:52.218Z]: (1459421992218): Failed to initialize libwi due to  Dynamic Linking Error: libssl.so.1.0.0: cannot open shared object file: Arquivo ou diretório não encontrado
xdk:client:[2016-03-31T10:59:52.218Z]: (1459421992218): Component "client:device" finished initialization
xdk:client:[2016-03-31T10:59:52.224Z]: (1459421992224): Component "client:device-discovery" finished delayed initialization
xdk:client:[2016-03-31T10:59:52.225Z]: (1459421992225): Component "client:settings-db" finished delayed initialization
client:git-manager:[2016-03-31T10:59:52.253Z]: (1459421992253): Custom Git Client Path is /usr/bin/git
client:git-manager:[2016-03-31T10:59:52.253Z]: (1459421992253): Auto-Proxy setting is true
xdk:client:[2016-03-31T10:59:52.284Z]: (1459421992284): Component "client:bower-package-manager" calling init()
xdk:client:[2016-03-31T10:59:52.285Z]: (1459421992285): Component "client:bower-package-manager" waiting for delayed initialization
xdk:client:[2016-03-31T10:59:52.286Z]: (1459421992286): Component "client:bower-package-manager" finished delayed initialization
xdk:client:[2016-03-31T10:59:52.316Z]: (1459421992316): Component "client:projects-renderers-webapp" calling init()
xdk:client:[2016-03-31T10:59:52.317Z]: (1459421992317): Component "client:projects-renderers-webapp" finished initialization
xdk:client:[2016-03-31T10:59:52.325Z]: (1459421992325): Component "client:projects-renderers-jsapp" calling init()
xdk:client:[2016-03-31T10:59:52.326Z]: (1459421992326): Component "client:projects-renderers-jsapp" finished initialization
xdk:client:[2016-03-31T10:59:52.345Z]: (1459421992345): Component "client:build-service" getting UI region for "build"
xdk:client:[2016-03-31T10:59:52.346Z]: (1459421992346): Component "client:build-service" calling init()
xdk:client:[2016-03-31T10:59:52.346Z]: (1459421992346): Component "client:build-service" finished initialization
xdk:client:[2016-03-31T10:59:52.368Z]: (1459421992368): Component "client:projects-renderers" finished delayed initialization
xdk:client:[2016-03-31T10:59:52.373Z]: (1459421992373): Component "client:git-manager" finished delayed initialization
xdk:client:[2016-03-31T10:59:52.395Z]: (1459421992395): Component "client:account" getting UI region for "account"
xdk:client:[2016-03-31T10:59:52.396Z]: (1459421992396): Component "client:account" calling init()
xdk:client:[2016-03-31T10:59:52.402Z]: (1459421992402): Component "client:account" finished initialization
xdk:client:[2016-03-31T10:59:52.404Z]: (1459421992404): Component "client:project-selector" getting UI region for "project-selector"
xdk:client:[2016-03-31T10:59:52.405Z]: (1459421992405): Component "client:project-selector" calling init()
xdk:client:[2016-03-31T10:59:52.405Z]: (1459421992405): Component "client:project-selector" finished initialization
xdk:client:[2016-03-31T10:59:52.422Z]: (1459421992422): Component "client:editor" calling init()
xdk:client:[2016-03-31T10:59:52.422Z]: (1459421992422): Component "client:editor" finished initialization
xdk:client:[2016-03-31T10:59:52.423Z]: (1459421992423): Component "client:live-preview" calling init()
xdk:client:[2016-03-31T10:59:52.423Z]: (1459421992423): Component "client:live-preview" finished initialization
xdk:client:[2016-03-31T10:59:52.423Z]: (1459421992423): Component "client:editor-tab" getting UI region for "develop"
xdk:client:[2016-03-31T10:59:52.423Z]: (1459421992423): Component "client:editor-tab" calling init()
xdk:client:[2016-03-31T10:59:52.436Z]: (1459421992436): Component "client:editor-tab" waiting for delayed initialization
xdk:client:[2016-03-31T10:59:52.442Z]: (1459421992442): Component "client:tweets" finished initialization
xdk:client:[2016-03-31T10:59:52.443Z]: (1459421992443): Component "client:projects-tab" getting UI region for "project"
xdk:client:[2016-03-31T10:59:52.443Z]: (1459421992443): Component "client:projects-tab" calling init()
xdk:client:[2016-03-31T10:59:52.445Z]: (1459421992445): Component "client:projects-tab" waiting for delayed initialization
xdk:client:[2016-03-31T10:59:52.447Z]: (1459421992447): Component "client:test-tab" getting UI region for "test"
xdk:client:[2016-03-31T10:59:52.447Z]: (1459421992447): Component "client:test-tab" calling init()
xdk:client:[2016-03-31T10:59:52.448Z]: (1459421992448): Component "client:test-tab" waiting for delayed initialization
xdk:client:[2016-03-31T10:59:52.465Z]: (1459421992465): Component "client:emulator" getting UI region for "emulate"
xdk:client:[2016-03-31T10:59:52.465Z]: (1459421992465): Component "client:emulator" calling init()
xdk:client:[2016-03-31T10:59:52.469Z]: (1459421992469): Component "client:emulator" finished initialization
xdk:client:[2016-03-31T10:59:52.478Z]: (1459421992478): Component "client:remote-tab" getting UI region for "debug"
xdk:client:[2016-03-31T10:59:52.478Z]: (1459421992478): Component "client:remote-tab" calling init()
xdk:client:[2016-03-31T10:59:52.591Z]: (1459421992591): Component "client:remote-tab" waiting for delayed initialization
xdk:client:[2016-03-31T10:59:52.616Z]: (1459421992616): Component "client:remote-tab" finished delayed initialization
xdk:client:[2016-03-31T10:59:52.619Z]: (1459421992619): Component "client:cordova" finished delayed initialization
xdk:client:[2016-03-31T10:59:52.623Z]: (1459421992623): Component "client:navbar" getting UI region for "navbar-common"
xdk:client:[2016-03-31T10:59:52.623Z]: (1459421992623): Component "client:navbar" calling init()
client:navbar:[2016-03-31T10:59:52.623Z]: (1459421992623): navbar options: {"common":{"servicesVersion":"release-2016-ww11"},"updatePollingInterval":1800,"forceUpdate":false}
xdk:client:[2016-03-31T10:59:52.623Z]: (1459421992623): Component "client:navbar" finished initialization
xdk:client:[2016-03-31T10:59:52.641Z]: (1459421992641): Component "client:build-tab" getting UI region for "build"
xdk:client:[2016-03-31T10:59:52.641Z]: (1459421992641): Component "client:build-tab" calling init()
xdk:client:[2016-03-31T10:59:52.647Z]: (1459421992647): Component "client:build-tab" waiting for delayed initialization
xdk:client:[2016-03-31T10:59:52.654Z]: (1459421992654): Component "client:publish-tab" getting UI region for "publish"
xdk:client:[2016-03-31T10:59:52.654Z]: (1459421992654): Component "client:publish-tab" calling init()
xdk:client:[2016-03-31T10:59:52.662Z]: (1459421992662): Component "client:build-tab" finished delayed initialization
xdk:client:[2016-03-31T10:59:52.663Z]: (1459421992663): Component "client:publish-tab" finished initialization
xdk:client:[2016-03-31T10:59:52.684Z]: (1459421992684): Component "client:bower-client" getting UI region for "deps-manager"
xdk:client:[2016-03-31T10:59:52.684Z]: (1459421992684): Component "client:bower-client" calling init()
xdk:client:[2016-03-31T10:59:52.686Z]: (1459421992686): Component "client:bower-client" finished initialization
xdk:client:[2016-03-31T10:59:52.762Z]: (1459421992762): Component "client:profilingTab" getting UI region for "profile"
xdk:client:[2016-03-31T10:59:52.762Z]: (1459421992762): Component "client:profilingTab" calling init()
xdk:client:[2016-03-31T10:59:52.766Z]: (1459421992766): Component "client:profilingTab" finished initialization
client:appcenter-options:[2016-03-31T10:59:53.618Z]: (1459421993618): Fetch Status: 1, Message: Feched latest appcenter-options info because network is available.
xdk:client:[2016-03-31T10:59:53.619Z]: (1459421993619): Component "client:appcenter-options" finished delayed initialization
xdk:client:[2016-03-31T10:59:53.621Z]: (1459421993621): Component "client:test-tab" finished delayed initialization
xdk:client:[2016-03-31T10:59:53.769Z]: (1459421993769): Component "client:cordova-registry" finished delayed initialization
xdk:client:[2016-03-31T10:59:54.209Z]: (1459421994209): memmrk:	48795056	76273264
client:adb:[2016-03-31T10:59:54.391Z]: (1459421994391): Using existing adb at "/home/hpandelo/Softwares/intel/XDK/bin/adb/adb"
xdk:client:[2016-03-31T10:59:54.399Z]: (1459421994399): Component "client:adb" finished delayed initialization
xdk:client:[2016-03-31T10:59:55.024Z]: (1459421995024): Component "client:persistance" finished delayed initialization
xdk:server:[2016-03-31T10:59:55.049Z]: (1459421995049): memmrk:	39326640	69612936
xdk:client:[2016-03-31T10:59:55.229Z]: (1459421995229): Component "client:project-manager" finished delayed initialization
xdk:client:[2016-03-31T10:59:55.230Z]: (1459421995230): Component "client:project-list-load" finished delayed initialization
xdk:client:[2016-03-31T10:59:55.235Z]: (1459421995235): Component "client:resource-manager" finished delayed initialization
xdk:client:[2016-03-31T10:59:55.235Z]: (1459421995235): Component "client:projects-tab" finished delayed initialization
xdk:client:[2016-03-31T10:59:55.235Z]: (1459421995235): Component "client:projects-list" starting import
xdk:client:[2016-03-31T10:59:55.235Z]: (1459421995235): Component "client:projects-info" starting import
xdk:client:[2016-03-31T10:59:55.236Z]: (1459421995236): Component "client:projects-create-list" starting import
xdk:client:[2016-03-31T10:59:55.236Z]: (1459421995236): Component "client:projects-create-info" starting import
xdk:client:[2016-03-31T10:59:56.055Z]: (1459421996055): Component "client:projects-list" getting UI region for "existing-list"
xdk:client:[2016-03-31T10:59:56.055Z]: (1459421996055): Component "client:projects-list" calling init()
xdk:client:[2016-03-31T10:59:56.057Z]: (1459421996057): Component "client:projects-list" finished initialization
xdk:client:[2016-03-31T10:59:56.059Z]: (1459421996059): Component "client:projects-info" getting UI region for "existing-info"
xdk:client:[2016-03-31T10:59:56.059Z]: (1459421996059): Component "client:projects-info" calling init()
xdk:client:[2016-03-31T10:59:56.059Z]: (1459421996059): Component "client:projects-info" finished initialization
xdk:client:[2016-03-31T10:59:56.066Z]: (1459421996066): Component "client:projects-create-info" getting UI region for "create-info"
xdk:client:[2016-03-31T10:59:56.066Z]: (1459421996066): Component "client:projects-create-info" calling init()
xdk:client:[2016-03-31T10:59:56.066Z]: (1459421996066): Component "client:projects-create-info" finished initialization
xdk:client:[2016-03-31T10:59:56.071Z]: (1459421996071): Component "client:projects-create-list" getting UI region for "create-list"
xdk:client:[2016-03-31T10:59:56.071Z]: (1459421996071): Component "client:projects-create-list" calling init()
xdk:client:[2016-03-31T10:59:56.071Z]: (1459421996071): Component "client:projects-create-list" finished initialization
xdk:client:[2016-03-31T11:00:00.041Z]: (1459422000041): memmrk:	55434648	92493936
xdk:server:[2016-03-31T11:00:00.049Z]: (1459422000049): memmrk:	39505424	69620776
xdk:client:[2016-03-31T11:00:02.169Z]: (1459422002169): onExitRequest listener 1:
    at Object.exports.onExitRequest (/home/hpandelo/Softwares/intel/XDK/xdk/core-modules/public/exit-notifier.js:17:2170)
    at Object.<anonymous> (file:///home/hpandelo/Softwares/intel/XDK/xdk/brackets/b/extensions/default/XDK/main.js:459:21)
    at Object.context.execCb (file:///home/hpandelo/Softwares/intel/XDK/xdk/brackets/b/thirdparty/requirejs/require.js:1658:33)
    at Object.Module.check (file:///home/hpandelo/Softwares/intel/XDK/xdk/brackets/b/thirdparty/requirejs/require.js:869:55)
    at Object.<anonymous> (file:///home/hpandelo/Softwares/intel/XDK/xdk/brackets/b/thirdparty/requirejs/require.js:1121:34)
    at file:///home/hpandelo/Softwares/intel/XDK/xdk/brackets/b/thirdparty/requirejs/require.js:132:23
    at file:///home/hpandelo/Softwares/intel/XDK/xdk/brackets/b/thirdparty/requirejs/require.js:1164:21
    at each (file:///home/hpandelo/Softwares/intel/XDK/xdk/brackets/b/thirdparty/requirejs/require.js:57:31)
    at Object.Module.emit (file:///home/hpandelo/Softwares/intel/XDK/xdk/brackets/b/thirdparty/requirejs/require.js:1163:17)
xdk:client:[2016-03-31T11:00:05.041Z]: (1459422005041): memmrk:	81982296	113429520
xdk:server:[2016-03-31T11:00:05.049Z]: (1459422005049): memmrk:	30233512	70231800
client:services-tab:[2016-03-31T11:00:05.212Z]: (1459422005212): component:services-tab : Container provided by brackets :
client:services-tab:[2016-03-31T11:00:05.212Z]: (1459422005212): component:services-tab : mainContainer_ = XDKMiniServices-main
client:services-tab:[2016-03-31T11:00:05.212Z]: (1459422005212): component:services-tab : sidebarContainer = XDKMiniServices-list
client:services-tab:[2016-03-31T11:00:05.212Z]: (1459422005212): component:services-tab : Iframes inserted by services-tab : .
client:services-tab:[2016-03-31T11:00:05.212Z]: (1459422005212): component:services-tab : $mainContainer_ = mini-api-explorer
client:services-tab:[2016-03-31T11:00:05.212Z]: (1459422005212): component:services-tab : $sidebarContainer_ = api-sidebar
xdk:client:[2016-03-31T11:00:05.291Z]: (1459422005291): Component "client:editor-tab" finished delayed initialization
xdk:client:[2016-03-31T11:00:05.292Z]: (1459422005292): Component "client:app" calling start()
xdk:client:[2016-03-31T11:00:05.306Z]: (1459422005306): Component "client:app" finished start()
xdk:client:[2016-03-31T11:00:05.306Z]: (1459422005306): Component "client:navbar" calling start()
xdk:client:[2016-03-31T11:00:05.321Z]: (1459422005321): Component "client:navbar" finished start()
xdk:client:[2016-03-31T11:00:05.321Z]: (1459422005321): Component "client:project-manager" calling start()
xdk:client:[2016-03-31T11:00:05.321Z]: (1459422005321): Component "client:project-manager" finished start()
xdk:client:[2016-03-31T11:00:05.321Z]: (1459422005321): Component "client:aa-controller" calling start()
xdk:client:[2016-03-31T11:00:05.322Z]: (1459422005322): Component "client:aa-controller" finished start()
xdk:client:[2016-03-31T11:00:05.322Z]: (1459422005322): Component "client:projects-tab" calling start()
xdk:client:[2016-03-31T11:00:05.329Z]: (1459422005329): Component "client:projects-tab" finished start()
xdk:client:[2016-03-31T11:00:05.329Z]: (1459422005329): Component "client:projects-list" calling start()
xdk:client:[2016-03-31T11:00:05.331Z]: (1459422005331): Component "client:projects-list" finished start()
xdk:client:[2016-03-31T11:00:05.331Z]: (1459422005331): Component "client:projects-info" calling start()
xdk:client:[2016-03-31T11:00:05.333Z]: (1459422005333): Component "client:projects-info" finished start()
xdk:client:[2016-03-31T11:00:05.333Z]: (1459422005333): Component "client:projects-create-list" calling start()
xdk:client:[2016-03-31T11:00:05.363Z]: (1459422005363): Component "client:projects-create-list" finished start()
xdk:client:[2016-03-31T11:00:05.363Z]: (1459422005363): Component "client:projects-create-info" calling start()
xdk:client:[2016-03-31T11:00:05.370Z]: (1459422005371): Component "client:projects-create-info" finished start()
xdk:client:[2016-03-31T11:00:05.371Z]: (1459422005371): Component "client:test-tab" calling start()
xdk:client:[2016-03-31T11:00:05.374Z]: (1459422005374): Component "client:test-tab" finished start()
xdk:client:[2016-03-31T11:00:05.374Z]: (1459422005374): Component "client:profilingTab" calling start()
xdk:client:[2016-03-31T11:00:05.416Z]: (1459422005416): Component "client:profilingTab" finished start()
xdk:client:[2016-03-31T11:00:05.416Z]: (1459422005416): Component "client:emulator" calling start()
xdk:client:[2016-03-31T11:00:05.417Z]: (1459422005417): Component "client:emulator" finished start()
xdk:client:[2016-03-31T11:00:05.417Z]: (1459422005417): Component "client:remote-tab" calling start()
xdk:client:[2016-03-31T11:00:05.421Z]: (1459422005421): onExitRequest listener 2:
    at Object.myExports.start (file:///home/hpandelo/Softwares/intel/XDK/xdk/components/client/remote-tab/remote-tab.js:20:3484)
    at resumeClientInit (/home/hpandelo/Softwares/intel/XDK/xdk/core-modules/private/main.js:17:12040)
    at /home/hpandelo/Softwares/intel/XDK/xdk/core-modules/private/main.js:17:1734
xdk:client:[2016-03-31T11:00:05.422Z]: (1459422005422): Component "client:remote-tab" finished start()
xdk:client:[2016-03-31T11:00:05.422Z]: (1459422005422): Component "client:build-tab" calling start()
xdk:client:[2016-03-31T11:00:05.424Z]: (1459422005424): Component "client:build-tab" finished start()
xdk:client:[2016-03-31T11:00:05.424Z]: (1459422005424): Component "client:active-sync" calling start()
xdk:client:[2016-03-31T11:00:05.425Z]: (1459422005425): Component "client:active-sync" finished start()
xdk:client:[2016-03-31T11:00:05.425Z]: (1459422005425): Component "client:apk-installer" calling start()
xdk:client:[2016-03-31T11:00:05.425Z]: (1459422005425): Component "client:apk-installer" finished start()
xdk:client:[2016-03-31T11:00:05.425Z]: (1459422005425): Component "client:resource-manager" calling start()
xdk:client:[2016-03-31T11:00:05.425Z]: (1459422005425): Component "client:resource-manager" finished start()
xdk:client:[2016-03-31T11:00:05.425Z]: (1459422005425): Component "client:resource-cocos2d" calling start()
xdk:client:[2016-03-31T11:00:05.425Z]: (1459422005425): Component "client:resource-cocos2d" finished start()
xdk:client:[2016-03-31T11:00:05.425Z]: (1459422005425): Component "client:resource-cocos2djs" calling start()
xdk:client:[2016-03-31T11:00:05.425Z]: (1459422005425): Component "client:resource-cocos2djs" finished start()
xdk:client:[2016-03-31T11:00:05.425Z]: (1459422005425): Component "client:resource-phaser" calling start()
xdk:client:[2016-03-31T11:00:05.425Z]: (1459422005425): Component "client:resource-phaser" finished start()
xdk:client:[2016-03-31T11:00:05.425Z]: (1459422005425): Component "client:resource-pixi" calling start()
xdk:client:[2016-03-31T11:00:05.425Z]: (1459422005425): Component "client:resource-pixi" finished start()
xdk:client:[2016-03-31T11:00:05.425Z]: (1459422005425): Component "client:resource-easeljs" calling start()
xdk:client:[2016-03-31T11:00:05.425Z]: (1459422005425): Component "client:resource-easeljs" finished start()
xdk:client:[2016-03-31T11:00:05.425Z]: (1459422005425): Component "client:resource-plain" calling start()
xdk:client:[2016-03-31T11:00:05.426Z]: (1459422005426): Component "client:resource-plain" finished start()
xdk:client:[2016-03-31T11:00:05.426Z]: (1459422005426): Component "client:resource-render-frame" calling start()
xdk:client:[2016-03-31T11:00:05.426Z]: (1459422005426): Component "client:resource-render-frame" finished start()
xdk:client:[2016-03-31T11:00:05.426Z]: (1459422005426): Component "client:resource-util" calling start()
xdk:client:[2016-03-31T11:00:05.426Z]: (1459422005426): Component "client:resource-util" finished start()
xdk:client:[2016-03-31T11:00:05.426Z]: (1459422005426): Component "client:bower-client" calling start()
xdk:client:[2016-03-31T11:00:05.426Z]: (1459422005426): Component "client:bower-client" finished start()
xdk:client:[2016-03-31T11:00:05.426Z]: (1459422005426): Component "client:editor" calling start()
xdk:client:[2016-03-31T11:00:05.427Z]: (1459422005427): Component "client:editor" finished start()
xdk:client:[2016-03-31T11:00:05.427Z]: (1459422005427): Component "client:editor-tab" calling start()
xdk:client:[2016-03-31T11:00:05.447Z]: (1459422005447): Component "client:editor-tab" finished start()
xdk:client:[2016-03-31T11:00:05.447Z]: (1459422005447): Component "client:live-preview" calling start()
xdk:client:[2016-03-31T11:00:05.447Z]: (1459422005447): Component "client:live-preview" finished start()
xdk:client:[2016-03-31T11:00:05.447Z]: (1459422005447): Component "client:account" calling start()
xdk:client:[2016-03-31T11:00:05.449Z]: (1459422005449): Component "client:account" finished start()
xdk:client:[2016-03-31T11:00:05.449Z]: (1459422005449): Component "client:project-selector" calling start()
xdk:client:[2016-03-31T11:00:05.451Z]: (1459422005451): Component "client:project-selector" finished start()
xdk:client:[2016-03-31T11:00:05.451Z]: (1459422005451): Component "client:ui-builder-client" calling start()
xdk:client:[2016-03-31T11:00:05.452Z]: (1459422005452): Component "client:ui-builder-client" finished start()
xdk:client:[2016-03-31T11:00:05.452Z]: (1459422005452): Component "client:project-meta" calling start()
xdk:client:[2016-03-31T11:00:05.453Z]: (1459422005453): Component "client:project-meta" finished start()
xdk:client:[2016-03-31T11:00:05.453Z]: (1459422005453): Component "client:cordova-registry" calling start()
xdk:client:[2016-03-31T11:00:05.453Z]: (1459422005453): Component "client:cordova-registry" finished start()
xdk:client:[2016-03-31T11:00:05.453Z]: (1459422005453): Component "client:adb" calling start()
xdk:client:[2016-03-31T11:00:05.453Z]: (1459422005453): Component "client:adb" finished start()
xdk:client:[2016-03-31T11:00:05.453Z]: (1459422005453): Component "client:iosdb" calling start()
xdk:client:[2016-03-31T11:00:05.454Z]: (1459422005454): Component "client:iosdb" finished start()
xdk:client:[2016-03-31T11:00:05.454Z]: (1459422005454): Component "client:device-discovery" calling start()
xdk:client:[2016-03-31T11:00:05.455Z]: (1459422005455): Component "client:device-discovery" threw exception during start()
xdk:client:[2016-03-31T11:00:05.455Z]: (1459422005455): Unexpected exception while initializing "device-discovery" (maybe crash): Error: Dynamic Linking Error: libssl.so.1.0.0: cannot open shared object file: Arquivo ou diretório não encontrado
    at new DynamicLibrary (/home/hpandelo/Softwares/intel/XDK/xdk/node_modules/ffi/lib/dynamic_library.js:74:11)
    at Object.Library (/home/hpandelo/Softwares/intel/XDK/xdk/node_modules/ffi/lib/library.js:45:12)
    at start (file:///home/hpandelo/Softwares/intel/XDK/xdk/components/client/device-discovery/impl/discovery-iosdb.js:17:217)
    at file:///home/hpandelo/Softwares/intel/XDK/xdk/components/client/device-discovery/device-discovery.js:17:9939
    at Array.map (native)
    at Array.impls_.call (file:///home/hpandelo/Softwares/intel/XDK/xdk/components/client/device-discovery/device-discovery.js:17:9879)
    at Object.start (file:///home/hpandelo/Softwares/intel/XDK/xdk/components/client/device-discovery/device-discovery.js:17:8460)
xdk:client:[2016-03-31T11:00:05.455Z]: (1459422005455): Component "client:test-local-server" calling start()
xdk:client:[2016-03-31T11:00:05.456Z]: (1459422005456): Component "client:test-local-server" finished start()
xdk:client:[2016-03-31T11:00:05.456Z]: (1459422005456): Component "client:quick-tour" calling start()
xdk:client:[2016-03-31T11:00:05.456Z]: (1459422005456): Component "client:quick-tour" finished start()
xdk:client:[2016-03-31T11:00:05.456Z]: (1459422005456): Component "client:hot-keys" calling start()
xdk:client:[2016-03-31T11:00:05.457Z]: (1459422005457): Component "client:hot-keys" finished start()
xdk:client:[2016-03-31T11:00:05.457Z]: (1459422005457): Component "client:persistance" calling start()
xdk:client:[2016-03-31T11:00:05.458Z]: (1459422005458): onExit listener 3:
    at Object.start (file:///home/hpandelo/Softwares/intel/XDK/xdk/components/client/persistance/persistance.js:17:4613)
xdk:client:[2016-03-31T11:00:05.458Z]: (1459422005458): Component "client:persistance" finished start()
xdk:client:[2016-03-31T11:00:05.458Z]: (1459422005458): Component "client:file-watcher" calling start()
xdk:client:[2016-03-31T11:00:05.458Z]: (1459422005458): Component "client:file-watcher" finished start()
xdk:client:[2016-03-31T11:00:05.458Z]: (1459422005458): Component "client:cordova" calling start()
xdk:client:[2016-03-31T11:00:05.458Z]: (1459422005458): Component "client:cordova" finished start()
xdk:client:[2016-03-31T11:00:05.458Z]: (1459422005458): Component "client:external-editors-runner" calling start()
xdk:client:[2016-03-31T11:00:05.459Z]: (1459422005459): Component "client:external-editors-runner" finished start()
xdk:client:[2016-03-31T11:00:05.459Z]: (1459422005459): Component "client:upload-manager" calling start()
xdk:client:[2016-03-31T11:00:05.459Z]: (1459422005459): Component "client:upload-manager" finished start()
xdk:client:[2016-03-31T11:00:05.459Z]: (1459422005459): Component "client:publish-tab" calling start()
xdk:client:[2016-03-31T11:00:05.461Z]: (1459422005461): onExitRequest listener 4:
    at AutofillController.registerForEvents_ (file:///home/hpandelo/Softwares/intel/XDK/xdk/components/client/publish-tab/autofill-form-controller.js:17:1607)
    at new AutofillController (file:///home/hpandelo/Softwares/intel/XDK/xdk/components/client/publish-tab/autofill-form-controller.js:17:470)
    at Object.myExports.start (file:///home/hpandelo/Softwares/intel/XDK/xdk/components/client/publish-tab/publish-tab.js:17:4918)
xdk:client:[2016-03-31T11:00:05.486Z]: (1459422005486): Component "client:publish-tab" finished start()
xdk:client:[2016-03-31T11:00:05.487Z]: (1459422005487): Error in common initialization
client:build-tab:[2016-03-31T11:00:05.504Z]: (1459422005504): [refreshPage] Unable to generate project hash. { message_: 'no project selected',
  code_: null,
  componentName_: null,
  stack_: 'Error\n    at new ComponentError (/home/hpandelo/Softwares/intel/XDK/xdk/core-modules/public/component-error.js:17:1122)\n    at makeError (file:///home/hpandelo/Softwares/intel/XDK/xdk/components/client/backend-service-utils/backend-service-utils.js:17:187)\n    at Object.exports.generateProjectHash (file:///home/hpandelo/Softwares/intel/XDK/xdk/components/client/backend-service-utils/backend-service-utils.js:17:1440)\n    at _refreshPage (file:///home/hpandelo/Softwares/intel/XDK/xdk/components/client/build-tab/build-tab.js:17:6994)\n    at Object.start (file:///home/hpandelo/Softwares/intel/XDK/xdk/components/client/build-tab/build-tab.js:17:3869)\n    at resumeClientInit (/home/hpandelo/Softwares/intel/XDK/xdk/core-modules/private/main.js:17:12040)\n    at /home/hpandelo/Softwares/intel/XDK/xdk/core-modules/private/main.js:17:1734\n    at _fulfilled (/home/hpandelo/Softwares/intel/XDK/xdk/node_modules/q/q.js:834:54)\n    at self.promiseDispatch.done (/home/hpandelo/Softwares/intel/XDK/xdk/node_modules/q/q.js:863:30)\n    at Promise.promise.promiseDispatch (/home/hpandelo/Softwares/intel/XDK/xdk/node_modules/q/q.js:796:13)' }
client:build-tab:[2016-03-31T11:00:05.505Z]: (1459422005505): [updatePageStatus] Set Status: PAGE_STATUS_ERROR
[Log closed from xdk:client]
Helcio_R__Macedo_Pan
Making 3 Links
sudo ln -s /lib64 ./x86_64-linux-gnu && sudo ln -s /lib64/libssl.so.1.0.2g /lib64/libssl.so.1.0.0 && sudo ln -s /lib64/libcrypto.so.1.0.2g /lib64/libcrypto.so.1.0.0
Now.. its warning
ios-device:[2016-03-31T11:22:09.168Z]: (1459423329168): Failed to initialize libwi due to  Dynamic Linking Error: /lib64/libssl.so.1.0.0: version `OPENSSL_1.0.0' not found (required by /home/hpandelo/Softwares/intel/XDK/bin/libwi/libimobiledevice.so.5)
xdk:client:[2016-03-31T11:22:22.611Z]: (1459423342611): Unexpected exception while initializing "device-discovery" (maybe crash): Error: Dynamic Linking Error: /lib64/libssl.so.1.0.0: version `OPENSSL_1.0.0' not found (required by /home/hpandelo/Softwares/intel/XDK/bin/libwi/libimobiledevice.so.5)
