Hi, I built a VM in Oracle VirtualBox, and XDK it is the first thing I am installing. Windows is clean.
VM is Windows 7 64x Pro
Is there anything I'm missing?
- Tags:
- HTML5
- Intel® XDK
I have no idea what might be causing that. I'll ask the install engineer to take a look, they might have some insight.
Hello, could you please send the installation log? in windows it is located in this location
C:\Users\<USERNAME>\AppData\Local\Temp\micl_tmp_<username>\2015.10.xx_xx.xx.xx_xxxxxxxx\log
We will analyze from there. Thanks
I found out I was behind a proxy, but still, it was an awkward error message.
That is a very odd error message. I'll ask engineering to see if they can detect this condition more explicitly so that a better error message can be provided. Thanks for providing the resolution to the problem.
Douglas, I am glad it worked fine, and thanks for the feedback.
Question: what did you do to get the problem fixed? did you attempt again to reinstall the Intel XDK? Did you get an error message that time? or the Install process continues despite the error?
Thanks a lot for the information.
Javier.
Javier.
Hi Javier,
I tried to install another software, so I got a network error, then I realized I was behind a proxy, and which I haven't configured on the VM side. Doing that, everything went fine.
I'm glad to help.
I think you're looking for this post > https://software.intel.com/en-us/forums/intel-xdk/topic/598065 < which points to this thread that my help > https://software.intel.com/en-us/forums/intel-xdk/topic/603992#comment-1852411 <
I think you're looking for this post > https://software.intel.com/en-us/forums/intel-xdk/topic/598065 < which points to this thread that my help > https://software.intel.com/en-us/forums/intel-xdk/topic/603992#comment-1... <
I was trying it ....
Well, it's not working ... until I connecting my PC to internet. I think the main problem in here is; I must installing this software when my PC is connected with internet and activate "Certificate Propagation" services. But I still curious, when my friends installing Intel XDA in their PC without internet connection, it works well.They have same Windows version and architecture with me.
Okay, I hope if someone face same problem with me, they will do same thing as I do like above.
