Software Archive
Read-only legacy content
17060 Discussions
Build Error - Andriod Crosswalk (3088)
Dennis_K_
    Building a Cordova 5.1.1 application.
    Using platform cordova-android 4.1.1.
    The application name is "APP_NAME"
    The package name is "xdk.intel.blank.ad.template"
    Using Crosswalk Embedded 16
    Plugin "cordova-plugin-statusbar" (2.1.2) installed.
    Plugin "cordova-plugin-device" (1.1.1) installed.
    Plugin "cordova-plugin-splashscreen" (3.2.1) installed.
    Plugin "cordova-plugin-dialogs" (1.2.0) installed.
    Plugin "intel.xdk.cache" (1.2.4) installed.
    Plugin "phonegap-facebook-plugin" (0.12.0) installed.
    Plugin "cordova-plugin-whitelist" (1.2.1) installed.
    Plugin "cordova-plugin-crosswalk-webview" (1.4.0) installed.
    App name updated to [APP_NAME]
    Updated "minSdkVersion" with "15"
    Updated "targetSdkVersion" with "19"
    Updated "installLocation" to "auto"
    Updated "versionCode" to "21"
    Updated "versionName" to "0.2.1"
    Added "debuggable" to "false"
    Error: A build error occurred. Check the build log.
Any ideas about the problem to solve or circumvent it?
Elroy_A_Intel
Can you please provide your build log?
Dennis_K_
In advance apology for the Google translation.
I'm trying for days to push notifications, it could then also implement last week and tested successfully.
Now I wanted to reflect on my test app all on my current. So far so good, mirrored everything and then adjusted.
Prefer the apk bodybuilding and get an error.
Current:(provoked error)
Building a Cordova 5.4.1 application.
Using platform cordova-android 5.0.0.
The package name is "xdk.intel.taram.card"
Preference android-signed set to true. Application will be signed.
Using Crosswalk Embedded 15
Plugin "cordova-plugin-statusbar" (2.0.0) installed.
Plugin "cordova-plugin-device" (1.1.0) installed.
Plugin "cordova-plugin-splashscreen" (2.1.0) installed.
Plugin "phonegap-facebook-plugin" (0.12.0) installed.    <--------------
Plugin "intel.xdk.cache" (1.2.4) installed.                <--------------
Plugin "phonegap-plugin-push" (1.6.1) installed.
Plugin "cordova-plugin-crosswalk-webview" (1.5.0) installed.
Updated "versionCode" to "24"
Updated "versionName" to "0.2.4"
Test-App:
The application name is "Test App"
The package name is "test.events.news.app"
App name updated to [Test App]
Updated "installLocation" to "preferExternal"
Updated "versionCode" to "4"
Updated "versionName" to "0.0.4"
* Try:
Run with --stacktrace option to get the stack trace. Run with --info or --debug option to get more log output.
BUILD FAILED
Total time: 1 mins 16.804 secs
ERROR building one of the platforms: Error: .../builds/build.2016-04-11.15-04-38.U8m3GY.tmp/app/platforms/android/gradlew: Command failed with exit code 1
You may not have the required environment or OS to build this project
Error: .../builds/build.2016-04-11.15-04-38.U8m3GY.tmp/tara_m/platforms/android/gradlew: Command failed with exit code 1
    at ChildProcess.whenDone (.../builds/build.2016-04-11.15-04-38.U8m3GY.tmp/app/platforms/android/cordova/node_modules/cordova-common/src/superspawn.js:139:23)
    at emitTwo (events.js:87:13)
    at ChildProcess.emit (events.js:172:7)
    at maybeClose (internal/child_process.js:821:16)
    at Process.ChildProcess._handle.onexit (internal/child_process.js:211:5)
PaulF_IntelCorp
You're using some very old plugins for your CLI 5.4.1 build, especially the splash screen plugin. Here’s what I suggest:
  • change to CLI 5.1.1 and choose “Downgrade CLI and Plugins" (or it might say "Upgrade CLI and Plugins")
  • try the build and see if it works
  • if that fails, change to CLI 5.4.1 and choose “Upgrade CLI and Plugins”
Report your results here.
Dennis_K_
still not working, even after downgrade phonegap-plugin-push to 1.4.3
Build Log
Plugin "cordova-plugin-statusbar" (2.1.0) installed.
Plugin "cordova-plugin-splashscreen" (3.2.0) installed.
Plugin "cordova-plugin-legacy-whitelist" (1.1.1) installed.
* Try:
BUILD FAILED
Total time: 1 mins 17.46 secs
ERROR building one of the platforms: Error: .../app/platforms/android/gradlew: Command failed with exit code 1
    at ChildProcess.whenDone (.../app/platforms/android/cordova/node_modules/cordova-common/src/superspawn.js:139:23)
Build Log
* Try:
BUILD FAILED
Total time: 1 mins 16.818 secs
.../app/platforms/android/cordova/node_modules/q/q.js:126
                    throw e;
Error code 1 for command: .../app/platforms/android/gradlew with args: cdvBuildRelease,-b,.../app/platforms/android/build.gradle,--no-daemon
Command finished with error code 1: .../app/platforms/android/cordova/build --release
ERROR building one of the platforms: Error: .../app/platforms/android/cordova/build: Command failed with exit code 1
    at ChildProcess.whenDone (.../cordova/cordova-cli/5.1.1/node_modules/cordova/node_modules/cordova-lib/src/cordova/superspawn.js:134:23)
PaulF_IntelCorp
What happens if you remove the intel.xdk.cache plugin? Also, have you tried removing individual plugins and building after each removal, to isolate which plugin is causing the problem?
