Software Archive
Read-only legacy content
17060 Discussions
Build Failed when trying to build to windows 8
Daniel_C_3
I tried searching the forums before I posted but I had no luck in finding a solution. I can build an android apk but it fails when I try to build to windows 8.
The build failed. An error occurred while building the application. Verify your build assets are correct and try again.
Windows 8 Build Log:
<!--break-->
Creating a new cordova project with name "84MobileCS" and id "not.yet.specified" at location "...\84MobileCS"
Using stock cordova hello-world application.
cordova library for "www" already exists. No need to download. Continuing.
Copying stock Cordova www assets into "...\84MobileCS\www"
Creating windows project...
Running command: C:\Windows\system32\config\systemprofile\.cordova\lib\npm_cache\cordova-windows\3.7.1\package\bin\create.bat ...\84MobileCS\platforms\windows not.yet.specified 84MobileCS
Creating Cordova Windows Project:
	App Name  : 84MobileCS
	Namespace : not.yet.specified
	Path      : ...\84MobileCS\platforms\windows
Copying template to ...\84MobileCS\platforms\windows
Command finished with error code 0: C:\Windows\system32\config\systemprofile\.cordova\lib\npm_cache\cordova-windows\3.7.1\package\bin\create.bat ...\84MobileCS\platforms\windows,not.yet.specified,84MobileCS
Calling plugman.prepare for platform "windows"
Preparing windows project
Processing configuration changes for plugins.
Iterating over installed plugins: []
Writing out cordova_plugins.js...
Calling plugman.fetch on plugin "...\pl.st.wcxrpp23.qt5\org.apache.cordova.device"
Copying plugin "...\pl.st.wcxrpp23.qt5\org.apache.cordova.device" => "...\84MobileCS\plugins\org.apache.cordova.device"
Calling plugman.install on plugin "...\84MobileCS\plugins\org.apache.cordova.device" for platform "windows" with options "{"cli_variables":{},"browserify":false,"nohooks":["."]}"
Installing "org.apache.cordova.device" for windows
Install start for "org.apache.cordova.device" on windows.
Beginning processing of action stack for windows project...
Parsing windows project files...
creating jsproj from project at : ...\84MobileCS\platforms\windows\CordovaApp.projitems
Action stack processing complete.
Writing out windows project files...
Iterating over installed plugins: [ 'org.apache.cordova.device' ]
Install complete for org.apache.cordova.device on windows.
Calling plugman.fetch on plugin "...\pl.st.wcxrpp23.qt5\org.apache.cordova.splashscreen"
Copying plugin "...\pl.st.wcxrpp23.qt5\org.apache.cordova.splashscreen" => "...\84MobileCS\plugins\org.apache.cordova.splashscreen"
Calling plugman.install on plugin "...\84MobileCS\plugins\org.apache.cordova.splashscreen" for platform "windows" with options "{"cli_variables":{},"browserify":false,"nohooks":["."]}"
Installing "org.apache.cordova.splashscreen" for windows
Install start for "org.apache.cordova.splashscreen" on windows.
Iterating over installed plugins: [ 'org.apache.cordova.device',
  'org.apache.cordova.splashscreen' ]
Install complete for org.apache.cordova.splashscreen on windows.
Calling plugman.fetch on plugin "...\pl.st.wcxrpp23.qt5\org.apache.cordova.inappbrowser"
Copying plugin "...\pl.st.wcxrpp23.qt5\org.apache.cordova.inappbrowser" => "...\84MobileCS\plugins\org.apache.cordova.inappbrowser"
Calling plugman.install on plugin "...\84MobileCS\plugins\org.apache.cordova.inappbrowser" for platform "windows" with options "{"cli_variables":{},"browserify":false,"nohooks":["."]}"
Installing "org.apache.cordova.inappbrowser" for windows
Install start for "org.apache.cordova.inappbrowser" on windows.
  'org.apache.cordova.splashscreen',
  'org.apache.cordova.inappbrowser' ]
Install complete for org.apache.cordova.inappbrowser on windows.
Generating config.xml from defaults for platform "windows"
Running command: ...\84MobileCS\hooks\after_prepare\cordova_4.1.2.cmd ...\84MobileCS
...\84MobileCS>python .\hooks\after_prepare\python.code\cordova_4.1.2.py ...\84MobileCS
NO stdout encoding...
NO stdout encoding after..
************* Processing the main config.xml file (after_prepare)  *****************
Platforms = windows
Platform = [windows]
2 arguments passed.
App Directory = [...\84MobileCS]
Current Directory = [.\hooks\after_prepare\python.code\cordova_4.1.2.py]
Will process and update the following config files:
    Config.xml = [...\84MobileCS\config.xml]
Namespaces:
    prefix/uri ''/'http://www.w3.org/ns/widgets'
    prefix/uri 'intelxdk'/'http://xdk.intel.com/ns/v1'
getting into a windows manifest
Windows8 Manifest Namespaces:
    prefix/uri ''/'http://schemas.microsoft.com/appx/2010/manifest'
Processing windows configuration items.
Name of the app is [84MobileCS]
    Deleting [...\84MobileCS\platforms\windows\images\SplashScreen.scale-100.png]
    Deleting [...\84MobileCS\platforms\windows\images\SplashScreenPhone.scale-240.png]
    Deleting [...\84MobileCS\platforms\windows\images\Square150x150Logo.scale-100.png]
    Deleting [...\84MobileCS\platforms\windows\images\Square150x150Logo.scale-240.png]
    Deleting [...\84MobileCS\platforms\windows\images\Square30x30Logo.scale-100.png]
    Deleting [...\84MobileCS\platforms\windows\images\Square310x310Logo.scale-100.png]
    Deleting [...\84MobileCS\platforms\windows\images\Square44x44Logo.scale-240.png]
    Deleting [...\84MobileCS\platforms\windows\images\Square70x70Logo.scale-100.png]
    Deleting [...\84MobileCS\platforms\windows\images\Square71x71Logo.scale-240.png]
    Deleting [...\84MobileCS\platforms\windows\images\StoreLogo.scale-100.png]
    Deleting [...\84MobileCS\platforms\windows\images\StoreLogo.scale-240.png]
    Deleting [...\84MobileCS\platforms\windows\images\Wide310x150Logo.scale-100.png]
    Deleting [...\84MobileCS\platforms\windows\images\Wide310x150Logo.scale-240.png]
Searching for images in [...\84MobileCS\hooks\Images.windows.4.1.2\*.png]
    Copying [...\84MobileCS\platforms\windows\images\SplashScreen.scale-100.png]
    Copying [...\84MobileCS\platforms\windows\images\Square150x150Logo.scale-100.png]
    Copying [...\84MobileCS\platforms\windows\images\Square30x30Logo.scale-100.png]
    Copying [...\84MobileCS\platforms\windows\images\StoreLogo.scale-100.png]
Looking for [{http://www.w3.org/ns/widgets}preference]
Processing preference permissions
    prefix/uri ''/'http://schemas.microsoft.com/developer/msbuild/2003'
Saving config.xml to [...\84MobileCS\config.xml]
************* Completed processing the main config.xml file (after_prepare)  *****************
Command finished with error code 0: ...\84MobileCS\hooks\after_prepare\cordova_4.1.2.cmd ...\84MobileCS
skipped directory "...\84MobileCS\hooks\after_prepare\python.code" within hook directory
Updating settings....
...\84MobileCS>python .\hooks\after_prepare\python.code\cordova_4.1.2.py "...\84MobileCS" "...\84MobileCS"
Platforms = windows
3 arguments passed.
Namespaces:
Running command: ...\84MobileCS\platforms\windows\cordova\build.bat --release --win --verbose
Applying Platform Config...
MSBuildToolsPath: C:\Windows\Microsoft.NET\Framework64\v4.0.30319\
Building project: ...\84MobileCS\platforms\windows\CordovaApp.vs2012.sln
	Configuration : release
	Platform      : anycpu
Building the projects in this solution one at a time. To enable parallel build, please add the "/m" switch.
MakePRI : warning 0xdef00522: Resources found for language(s) 'de, es, fr, it, ja, ko, pl, ru' but no resources found for default language(s): 'en-US'. Change the default language or qualify resources with the default language. http://go.microsoft.com/fwlink/?LinkId=231899 [...\84MobileCS\platforms\windows\CordovaApp.Windows80.jsproj]
  CordovaApp.Windows80 -> ...\84MobileCS\platforms\windows\AppPackages\CordovaApp.Windows80_0.0.0.1_AnyCPU_Test\CordovaApp.Windows80_0.0.0.1_AnyCPU.appx
  CordovaApp.Windows80 -> ...\84MobileCS\platforms\windows\AppPackages\CordovaApp.Windows80_0.0.0.1_AnyCPU.appxupload
  Your package has been successfully created.
Command finished with error code 0: ...\84MobileCS\platforms\windows\cordova\build.bat --release,--win,--verbose
Elroy_A_Intel
It seems that your App ID hasn't been set for Windows 8. You can update your App ID under Projects > Cordova Hybrid Mobile App Settings > Build Settings > App ID. Are you still experiencing building Windows 8 apps?
Jaap_v_
Running in this same error when trying to build with XDK 2248 to windows 8 (and I did enter a valid app ID)
http://go.microsoft.com/fwlink/?LinkId=231899 [...\FD2\platforms\windows\CordovaApp.Windows80.jsproj]
  CordovaApp.Windows80 -> ...\FD2\platforms\windows\AppPackages\CordovaApp.Windows80_0.0.0.1_AnyCPU_Test\CordovaApp.Windows80_0.0.0.1_AnyCPU.appx
  CordovaApp.Windows80 -> ...\FD2\platforms\windows\AppPackages\CordovaApp.Windows80_0.0.0.1_AnyCPU.appxupload
Command finished with error code 0: ...\FD2\platforms\windows\cordova\build.bat --release,--win,--verbose
Jaap_v_
I've tried it again today with the same settings and now XDK report a successfull build!
