Software Archive
Read-only legacy content
Build Failed
John_Michael_T_
Hi guys,
I have a problem building this can someone help me how to solve this?
:compileArmv7ReleaseNdk UP-TO-DATE
:compileArmv7ReleaseSources
:transformClassesWithDexForArmv7Release
:mergeArmv7ReleaseJniLibFolders
:transformNative_libsWithMergeJniLibsForArmv7Release
:processArmv7ReleaseJavaRes UP-TO-DATE
:transformResourcesWithMergeJavaResForArmv7Release
:packageArmv7Release
:assembleArmv7Release
:checkX86ReleaseManifest
:prepareX86ReleaseDependencies
:compileX86ReleaseAidl
:compileX86ReleaseRenderscript
:generateX86ReleaseBuildConfig
:generateX86ReleaseAssets UP-TO-DATE
:mergeX86ReleaseAssets
:createXwalkCommandLineFileX86Release
:generateX86ReleaseResValues
:generateX86ReleaseResources
:mergeX86ReleaseResources
:processX86ReleaseManifest
:processX86ReleaseResources
:generateX86ReleaseSources
:compileX86ReleaseJavaWithJavacNote: Some input files use or override a deprecated API.
Note: Recompile with -Xlint:deprecation for details.
Note: .../cordova_project/platforms/android/src/org/apache/cordova/file/AssetFilesystem.java uses unchecked or unsafe operations.
Note: Recompile with -Xlint:unchecked for details.
:compileX86ReleaseNdk UP-TO-DATE
:compileX86ReleaseSources
:transformClassesWithDexForX86Release
:mergeX86ReleaseJniLibFolders
:transformNative_libsWithMergeJniLibsForX86Release FAILED
FAILURE: Build failed with an exception.
* What went wrong:
Execution failed for task ':transformNative_libsWithMergeJniLibsForX86Release'.
> java.io.IOException: No space left on device
* Try:
Run with --stacktrace option to get the stack trace. Run with --info or --debug option to get more log output.
BUILD FAILED
Total time: 3 mins 8.587 secs
* What went wrong:
Failed to notify build listener.
* Try:
Error: Error code 1 for command: .../cordova_project/platforms/android/gradlew with args: cdvBuildRelease,-b,.../cordova_project/platforms/android/build.gradle,--no-daemon,-Pandroid.useDeprecatedNdk=true
PaulF_IntelCorp
John -- please attach the entire detailed build log as a file attachment so we can take a closer look. Most often, the problem is due to a plugin that is either incompatible with our build system or incompatible with another plugin you are using. Simplest way to diagnose this case is to remove one plugin, try to build, remove another, try to build, etc. until you can isolate which plugin is the source of the problem.
canip_ü_
??? please
Calling plugman.fetch on plugin ".../cachedPlugins.r3V3pT.tmp/cache.5DSfa7.pl/cordova-plugin-legacy-whitelist"
Copying plugin ".../cachedPlugins.r3V3pT.tmp/cache.5DSfa7.pl/cordova-plugin-legacy-whitelist" => ".../cordova_project/plugins/cordova-plugin-legacy-whitelist"
Calling plugman.install on plugin ".../cordova_project/plugins/cordova-plugin-legacy-whitelist" for platform "android
Installing "cordova-plugin-legacy-whitelist" for android
Running command: .../cordova_project/platforms/android/cordova/version
Command finished with error code 0: .../cordova_project/platforms/android/cordova/version
Install start for "cordova-plugin-legacy-whitelist" on android.
Install complete for cordova-plugin-legacy-whitelist on android.
Checking for any plugins added to the project that have not been installed in android platform
No differences found between plugins added to project and installed in android platform. Continuing...
Generating config.xml from defaults for platform "android"
Wrote out Android application name to "vusal"
Wrote out Android package name to "xdk.intel.blank.ad.template.crosswalk"
This app does not have launcher icons defined
updated project successfully
Calling plugman.fetch on plugin ".../cachedPlugins.r3V3pT.tmp/cache.lV5o1y.pl/cordova-plugin-crosswalk-webview"
Copying plugin ".../cachedPlugins.r3V3pT.tmp/cache.lV5o1y.pl/cordova-plugin-crosswalk-webview" => ".../cordova_project/plugins/cordova-plugin-crosswalk-webview"
Calling plugman.install on plugin ".../cordova_project/plugins/cordova-plugin-crosswalk-webview" for platform "android
Installing "cordova-plugin-crosswalk-webview" for android
Install start for "cordova-plugin-crosswalk-webview" on android.
Updating build files since android plugin contained <framework>
Install complete for cordova-plugin-crosswalk-webview on android.
Checking config.xml for saved platforms that haven't been added to the project
Checking config.xml for saved plugins that haven't been added to the project
************* Processing the main config.xml file (after_prepare)  *****************
App Directory = [.../cordova_project]
Will process and update the following config files:
    Config.xml = [.../cordova_project/config.xml]
Namespaces:
    prefix/uri ''/'http://www.w3.org/ns/widgets'
    prefix/uri 'intelxdk'/'http://xdk.intel.com/ns/v1'
Android Manifest Namespaces:
    prefix/uri 'android'/'http://schemas.android.com/apk/res/android'
Name of the app is [vusal]
Updating full app name to [vusal]
Processing preference android-minSdkVersion [14]
Processing preference android-targetSdkVersion [21]
Processing preference android-installLocation [auto]
Processing preference permissions
Updating the versionCode
Updating the versionName
Processing debuggable
Added [{http://schemas.android.com/apk/res/android}debuggable] with [false]
Processing config file values
Saving config.xml to [.../cordova_project/config.xml]
************* Completed processing the main config.xml file (after_prepare)  *****************
ANDROID_HOME=.../android-sdk/
JAVA_HOME=/usr/lib/jvm/java-8-oracle-amd64
Downloading file://.../cordova/gradle/gradle-2.2.1-all.zip
Unzipping /home/builduser/.gradle/wrapper/dists/gradle-2.2.1-all/3d6ng971birsf8vhjv1s2o93eu/gradle-2.2.1-all.zip to /home/builduser/.gradle/wrapper/dists/gradle-2.2.1-all/3d6ng971birsf8vhjv1s2o93eu
Set executable permissions for: /home/builduser/.gradle/wrapper/dists/gradle-2.2.1-all/3d6ng971birsf8vhjv1s2o93eu/gradle-2.2.1/bin/gradle
Starting Build
Compiling settings file '.../cordova_project/platforms/android/settings.gradle' using StatementExtractingScriptTransformer.
Compiling settings file '.../cordova_project/platforms/android/settings.gradle' using BuildScriptTransformer.
Settings evaluated using settings file '.../cordova_project/platforms/android/settings.gradle'.
Projects loaded. Root project using build file '.../cordova_project/platforms/android/build.gradle'.
Included projects: [root project 'android', project ':CordovaLib']
Evaluating root project 'android' using build file '.../cordova_project/platforms/android/build.gradle'.
Compiling build file '.../cordova_project/platforms/android/build.gradle' using StatementExtractingScriptTransformer.
Download https://repo1.maven.org/maven2/com/android/tools/build/gradle/1.5.0/gradle-1.5.0.pom
Download https://repo1.maven.org/maven2/com/android/tools/build/gradle-core/1.5.0/gradle-core-1.5.0.pom
Download https://repo1.maven.org/maven2/com/android/tools/build/builder/1.5.0/builder-1.5.0.pom
Download https://repo1.maven.org/maven2/com/android/tools/lint/lint/24.5.0/lint-24.5.0.pom
Download https://repo1.maven.org/maven2/com/android/tools/build/transform-api/1.5.0/transform-api-1.5.0.pom
Download https://repo1.maven.org/maven2/com/android/databinding/compilerCommon/1.0-rc5/compilerCommon-1.0-rc5.pom
Download https://repo1.maven.org/maven2/net/sf/proguard/proguard-gradle/5.2.1/proguard-gradle-5.2.1.pom
Download https://repo1.maven.org/maven2/net/sf/proguard/proguard-parent/5.2.1/proguard-parent-5.2.1.pom
Download https://repo1.maven.org/maven2/org/jacoco/org.jacoco.core/0.7.4.201502262128/org.jacoco.core-0.7.4.201502262128.pom
Download https://repo1.maven.org/maven2/org/jacoco/org.jacoco.build/0.7.4.201502262128/org.jacoco.build-0.7.4.201502262128.pom
Download https://repo1.maven.org/maven2/com/android/tools/build/builder-model/1.5.0/builder-model-1.5.0.pom
Download https://repo1.maven.org/maven2/com/android/tools/build/builder-test-api/1.5.0/builder-test-api-1.5.0.pom
Download https://repo1.maven.org/maven2/com/android/tools/sdklib/24.5.0/sdklib-24.5.0.pom
Download https://repo1.maven.org/maven2/com/android/tools/sdk-common/24.5.0/sdk-common-24.5.0.pom
Download https://repo1.maven.org/maven2/com/android/tools/common/24.5.0/common-24.5.0.pom
Download https://repo1.maven.org/maven2/com/android/tools/build/manifest-merger/24.5.0/manifest-merger-24.5.0.pom
Download https://repo1.maven.org/maven2/com/android/tools/ddms/ddmlib/24.5.0/ddmlib-24.5.0.pom
Download https://repo1.maven.org/maven2/com/android/tools/jack/jack-api/0.9.0/jack-api-0.9.0.pom
Download https://repo1.maven.org/maven2/com/android/tools/jill/jill-api/0.9.0/jill-api-0.9.0.pom
Download https://repo1.maven.org/maven2/com/squareup/javawriter/2.5.0/javawriter-2.5.0.pom
Download https://repo1.maven.org/maven2/org/sonatype/oss/oss-parent/7/oss-parent-7.pom
Download https://repo1.maven.org/maven2/org/bouncycastle/bcpkix-jdk15on/1.48/bcpkix-jdk15on-1.48.pom
Download https://repo1.maven.org/maven2/org/bouncycastle/bcprov-jdk15on/1.48/bcprov-jdk15on-1.48.pom
Download https://repo1.maven.org/maven2/org/ow2/asm/asm/5.0.3/asm-5.0.3.pom
Download https://repo1.maven.org/maven2/org/ow2/asm/asm-parent/5.0.3/asm-parent-5.0.3.pom
Download https://repo1.maven.org/maven2/org/ow2/ow2/1.3/ow2-1.3.pom
Download https://repo1.maven.org/maven2/org/ow2/asm/asm-tree/5.0.3/asm-tree-5.0.3.pom
Download https://repo1.maven.org/maven2/org/antlr/antlr-runtime/3.5.2/antlr-runtime-3.5.2.pom
Download https://repo1.maven.org/maven2/org/antlr/antlr-master/3.5.2/antlr-master-3.5.2.pom
Download https://repo1.maven.org/maven2/org/sonatype/oss/oss-parent/9/oss-parent-9.pom
Download https://repo1.maven.org/maven2/org/antlr/antlr/3.5.2/antlr-3.5.2.pom
Download https://repo1.maven.org/maven2/com/android/tools/lint/lint-checks/24.5.0/lint-checks-24.5.0.pom
Download https://repo1.maven.org/maven2/org/eclipse/jdt/core/compiler/ecj/4.4.2/ecj-4.4.2.pom
Download https://repo1.maven.org/maven2/com/android/tools/annotations/24.5.0/annotations-24.5.0.pom
Download https://repo1.maven.org/maven2/com/google/guava/guava/17.0/guava-17.0.pom
Download https://repo1.maven.org/maven2/com/google/guava/guava-parent/17.0/guava-parent-17.0.pom
Download https://repo1.maven.org/maven2/com/android/databinding/baseLibrary/1.0-rc5/baseLibrary-1.0-rc5.pom
Download https://repo1.maven.org/maven2/org/apache/commons/commons-lang3/3.3.2/commons-lang3-3.3.2.pom
Download https://repo1.maven.org/maven2/org/apache/commons/commons-parent/33/commons-parent-33.pom
Download https://repo1.maven.org/maven2/org/apache/apache/13/apache-13.pom
Download https://repo1.maven.org/maven2/com/tunnelvisionlabs/antlr4/4.5/antlr4-4.5.pom
Download https://repo1.maven.org/maven2/com/tunnelvisionlabs/antlr4-master/4.5/antlr4-master-4.5.pom
Download https://repo1.maven.org/maven2/commons-io/commons-io/2.4/commons-io-2.4.pom
Download https://repo1.maven.org/maven2/org/apache/commons/commons-parent/25/commons-parent-25.pom
Download https://repo1.maven.org/maven2/org/apache/apache/9/apache-9.pom
Download https://repo1.maven.org/maven2/com/googlecode/juniversalchardet/juniversalchardet/1.0.3/juniversalchardet-1.0.3.pom
Download https://repo1.maven.org/maven2/net/sf/proguard/proguard-base/5.2.1/proguard-base-5.2.1.pom
Download https://repo1.maven.org/maven2/org/ow2/asm/asm-debug-all/5.0.1/asm-debug-all-5.0.1.pom
Download https://repo1.maven.org/maven2/org/ow2/asm/asm-parent/5.0.1/asm-parent-5.0.1.pom
Download https://repo1.maven.org/maven2/com/android/tools/layoutlib/layoutlib-api/24.5.0/layoutlib-api-24.5.0.pom
Download https://repo1.maven.org/maven2/com/android/tools/dvlib/24.5.0/dvlib-24.5.0.pom
Download https://repo1.maven.org/maven2/com/google/code/gson/gson/2.2.4/gson-2.2.4.pom
Download https://repo1.maven.org/maven2/org/apache/commons/commons-compress/1.8.1/commons-compress-1.8.1.pom
Download https://repo1.maven.org/maven2/org/apache/httpcomponents/httpclient/4.1.1/httpclient-4.1.1.pom
Download https://repo1.maven.org/maven2/org/apache/httpcomponents/httpcomponents-client/4.1.1/httpcomponents-client-4.1.1.pom
Download https://repo1.maven.org/maven2/org/apache/httpcomponents/project/4.1.1/project-4.1.1.pom
Download https://repo1.maven.org/maven2/org/apache/httpcomponents/httpmime/4.1/httpmime-4.1.pom
Download https://repo1.maven.org/maven2/org/apache/httpcomponents/httpcomponents-client/4.1/httpcomponents-client-4.1.pom
Download https://repo1.maven.org/maven2/net/sf/kxml/kxml2/2.3.0/kxml2-2.3.0.pom
Download https://repo1.maven.org/maven2/org/antlr/ST4/4.0.8/ST4-4.0.8.pom
Download https://repo1.maven.org/maven2/com/android/tools/lint/lint-api/24.5.0/lint-api-24.5.0.pom
Download https://repo1.maven.org/maven2/org/ow2/asm/asm-analysis/5.0.3/asm-analysis-5.0.3.pom
Download https://repo1.maven.org/maven2/com/tunnelvisionlabs/antlr4-runtime/4.5/antlr4-runtime-4.5.pom
Download https://repo1.maven.org/maven2/com/tunnelvisionlabs/antlr4-annotations/4.5/antlr4-annotations-4.5.pom
Download https://repo1.maven.org/maven2/com/intellij/annotations/12.0/annotations-12.0.pom
Download https://repo1.maven.org/maven2/org/apache/httpcomponents/httpcore/4.1/httpcore-4.1.pom
Download https://repo1.maven.org/maven2/org/apache/httpcomponents/httpcomponents-core/4.1/httpcomponents-core-4.1.pom
Download https://repo1.maven.org/maven2/commons-logging/commons-logging/1.1.1/commons-logging-1.1.1.pom
Download https://repo1.maven.org/maven2/org/apache/commons/commons-parent/5/commons-parent-5.pom
Download https://repo1.maven.org/maven2/org/apache/apache/4/apache-4.pom
Download https://repo1.maven.org/maven2/commons-codec/commons-codec/1.4/commons-codec-1.4.pom
Download https://repo1.maven.org/maven2/org/apache/commons/commons-parent/11/commons-parent-11.pom
Download https://repo1.maven.org/maven2/com/android/tools/external/lombok/lombok-ast/0.2.3/lombok-ast-0.2.3.pom
Download https://repo1.maven.org/maven2/org/abego/treelayout/org.abego.treelayout.core/1.0.1/org.abego.treelayout.core-1.0.1.pom
Download https://repo1.maven.org/maven2/com/android/tools/build/gradle/1.5.0/gradle-1.5.0.jar
Download https://repo1.maven.org/maven2/com/android/tools/build/gradle-core/1.5.0/gradle-core-1.5.0.jar
Download https://repo1.maven.org/maven2/com/android/tools/build/builder/1.5.0/builder-1.5.0.jar
Download https://repo1.maven.org/maven2/com/android/tools/lint/lint/24.5.0/lint-24.5.0.jar
Download https://repo1.maven.org/maven2/com/android/tools/build/transform-api/1.5.0/transform-api-1.5.0.jar
Download https://repo1.maven.org/maven2/com/android/databinding/compilerCommon/1.0-rc5/compilerCommon-1.0-rc5.jar
Download https://repo1.maven.org/maven2/net/sf/proguard/proguard-gradle/5.2.1/proguard-gradle-5.2.1.jar
Download https://repo1.maven.org/maven2/org/jacoco/org.jacoco.core/0.7.4.201502262128/org.jacoco.core-0.7.4.201502262128.jar
Download https://repo1.maven.org/maven2/com/android/tools/build/builder-model/1.5.0/builder-model-1.5.0.jar
Download https://repo1.maven.org/maven2/com/android/tools/build/builder-test-api/1.5.0/builder-test-api-1.5.0.jar
Download https://repo1.maven.org/maven2/com/android/tools/sdklib/24.5.0/sdklib-24.5.0.jar
Download https://repo1.maven.org/maven2/com/android/tools/sdk-common/24.5.0/sdk-common-24.5.0.jar
Download https://repo1.maven.org/maven2/com/android/tools/common/24.5.0/common-24.5.0.jar
Download https://repo1.maven.org/maven2/com/android/tools/build/manifest-merger/24.5.0/manifest-merger-24.5.0.jar
Download https://repo1.maven.org/maven2/com/android/tools/ddms/ddmlib/24.5.0/ddmlib-24.5.0.jar
Download https://repo1.maven.org/maven2/com/android/tools/jack/jack-api/0.9.0/jack-api-0.9.0.jar
Download https://repo1.maven.org/maven2/com/android/tools/jill/jill-api/0.9.0/jill-api-0.9.0.jar
Download https://repo1.maven.org/maven2/com/squareup/javawriter/2.5.0/javawriter-2.5.0.jar
Download https://repo1.maven.org/maven2/org/bouncycastle/bcpkix-jdk15on/1.48/bcpkix-jdk15on-1.48.jar
Download https://repo1.maven.org/maven2/org/bouncycastle/bcprov-jdk15on/1.48/bcprov-jdk15on-1.48.jar
Download https://repo1.maven.org/maven2/org/ow2/asm/asm/5.0.3/asm-5.0.3.jar
Download https://repo1.maven.org/maven2/org/ow2/asm/asm-tree/5.0.3/asm-tree-5.0.3.jar
Download https://repo1.maven.org/maven2/org/antlr/antlr-runtime/3.5.2/antlr-runtime-3.5.2.jar
Download https://repo1.maven.org/maven2/org/antlr/antlr/3.5.2/antlr-3.5.2.jar
Download https://repo1.maven.org/maven2/com/android/tools/lint/lint-checks/24.5.0/lint-checks-24.5.0.jar
Download https://repo1.maven.org/maven2/org/eclipse/jdt/core/compiler/ecj/4.4.2/ecj-4.4.2.jar
Download https://repo1.maven.org/maven2/com/android/tools/annotations/24.5.0/annotations-24.5.0.jar
Download https://repo1.maven.org/maven2/com/google/guava/guava/17.0/guava-17.0.jar
Download https://repo1.maven.org/maven2/com/android/databinding/baseLibrary/1.0-rc5/baseLibrary-1.0-rc5.jar
Download https://repo1.maven.org/maven2/org/apache/commons/commons-lang3/3.3.2/commons-lang3-3.3.2.jar
Download https://repo1.maven.org/maven2/com/tunnelvisionlabs/antlr4/4.5/antlr4-4.5.jar
Download https://repo1.maven.org/maven2/commons-io/commons-io/2.4/commons-io-2.4.jar
Download https://repo1.maven.org/maven2/com/googlecode/juniversalchardet/juniversalchardet/1.0.3/juniversalchardet-1.0.3.jar
Download https://repo1.maven.org/maven2/net/sf/proguard/proguard-base/5.2.1/proguard-base-5.2.1.jar
Download https://repo1.maven.org/maven2/org/ow2/asm/asm-debug-all/5.0.1/asm-debug-all-5.0.1.jar
Download https://repo1.maven.org/maven2/com/android/tools/layoutlib/layoutlib-api/24.5.0/layoutlib-api-24.5.0.jar
Download https://repo1.maven.org/maven2/com/android/tools/dvlib/24.5.0/dvlib-24.5.0.jar
Download https://repo1.maven.org/maven2/com/google/code/gson/gson/2.2.4/gson-2.2.4.jar
Download https://repo1.maven.org/maven2/org/apache/commons/commons-compress/1.8.1/commons-compress-1.8.1.jar
Download https://repo1.maven.org/maven2/org/apache/httpcomponents/httpclient/4.1.1/httpclient-4.1.1.jar
Download https://repo1.maven.org/maven2/org/apache/httpcomponents/httpmime/4.1/httpmime-4.1.jar
Download https://repo1.maven.org/maven2/net/sf/kxml/kxml2/2.3.0/kxml2-2.3.0.jar
Download https://repo1.maven.org/maven2/org/antlr/ST4/4.0.8/ST4-4.0.8.jar
Download https://repo1.maven.org/maven2/com/android/tools/lint/lint-api/24.5.0/lint-api-24.5.0.jar
Download https://repo1.maven.org/maven2/org/ow2/asm/asm-analysis/5.0.3/asm-analysis-5.0.3.jar
Download https://repo1.maven.org/maven2/com/tunnelvisionlabs/antlr4-runtime/4.5/antlr4-runtime-4.5.jar
Download https://repo1.maven.org/maven2/com/tunnelvisionlabs/antlr4-annotations/4.5/antlr4-annotations-4.5.jar
Download https://repo1.maven.org/maven2/com/intellij/annotations/12.0/annotations-12.0.jar
Download https://repo1.maven.org/maven2/org/apache/httpcomponents/httpcore/4.1/httpcore-4.1.jar
Download https://repo1.maven.org/maven2/commons-logging/commons-logging/1.1.1/commons-logging-1.1.1.jar
Download https://repo1.maven.org/maven2/commons-codec/commons-codec/1.4/commons-codec-1.4.jar
Download https://repo1.maven.org/maven2/com/android/tools/external/lombok/lombok-ast/0.2.3/lombok-ast-0.2.3.jar
Download https://repo1.maven.org/maven2/org/abego/treelayout/org.abego.treelayout.core/1.0.1/org.abego.treelayout.core-1.0.1.jar
Compiling build file '.../cordova_project/platforms/android/build.gradle' using BuildScriptTransformer.
Creating configuration compile
Creating configuration apk
Creating configuration provided
Creating configuration wearApp
Creating configuration androidTestCompile
Creating configuration androidTestApk
Creating configuration androidTestProvided
Creating configuration androidTestWearApp
Creating configuration testCompile
Creating configuration testApk
Creating configuration testProvided
Creating configuration testWearApp
Creating configuration debugCompile
Creating configuration debugApk
Creating configuration debugProvided
Creating configuration debugWearApp
Creating configuration testDebugCompile
Creating configuration testDebugApk
Creating configuration testDebugProvided
Creating configuration testDebugWearApp
Creating configuration releaseCompile
Creating configuration releaseApk
Creating configuration releaseProvided
Creating configuration releaseWearApp
Creating configuration testReleaseCompile
Creating configuration testReleaseApk
Creating configuration testReleaseProvided
Creating configuration testReleaseWearApp
Compiling script '.../cordova_project/platforms/android/CordovaLib/cordova.gradle' using StatementExtractingScriptTransformer.
Compiling script '.../cordova_project/platforms/android/CordovaLib/cordova.gradle' using BuildScriptTransformer.
Compiling script '.../cordova_project/platforms/android/cordova-plugin-crosswalk-webview/crosswalk-xwalk.gradle' using StatementExtractingScriptTransformer.
Compiling script '.../cordova_project/platforms/android/cordova-plugin-crosswalk-webview/crosswalk-xwalk.gradle' using BuildScriptTransformer.
null
Creating configuration armv7Compile
Creating configuration armv7Apk
Creating configuration armv7Provided
Creating configuration armv7WearApp
Creating configuration androidTestArmv7Compile
Creating configuration androidTestArmv7Apk
Creating configuration androidTestArmv7Provided
Creating configuration androidTestArmv7WearApp
Creating configuration testArmv7Compile
Creating configuration testArmv7Apk
Creating configuration testArmv7Provided
Creating configuration testArmv7WearApp
Creating configuration x86Compile
Creating configuration x86Apk
Creating configuration x86Provided
Creating configuration x86WearApp
Creating configuration androidTestX86Compile
Creating configuration androidTestX86Apk
Creating configuration androidTestX86Provided
Creating configuration androidTestX86WearApp
Creating configuration testX86Compile
Creating configuration testX86Apk
Creating configuration testX86Provided
Creating configuration testX86WearApp
org.xwalk:xwalk_core_library:19+
Creating configuration armv7DebugCompile
Creating configuration armv7DebugApk
Creating configuration armv7DebugProvided
Creating configuration armv7DebugWearApp
Evaluating project ':CordovaLib' using build file '.../cordova_project/platforms/android/CordovaLib/build.gradle'.
Compiling build file '.../cordova_project/platforms/android/CordovaLib/build.gradle' using StatementExtractingScriptTransformer.
Compiling build file '.../cordova_project/platforms/android/CordovaLib/build.gradle' using BuildScriptTransformer.
Creating configuration publish
Creating configuration androidTestPublish
Creating configuration testPublish
Creating configuration debugPublish
Creating configuration testDebugPublish
Creating configuration releasePublish
Creating configuration testReleasePublish
Resource missing. [HTTP GET: https://repo1.maven.org/maven2/org/xwalk/xwalk_core_library/maven-metadata.xml]
Resource missing. [HTTP GET: https://repo1.maven.org/maven2/org/xwalk/xwalk_core_library/]
Download https://download.01.org/crosswalk/releases/crosswalk/android/maven2/org/xwalk/xwalk_core_library/19.49.514.5/xwalk_core_library-19.49.514.5.pom
Resource missing. [HTTP GET: https://repo1.maven.org/maven2/com/android/support/support-v4/maven-metadata.xml]
Resource missing. [HTTP GET: https://repo1.maven.org/maven2/com/android/support/support-v4/]
Resource missing. [HTTP GET: https://download.01.org/crosswalk/releases/crosswalk/android/maven2/com/android/support/support-v4/maven-metadata.xml]
Resource missing. [HTTP GET: https://download.01.org/crosswalk/releases/crosswalk/android/maven2/com/android/support/support-v4/]
Resource missing. [HTTP GET: https://repo1.maven.org/maven2/com/android/support/support-compat/25.1.0/support-compat-25.1.0.pom]
Resource missing. [HTTP HEAD: https://repo1.maven.org/maven2/com/android/support/support-compat/25.1.0/support-compat-25.1.0.aar]
Resource missing. [HTTP GET: https://download.01.org/crosswalk/releases/crosswalk/android/maven2/com/android/support/support-compat/25.1.0/support-compat-25.1.0.pom]
Resource missing. [HTTP HEAD: https://download.01.org/crosswalk/releases/crosswalk/android/maven2/com/android/support/support-compat/25.1.0/support-compat-25.1.0.aar]
Resource missing. [HTTP GET: https://repo1.maven.org/maven2/com/android/support/support-media-compat/25.1.0/support-media-compat-25.1.0.pom]
Resource missing. [HTTP HEAD: https://repo1.maven.org/maven2/com/android/support/support-media-compat/25.1.0/support-media-compat-25.1.0.aar]
Resource missing. [HTTP GET: https://download.01.org/crosswalk/releases/crosswalk/android/maven2/com/android/support/support-media-compat/25.1.0/support-media-compat-25.1.0.pom]
Resource missing. [HTTP HEAD: https://download.01.org/crosswalk/releases/crosswalk/android/maven2/com/android/support/support-media-compat/25.1.0/support-media-compat-25.1.0.aar]
Resource missing. [HTTP GET: https://repo1.maven.org/maven2/com/android/support/support-core-utils/25.1.0/support-core-utils-25.1.0.pom]
Resource missing. [HTTP HEAD: https://repo1.maven.org/maven2/com/android/support/support-core-utils/25.1.0/support-core-utils-25.1.0.aar]
Resource missing. [HTTP GET: https://download.01.org/crosswalk/releases/crosswalk/android/maven2/com/android/support/support-core-utils/25.1.0/support-core-utils-25.1.0.pom]
Resource missing. [HTTP HEAD: https://download.01.org/crosswalk/releases/crosswalk/android/maven2/com/android/support/support-core-utils/25.1.0/support-core-utils-25.1.0.aar]
Resource missing. [HTTP GET: https://repo1.maven.org/maven2/com/android/support/support-core-ui/25.1.0/support-core-ui-25.1.0.pom]
Resource missing. [HTTP HEAD: https://repo1.maven.org/maven2/com/android/support/support-core-ui/25.1.0/support-core-ui-25.1.0.aar]
Resource missing. [HTTP GET: https://download.01.org/crosswalk/releases/crosswalk/android/maven2/com/android/support/support-core-ui/25.1.0/support-core-ui-25.1.0.pom]
Resource missing. [HTTP HEAD: https://download.01.org/crosswalk/releases/crosswalk/android/maven2/com/android/support/support-core-ui/25.1.0/support-core-ui-25.1.0.aar]
Resource missing. [HTTP GET: https://repo1.maven.org/maven2/com/android/support/support-fragment/25.1.0/support-fragment-25.1.0.pom]
Resource missing. [HTTP HEAD: https://repo1.maven.org/maven2/com/android/support/support-fragment/25.1.0/support-fragment-25.1.0.aar]
Resource missing. [HTTP GET: https://download.01.org/crosswalk/releases/crosswalk/android/maven2/com/android/support/support-fragment/25.1.0/support-fragment-25.1.0.pom]
Resource missing. [HTTP HEAD: https://download.01.org/crosswalk/releases/crosswalk/android/maven2/com/android/support/support-fragment/25.1.0/support-fragment-25.1.0.aar]
Resource missing. [HTTP GET: https://repo1.maven.org/maven2/com/android/support/support-annotations/25.1.0/support-annotations-25.1.0.pom]
Resource missing. [HTTP HEAD: https://repo1.maven.org/maven2/com/android/support/support-annotations/25.1.0/support-annotations-25.1.0.jar]
Resource missing. [HTTP GET: https://download.01.org/crosswalk/releases/crosswalk/android/maven2/com/android/support/support-annotations/25.1.0/support-annotations-25.1.0.pom]
Resource missing. [HTTP HEAD: https://download.01.org/crosswalk/releases/crosswalk/android/maven2/com/android/support/support-annotations/25.1.0/support-annotations-25.1.0.jar]
Download https://download.01.org/crosswalk/releases/crosswalk/android/maven2/org/xwalk/xwalk_core_library/19.49.514.5/xwalk_core_library-19.49.514.5.aar
Creating configuration testArmv7DebugCompile
Creating configuration testArmv7DebugApk
Creating configuration testArmv7DebugProvided
Creating configuration testArmv7DebugWearApp
Creating configuration armv7ReleaseCompile
Creating configuration armv7ReleaseApk
Creating configuration armv7ReleaseProvided
Creating configuration armv7ReleaseWearApp
Creating configuration testArmv7ReleaseCompile
Creating configuration testArmv7ReleaseApk
Creating configuration testArmv7ReleaseProvided
Creating configuration testArmv7ReleaseWearApp
Creating configuration x86DebugCompile
Creating configuration x86DebugApk
Creating configuration x86DebugProvided
Creating configuration x86DebugWearApp
Creating configuration testX86DebugCompile
Creating configuration testX86DebugApk
Creating configuration testX86DebugProvided
Creating configuration testX86DebugWearApp
Creating configuration x86ReleaseCompile
Creating configuration x86ReleaseApk
Creating configuration x86ReleaseProvided
Creating configuration x86ReleaseWearApp
Creating configuration testX86ReleaseCompile
Creating configuration testX86ReleaseApk
Creating configuration testX86ReleaseProvided
Creating configuration testX86ReleaseWearApp
All projects evaluated.
Selected primary task 'cdvBuildRelease' from project :
Tasks to be executed: [task ':preBuild', task ':preArmv7ReleaseBuild', task ':checkArmv7ReleaseManifest', task ':preX86ReleaseBuild', task ':CordovaLib:preBuild', task ':CordovaLib:preReleaseBuild', task ':CordovaLib:compileReleaseNdk', task ':CordovaLib:compileLint', task ':CordovaLib:copyReleaseLint', task ':CordovaLib:mergeReleaseProguardFiles', task ':CordovaLib:packageReleaseRenderscript', task ':CordovaLib:checkReleaseManifest', task ':CordovaLib:prepareReleaseDependencies', task ':CordovaLib:compileReleaseRenderscript', task ':CordovaLib:generateReleaseResValues', task ':CordovaLib:generateReleaseResources', task ':CordovaLib:packageReleaseResources', task ':CordovaLib:compileReleaseAidl', task ':CordovaLib:generateReleaseBuildConfig', task ':CordovaLib:generateReleaseAssets', task ':CordovaLib:mergeReleaseAssets', task ':CordovaLib:processReleaseManifest', task ':CordovaLib:processReleaseResources', task ':CordovaLib:generateReleaseSources', task ':CordovaLib:compileReleaseJavaWithJavac', task ':CordovaLib:processReleaseJavaRes', task ':CordovaLib:transformResourcesWithMergeJavaResForRelease', task ':CordovaLib:transformClassesAndResourcesWithSyncLibJarsForRelease', task ':CordovaLib:mergeReleaseJniLibFolders', task ':CordovaLib:transformNative_libsWithMergeJniLibsForRelease', task ':CordovaLib:transformNative_libsWithSyncJniLibsForRelease', task ':CordovaLib:bundleRelease', task ':prepareAndroidCordovaLibUnspecifiedReleaseLibrary', task ':preArmv7DebugBuild', task ':preX86DebugBuild', task ':CordovaLib:preDebugBuild', task ':CordovaLib:compileDebugNdk', task ':CordovaLib:copyDebugLint', task ':CordovaLib:mergeDebugProguardFiles', task ':CordovaLib:packageDebugRenderscript', task ':CordovaLib:checkDebugManifest', task ':CordovaLib:prepareDebugDependencies', task ':CordovaLib:compileDebugRenderscript', task ':CordovaLib:generateDebugResValues', task ':CordovaLib:generateDebugResources', task ':CordovaLib:packageDebugResources', task ':CordovaLib:compileDebugAidl', task ':CordovaLib:generateDebugBuildConfig', task ':CordovaLib:generateDebugAssets', task ':CordovaLib:mergeDebugAssets', task ':CordovaLib:processDebugManifest', task ':CordovaLib:processDebugResources', task ':CordovaLib:generateDebugSources', task ':CordovaLib:compileDebugJavaWithJavac', task ':CordovaLib:processDebugJavaRes', task ':CordovaLib:transformResourcesWithMergeJavaResForDebug', task ':CordovaLib:transformClassesAndResourcesWithSyncLibJarsForDebug', task ':CordovaLib:mergeDebugJniLibFolders', task ':CordovaLib:transformNative_libsWithMergeJniLibsForDebug', task ':CordovaLib:transformNative_libsWithSyncJniLibsForDebug', task ':CordovaLib:bundleDebug', task ':prepareComAndroidSupportSupportCompat2510Library', task ':prepareComAndroidSupportSupportCoreUi2510Library', task ':prepareComAndroidSupportSupportCoreUtils2510Library', task ':prepareComAndroidSupportSupportFragment2510Library', task ':prepareComAndroidSupportSupportMediaCompat2510Library', task ':prepareComAndroidSupportSupportV42510Library', task ':prepareOrgXwalkXwalk_core_library19495145Library', task ':prepareArmv7ReleaseDependencies', task ':compileArmv7ReleaseAidl', task ':compileArmv7ReleaseRenderscript', task ':generateArmv7ReleaseBuildConfig', task ':generateArmv7ReleaseAssets', task ':mergeArmv7ReleaseAssets', task ':createXwalkCommandLineFileArmv7Release', task ':generateArmv7ReleaseResValues', task ':generateArmv7ReleaseResources', task ':mergeArmv7ReleaseResources', task ':processArmv7ReleaseManifest', task ':processArmv7ReleaseResources', task ':generateArmv7ReleaseSources', task ':compileArmv7ReleaseJavaWithJavac', task ':compileArmv7ReleaseNdk', task ':compileArmv7ReleaseSources', task ':transformClassesWithDexForArmv7Release', task ':mergeArmv7ReleaseJniLibFolders', task ':transformNative_libsWithMergeJniLibsForArmv7Release', task ':processArmv7ReleaseJavaRes', task ':transformResourcesWithMergeJavaResForArmv7Release', task ':packageArmv7Release', task ':assembleArmv7Release', task ':checkX86ReleaseManifest', task ':prepareX86ReleaseDependencies', task ':compileX86ReleaseAidl', task ':compileX86ReleaseRenderscript', task ':generateX86ReleaseBuildConfig', task ':generateX86ReleaseAssets', task ':mergeX86ReleaseAssets', task ':createXwalkCommandLineFileX86Release', task ':generateX86ReleaseResValues', task ':generateX86ReleaseResources', task ':mergeX86ReleaseResources', task ':processX86ReleaseManifest', task ':processX86ReleaseResources', task ':generateX86ReleaseSources', task ':compileX86ReleaseJavaWithJavac', task ':compileX86ReleaseNdk', task ':compileX86ReleaseSources', task ':transformClassesWithDexForX86Release', task ':mergeX86ReleaseJniLibFolders', task ':transformNative_libsWithMergeJniLibsForX86Release', task ':processX86ReleaseJavaRes', task ':transformResourcesWithMergeJavaResForX86Release', task ':packageX86Release', task ':assembleX86Release', task ':assembleRelease', task ':cdvBuildRelease']
:preBuild (Thread[main,5,main]) started.
:preBuild
Skipping task ':preBuild' as it has no actions.
:preBuild UP-TO-DATE
:preBuild (Thread[main,5,main]) completed. Took 0.015 secs.
:preArmv7ReleaseBuild (Thread[main,5,main]) started.
Skipping task ':preArmv7ReleaseBuild' as it has no actions.
:preArmv7ReleaseBuild UP-TO-DATE
:preArmv7ReleaseBuild (Thread[main,5,main]) completed. Took 0.0 secs.
:checkArmv7ReleaseManifest (Thread[main,5,main]) started.
Executing task ':checkArmv7ReleaseManifest' (up-to-date check took 0.0 secs) due to:
  Task has not declared any outputs.
:checkArmv7ReleaseManifest (Thread[main,5,main]) completed. Took 0.003 secs.
:preX86ReleaseBuild (Thread[main,5,main]) started.
:preX86ReleaseBuild
Skipping task ':preX86ReleaseBuild' as it has no actions.
:preX86ReleaseBuild UP-TO-DATE
:preX86ReleaseBuild (Thread[main,5,main]) completed. Took 0.0 secs.
:CordovaLib:preBuild (Thread[main,5,main]) started.
Skipping task ':CordovaLib:preBuild' as it has no actions.
:CordovaLib:preBuild UP-TO-DATE
:CordovaLib:preBuild (Thread[main,5,main]) completed. Took 0.001 secs.
:CordovaLib:preReleaseBuild (Thread[main,5,main]) started.
Skipping task ':CordovaLib:preReleaseBuild' as it has no actions.
:CordovaLib:preReleaseBuild UP-TO-DATE
:CordovaLib:preReleaseBuild (Thread[main,5,main]) completed. Took 0.001 secs.
:CordovaLib:compileReleaseNdk (Thread[main,5,main]) started.
Skipping task ':CordovaLib:compileReleaseNdk' as it has no source files.
:CordovaLib:compileReleaseNdk UP-TO-DATE
:CordovaLib:compileReleaseNdk (Thread[main,5,main]) completed. Took 0.0 secs.
:CordovaLib:compileLint (Thread[main,5,main]) started.
Executing task ':CordovaLib:compileLint' (up-to-date check took 0.0 secs) due to:
:CordovaLib:compileLint (Thread[main,5,main]) completed. Took 0.001 secs.
:CordovaLib:copyReleaseLint (Thread[main,5,main]) started.
Skipping task ':CordovaLib:copyReleaseLint' as it has no source files.
:CordovaLib:copyReleaseLint UP-TO-DATE
:CordovaLib:copyReleaseLint (Thread[main,5,main]) completed. Took 0.0 secs.
:CordovaLib:mergeReleaseProguardFiles (Thread[main,5,main]) started.
Executing task ':CordovaLib:mergeReleaseProguardFiles' (up-to-date check took 0.009 secs) due to:
  No history is available.
:CordovaLib:mergeReleaseProguardFiles (Thread[main,5,main]) completed. Took 0.016 secs.
:CordovaLib:packageReleaseRenderscript (Thread[main,5,main]) started.
Skipping task ':CordovaLib:packageReleaseRenderscript' as it has no source files.
:CordovaLib:packageReleaseRenderscript UP-TO-DATE
:CordovaLib:packageReleaseRenderscript (Thread[main,5,main]) completed. Took 0.004 secs.
:CordovaLib:checkReleaseManifest (Thread[main,5,main]) started.
Executing task ':CordovaLib:checkReleaseManifest' (up-to-date check took 0.0 secs) due to:
:CordovaLib:checkReleaseManifest (Thread[main,5,main]) completed. Took 0.0 secs.
:CordovaLib:prepareReleaseDependencies (Thread[main,5,main]) started.
Executing task ':CordovaLib:prepareReleaseDependencies' (up-to-date check took 0.0 secs) due to:
:CordovaLib:prepareReleaseDependencies (Thread[main,5,main]) completed. Took 0.001 secs.
:CordovaLib:compileReleaseRenderscript (Thread[main,5,main]) started.
Executing task ':CordovaLib:compileReleaseRenderscript' (up-to-date check took 0.006 secs) due to:
:CordovaLib:compileReleaseRenderscript (Thread[main,5,main]) completed. Took 0.033 secs.
:CordovaLib:generateReleaseResValues (Thread[main,5,main]) started.
Executing task ':CordovaLib:generateReleaseResValues' (up-to-date check took 0.0 secs) due to:
:CordovaLib:generateReleaseResValues (Thread[main,5,main]) completed. Took 0.005 secs.
:CordovaLib:generateReleaseResources (Thread[main,5,main]) started.
Skipping task ':CordovaLib:generateReleaseResources' as it has no actions.
:CordovaLib:generateReleaseResources (Thread[main,5,main]) completed. Took 0.0 secs.
:CordovaLib:packageReleaseResources (Thread[main,5,main]) started.
Executing task ':CordovaLib:packageReleaseResources' (up-to-date check took 0.001 secs) due to:
All input files are considered out-of-date for incremental task ':CordovaLib:packageReleaseResources'.
Unable do incremental execution: full task run
QueuedCruncher is using .../android-sdk/build-tools/25.0.0/aapt
:CordovaLib:packageReleaseResources (Thread[main,5,main]) completed. Took 0.022 secs.
:CordovaLib:compileReleaseAidl (Thread[main,5,main]) started.
Executing task ':CordovaLib:compileReleaseAidl' (up-to-date check took 0.001 secs) due to:
All input files are considered out-of-date for incremental task ':CordovaLib:compileReleaseAidl'.
:CordovaLib:compileReleaseAidl (Thread[main,5,main]) completed. Took 0.005 secs.
:CordovaLib:generateReleaseBuildConfig (Thread[main,5,main]) started.
Executing task ':CordovaLib:generateReleaseBuildConfig' (up-to-date check took 0.001 secs) due to:
:CordovaLib:generateReleaseBuildConfig (Thread[main,5,main]) completed. Took 0.016 secs.
:CordovaLib:generateReleaseAssets (Thread[main,5,main]) started.
Skipping task ':CordovaLib:generateReleaseAssets' as it has no actions.
:CordovaLib:generateReleaseAssets UP-TO-DATE
:CordovaLib:generateReleaseAssets (Thread[main,5,main]) completed. Took 0.001 secs.
:CordovaLib:mergeReleaseAssets (Thread[main,5,main]) started.
Executing task ':CordovaLib:mergeReleaseAssets' (up-to-date check took 0.001 secs) due to:
All input files are considered out-of-date for incremental task ':CordovaLib:mergeReleaseAssets'.
:CordovaLib:mergeReleaseAssets (Thread[main,5,main]) completed. Took 0.012 secs.
:CordovaLib:processReleaseManifest (Thread[main,5,main]) started.
Executing task ':CordovaLib:processReleaseManifest' (up-to-date check took 0.001 secs) due to:
All input files are considered out-of-date for incremental task ':CordovaLib:processReleaseManifest'.
Merging main manifest .../cordova_project/platforms/android/CordovaLib/AndroidManifest.xml
Merging result:SUCCESS
Merged manifest saved to .../cordova_project/platforms/android/CordovaLib/build/intermediates/bundles/release/AndroidManifest.xml
:CordovaLib:processReleaseManifest (Thread[main,5,main]) completed. Took 0.048 secs.
:CordovaLib:processReleaseResources (Thread[main,5,main]) started.
Executing task ':CordovaLib:processReleaseResources' (up-to-date check took 0.002 secs) due to:
All input files are considered out-of-date for incremental task ':CordovaLib:processReleaseResources'.
Starting process 'command '.../android-sdk/build-tools/25.0.0/aapt''. Working directory: .../cordova_project/platforms/android/CordovaLib Command: .../android-sdk/build-tools/25.0.0/aapt package -f --no-crunch -I .../android-sdk/platforms/android-23/android.jar -M .../cordova_project/platforms/android/CordovaLib/build/intermediates/bundles/release/aapt/AndroidManifest.xml -S .../cordova_project/platforms/android/CordovaLib/build/intermediates/bundles/release/res -A .../cordova_project/platforms/android/CordovaLib/build/intermediates/bundles/release/assets -m -J .../cordova_project/platforms/android/CordovaLib/build/generated/source/r/release --custom-package org.apache.cordova --non-constant-id -0 apk --output-text-symbols .../cordova_project/platforms/android/CordovaLib/build/intermediates/bundles/release
Successfully started process 'command '.../android-sdk/build-tools/25.0.0/aapt''
:CordovaLib:processReleaseResources (Thread[main,5,main]) completed. Took 0.367 secs.
:CordovaLib:generateReleaseSources (Thread[main,5,main]) started.
Skipping task ':CordovaLib:generateReleaseSources' as it has no actions.
:CordovaLib:generateReleaseSources (Thread[main,5,main]) completed. Took 0.0 secs.
:CordovaLib:compileReleaseJavaWithJavac (Thread[main,5,main]) started.
Executing task ':CordovaLib:compileReleaseJavaWithJavac' (up-to-date check took 0.004 secs) due to:
All input files are considered out-of-date for incremental task ':CordovaLib:compileReleaseJavaWithJavac'.
Compiling with JDK Java compiler API.
:CordovaLib:compileReleaseJavaWithJavac (Thread[main,5,main]) completed. Took 1.936 secs.
:CordovaLib:processReleaseJavaRes (Thread[main,5,main]) started.
Skipping task ':CordovaLib:processReleaseJavaRes' as it has no source files.
:CordovaLib:processReleaseJavaRes UP-TO-DATE
:CordovaLib:processReleaseJavaRes (Thread[main,5,main]) completed. Took 0.001 secs.
:CordovaLib:transformResourcesWithMergeJavaResForRelease (Thread[main,5,main]) started.
Executing task ':CordovaLib:transformResourcesWithMergeJavaResForRelease' (up-to-date check took 0.001 secs) due to:
All input files are considered out-of-date for incremental task ':CordovaLib:transformResourcesWithMergeJavaResForRelease'.
:CordovaLib:transformResourcesWithMergeJavaResForRelease (Thread[main,5,main]) completed. Took 0.016 secs.
:CordovaLib:transformClassesAndResourcesWithSyncLibJarsForRelease (Thread[main,5,main]) started.
Executing task ':CordovaLib:transformClassesAndResourcesWithSyncLibJarsForRelease' (up-to-date check took 0.01 secs) due to:
All input files are considered out-of-date for incremental task ':CordovaLib:transformClassesAndResourcesWithSyncLibJarsForRelease'.
:CordovaLib:transformClassesAndResourcesWithSyncLibJarsForRelease (Thread[main,5,main]) completed. Took 0.049 secs.
:CordovaLib:mergeReleaseJniLibFolders (Thread[main,5,main]) started.
Executing task ':CordovaLib:mergeReleaseJniLibFolders' (up-to-date check took 0.001 secs) due to:
All input files are considered out-of-date for incremental task ':CordovaLib:mergeReleaseJniLibFolders'.
:CordovaLib:mergeReleaseJniLibFolders (Thread[main,5,main]) completed. Took 0.007 secs.
:CordovaLib:transformNative_libsWithMergeJniLibsForRelease (Thread[main,5,main]) started.
Executing task ':CordovaLib:transformNative_libsWithMergeJniLibsForRelease' (up-to-date check took 0.001 secs) due to:
All input files are considered out-of-date for incremental task ':CordovaLib:transformNative_libsWithMergeJniLibsForRelease'.
:CordovaLib:transformNative_libsWithMergeJniLibsForRelease (Thread[main,5,main]) completed. Took 0.004 secs.
:CordovaLib:transformNative_libsWithSyncJniLibsForRelease (Thread[main,5,main]) started.
Executing task ':CordovaLib:transformNative_libsWithSyncJniLibsForRelease' (up-to-date check took 0.001 secs) due to:
All input files are considered out-of-date for incremental task ':CordovaLib:transformNative_libsWithSyncJniLibsForRelease'.
:CordovaLib:transformNative_libsWithSyncJniLibsForRelease (Thread[main,5,main]) completed. Took 0.002 secs.
:CordovaLib:bundleRelease (Thread[main,5,main]) started.
Executing task ':CordovaLib:bundleRelease' (up-to-date check took 0.001 secs) due to:
:CordovaLib:bundleRelease (Thread[main,5,main]) completed. Took 0.037 secs.
:prepareAndroidCordovaLibUnspecifiedReleaseLibrary (Thread[main,5,main]) started.
Executing task ':prepareAndroidCordovaLibUnspecifiedReleaseLibrary' (up-to-date check took 0.0 secs) due to:
:prepareAndroidCordovaLibUnspecifiedReleaseLibrary (Thread[main,5,main]) completed. Took 0.034 secs.
:preArmv7DebugBuild (Thread[main,5,main]) started.
:preArmv7DebugBuild
Skipping task ':preArmv7DebugBuild' as it has no actions.
:preArmv7DebugBuild UP-TO-DATE
:preArmv7DebugBuild (Thread[main,5,main]) completed. Took 0.001 secs.
:preX86DebugBuild (Thread[main,5,main]) started.
:preX86DebugBuild
Skipping task ':preX86DebugBuild' as it has no actions.
:preX86DebugBuild UP-TO-DATE
:preX86DebugBuild (Thread[main,5,main]) completed. Took 0.0 secs.
:CordovaLib:preDebugBuild (Thread[main,5,main]) started.
Skipping task ':CordovaLib:preDebugBuild' as it has no actions.
:CordovaLib:preDebugBuild UP-TO-DATE
:CordovaLib:preDebugBuild (Thread[main,5,main]) completed. Took 0.001 secs.
:CordovaLib:compileDebugNdk (Thread[main,5,main]) started.
Skipping task ':CordovaLib:compileDebugNdk' as it has no source files.
:CordovaLib:compileDebugNdk UP-TO-DATE
:CordovaLib:compileDebugNdk (Thread[main,5,main]) completed. Took 0.0 secs.
:CordovaLib:copyDebugLint (Thread[main,5,main]) started.
Skipping task ':CordovaLib:copyDebugLint' as it has no source files.
:CordovaLib:copyDebugLint UP-TO-DATE
:CordovaLib:copyDebugLint (Thread[main,5,main]) completed. Took 0.001 secs.
:CordovaLib:mergeDebugProguardFiles (Thread[main,5,main]) started.
Executing task ':CordovaLib:mergeDebugProguardFiles' (up-to-date check took 0.001 secs) due to:
:CordovaLib:mergeDebugProguardFiles (Thread[main,5,main]) completed. Took 0.003 secs.
:CordovaLib:packageDebugRenderscript (Thread[main,5,main]) started.
Skipping task ':CordovaLib:packageDebugRenderscript' as it has no source files.
:CordovaLib:packageDebugRenderscript UP-TO-DATE
:CordovaLib:packageDebugRenderscript (Thread[main,5,main]) completed. Took 0.002 secs.
:CordovaLib:checkDebugManifest (Thread[main,5,main]) started.
Executing task ':CordovaLib:checkDebugManifest' (up-to-date check took 0.0 secs) due to:
:CordovaLib:checkDebugManifest (Thread[main,5,main]) completed. Took 0.001 secs.
:CordovaLib:prepareDebugDependencies (Thread[main,5,main]) started.
Executing task ':CordovaLib:prepareDebugDependencies' (up-to-date check took 0.0 secs) due to:
:CordovaLib:prepareDebugDependencies (Thread[main,5,main]) completed. Took 0.0 secs.
:CordovaLib:compileDebugRenderscript (Thread[main,5,main]) started.
Executing task ':CordovaLib:compileDebugRenderscript' (up-to-date check took 0.003 secs) due to:
:CordovaLib:compileDebugRenderscript (Thread[main,5,main]) completed. Took 0.012 secs.
:CordovaLib:generateDebugResValues (Thread[main,5,main]) started.
Executing task ':CordovaLib:generateDebugResValues' (up-to-date check took 0.0 secs) due to:
:CordovaLib:generateDebugResValues (Thread[main,5,main]) completed. Took 0.003 secs.
:CordovaLib:generateDebugResources (Thread[main,5,main]) started.
Skipping task ':CordovaLib:generateDebugResources' as it has no actions.
:CordovaLib:generateDebugResources (Thread[main,5,main]) completed. Took 0.001 secs.
:CordovaLib:packageDebugResources (Thread[main,5,main]) started.
Executing task ':CordovaLib:packageDebugResources' (up-to-date check took 0.002 secs) due to:
All input files are considered out-of-date for incremental task ':CordovaLib:packageDebugResources'.
:CordovaLib:packageDebugResources (Thread[main,5,main]) completed. Took 0.007 secs.
:CordovaLib:compileDebugAidl (Thread[main,5,main]) started.
Executing task ':CordovaLib:compileDebugAidl' (up-to-date check took 0.001 secs) due to:
All input files are considered out-of-date for incremental task ':CordovaLib:compileDebugAidl'.
:CordovaLib:compileDebugAidl (Thread[main,5,main]) completed. Took 0.005 secs.
:CordovaLib:generateDebugBuildConfig (Thread[main,5,main]) started.
Executing task ':CordovaLib:generateDebugBuildConfig' (up-to-date check took 0.0 secs) due to:
:CordovaLib:generateDebugBuildConfig (Thread[main,5,main]) completed. Took 0.007 secs.
:CordovaLib:generateDebugAssets (Thread[main,5,main]) started.
Skipping task ':CordovaLib:generateDebugAssets' as it has no actions.
:CordovaLib:generateDebugAssets UP-TO-DATE
:CordovaLib:generateDebugAssets (Thread[main,5,main]) completed. Took 0.0 secs.
:CordovaLib:mergeDebugAssets (Thread[main,5,main]) started.
Executing task ':CordovaLib:mergeDebugAssets' (up-to-date check took 0.001 secs) due to:
All input files are considered out-of-date for incremental task ':CordovaLib:mergeDebugAssets'.
:CordovaLib:mergeDebugAssets (Thread[main,5,main]) completed. Took 0.005 secs.
:CordovaLib:processDebugManifest (Thread[main,5,main]) started.
Executing task ':CordovaLib:processDebugManifest' (up-to-date check took 0.001 secs) due to:
All input files are considered out-of-date for incremental task ':CordovaLib:processDebugManifest'.
Merged manifest saved to .../cordova_project/platforms/android/CordovaLib/build/intermediates/bundles/debug/AndroidManifest.xml
:CordovaLib:processDebugManifest (Thread[main,5,main]) completed. Took 0.008 secs.
:CordovaLib:processDebugResources (Thread[main,5,main]) started.
Executing task ':CordovaLib:processDebugResources' (up-to-date check took 0.009 secs) due to:
All input files are considered out-of-date for incremental task ':CordovaLib:processDebugResources'.
Starting process 'command '.../android-sdk/build-tools/25.0.0/aapt''. Working directory: .../cordova_project/platforms/android/CordovaLib Command: .../android-sdk/build-tools/25.0.0/aapt package -f --no-crunch -I .../android-sdk/platforms/android-23/android.jar -M .../cordova_project/platforms/android/CordovaLib/build/intermediates/bundles/debug/aapt/AndroidManifest.xml -S .../cordova_project/platforms/android/CordovaLib/build/intermediates/bundles/debug/res -A .../cordova_project/platforms/android/CordovaLib/build/intermediates/bundles/debug/assets -m -J .../cordova_project/platforms/android/CordovaLib/build/generated/source/r/debug --debug-mode --custom-package org.apache.cordova --non-constant-id -0 apk --output-text-symbols .../cordova_project/platforms/android/CordovaLib/build/intermediates/bundles/debug
:CordovaLib:processDebugResources (Thread[main,5,main]) completed. Took 0.038 secs.
:CordovaLib:generateDebugSources (Thread[main,5,main]) started.
Skipping task ':CordovaLib:generateDebugSources' as it has no actions.
:CordovaLib:generateDebugSources (Thread[main,5,main]) completed. Took 0.0 secs.
:CordovaLib:compileDebugJavaWithJavac (Thread[main,5,main]) started.
Executing task ':CordovaLib:compileDebugJavaWithJavac' (up-to-date check took 0.007 secs) due to:
All input files are considered out-of-date for incremental task ':CordovaLib:compileDebugJavaWithJavac'.
:CordovaLib:compileDebugJavaWithJavac (Thread[main,5,main]) completed. Took 0.523 secs.
:CordovaLib:processDebugJavaRes (Thread[main,5,main]) started.
Skipping task ':CordovaLib:processDebugJavaRes' as it has no source files.
:CordovaLib:processDebugJavaRes UP-TO-DATE
:CordovaLib:processDebugJavaRes (Thread[main,5,main]) completed. Took 0.002 secs.
:CordovaLib:transformResourcesWithMergeJavaResForDebug (Thread[main,5,main]) started.
Executing task ':CordovaLib:transformResourcesWithMergeJavaResForDebug' (up-to-date check took 0.0 secs) due to:
All input files are considered out-of-date for incremental task ':CordovaLib:transformResourcesWithMergeJavaResForDebug'.
:CordovaLib:transformResourcesWithMergeJavaResForDebug (Thread[main,5,main]) completed. Took 0.003 secs.
:CordovaLib:transformClassesAndResourcesWithSyncLibJarsForDebug (Thread[main,5,main]) started.
Executing task ':CordovaLib:transformClassesAndResourcesWithSyncLibJarsForDebug' (up-to-date check took 0.005 secs) due to:
All input files are considered out-of-date for incremental task ':CordovaLib:transformClassesAndResourcesWithSyncLibJarsForDebug'.
:CordovaLib:transformClassesAndResourcesWithSyncLibJarsForDebug (Thread[main,5,main]) completed. Took 0.035 secs.
:CordovaLib:mergeDebugJniLibFolders (Thread[main,5,main]) started.
Executing task ':CordovaLib:mergeDebugJniLibFolders' (up-to-date check took 0.001 secs) due to:
All input files are considered out-of-date for incremental task ':CordovaLib:mergeDebugJniLibFolders'.
:CordovaLib:mergeDebugJniLibFolders (Thread[main,5,main]) completed. Took 0.007 secs.
:CordovaLib:transformNative_libsWithMergeJniLibsForDebug (Thread[main,5,main]) started.
Executing task ':CordovaLib:transformNative_libsWithMergeJniLibsForDebug' (up-to-date check took 0.001 secs) due to:
All input files are considered out-of-date for incremental task ':CordovaLib:transformNative_libsWithMergeJniLibsForDebug'.
:CordovaLib:transformNative_libsWithMergeJniLibsForDebug (Thread[main,5,main]) completed. Took 0.003 secs.
:CordovaLib:transformNative_libsWithSyncJniLibsForDebug (Thread[main,5,main]) started.
Executing task ':CordovaLib:transformNative_libsWithSyncJniLibsForDebug' (up-to-date check took 0.0 secs) due to:
All input files are considered out-of-date for incremental task ':CordovaLib:transformNative_libsWithSyncJniLibsForDebug'.
:CordovaLib:transformNative_libsWithSyncJniLibsForDebug (Thread[main,5,main]) completed. Took 0.001 secs.
:CordovaLib:bundleDebug (Thread[main,5,main]) started.
Executing task ':CordovaLib:bundleDebug' (up-to-date check took 0.001 secs) due to:
:CordovaLib:bundleDebug (Thread[main,5,main]) completed. Took 0.016 secs.
:prepareComAndroidSupportSupportCompat2510Library (Thread[main,5,main]) started.
Executing task ':prepareComAndroidSupportSupportCompat2510Library' (up-to-date check took 0.013 secs) due to:
:prepareComAndroidSupportSupportCompat2510Library (Thread[main,5,main]) completed. Took 0.031 secs.
:prepareComAndroidSupportSupportCoreUi2510Library (Thread[main,5,main]) started.
Executing task ':prepareComAndroidSupportSupportCoreUi2510Library' (up-to-date check took 0.005 secs) due to:
:prepareComAndroidSupportSupportCoreUi2510Library (Thread[main,5,main]) completed. Took 0.018 secs.
:prepareComAndroidSupportSupportCoreUtils2510Library (Thread[main,5,main]) started.
Executing task ':prepareComAndroidSupportSupportCoreUtils2510Library' (up-to-date check took 0.004 secs) due to:
:prepareComAndroidSupportSupportCoreUtils2510Library (Thread[main,5,main]) completed. Took 0.01 secs.
:prepareComAndroidSupportSupportFragment2510Library (Thread[main,5,main]) started.
Executing task ':prepareComAndroidSupportSupportFragment2510Library' (up-to-date check took 0.005 secs) due to:
:prepareComAndroidSupportSupportFragment2510Library (Thread[main,5,main]) completed. Took 0.013 secs.
:prepareComAndroidSupportSupportMediaCompat2510Library (Thread[main,5,main]) started.
Executing task ':prepareComAndroidSupportSupportMediaCompat2510Library' (up-to-date check took 0.006 secs) due to:
:prepareComAndroidSupportSupportMediaCompat2510Library (Thread[main,5,main]) completed. Took 0.021 secs.
:prepareComAndroidSupportSupportV42510Library (Thread[main,5,main]) started.
Executing task ':prepareComAndroidSupportSupportV42510Library' (up-to-date check took 0.008 secs) due to:
:prepareComAndroidSupportSupportV42510Library (Thread[main,5,main]) completed. Took 0.016 secs.
:prepareOrgXwalkXwalk_core_library19495145Library (Thread[main,5,main]) started.
Executing task ':prepareOrgXwalkXwalk_core_library19495145Library' (up-to-date check took 0.157 secs) due to:
:prepareOrgXwalkXwalk_core_library19495145Library (Thread[main,5,main]) completed. Took 1.48 secs.
:prepareArmv7ReleaseDependencies (Thread[main,5,main]) started.
Executing task ':prepareArmv7ReleaseDependencies' (up-to-date check took 0.0 secs) due to:
:prepareArmv7ReleaseDependencies (Thread[main,5,main]) completed. Took 0.0 secs.
:compileArmv7ReleaseAidl (Thread[main,5,main]) started.
Executing task ':compileArmv7ReleaseAidl' (up-to-date check took 0.002 secs) due to:
All input files are considered out-of-date for incremental task ':compileArmv7ReleaseAidl'.
:compileArmv7ReleaseAidl (Thread[main,5,main]) completed. Took 0.004 secs.
:compileArmv7ReleaseRenderscript (Thread[main,5,main]) started.
Executing task ':compileArmv7ReleaseRenderscript' (up-to-date check took 0.003 secs) due to:
:compileArmv7ReleaseRenderscript (Thread[main,5,main]) completed. Took 0.008 secs.
:generateArmv7ReleaseBuildConfig (Thread[main,5,main]) started.
Executing task ':generateArmv7ReleaseBuildConfig' (up-to-date check took 0.001 secs) due to:
:generateArmv7ReleaseBuildConfig (Thread[main,5,main]) completed. Took 0.007 secs.
:generateArmv7ReleaseAssets (Thread[main,5,main]) started.
Skipping task ':generateArmv7ReleaseAssets' as it has no actions.
:generateArmv7ReleaseAssets UP-TO-DATE
:generateArmv7ReleaseAssets (Thread[main,5,main]) completed. Took 0.0 secs.
:mergeArmv7ReleaseAssets (Thread[main,5,main]) started.
Executing task ':mergeArmv7ReleaseAssets' (up-to-date check took 0.051 secs) due to:
All input files are considered out-of-date for incremental task ':mergeArmv7ReleaseAssets'.
:mergeArmv7ReleaseAssets (Thread[main,5,main]) completed. Took 0.137 secs.
:createXwalkCommandLineFileArmv7Release (Thread[main,5,main]) started.
Executing task ':createXwalkCommandLineFileArmv7Release' (up-to-date check took 0.0 secs) due to:
:createXwalkCommandLineFileArmv7Release (Thread[main,5,main]) completed. Took 0.006 secs.
:generateArmv7ReleaseResValues (Thread[main,5,main]) started.
Executing task ':generateArmv7ReleaseResValues' (up-to-date check took 0.0 secs) due to:
:generateArmv7ReleaseResValues (Thread[main,5,main]) completed. Took 0.001 secs.
:generateArmv7ReleaseResources (Thread[main,5,main]) started.
Skipping task ':generateArmv7ReleaseResources' as it has no actions.
:generateArmv7ReleaseResources (Thread[main,5,main]) completed. Took 0.001 secs.
:mergeArmv7ReleaseResources (Thread[main,5,main]) started.
Executing task ':mergeArmv7ReleaseResources' (up-to-date check took 0.017 secs) due to:
All input files are considered out-of-date for incremental task ':mergeArmv7ReleaseResources'.
:mergeArmv7ReleaseResources (Thread[main,5,main]) completed. Took 7.299 secs.
:processArmv7ReleaseManifest (Thread[main,5,main]) started.
Executing task ':processArmv7ReleaseManifest' (up-to-date check took 0.001 secs) due to:
All input files are considered out-of-date for incremental task ':processArmv7ReleaseManifest'.
Loading library manifest .../cordova_project/platforms/android/build/intermediates/exploded-aar/org.xwalk/xwalk_core_library/19.49.514.5/AndroidManifest.xml
Loading library manifest .../cordova_project/platforms/android/build/intermediates/exploded-aar/com.android.support/support-v4/25.1.0/AndroidManifest.xml
Loading library manifest .../cordova_project/platforms/android/build/intermediates/exploded-aar/com.android.support/support-compat/25.1.0/AndroidManifest.xml
Loading library manifest .../cordova_project/platforms/android/build/intermediates/exploded-aar/com.android.support/support-media-compat/25.1.0/AndroidManifest.xml
Loading library manifest .../cordova_project/platforms/android/build/intermediates/exploded-aar/com.android.support/support-core-utils/25.1.0/AndroidManifest.xml
Loading library manifest .../cordova_project/platforms/android/build/intermediates/exploded-aar/com.android.support/support-core-ui/25.1.0/AndroidManifest.xml
Loading library manifest .../cordova_project/platforms/android/build/intermediates/exploded-aar/com.android.support/support-fragment/25.1.0/AndroidManifest.xml
Loading library manifest .../cordova_project/platforms/android/build/intermediates/exploded-aar/android/CordovaLib/unspecified/release/AndroidManifest.xml
Merging main manifest .../cordova_project/platforms/android/AndroidManifest.xml
Merging library manifest .../cordova_project/platforms/android/build/intermediates/exploded-aar/org.xwalk/xwalk_core_library/19.49.514.5/AndroidManifest.xml
Merging manifest with lower [org.xwalk:xwalk_core_library:19.49.514.5] AndroidManifest.xml:1:1-9:12
Merging uses-sdk with lower [org.xwalk:xwalk_core_library:19.49.514.5] AndroidManifest.xml:6:5-8:41
Merging library manifest .../cordova_project/platforms/android/build/intermediates/exploded-aar/com.android.support/support-v4/25.1.0/AndroidManifest.xml
Merging manifest with lower [com.android.support:support-v4:25.1.0] AndroidManifest.xml:17:1-27:12
Merging uses-sdk with lower [com.android.support:support-v4:25.1.0] AndroidManifest.xml:21:5-23:54
Merging application with lower [com.android.support:support-v4:25.1.0] AndroidManifest.xml:25:5-20
Merging library manifest .../cordova_project/platforms/android/build/intermediates/exploded-aar/com.android.support/support-compat/25.1.0/AndroidManifest.xml
Merging manifest with lower [com.android.support:support-compat:25.1.0] AndroidManifest.xml:17:1-27:12
Merging uses-sdk with lower [com.android.support:support-compat:25.1.0] AndroidManifest.xml:21:5-23:58
Merging application with lower [com.android.support:support-compat:25.1.0] AndroidManifest.xml:25:5-20
Merging library manifest .../cordova_project/platforms/android/build/intermediates/exploded-aar/com.android.support/support-media-compat/25.1.0/AndroidManifest.xml
Merging manifest with lower [com.android.support:support-media-compat:25.1.0] AndroidManifest.xml:17:1-27:12
Merging uses-sdk with lower [com.android.support:support-media-compat:25.1.0] AndroidManifest.xml:21:5-23:63
Merging application with lower [com.android.support:support-media-compat:25.1.0] AndroidManifest.xml:25:5-20
Merging library manifest .../cordova_project/platforms/android/build/intermediates/exploded-aar/com.android.support/support-core-utils/25.1.0/AndroidManifest.xml
Merging manifest with lower [com.android.support:support-core-utils:25.1.0] AndroidManifest.xml:17:1-27:12
Merging uses-sdk with lower [com.android.support:support-core-utils:25.1.0] AndroidManifest.xml:21:5-23:61
Merging application with lower [com.android.support:support-core-utils:25.1.0] AndroidManifest.xml:25:5-20
Merging library manifest .../cordova_project/platforms/android/build/intermediates/exploded-aar/com.android.support/support-core-ui/25.1.0/AndroidManifest.xml
Merging manifest with lower [com.android.support:support-core-ui:25.1.0] AndroidManifest.xml:17:1-27:12
Merging uses-sdk with lower [com.android.support:support-core-ui:25.1.0] AndroidManifest.xml:21:5-23:58
Merging application with lower [com.android.support:support-core-ui:25.1.0] AndroidManifest.xml:25:5-20
Merging library manifest .../cordova_project/platforms/android/build/intermediates/exploded-aar/com.android.support/support-fragment/25.1.0/AndroidManifest.xml
Merging manifest with lower [com.android.support:support-fragment:25.1.0] AndroidManifest.xml:17:1-27:12
Merging uses-sdk with lower [com.android.support:support-fragment:25.1.0] AndroidManifest.xml:21:5-23:60
Merging application with lower [com.android.support:support-fragment:25.1.0] AndroidManifest.xml:25:5-20
Merging library manifest .../cordova_project/platforms/android/build/intermediates/exploded-aar/android/CordovaLib/unspecified/release/AndroidManifest.xml
Merging manifest with lower [android:CordovaLib:unspecified:release] AndroidManifest.xml:20:1-27:12
Merging uses-sdk with lower [android:CordovaLib:unspecified:release] AndroidManifest.xml:25:5-44
Merged manifest saved to .../cordova_project/platforms/android/build/intermediates/manifests/full/armv7/release/AndroidManifest.xml
:processArmv7ReleaseManifest (Thread[main,5,main]) completed. Took 0.047 secs.
:processArmv7ReleaseResources (Thread[main,5,main]) started.
Executing task ':processArmv7ReleaseResources' (up-to-date check took 0.011 secs) due to:
All input files are considered out-of-date for incremental task ':processArmv7ReleaseResources'.
Starting process 'command '.../android-sdk/build-tools/25.0.0/aapt''. Working directory: .../cordova_project/platforms/android Command: .../android-sdk/build-tools/25.0.0/aapt package -f --no-crunch -I .../android-sdk/platforms/android-23/android.jar -M .../cordova_project/platforms/android/build/intermediates/manifests/full/armv7/release/AndroidManifest.xml -S .../cordova_project/platforms/android/build/intermediates/res/merged/armv7/release -A .../cordova_project/platforms/android/build/intermediates/assets/armv7/release -m -J .../cordova_project/platforms/android/build/generated/source/r/armv7/release -F .../cordova_project/platforms/android/build/intermediates/res/resources-armv7-release.ap_ --custom-package xdk.intel.blank.ad.template.crosswalk -0 apk --output-text-symbols .../cordova_project/platforms/android/build/intermediates/symbols/armv7/release
Unknown source file :       Unable to add '.../cordova_project/platforms/android/build/intermediates/assets/armv7/release/www/node_modules/http-get/node_modules/semver/semver.browser.js.gz': file already in archive (try '-u'?)
Unknown source file : ERROR: unable to process assets while packaging '.../cordova_project/platforms/android/build/intermediates/res/resources-armv7-release.ap_'
:processArmv7ReleaseResources FAILED
:processArmv7ReleaseResources (Thread[main,5,main]) completed. Took 0.371 secs.
FAILURE: Build failed with an exception.
* What went wrong:
Execution failed for task ':processArmv7ReleaseResources'.
> com.android.ide.common.process.ProcessException: org.gradle.process.internal.ExecException: Process 'command '.../android-sdk/build-tools/25.0.0/aapt'' finished with non-zero exit value 1
* Try:
Run with --stacktrace option to get the stack trace. Run with --debug option to get more log output.
BUILD FAILED
Total time: 30.618 secs
Stopped 0 compiler daemon(s).
Error: Error code 1 for command: .../cordova_project/platforms/android/gradlew with args: cdvBuildRelease,-b,.../cordova_project/platforms/android/build.gradle,--no-daemon,-Pandroid.useDeprecatedNdk=true,--info
PaulF_IntelCorp
canip -- please attach the entire detailed build log as a file attachment. It's extremely difficult and time consuming to read something that large and with long lines pasted into a thread, it makes it nearly impossible to help. Please attach your log as a text file using the "Attach Files to Post" link at the bottom of the forum edit window.
