Software Archive
Read-only legacy content
17060 Discussions
Error creating Project
Ridwaan_L_1
Hi I am using intel xdk version 3759 on mac os sierra when trying to create a new project I get an error saying Illegal invocation unknown You can cancel plugin resolution and exit this project. please see attachment for screenshot Thanks in advance
Alex_Hang
New Contributor II
I also had such a problem when  I used a third-party plugin, and it solved by itself when I removed the plugin, and added it using a GIT Repo.
Alex_Hang
New Contributor II
Did you added any plugin? If so what plugin?
Try to remove it and add IT again.
Alex_Hang
New Contributor II
Ridwaan_L_1
I actually just tried to create a template project ... but it seem a reinstall fixed my problem
than you for the assist (Because it did seem to fail on plugin setup previously)
PaulF_IntelCorp
See if the solution provided at the end of this thread works > https://software.intel.com/en-us/forums/intel-xdk/topic/706360 < regarding complete uninstall of old versions as well as the new (they changed the install location, so the old versions don't always get uninstalled now).
In other words, remove /Applications/Intel XDK.app as well as /Applications/Intel XDK/Intel XDK.app from your system.
PaulF_IntelCorp
For anyone else who is reading this thread, please try the recommendation provided here > https://software.intel.com/en-us/forums/intel-xdk/topic/707314 < and report on that thread if those recommendations solved this issue for you.
