Software Archive
Read-only legacy content
Build Failed
staurt_s_
Hi, i am experiencing build failed when i try to create build it is because some plugins are failing to install which i do not know why, it was working before i update. now it is not building i am running intel xdk 3641(i think this is the latest version). can someone help me or give me any advice on what to do to try and fix this issue? i will attach sceeenshot of the error here. TIA.buildfailed.jpg
PaulF_IntelCorp
Are you specifying your plugins via the intelxdk.config.additions.xml file? Or using the plugin manager?
staurt_s_
Hi thanks for reply, im using the plugin management under cordova hybrid mobile app settings. should i use intelxdk.config.additions.xml? how?
PaulF_IntelCorp
You should be using the plugin manager, not the additions file. I recommend that you remove the two problem plugins and try adding them back, using the plugin manager.
Jerroyd_M_Intel
Hi staurt s.,
Can you provide the detailed compiled output log? That will tell us more information about why the plugins could not be installed (could not be downloaded, etc.)
--Jerroyd
