Software Archive
Read-only legacy content
17060 Discussions
Build Release Notes for Intel DHDCW v.1.0.2777
Intel_Software_Netw1
(All the changes that mention QOS support arespecifically talking about 802.1p packet tagging. Support was added in a generic fashion, but only Win32 has a default provider, using qWave).
DLNAHTTPClient:Added QOS Support
MicroAVRCP.c:Added a null check to prevent ac rash caused by a malformed device
UPnPControlPointStructs.h / UPnPControlPoint.h:Added callback to notify application if device discovery failed
ILibWebClient.h:Added QOS support
ILibParsers.h/.c:Fixed some Linux compile errors,fixed white spacing errors in XML parser
ILibParsers.c:Removed compiler warning for unreferenced variable
ILibAsyncSocket.h:Added QOS Support
UPnPControlPoint.c:Added callback to notify application if device discovery failed,added QOS Support,fixed crash on shutdown that happened when above DeviceDiscoveryFailed callback was not set.
main.c: The microstack was modified to shut down differently on Linux.The sig handler used to stop the microstack, which would then stop the threadpool when the microstack quit. This caused a race condition, because the threadpool could be doing operations on the microstack, thereforethe signal handler was modified to dispatch the microstack thread to call stopchain after it first frees the threadpool.
ILibWebClient.c:Added QOS Support
ILibAsyncSocket.c:Added QOS Support,fixed some Linux compiler errors
ILibAsyncSer verSocket.c:Fixed some linux compiler errors
