Software Archive
Read-only legacy content
Build failed for iOS
Christoff_P_
Hi, ios build fails, I have make sure the provision file and certificate is correct See attached log file
Signing Identity:     "iPhone Distribution: XXXXXXXXX (PTY) LTD (Z2X2Q65645)"
Provisioning Profile: "FleetTrack"
                      (b5bd6f76-7a84-4c22-b00f-b5437bbc9be1)
    /usr/bin/codesign --force --sign 9A7F3E10151E5C3B8B529E2A2024397D9BF6B6A6 --resource-rules=.../FleetTrack/platforms/ios/build/device/FleetTrack.app/ResourceRules.plist --entitlements .../FleetTrack/platforms/ios/build/FleetTrack.build/Release-iphoneos/FleetTrack.build/FleetTrack.app.xcent .../FleetTrack/platforms/ios/build/device/FleetTrack.app
9A7F3E10151E5C3B8B529E2A2024397D9BF6B6A6: no identity found
Command /usr/bin/codesign failed with exit code 1
** BUILD FAILED **
Elroy_A_Intel
Are you still experiencing build issues?
Christoff_P_
Hi
Yes, I am still experiencing build issues, same as above.
Signing Identity:     "iPhone Distribution: XXXXXXXXXXX(PTY) LTD (Z2X2Q65645)"
** BUILD FAILED **
Christoff_P_
Hi Elroy
Any ideas why I cant build using ios?
Elroy_A_Intel
It seems to be complaining about your distribution certificate. Did you create a provisioning profile with your distribution certificate?
Christoff_P_
Yes I did create the provisioning profile with the distribution certificate, I even tried to re-create it a few times but still with no luck
Christoff_P_
Hi
Thank you, it is working now
