Software Archive
Read-only legacy content
17060 Discussions
Build failed
Bram_H_
Hallo, today i try to build a BLE-sample project with intel XDK but i got error message:
FAILURE: Build failed with an exception.
* What went wrong:
A problem occurred configuring root project 'android'.
> Could not resolve all dependencies for configuration ':_armv7DebugCompile'.
   > Could not resolve org.xwalk:xwalk_core_library:19+.
     Required by:
         :android:unspecified
      > Failed to list versions for org.xwalk:xwalk_core_library.
         > Unable to load Maven meta-data from https://download.01.org/crosswalk/releases/crosswalk/android/maven2/org/xwalk/xwalk_core_library/maven-metadata.xml.
            > Could not GET 'https://download.01.org/crosswalk/releases/crosswalk/android/maven2/org/xwalk/xwalk_core_library/maven-metadata.xml'. Received status code 403 from server: Forbidden
* Try:
Run with --stacktrace option to get the stack trace. Run with --debug option to get more log output.
BUILD FAILED
Total time: 14.517 secs
Stopped 0 compiler daemon(s).
Error: Error code 1 for command: .../builds/build.2017-01-30.13-17-54.ZFfWFA.tmp/cordova_project/platforms/android/gradlew with args: cdvBuildRelease,-b,.../builds/build.2017-01-30.13-17-54.ZFfWFA.tmp/cordova_project/platforms/android/build.gradle,--no-daemon,-Pandroid.useDeprecatedNdk=true,--info
can someone please help me. What did i do wrong? Thank you
PaulF_IntelCorp
