Software Archive
Read-only legacy content
17061 Discussions
Build fails after adding logos and splash screens ...
proxsys
After updating and succesfully building a legacy app with the cordova build, I went and added the logos and splash screens.
After this change the build fails.
This is a snippet:
  • Installed ldpi launch icon
  • Installed mdpi launch icon
  • Installed hdpi launch icon
  • Installed xhdpi launch icon
  • Installing splash screen "drawable-port-xhdpi/splash.png"
  • Installing splash screen "drawable-port-ldpi/splash.png"
  • Installing splash screen "drawable-port-mdpi/splash.png"
  • Installing splash screen "drawable-port-hdpi/splash.png"
  • Installing splash screen "drawable-land-mdpi/splash.png"
  • Installing splash screen "drawable-land-ldpi/splash.png"
  • Installing splash screen "drawable-land-hdpi/splash.png"
  • Installing splash screen "drawable-land-xhdpi/splash.png"
  • An unexpected error occured while attempting to build the application.
Not much information regarding the actual error:
Error: An error occurred while building the android project.Error executing "ant release -f ".../taggoodemoCamera/platforms/android/build.xml"":
BUILD FAILED
/Developer/android-sdk-linux/tools/ant/build.xml:720: The following error occurred while executing this line:
/Developer/android-sdk-linux/tools/ant/build.xml:734: Compile failed; see the compiler error output for details.
Total time: 5 seconds
    at ChildProcess.<anonymous> (/Developer/cordova/3.3.1-0.1.2/node_modules/cordova/src/compile.js:65:22)
    at ChildProcess.EventEmitter.emit (events.js:98:17)
    at maybeClose (child_process.js:743:16)
    at Process.ChildProcess._handle.onexit (child_process.js:810:5)
PaulF_IntelCorp
Can you attach the error.log file to the post (don't copy the entire error log, please attach it).
proxsys
I have attached the log file.
PaulF_IntelCorp
It looks to me like you've included every plugin and are building against Cordova 3.3. Including every plugin is not a good thing, it usually ends badly (that "add all" button is going away, I've been lobbying for that for quite a while). Also, Cordova 3.3 is obsolete, you should change your CLI version number (in the Build Settings) to 4.1.2.
Iterating over installed plugins: [
  'org.apache.cordova.device-motion',
  'org.apache.cordova.camera',
  'org.apache.cordova.file',
  'org.apache.cordova.media-capture',
  'org.apache.cordova.device-orientation',
  'org.apache.cordova.network-information',
  'org.apache.cordova.contacts',
  'org.apache.cordova.device',
  'org.apache.cordova.battery-status',
  'org.apache.cordova.geolocation',
  'org.apache.cordova.globalization',
  'org.apache.cordova.inappbrowser',
  'org.apache.cordova.media',
  'org.apache.cordova.dialogs',
  'org.apache.cordova.vibration',
  'org.apache.cordova.splashscreen',
  'com.intel.xdk.accelerometer',
  'com.intel.xdk.audio',
  'com.intel.xdk.base',
  'com.intel.xdk.cache',
  'com.intel.xdk.camera',
  'com.intel.xdk.contacts',
  'com.intel.xdk.device',
  'com.intel.xdk.display',
  'com.intel.xdk.facebook',
  'com.intel.xdk.file',
  'com.intel.xdk.geolocation',
  'com.intel.xdk.notification',
  'com.intel.xdk.player',
  'org.apache.cordova.statusbar',
  'org.apache.cordova.file-transfer' ]
Remove all the plugins you do not use and change the CLI to 4.1.2 and let me know what happens.
