Software Archive
Read-only legacy content
17061 Discussions
Build fails and Emulator shows only black screen
Tina_S_
I tried to import a html5 game built with Construct2 and exported with the Cordova option. The Emulator just shows a black screen and when trying to build the app, the following error occurs:
Can anyone help me please?
Thank you
Tina
Calling plugman.fetch on plugin ".../cachedPlugins.2tS1ac.tmp/cache.GxdP4c.pl/com.phonegap.plugins.facebookconnect"
Copying plugin ".../cachedPlugins.2tS1ac.tmp/cache.GxdP4c.pl/com.phonegap.plugins.facebookconnect" => ".../mygamename/plugins/com.phonegap.plugins.facebookconnect"
Calling plugman.install on plugin ".../mygamename/plugins/com.phonegap.plugins.facebookconnect" for platform "android" with options "{"cli_variables":{"APP_ID":"722104087923014","APP_NAME":"Tipico - Safe Hands"},"browserify":false,"link":false,"pluginInfoProvider":{"_cache":{".../cachedPlugins.2tS1ac.tmp/cache.GxdP4c.pl/com.phonegap.plugins.facebookconnect":{"filepath":".../cachedPlugins.2tS1ac.tmp/cache.GxdP4c.pl/com.phonegap.plugins.facebookconnect/plugin.xml","dir":".../cachedPlugins.2tS1ac.tmp/cache.GxdP4c.pl/com.phonegap.plugins.facebookconnect","_et":{"_root":{"_id":25,"tag":"plugin","attrib":{"xmlns":"http://apache.org/cordova/ns/plugins/1.0","xmlns:android":"http://schemas.android.com/apk/res/android","id":"com.phonegap.plugins.facebookconnect","version":"0.11.0"},"text":"\r\n\r\n    ","tail":null,"_children":[{"_id":26,"tag":"name","attrib":{},"text":"Facebook Connect","tail":"\r\n\r\n    ","_children":[]},{"_id":27,"tag":"description","attrib":{},"text":"\r\n      This is the official plugin for Facebook in Apache Cordova/PhoneGap!\r\n      \r\n      The Facebook plugin for Apache Cordova allows you to use the same JavaScript code in your\r\n      Cordova application as you use in your web application.\r\n      Docs: https://github.com/Wizcorp/phonegap-facebook-plugin.\r\n   ; ","tail":"\r\n\r\n    ","_children":[]},{"_id":28,"tag":"license","attrib":{},"text":"Apache 2.0","tail":"\r\n\r\n    ","_children":[]},{"_id":29,"tag":"preference","attrib":{"name":"APP_ID"},"text":"","tail":"\r\n    ","_children":[]},{"_id":30,"tag":"preference","attrib":{"name":"APP_NAME"},"text":"","tail":"\r\n\r\n    ","_children":[]},{"_id":31,"tag":"engines","attrib":{},"text":"\r\n        \r\n        \r\n        ","tail":"\r\n\r\n    \r\n    ","_children":[{"_id":32,"tag":"engine","attrib":{"name":"cordova","version":">=3.5.0"},"text":"","tail":"\r\n    ","_children":[]}]},{"_id":33,"tag":"js-module","attrib":{"src":"facebookConnectPlugin.js","name":"FacebookConnectPlugin","target":"phonegap/plugin/facebookConnectPlugin/facebookConnectPlugin.js"},"text":"\r\n        ","tail":"\r\n\r\n    \r\n    ","_children":[{"_id":34,"tag":"clobbers","attrib":{"target":"facebookConnectPlugin"},"text":"","tail":"\r\n    ","_children":[]}]},{"_id":35,"tag":"platform","attrib":{"name":"android"},"text":"\r\n\r\n        ","tail":"\r\n\r\n    \r\n    ","_children":[{"_id":36,"tag":"config-file","attrib":{"target":"res/xml/config.xml","parent":"/*"},"text":"\r\n            ","tail":"\r\n\r\n        ","_children":[{"_id":37,"tag":"feature","attrib":{"name":"FacebookConnectPlugin"},"text":"\r\n                ","tail":"\r\n            ","_children":[{"_id":38,"tag":"param","attrib":{"name":"android-package","value":"org.apache.cordova.facebook.ConnectPlugin"},"text":"","tail":"\r\n            ","_children":[]}]},{"_id":39,"tag":"access","attrib":{"origin":"https://m.facebook.com"},"text":"","tail":"\r\n            ","_children":[]},{"_id":40,"tag":"access","attrib":{"origin":"https://graph.facebook.com"},"text":"","tail":"\r\n            ","_children":[]},{"_id":41,"tag":"access","attrib":{"origin":"https://api.facebook.com"},"text":"","tail":"\r\n            ","_children":[]},{"_id":42,"tag":"access","attrib":{"origin":"https://*.fbcdn.net"},"text":"","tail":"\r\n            ","_children":[]},{"_id":43,"tag":"access","attrib":{"origin":"https://*.akamaihd.net"},"text":"","tail":"\r\n        ","_children":[]}]},{"_id":44,"tag":"source-file","attrib":{"src":"platforms/android/res/values/facebookconnect.xml","target-dir":"res/values"},"text":"","tail":"\r\n        ","_children":[]},{"_id":45,"tag":"config-file","attrib":{"target":"res/values/facebookconnect.xml","parent":"/*"},"text":"\r\n            ","tail":"\r\n\r\n        ","_children":[{"_id":46,"tag":"string","attrib":{"name":"fb_app_id"},"text":"$APP_ID","tail":"\r\n            ","_children":[]},{"_id":47,"tag":"string","attrib":{"name":"fb_app_name"},"text":"$APP_NAME","tail":"\r\n        ","_children":[]}]},{"_id":48,"tag":"config-file","attrib":{"target":"AndroidManifest.xml","parent":"application"},"text":"\r\n            ","tail":"\r\n\r\n        ","_children":[{"_id":49,"tag":"meta-data","attrib":{"android:name":"com.facebook.sdk.ApplicationId","android:value":"@string/fb_app_id"},"text":"","tail":"\r\n            ","_children":[]},{"_id":50,"tag":"activity","attrib":{"android:label":"@string/fb_app_name","android:name":"com.facebook.LoginActivity","android:theme":"@android:style/Theme.Translucent.NoTitleBar"},"text":"","tail":"\r\n        ","_children":[]}]},{"_id":51,"tag":"framework","attrib":{"src":"platforms/android/FacebookLib","custom":"true"},"text":"","tail":"\r\n\r\n        \r\n        ","_children":[]},{"_id":52,"tag":"source-file","attrib":{"src":"platforms/android/src/org/apache/cordova/facebook/ConnectPlugin.java","target-dir":"src/org/apache/cordova/facebook"},"text":"","tail":"\r\n\r\n    ","_children":[]}]},{"_id":53,"tag":"platform","attrib":{"name":"ios"},"text":"\r\n        ","tail":"\r\n\r\n    \r\n    ","_children":[{"_id":54,"tag":"config-file","attrib":{"target":"config.xml","parent":"/*"},"text":"\r\n            ","tail":"\r\n\r\n        ","_children":[{"_id":55,"tag":"feature","attrib":{"name":"FacebookConnectPlugin"},"text":"\r\n                ","tail":"\r\n            ","_children":[{"_id":56,"tag":"param","attrib":{"name":"ios-package","value":"FacebookConnectPlugin"},"text":"","tail":"\r\n                ","_children":[]},{"_id":57,"tag":"param","attrib":{"name":"onload","value":"true"},"text":"","tail":"\r\n            ","_children":[]}]},{"_id":58,"tag":"plugin","attrib":{"name":"FacebookConnectPlugin","value":"FacebookConnectPlugin"},"text":"","tail":"\r\n            ","_children":[]},{"_id":59,"tag":"access","attrib":{"origin":"https://m.facebook.com"},"text":"","tail":"\r\n            ","_children":[]},{"_id":60,"tag":"access","attrib":{"origin":"https://graph.facebook.com"},"text":"","tail":"\r\n            ","_children":[]},{"_id":61,"tag":"access","attrib":{"origin":"https://api.facebook.com"},"text":"","tail":"\r\n            ","_children":[]},{"_id":62,"tag":"access","attrib":{"origin":"https://*.fbcdn.net"},"text":"","tail":"\r\n            ","_children":[]},{"_id":63,"tag":"access","attrib":{"origin":"https://*.akamaihd.net"},"text":"","tail":"\r\n        ","_children":[]}]},{"_id":64,"tag":"header-file","attrib":{"src":"platforms/ios/HelloCordova/Plugins/com.phonegap.plugins.facebookconnect/FacebookConnectPlugin.h"},"text":"","tail":"\r\n        ","_children":[]},{"_id":65,"tag":"source-file","attrib":{"src":"platforms/ios/HelloCordova/Plugins/com.phonegap.plugins.facebookconnect/FacebookConnectPlugin.m"},"text":"","tail":"\r\n\r\n        ","_children":[]},{"_id":66,"tag":"config-file","attrib":{"target":"*-Info.plist","parent":"FacebookAppID"},"text":"\r\n            ","tail":"\r\n\r\n        ","_children":[{"_id":67,"tag":"string","attrib":{},"text":"$APP_ID","tail":"\r\n        ","_children":[]}]},{"_id":68,"tag":"config-file","attrib":{"target":"*-Info.plist","parent":"FacebookDisplayName"},"text":"\r\n            ","tail":"\r\n\r\n        ","_children":[{"_id":69,"tag":"string","attrib":{},"text":"$APP_NAME","tail":"\r\n        ","_children":[]}]},{"_id":70,"tag":"config-file","attrib":{"target":"*-Info.plist","parent":"CFBundleURLTypes"},"text":"\r\n          ","tail":"\r\n\r\n        \r\n        ","_children":[{"_id":71,"tag":"array","attrib":{},"text":"\r\n            ","tail":"\r\n        ","_children":[{"_id":72,"tag":"dict","attrib":{},"text":"\r\n              ","tail":"\r\n          ","_children":[{"_id":73,"tag":"key","attrib":{},"text":"CFBundleURLSchemes","tail":"\r\n              ","_children":[]},{"_id":74,"tag":"array","attrib":{},"text":"\r\n                ","tail":"\r\n            ","_children":[{"_id":75,"tag":"string","attrib":{},"text":"fb$APP_ID","tail":"\r\n              ","_children":[]}]}]}]}]},{"_id":76,"tag":"framework","attrib":{"src":"platforms/ios/FacebookSDK.framework","custom":"true"},"text":"","tail":"\r\n\r\n        \r\n        ","_children":[]},{"_id":77,"tag":"framework","attrib":{"src":"libsqlite3.dylib"},"text":"","tail":"\r\n        ","_children":[]},{"_id":78,"tag":"framework","attrib":{"src":"Social.framework","weak":"true"},"text":"","tail":"\r\n        ","_children":[]},{"_id":79,"tag":"framework","attrib":{"src":"Accounts.framework","weak":"true"},"text":"","tail":"\r\n        ","_children":[]},{"_id":80,"tag":"framework","attrib":{"src":"Security.framework","weak":"true"},"text":"","tail":"\r\n\r\n    ","_children":[]}]},{"_id":81,"tag":"platform","attrib":{"name":"browser"},"text":"\r\n        ","tail":"\r\n","_children":[{"_id":82,"tag":"config-file","attrib":{"target":"config.xml","parent":"/*"},"text":"\r\n            ","tail":"\r\n    ","_children":[{"_id":83,"tag":"feature","attrib":{"name":"FacebookConnectPlugin"},"text":"\r\n                ","tail":"\r\n            ","_children":[{"_id":84,"tag":"param","attrib":{"name":"browser-package","value":"FacebookConnectPlugin"},"text":"","tail":"\r\n                ","_children":[]},{"_id":85,"tag":"param","attrib":{"name":"onload","value":"true"},"text":"","tail":"\r\n            ","_children":[]}]},{"_id":86,"tag":"plugin","attrib":{"name":"FacebookConnectPlugin","value":"FacebookConnectPlugin"},"text":"","tail":"\r\n            ","_children":[]},{"_id":87,"tag":"access","attrib":{"origin":"https://m.facebook.com"},"text":"","tail":"\r\n            ","_children":[]},{"_id":88,"tag":"access","attrib":{"origin":"https://graph.facebook.com"},"text":"","tail":"\r\n            ","_children":[]},{"_id":89,"tag":"access","attrib":{"origin":"https://api.facebook.com"},"text":"","tail":"\r\n            ","_children":[]},{"_id":90,"tag":"access","attrib":{"origin":"https://*.fbcdn.net"},"text":"","tail":"\r\n            ","_children":[]},{"_id":91,"tag":"access","attrib":{"origin":"https://*.akamaihd.net"},"text":"","tail":"\r\n        ","_children":[]}]}]}]}},"id":"com.phonegap.plugins.facebookconnect","version":"0.11.0","name":"Facebook Connect","description":"\r\n      This is the official plugin for Facebook in Apache Cordova/PhoneGap!\r\n      \r\n      The Facebook plugin for Apache Cordova allows you to use the same JavaScript code in your\r\n      Cordova application as you use in your web application.\r\n      Docs: https://github.com/Wizcorp/phonegap-facebook-plugin.\r\n   ; ","license":"Apache 2.0"},".../mygamename/plugins/com.phonegap.plugins.facebookconnect":{"filepath":".../mygamename/plugins/com.phonegap.plugins.facebookconnect/plugin.xml","dir":".../mygamename/plugins/com.phonegap.plugins.facebookconnect","_et":{"_root":{"_id":92,"tag":"plugin","attrib":{"xmlns":"http://apache.org/cordova/ns/plugins/1.0","xmlns:android":"http://schemas.android.com/apk/res/android","id":"com.phonegap.plugins.facebookconnect","version":"0.11.0"},"text":"\r\n\r\n    ","tail":null,"_children":[{"_id":93,"tag":"name","attrib":{},"text":"Facebook Connect","tail":"\r\n\r\n    ","_children":[]},{"_id":94,"tag":"description","attrib":{},"text":"\r\n      This is the official plugin for Facebook in Apache Cordova/PhoneGap!\r\n      \r\n      The Facebook plugin for Apache Cordova allows you to use the same JavaScript code in your\r\n      Cordova application as you use in your web application.\r\n      Docs: https://github.com/Wizcorp/phonegap-facebook-plugin.\r\n   ; ","tail":"\r\n\r\n    ","_children":[]},{"_id":95,"tag":"license","attrib":{},"text":"Apache 2.0","tail":"\r\n\r\n    ","_children":[]},{"_id":96,"tag":"preference","attrib":{"name":"APP_ID"},"text":"","tail":"\r\n    ","_children":[]},{"_id":97,"tag":"preference","attrib":{"name":"APP_NAME"},"text":"","tail":"\r\n\r\n    ","_children":[]},{"_id":98,"tag":"engines","attrib":{},"text":"\r\n        \r\n        \r\n        ","tail":"\r\n\r\n    \r\n    ","_children":[{"_id":99,"tag":"engine","attrib":{"name":"cordova","version":">=3.5.0"},"text":"","tail":"\r\n    ","_children":[]}]},{"_id":100,"tag":"js-module","attrib":{"src":"facebookConnectPlugin.js","name":"FacebookConnectPlugin","target":"phonegap/plugin/facebookConnectPlugin/facebookConnectPlugin.js"},"text":"\r\n        ","tail":"\r\n\r\n    \r\n    ","_children":[{"_id":101,"tag":"clobbers","attrib":{"target":"facebookConnectPlugin"},"text":"","tail":"\r\n    ","_children":[]}]},{"_id":102,"tag":"platform","attrib":{"name":"android"},"text":"\r\n\r\n        ","tail":"\r\n\r\n    \r\n    ","_children":[{"_id":103,"tag":"config-file","attrib":{"target":"res/xml/config.xml","parent":"/*"},"text":"\r\n            ","tail":"\r\n\r\n        ","_children":[{"_id":104,"tag":"feature","attrib":{"name":"FacebookConnectPlugin"},"text":"\r\n                ","tail":"\r\n            ","_children":[{"_id":105,"tag":"param","attrib":{"name":"android-package","value":"org.apache.cordova.facebook.ConnectPlugin"},"text":"","tail":"\r\n            ","_children":[]}]},{"_id":106,"tag":"access","attrib":{"origin":"https://m.facebook.com"},"text":"","tail":"\r\n            ","_children":[]},{"_id":107,"tag":"access","attrib":{"origin":"https://graph.facebook.com"},"text":"","tail":"\r\n            ","_children":[]},{"_id":108,"tag":"access","attrib":{"origin":"https://api.facebook.com"},"text":"","tail":"\r\n            ","_children":[]},{"_id":109,"tag":"access","attrib":{"origin":"https://*.fbcdn.net"},"text":"","tail":"\r\n            ","_children":[]},{"_id":110,"tag":"access","attrib":{"origin":"https://*.akamaihd.net"},"text":"","tail":"\r\n        ","_children":[]}]},{"_id":111,"tag":"source-file","attrib":{"src":"platforms/android/res/values/facebookconnect.xml","target-dir":"res/values"},"text":"","tail":"\r\n        ","_children":[]},{"_id":112,"tag":"config-file","attrib":{"target":"res/values/facebookconnect.xml","parent":"/*"},"text":"\r\n            ","tail":"\r\n\r\n        ","_children":[{"_id":113,"tag":"string","attrib":{"name":"fb_app_id"},"text":"$APP_ID","tail":"\r\n            ","_children":[]},{"_id":114,"tag":"string","attrib":{"name":"fb_app_name"},"text":"$APP_NAME","tail":"\r\n        ","_children":[]}]},{"_id":115,"tag":"config-file","attrib":{"target":"AndroidManifest.xml","parent":"application"},"text":"\r\n            ","tail":"\r\n\r\n        ","_children":[{"_id":116,"tag":"meta-data","attrib":{"android:name":"com.facebook.sdk.ApplicationId","android:value":"@string/fb_app_id"},"text":"","tail":"\r\n            ","_children":[]},{"_id":117,"tag":"activity","attrib":{"android:label":"@string/fb_app_name","android:name":"com.facebook.LoginActivity","android:theme":"@android:style/Theme.Translucent.NoTitleBar"},"text":"","tail":"\r\n        ","_children":[]}]},{"_id":118,"tag":"framework","attrib":{"src":"platforms/android/FacebookLib","custom":"true"},"text":"","tail":"\r\n\r\n        \r\n        ","_children":[]},{"_id":119,"tag":"source-file","attrib":{"src":"platforms/android/src/org/apache/cordova/facebook/ConnectPlugin.java","target-dir":"src/org/apache/cordova/facebook"},"text":"","tail":"\r\n\r\n    ","_children":[]}]},{"_id":120,"tag":"platform","attrib":{"name":"ios"},"text":"\r\n        ","tail":"\r\n\r\n    \r\n    ","_children":[{"_id":121,"tag":"config-file","attrib":{"target":"config.xml","parent":"/*"},"text":"\r\n            ","tail":"\r\n\r\n        ","_children":[{"_id":122,"tag":"feature","attrib":{"name":"FacebookConnectPlugin"},"text":"\r\n                ","tail":"\r\n            ","_children":[{"_id":123,"tag":"param","attrib":{"name":"ios-package","value":"FacebookConnectPlugin"},"text":"","tail":"\r\n                ","_children":[]},{"_id":124,"tag":"param","attrib":{"name":"onload","value":"true"},"text":"","tail":"\r\n            ","_children":[]}]},{"_id":125,"tag":"plugin","attrib":{"name":"FacebookConnectPlugin","value":"FacebookConnectPlugin"},"text":"","tail":"\r\n            ","_children":[]},{"_id":126,"tag":"access","attrib":{"origin":"https://m.facebook.com"},"text":"","tail":"\r\n            ","_children":[]},{"_id":127,"tag":"access","attrib":{"origin":"https://graph.facebook.com"},"text":"","tail":"\r\n            ","_children":[]},{"_id":128,"tag":"access","attrib":{"origin":"https://api.facebook.com"},"text":"","tail":"\r\n            ","_children":[]},{"_id":129,"tag":"access","attrib":{"origin":"https://*.fbcdn.net"},"text":"","tail":"\r\n            ","_children":[]},{"_id":130,"tag":"access","attrib":{"origin":"https://*.akamaihd.net"},"text":"","tail":"\r\n        ","_children":[]}]},{"_id":131,"tag":"header-file","attrib":{"src":"platforms/ios/HelloCordova/Plugins/com.phonegap.plugins.facebookconnect/FacebookConnectPlugin.h"},"text":"","tail":"\r\n        ","_children":[]},{"_id":132,"tag":"source-file","attrib":{"src":"platforms/ios/HelloCordova/Plugins/com.phonegap.plugins.facebookconnect/FacebookConnectPlugin.m"},"text":"","tail":"\r\n\r\n        ","_children":[]},{"_id":133,"tag":"config-file","attrib":{"target":"*-Info.plist","parent":"FacebookAppID"},"text":"\r\n            ","tail":"\r\n\r\n        ","_children":[{"_id":134,"tag":"string","attrib":{},"text":"$APP_ID","tail":"\r\n        ","_children":[]}]},{"_id":135,"tag":"config-file","attrib":{"target":"*-Info.plist","parent":"FacebookDisplayName"},"text":"\r\n            ","tail":"\r\n\r\n        ","_children":[{"_id":136,"tag":"string","attrib":{},"text":"$APP_NAME","tail":"\r\n        ","_children":[]}]},{"_id":137,"tag":"config-file","attrib":{"target":"*-Info.plist","parent":"CFBundleURLTypes"},"text":"\r\n          ","tail":"\r\n\r\n        \r\n        ","_children":[{"_id":138,"tag":"array","attrib":{},"text":"\r\n            ","tail":"\r\n        ","_children":[{"_id":139,"tag":"dict","attrib":{},"text":"\r\n              ","tail":"\r\n          ","_children":[{"_id":140,"tag":"key","attrib":{},"text":"CFBundleURLSchemes","tail":"\r\n              ","_children":[]},{"_id":141,"tag":"array","attrib":{},"text":"\r\n                ","tail":"\r\n            ","_children":[{"_id":142,"tag":"string","attrib":{},"text":"fb$APP_ID","tail":"\r\n              ","_children":[]}]}]}]}]},{"_id":143,"tag":"framework","attrib":{"src":"platforms/ios/FacebookSDK.framework","custom":"true"},"text":"","tail":"\r\n\r\n        \r\n        ","_children":[]},{"_id":144,"tag":"framework","attrib":{"src":"libsqlite3.dylib"},"text":"","tail":"\r\n        ","_children":[]},{"_id":145,"tag":"framework","attrib":{"src":"Social.framework","weak":"true"},"text":"","tail":"\r\n        ","_children":[]},{"_id":146,"tag":"framework","attrib":{"src":"Accounts.framework","weak":"true"},"text":"","tail":"\r\n        ","_children":[]},{"_id":147,"tag":"framework","attrib":{"src":"Security.framework","weak":"true"},"text":"","tail":"\r\n\r\n    ","_children":[]}]},{"_id":148,"tag":"platform","attrib":{"name":"browser"},"text":"\r\n        ","tail":"\r\n","_children":[{"_id":149,"tag":"config-file","attrib":{"target":"config.xml","parent":"/*"},"text":"\r\n            ","tail":"\r\n    ","_children":[{"_id":150,"tag":"feature","attrib":{"name":"FacebookConnectPlugin"},"text":"\r\n                ","tail":"\r\n            ","_children":[{"_id":151,"tag":"param","attrib":{"name":"browser-package","value":"FacebookConnectPlugin"},"text":"","tail":"\r\n                ","_children":[]},{"_id":152,"tag":"param","attrib":{"name":"onload","value":"true"},"text":"","tail":"\r\n            ","_children":[]}]},{"_id":153,"tag":"plugin","attrib":{"name":"FacebookConnectPlugin","value":"FacebookConnectPlugin"},"text":"","tail":"\r\n            ","_children":[]},{"_id":154,"tag":"access","attrib":{"origin":"https://m.facebook.com"},"text":"","tail":"\r\n            ","_children":[]},{"_id":155,"tag":"access","attrib":{"origin":"https://graph.facebook.com"},"text":"","tail":"\r\n            ","_children":[]},{"_id":156,"tag":"access","attrib":{"origin":"https://api.facebook.com"},"text":"","tail":"\r\n            ","_children":[]},{"_id":157,"tag":"access","attrib":{"origin":"https://*.fbcdn.net"},"text":"","tail":"\r\n            ","_children":[]},{"_id":158,"tag":"access","attrib":{"origin":"https://*.akamaihd.net"},"text":"","tail":"\r\n        ","_children":[]}]}]}]}},"id":"com.phonegap.plugins.facebookconnect","version":"0.11.0","name":"Facebook Connect","description":"\r\n      This is the official plugin for Facebook in Apache Cordova/PhoneGap!\r\n      \r\n      The Facebook plugin for Apache Cordova allows you to use the same JavaScript code in your\r\n      Cordova application as you use in your web application.\r\n      Docs: https://github.com/Wizcorp/phonegap-facebook-plugin.\r\n   ; ","license":"Apache 2.0"}},"_getAllCache":{}},"nohooks":["."]}"
Installing "com.phonegap.plugins.facebookconnect" for android
Running command: .../mygamename/platforms/android/cordova/version
Command finished with error code 0: .../mygamename/platforms/android/cordova/version
Install start for "com.phonegap.plugins.facebookconnect" on android.
Beginning processing of action stack for android project...
Parsing android project files...
Installing Android library: platforms/android/FacebookLib
Action stack processing complete.
Writing out android project files...
Preparing android project
Processing configuration changes for plugins.
Iterating over installed plugins: [ 'com.phonegap.plugins.facebookconnect' ]
Writing out cordova_plugins.js...
Install complete for com.phonegap.plugins.facebookconnect on android.
Updating build files since android plugin contained <framework>
Calling plugman.fetch on plugin ".../cachedPlugins.2tS1ac.tmp/cache.yIiZ2C.pl/android.support.v4"
Copying plugin ".../cachedPlugins.2tS1ac.tmp/cache.yIiZ2C.pl/android.support.v4" => ".../mygamename/plugins/android.support.v4"
Calling plugman.install on plugin ".../mygamename/plugins/android.support.v4" for platform "android" with options "{"cli_variables":{},"browserify":false,"link":false,"pluginInfoProvider":{"_cache":{".../cachedPlugins.2tS1ac.tmp/cache.yIiZ2C.pl/android.support.v4":{"filepath":".../cachedPlugins.2tS1ac.tmp/cache.yIiZ2C.pl/android.support.v4/plugin.xml","dir":".../cachedPlugins.2tS1ac.tmp/cache.yIiZ2C.pl/android.support.v4","_et":{"_root":{"_id":25,"tag":"plugin","attrib":{"xmlns":"http://cordova.apache.org/ns/plugins/1.0","id":"android.support.v4","version":"21.0.1"},"text":"\r\n  ","tail":null,"_children":[{"_id":26,"tag":"engines","attrib":{},"text":"\r\n    ","tail":"\r\n\r\n  ","_children":[{"_id":27,"tag":"engine","attrib":{"name":"cordova","version":">=3.0.0"},"text":"","tail":"\r\n  ","_children":[]}]},{"_id":28,"tag":"name","attrib":{},"text":"Android Support v4","tail":"\r\n\r\n  ","_children":[]},{"_id":29,"tag":"platform","attrib":{"name":"android"},"text":"\r\n    ","tail":"\r\n","_children":[{"_id":30,"tag":"source-file","attrib":{"src":"android-support-v4.jar","target-dir":"libs"},"text":"","tail":"\r\n  ","_children":[]}]}]}},"id":"android.support.v4","version":"21.0.1","name":"Android Support v4"},".../mygamename/plugins/android.support.v4":{"filepath":".../mygamename/plugins/android.support.v4/plugin.xml","dir":".../mygamename/plugins/android.support.v4","_et":{"_root":{"_id":31,"tag":"plugin","attrib":{"xmlns":"http://cordova.apache.org/ns/plugins/1.0","id":"android.support.v4","version":"21.0.1"},"text":"\r\n  ","tail":null,"_children":[{"_id":32,"tag":"engines","attrib":{},"text":"\r\n    ","tail":"\r\n\r\n  ","_children":[{"_id":33,"tag":"engine","attrib":{"name":"cordova","version":">=3.0.0"},"text":"","tail":"\r\n  ","_children":[]}]},{"_id":34,"tag":"name","attrib":{},"text":"Android Support v4","tail":"\r\n\r\n  ","_children":[]},{"_id":35,"tag":"platform","attrib":{"name":"android"},"text":"\r\n    ","tail":"\r\n","_children":[{"_id":36,"tag":"source-file","attrib":{"src":"android-support-v4.jar","target-dir":"libs"},"text":"","tail":"\r\n  ","_children":[]}]}]}},"id":"android.support.v4","version":"21.0.1","name":"Android Support v4"}},"_getAllCache":{}},"nohooks":["."]}"
Installing "android.support.v4" for android
Install start for "android.support.v4" on android.
Iterating over installed plugins: [ 'com.phonegap.plugins.facebookconnect', 'android.support.v4' ]
Install complete for android.support.v4 on android.
Calling plugman.fetch on plugin ".../cachedPlugins.2tS1ac.tmp/cache.MhVUsC.pl/com.google.playservices"
Copying plugin ".../cachedPlugins.2tS1ac.tmp/cache.MhVUsC.pl/com.google.playservices" => ".../mygamename/plugins/com.google.playservices"
Calling plugman.install on plugin ".../mygamename/plugins/com.google.playservices" for platform "android" with options "{"cli_variables":{},"browserify":false,"link":false,"pluginInfoProvider":{"_cache":{".../cachedPlugins.2tS1ac.tmp/cache.MhVUsC.pl/com.google.playservices":{"filepath":".../cachedPlugins.2tS1ac.tmp/cache.MhVUsC.pl/com.google.playservices/plugin.xml","dir":".../cachedPlugins.2tS1ac.tmp/cache.MhVUsC.pl/com.google.playservices","_et":{"_root":{"_id":25,"tag":"plugin","attrib":{"xmlns":"http://cordova.apache.org/ns/plugins/1.0","id":"com.google.playservices","version":"21.0.0"},"text":"\r\n  ","tail":null,"_children":[{"_id":26,"tag":"engines","attrib":{},"text":"\r\n    ","tail":"\r\n\r\n  ","_children":[{"_id":27,"tag":"engine","attrib":{"name":"cordova","version":">=3.0.0"},"text":"","tail":"\r\n  ","_children":[]}]},{"_id":28,"tag":"name","attrib":{},"text":"Google Play Services for Android","tail":"\r\n\r\n  ","_children":[]},{"_id":29,"tag":"platform","attrib":{"name":"android"},"text":"\r\n    ","tail":"\r\n","_children":[{"_id":30,"tag":"config-file","attrib":{"target":"AndroidManifest.xml","parent":"/manifest/application"},"text":"\r\n        ","tail":"\r\n\r\n    ","_children":[{"_id":31,"tag":"meta-data","attrib":{"android:name":"com.google.android.gms.version","android:value":"@integer/google_play_services_version"},"text":"","tail":"\r\n    ","_children":[]}]},{"_id":32,"tag":"source-file","attrib":{"src":"version.xml","target-dir":"res/values"},"text":"","tail":"\r\n    ","_children":[]},{"_id":33,"tag":"framework","attrib":{"src":"libs/google-play-services_lib","custom":"true"},"text":"","tail":"\r\n  ","_children":[]}]}]}},"id":"com.google.playservices","version":"21.0.0","name":"Google Play Services for Android"},".../mygamename/plugins/com.google.playservices":{"filepath":".../mygamename/plugins/com.google.playservices/plugin.xml","dir":".../mygamename/plugins/com.google.playservices","_et":{"_root":{"_id":34,"tag":"plugin","attrib":{"xmlns":"http://cordova.apache.org/ns/plugins/1.0","id":"com.google.playservices","version":"21.0.0"},"text":"\r\n  ","tail":null,"_children":[{"_id":35,"tag":"engines","attrib":{},"text":"\r\n    ","tail":"\r\n\r\n  ","_children":[{"_id":36,"tag":"engine","attrib":{"name":"cordova","version":">=3.0.0"},"text":"","tail":"\r\n  ","_children":[]}]},{"_id":37,"tag":"name","attrib":{},"text":"Google Play Services for Android","tail":"\r\n\r\n  ","_children":[]},{"_id":38,"tag":"platform","attrib":{"name":"android"},"text":"\r\n    ","tail":"\r\n","_children":[{"_id":39,"tag":"config-file","attrib":{"target":"AndroidManifest.xml","parent":"/manifest/application"},"text":"\r\n        ","tail":"\r\n\r\n    ","_children":[{"_id":40,"tag":"meta-data","attrib":{"android:name":"com.google.android.gms.version","android:value":"@integer/google_play_services_version"},"text":"","tail":"\r\n    ","_children":[]}]},{"_id":41,"tag":"source-file","attrib":{"src":"version.xml","target-dir":"res/values"},"text":"","tail":"\r\n    ","_children":[]},{"_id":42,"tag":"framework","attrib":{"src":"libs/google-play-services_lib","custom":"true"},"text":"","tail":"\r\n  ","_children":[]}]}]}},"id":"com.google.playservices","version":"21.0.0","name":"Google Play Services for Android"}},"_getAllCache":{}},"nohooks":["."]}"
Installing "com.google.playservices" for android
Install start for "com.google.playservices" on android.
Installing Android library: libs/google-play-services_lib
  'android.support.v4',
  'com.google.playservices' ]
Install complete for com.google.playservices on android.
Calling plugman.fetch on plugin ".../cachedPlugins.2tS1ac.tmp/cache.qqO3I4.pl/com.intel.googleplaygamesplugin"
Copying plugin ".../cachedPlugins.2tS1ac.tmp/cache.qqO3I4.pl/com.intel.googleplaygamesplugin" => ".../mygamename/plugins/com.intel.googleplaygamesplugin"
Calling plugman.install on plugin ".../mygamename/plugins/com.intel.googleplaygamesplugin" for platform "android" with options "{"cli_variables":{"GPSAPPID":"242772766904"},"browserify":false,"link":false,"pluginInfoProvider":{"_cache":{".../cachedPlugins.2tS1ac.tmp/cache.qqO3I4.pl/com.intel.googleplaygamesplugin":{"filepath":".../cachedPlugins.2tS1ac.tmp/cache.qqO3I4.pl/com.intel.googleplaygamesplugin/plugin.xml","dir":".../cachedPlugins.2tS1ac.tmp/cache.qqO3I4.pl/com.intel.googleplaygamesplugin","_et":{"_root":{"_id":25,"tag":"plugin","attrib":{"xmlns":"http://www.phonegap.com/ns/plugins/1.0","xmlns:android":"http://schemas.android.com/apk/res/android","id":"com.intel.googleplaygamesplugin","version":"1.0.7"},"text":"\n\n    ","tail":null,"_children":[{"_id":26,"tag":"name","attrib":{},"text":"GooglePlayGamesPlugin","tail":"\n\n    ","_children":[]},{"_id":27,"tag":"description","attrib":{},"text":"Google Play Games Plugin","tail":"\n\n    ","_children":[]},{"_id":28,"tag":"author","attrib":{},"text":"Ian Maffett","tail":"\n\n    ","_children":[]},{"_id":29,"tag":"keywords","attrib":{},"text":"GooglePlayGamesPlugin","tail":"\n\n    ","_children":[]},{"_id":30,"tag":"engines","attrib":{},"text":"\n        ","tail":"\n\n    ","_children":[{"_id":31,"tag":"engine","attrib":{"name":"cordova","version":">=3.0.0"},"text":"","tail":"\n    ","_children":[]}]},{"_id":32,"tag":"license","attrib":{},"text":"MIT","tail":"\n\n\n    ","_children":[]},{"_id":33,"tag":"preference","attrib":{"name":"GPSAPPID"},"text":"","tail":"\n\n\n     ","_children":[]},{"_id":34,"tag":"js-module","attrib":{"src":"www/GooglePlayGamesCore.js","name":"GooglePlayGamesPluginCore"},"text":"\n            ","tail":"\n\n    \n    ","_children":[{"_id":35,"tag":"clobbers","attrib":{"target":"window.GooglePlayGamesPlugin"},"text":"","tail":"\n    ","_children":[]}]},{"_id":36,"tag":"platform","attrib":{"name":"android"},"text":"\n        ","tail":"\n\n\n    ","_children":[{"_id":37,"tag":"js-module","attrib":{"src":"www/AndroidGooglePlayGamesPlugin.js","name":"GooglePlayGamesPlugin"},"text":"\n            ","tail":"\n\n        \n        ","_children":[{"_id":38,"tag":"merges","attrib":{"target":"window.GooglePlayGamesPlugin"},"text":"","tail":"\n        ","_children":[]}]},{"_id":39,"tag":"dependency","attrib":{"id":"android.support.v4","url":"https://github.com/MobileChromeApps/cordova-plugin-android-support-v4"},"text":"","tail":"\n\n        \n        ","_children":[]},{"_id":40,"tag":"dependency","attrib":{"id":"com.google.playservices","url":"https://github.com/MobileChromeApps/google-play-services","commit":"1f56399572d255193f8f9564843df60e50938e69"},"text":"","tail":"\n\n\n        ","_children":[]},{"_id":41,"tag":"config-file","attrib":{"target":"res/xml/config.xml","parent":"/*"},"text":"\n            ","tail":"\n\n        ","_children":[{"_id":42,"tag":"feature","attrib":{"name":"GooglePlayGamesPlugin"},"text":"\n                ","tail":"\n        ","_children":[{"_id":43,"tag":"param","attrib":{"name":"android-package","value":"com.intel.GooglePlayGamesPlugin"},"text":"","tail":"\n            ","_children":[]}]}]},{"_id":44,"tag":"config-file","attrib":{"target":"res/values/strings.xml","parent":"/*"},"text":"\n             ","tail":"\n\n        ","_children":[{"_id":45,"tag":"string","attrib":{"name":"google_play_services_app_id"},"text":"$GPSAPPID","tail":"\n        ","_children":[]}]},{"_id":46,"tag":"source-file","attrib":{"src":"src/android/gamehelper_strings.xml","target-dir":"res/values"},"text":"","tail":"\n\n        ","_children":[]},{"_id":47,"tag":"config-file","attrib":{"target":"AndroidManifest.xml","parent":"/manifest/application"},"text":"\n            ","tail":"\n\n\n        ","_children":[{"_id":48,"tag":"meta-data","attrib":{"android:name":"com.google.android.gms.version","android:value":"@integer/google_play_services_version"},"text":"","tail":"\n            ","_children":[]},{"_id":49,"tag":"uses-permission","attrib":{"android:name":"android.permission.INTERACT_ACROSS_USERS"},"text":"","tail":"\n            ","_children":[]},{"_id":50,"tag":"activity","attrib":{"android:name":"com.intel.GooglePlayGamesService"},"text":"\n        ","tail":"\n            ","_children":[]},{"_id":51,"tag":"meta-data","attrib":{"android:name":"com.google.android.gms.games.APP_ID","android:value":"@string/google_play_services_app_id"},"text":"","tail":"\n        ","_children":[]}]},{"_id":52,"tag":"source-file","attrib":{"src":"src/android/GooglePlayGamesService.java","target-dir":"src/com/intel"},"text":"","tail":"\n        ","_children":[]},{"_id":53,"tag":"source-file","attrib":{"src":"src/android/GooglePlayGamesPlugin.java","target-dir":"src/com/intel"},"text":"","tail":"\n        ","_children":[]},{"_id":54,"tag":"source-file","attrib":{"src":"src/android/com/google/example/games/basegameutils/BaseGameActivity.java","target-dir":"src/com/google/example/games/basegameutils"},"text":"","tail":"\n        ","_children":[]},{"_id":55,"tag":"source-file","attrib":{"src":"src/android/com/google/example/games/basegameutils/GameHelper.java","target-dir":"src/com/google/example/games/basegameutils"},"text":"","tail":"\n            ","_children":[]},{"_id":56,"tag":"source-file","attrib":{"src":"src/android/com/google/example/games/basegameutils/GameHelperUtils.java","target-dir":"src/com/google/example/games/basegameutils"},"text":"","tail":"\n    ","_children":[]}]},{"_id":57,"tag":"platform","attrib":{"name":"ios"},"text":"\n        ","tail":"\n","_children":[{"_id":58,"tag":"dependency","attrib":{"id":"cordova-plugin-gamecenter","url":"https://github.com/Wizcorp/cordova-plugin-gameCenter"},"text":"","tail":"\n         ","_children":[]},{"_id":59,"tag":"js-module","attrib":{"src":"www/iOSGooglePlayGamesPlugin.js","name":"GooglePlayGamesPlugin"},"text":"\n            ","tail":"\n    ","_children":[{"_id":60,"tag":"merges","attrib":{"target":"window.GooglePlayGamesPlugin"},"text":"","tail":"\n        ","_children":[]}]}]}]}},"id":"com.intel.googleplaygamesplugin","version":"1.0.7","name":"GooglePlayGamesPlugin","description":"Google Play Games Plugin","license":"MIT","keywords":["GooglePlayGamesPlugin"]},".../mygamename/plugins/com.intel.googleplaygamesplugin":{"filepath":".../mygamename/plugins/com.intel.googleplaygamesplugin/plugin.xml","dir":".../mygamename/plugins/com.intel.googleplaygamesplugin","_et":{"_root":{"_id":61,"tag":"plugin","attrib":{"xmlns":"http://www.phonegap.com/ns/plugins/1.0","xmlns:android":"http://schemas.android.com/apk/res/android","id":"com.intel.googleplaygamesplugin","version":"1.0.7"},"text":"\n\n    ","tail":null,"_children":[{"_id":62,"tag":"name","attrib":{},"text":"GooglePlayGamesPlugin","tail":"\n\n    ","_children":[]},{"_id":63,"tag":"description","attrib":{},"text":"Google Play Games Plugin","tail":"\n\n    ","_children":[]},{"_id":64,"tag":"author","attrib":{},"text":"Ian Maffett","tail":"\n\n    ","_children":[]},{"_id":65,"tag":"keywords","attrib":{},"text":"GooglePlayGamesPlugin","tail":"\n\n    ","_children":[]},{"_id":66,"tag":"engines","attrib":{},"text":"\n        ","tail":"\n\n    ","_children":[{"_id":67,"tag":"engine","attrib":{"name":"cordova","version":">=3.0.0"},"text":"","tail":"\n    ","_children":[]}]},{"_id":68,"tag":"license","attrib":{},"text":"MIT","tail":"\n\n\n    ","_children":[]},{"_id":69,"tag":"preference","attrib":{"name":"GPSAPPID"},"text":"","tail":"\n\n\n     ","_children":[]},{"_id":70,"tag":"js-module","attrib":{"src":"www/GooglePlayGamesCore.js","name":"GooglePlayGamesPluginCore"},"text":"\n            ","tail":"\n\n    \n    ","_children":[{"_id":71,"tag":"clobbers","attrib":{"target":"window.GooglePlayGamesPlugin"},"text":"","tail":"\n    ","_children":[]}]},{"_id":72,"tag":"platform","attrib":{"name":"android"},"text":"\n        ","tail":"\n\n\n    ","_children":[{"_id":73,"tag":"js-module","attrib":{"src":"www/AndroidGooglePlayGamesPlugin.js","name":"GooglePlayGamesPlugin"},"text":"\n            ","tail":"\n\n        \n        ","_children":[{"_id":74,"tag":"merges","attrib":{"target":"window.GooglePlayGamesPlugin"},"text":"","tail":"\n        ","_children":[]}]},{"_id":75,"tag":"dependency","attrib":{"id":"android.support.v4","url":"https://github.com/MobileChromeApps/cordova-plugin-android-support-v4"},"text":"","tail":"\n\n        \n        ","_children":[]},{"_id":76,"tag":"dependency","attrib":{"id":"com.google.playservices","url":"https://github.com/MobileChromeApps/google-play-services","commit":"1f56399572d255193f8f9564843df60e50938e69"},"text":"","tail":"\n\n\n        ","_children":[]},{"_id":77,"tag":"config-file","attrib":{"target":"res/xml/config.xml","parent":"/*"},"text":"\n            ","tail":"\n\n        ","_children":[{"_id":78,"tag":"feature","attrib":{"name":"GooglePlayGamesPlugin"},"text":"\n                ","tail":"\n        ","_children":[{"_id":79,"tag":"param","attrib":{"name":"android-package","value":"com.intel.GooglePlayGamesPlugin"},"text":"","tail":"\n            ","_children":[]}]}]},{"_id":80,"tag":"config-file","attrib":{"target":"res/values/strings.xml","parent":"/*"},"text":"\n             ","tail":"\n\n        ","_children":[{"_id":81,"tag":"string","attrib":{"name":"google_play_services_app_id"},"text":"$GPSAPPID","tail":"\n        ","_children":[]}]},{"_id":82,"tag":"source-file","attrib":{"src":"src/android/gamehelper_strings.xml","target-dir":"res/values"},"text":"","tail":"\n\n        ","_children":[]},{"_id":83,"tag":"config-file","attrib":{"target":"AndroidManifest.xml","parent":"/manifest/application"},"text":"\n            ","tail":"\n\n\n        ","_children":[{"_id":84,"tag":"meta-data","attrib":{"android:name":"com.google.android.gms.version","android:value":"@integer/google_play_services_version"},"text":"","tail":"\n            ","_children":[]},{"_id":85,"tag":"uses-permission","attrib":{"android:name":"android.permission.INTERACT_ACROSS_USERS"},"text":"","tail":"\n            ","_children":[]},{"_id":86,"tag":"activity","attrib":{"android:name":"com.intel.GooglePlayGamesService"},"text":"\n        ","tail":"\n            ","_children":[]},{"_id":87,"tag":"meta-data","attrib":{"android:name":"com.google.android.gms.games.APP_ID","android:value":"@string/google_play_services_app_id"},"text":"","tail":"\n        ","_children":[]}]},{"_id":88,"tag":"source-file","attrib":{"src":"src/android/GooglePlayGamesService.java","target-dir":"src/com/intel"},"text":"","tail":"\n        ","_children":[]},{"_id":89,"tag":"source-file","attrib":{"src":"src/android/GooglePlayGamesPlugin.java","target-dir":"src/com/intel"},"text":"","tail":"\n        ","_children":[]},{"_id":90,"tag":"source-file","attrib":{"src":"src/android/com/google/example/games/basegameutils/BaseGameActivity.java","target-dir":"src/com/google/example/games/basegameutils"},"text":"","tail":"\n        ","_children":[]},{"_id":91,"tag":"source-file","attrib":{"src":"src/android/com/google/example/games/basegameutils/GameHelper.java","target-dir":"src/com/google/example/games/basegameutils"},"text":"","tail":"\n            ","_children":[]},{"_id":92,"tag":"source-file","attrib":{"src":"src/android/com/google/example/games/basegameutils/GameHelperUtils.java","target-dir":"src/com/google/example/games/basegameutils"},"text":"","tail":"\n    ","_children":[]}]},{"_id":93,"tag":"platform","attrib":{"name":"ios"},"text":"\n        ","tail":"\n","_children":[{"_id":94,"tag":"dependency","attrib":{"id":"cordova-plugin-gamecenter","url":"https://github.com/Wizcorp/cordova-plugin-gameCenter"},"text":"","tail":"\n         ","_children":[]},{"_id":95,"tag":"js-module","attrib":{"src":"www/iOSGooglePlayGamesPlugin.js","name":"GooglePlayGamesPlugin"},"text":"\n            ","tail":"\n    ","_children":[{"_id":96,"tag":"merges","attrib":{"target":"window.GooglePlayGamesPlugin"},"text":"","tail":"\n        ","_children":[]}]}]}]}},"id":"com.intel.googleplaygamesplugin","version":"1.0.7","name":"GooglePlayGamesPlugin","description":"Google Play Games Plugin","license":"MIT","keywords":["GooglePlayGamesPlugin"]}},"_getAllCache":{}},"nohooks":["."]}"
Installing "com.intel.googleplaygamesplugin" for android
Dependencies detected, iterating through them...
Dependent plugin "android.support.v4" already fetched, using that version.
Dependent plugin "android.support.v4" already installed on android.
Dependent plugin "com.google.playservices" already fetched, using that version.
Dependent plugin "com.google.playservices" already installed on android.
Install start for "com.intel.googleplaygamesplugin" on android.
  'com.google.playservices',
  'com.intel.googleplaygamesplugin' ]
Install complete for com.intel.googleplaygamesplugin on android.
Calling plugman.fetch on plugin ".../cachedPlugins.2tS1ac.tmp/cache.jr7XDb.pl/cordova-plugin-gamecenter"
Copying plugin ".../cachedPlugins.2tS1ac.tmp/cache.jr7XDb.pl/cordova-plugin-gamecenter" => ".../mygamename/plugins/cordova-plugin-gamecenter"
Calling plugman.install on plugin ".../mygamename/plugins/cordova-plugin-gamecenter" for platform "android" with options "{"cli_variables":{},"browserify":false,"link":false,"pluginInfoProvider":{"_cache":{".../cachedPlugins.2tS1ac.tmp/cache.jr7XDb.pl/cordova-plugin-gamecenter":{"filepath":".../cachedPlugins.2tS1ac.tmp/cache.jr7XDb.pl/cordova-plugin-gamecenter/plugin.xml","dir":".../cachedPlugins.2tS1ac.tmp/cache.jr7XDb.pl/cordova-plugin-gamecenter","_et":{"_root":{"_id":25,"tag":"plugin","attrib":{"xmlns":"http://apache.org/cordova/ns/plugins/1.0","xmlns:android":"http://schemas.android.com/apk/res/android","id":"cordova-plugin-gamecenter","version":"0.4.0"},"text":"\r\n\r\n    ","tail":null,"_children":[{"_id":26,"tag":"name","attrib":{},"text":"Game Center Plugin","tail":"\r\n    \r\n    ","_children":[]},{"_id":27,"tag":"description","attrib":{},"text":"This plugin allows interaction with iOS Game Center.","tail":"\r\n    \r\n    ","_children":[]},{"_id":28,"tag":"author","attrib":{},"text":"Ally Ogilvie - aogilvie@wizcorp.jp","tail":"\r\n    \r\n    ","_children":[]},{"_id":29,"tag":"keywords","attrib":{},"text":"wizcorp, wizard, gamecenter, game, center","tail":"\r\n\t\r\n\t","_children":[]},{"_id":30,"tag":"engines","attrib":{},"text":"\r\n\t    ","tail":"\r\n\r\n    ","_children":[{"_id":31,"tag":"engine","attrib":{"name":"cordova","version":">=3.0.0"},"text":"","tail":"\r\n\t","_children":[]}]},{"_id":32,"tag":"license","attrib":{},"text":"MIT","tail":"\r\n\r\n    ","_children":[]},{"_id":33,"tag":"js-module","attrib":{"src":"www/GameCenter.js","name":"GameCenter"},"text":"\r\n        ","tail":"\r\n    \r\n    \r\n    ","_children":[{"_id":34,"tag":"clobbers","attrib":{"target":"window.gameCenter"},"text":"","tail":"\r\n    ","_children":[]}]},{"_id":35,"tag":"platform","attrib":{"name":"ios"},"text":"\r\n\r\n        ","tail":"\r\n\r\n","_children":[{"_id":36,"tag":"config-file","attrib":{"target":"config.xml","parent":"/*"},"text":"\r\n\t\t    ","tail":"\r\n               \r\n        \r\n        ","_children":[{"_id":37,"tag":"feature","attrib":{"name":"GameCenterPlugin"},"text":"\r\n\t\t        ","tail":"\r\n        ","_children":[{"_id":38,"tag":"param","attrib":{"name":"ios-package","value":"GameCenterPlugin"},"text":"","tail":"\r\n\t\t        ","_children":[]},{"_id":39,"tag":"param","attrib":{"name":"onload","value":"true"},"text":"","tail":"\r\n\t\t    ","_children":[]}]}]},{"_id":40,"tag":"header-file","attrib":{"src":"platforms/ios/HelloCordova/Plugins/GameCenterPlugin/GameCenterPlugin.h","compiler-flags":"-fno-objc-arc"},"text":"","tail":"\r\n        ","_children":[]},{"_id":41,"tag":"source-file","attrib":{"src":"platforms/ios/HelloCordova/Plugins/GameCenterPlugin/GameCenterPlugin.m","compiler-flags":"-fno-objc-arc"},"text":"","tail":"\r\n        \r\n        ","_children":[]},{"_id":42,"tag":"framework","attrib":{"src":"GameKit.framework"},"text":"","tail":"\r\n                \t\r\n    ","_children":[]}]}]}},"id":"cordova-plugin-gamecenter","version":"0.4.0","name":"Game Center Plugin","description":"This plugin allows interaction with iOS Game Center.","license":"MIT","keywords":["wizcorp","wizard","gamecenter","game","center"]},".../mygamename/plugins/cordova-plugin-gamecenter":{"filepath":".../mygamename/plugins/cordova-plugin-gamecenter/plugin.xml","dir":".../mygamename/plugins/cordova-plugin-gamecenter","_et":{"_root":{"_id":43,"tag":"plugin","attrib":{"xmlns":"http://apache.org/cordova/ns/plugins/1.0","xmlns:android":"http://schemas.android.com/apk/res/android","id":"cordova-plugin-gamecenter","version":"0.4.0"},"text":"\r\n\r\n    ","tail":null,"_children":[{"_id":44,"tag":"name","attrib":{},"text":"Game Center Plugin","tail":"\r\n    \r\n    ","_children":[]},{"_id":45,"tag":"description","attrib":{},"text":"This plugin allows interaction with iOS Game Center.","tail":"\r\n    \r\n    ","_children":[]},{"_id":46,"tag":"author","attrib":{},"text":"Ally Ogilvie - aogilvie@wizcorp.jp","tail":"\r\n    \r\n    ","_children":[]},{"_id":47,"tag":"keywords","attrib":{},"text":"wizcorp, wizard, gamecenter, game, center","tail":"\r\n\t\r\n\t","_children":[]},{"_id":48,"tag":"engines","attrib":{},"text":"\r\n\t    ","tail":"\r\n\r\n    ","_children":[{"_id":49,"tag":"engine","attrib":{"name":"cordova","version":">=3.0.0"},"text":"","tail":"\r\n\t","_children":[]}]},{"_id":50,"tag":"license","attrib":{},"text":"MIT","tail":"\r\n\r\n    ","_children":[]},{"_id":51,"tag":"js-module","attrib":{"src":"www/GameCenter.js","name":"GameCenter"},"text":"\r\n        ","tail":"\r\n    \r\n    \r\n    ","_children":[{"_id":52,"tag":"clobbers","attrib":{"target":"window.gameCenter"},"text":"","tail":"\r\n    ","_children":[]}]},{"_id":53,"tag":"platform","attrib":{"name":"ios"},"text":"\r\n\r\n        ","tail":"\r\n\r\n","_children":[{"_id":54,"tag":"config-file","attrib":{"target":"config.xml","parent":"/*"},"text":"\r\n\t\t    ","tail":"\r\n               \r\n        \r\n        ","_children":[{"_id":55,"tag":"feature","attrib":{"name":"GameCenterPlugin"},"text":"\r\n\t\t        ","tail":"\r\n        ","_children":[{"_id":56,"tag":"param","attrib":{"name":"ios-package","value":"GameCenterPlugin"},"text":"","tail":"\r\n\t\t        ","_children":[]},{"_id":57,"tag":"param","attrib":{"name":"onload","value":"true"},"text":"","tail":"\r\n\t\t    ","_children":[]}]}]},{"_id":58,"tag":"header-file","attrib":{"src":"platforms/ios/HelloCordova/Plugins/GameCenterPlugin/GameCenterPlugin.h","compiler-flags":"-fno-objc-arc"},"text":"","tail":"\r\n        ","_children":[]},{"_id":59,"tag":"source-file","attrib":{"src":"platforms/ios/HelloCordova/Plugins/GameCenterPlugin/GameCenterPlugin.m","compiler-flags":"-fno-objc-arc"},"text":"","tail":"\r\n        \r\n        ","_children":[]},{"_id":60,"tag":"framework","attrib":{"src":"GameKit.framework"},"text":"","tail":"\r\n                \t\r\n    ","_children":[]}]}]}},"id":"cordova-plugin-gamecenter","version":"0.4.0","name":"Game Center Plugin","description":"This plugin allows interaction with iOS Game Center.","license":"MIT","keywords":["wizcorp","wizard","gamecenter","game","center"]}},"_getAllCache":{}},"nohooks":["."]}"
Installing "cordova-plugin-gamecenter" for android
Install start for "cordova-plugin-gamecenter" on android.
  'com.intel.googleplaygamesplugin',
  'cordova-plugin-gamecenter' ]
Install complete for cordova-plugin-gamecenter on android.
Calling plugman.fetch on plugin ".../cachedPlugins.2tS1ac.tmp/cache.brjvE0.pl/cordova-plugin-legacy-whitelist"
Copying plugin ".../cachedPlugins.2tS1ac.tmp/cache.brjvE0.pl/cordova-plugin-legacy-whitelist" => ".../mygamename/plugins/cordova-plugin-legacy-whitelist"
Calling plugman.install on plugin ".../mygamename/plugins/cordova-plugin-legacy-whitelist" for platform "android" with options "{"cli_variables":{},"browserify":false,"link":false,"pluginInfoProvider":{"_cache":{".../cachedPlugins.2tS1ac.tmp/cache.brjvE0.pl/cordova-plugin-legacy-whitelist":{"filepath":".../cachedPlugins.2tS1ac.tmp/cache.brjvE0.pl/cordova-plugin-legacy-whitelist/plugin.xml","dir":".../cachedPlugins.2tS1ac.tmp/cache.brjvE0.pl/cordova-plugin-legacy-whitelist","_et":{"_root":{"_id":25,"tag":"plugin","attrib":{"xmlns":"http://apache.org/cordova/ns/plugins/1.0","id":"cordova-plugin-legacy-whitelist","version":"1.1.0"},"text":"\n    ","tail":null,"_children":[{"_id":26,"tag":"name","attrib":{},"text":"Legacy Whitelist","tail":"\n    ","_children":[]},{"_id":27,"tag":"description","attrib":{},"text":"Cordova Legacy Whitelist Plugin","tail":"\n    ","_children":[]},{"_id":28,"tag":"license","attrib":{},"text":"Apache 2.0","tail":"\n    ","_children":[]},{"_id":29,"tag":"keywords","attrib":{},"text":"cordova,whitelist","tail":"\n\n    ","_children":[]},{"_id":30,"tag":"platform","attrib":{"name":"android"},"text":"\n        ","tail":"\n\n    \n","_children":[{"_id":31,"tag":"config-file","attrib":{"target":"res/xml/config.xml","parent":"/*"},"text":"\n            ","tail":"\n\n        ","_children":[{"_id":32,"tag":"feature","attrib":{"name":"Whitelist"},"text":"\n                ","tail":"\n        ","_children":[{"_id":33,"tag":"param","attrib":{"name":"android-package","value":"org.apache.cordova.whitelist.LegacyWhitelistPlugin"},"text":"","tail":"\n                ","_children":[]},{"_id":34,"tag":"param","attrib":{"name":"onload","value":"true"},"text":"","tail":"\n            ","_children":[]}]}]},{"_id":35,"tag":"source-file","attrib":{"src":"src/android/LegacyWhitelistPlugin.java","target-dir":"src/org/apache/cordova/whitelist"},"text":"","tail":"\n    ","_children":[]}]}]}},"id":"cordova-plugin-legacy-whitelist","version":"1.1.0","name":"Legacy Whitelist","description":"Cordova Legacy Whitelist Plugin","license":"Apache 2.0","keywords":["cordova","whitelist"]},".../mygamename/plugins/cordova-plugin-legacy-whitelist":{"filepath":".../mygamename/plugins/cordova-plugin-legacy-whitelist/plugin.xml","dir":".../mygamename/plugins/cordova-plugin-legacy-whitelist","_et":{"_root":{"_id":36,"tag":"plugin","attrib":{"xmlns":"http://apache.org/cordova/ns/plugins/1.0","id":"cordova-plugin-legacy-whitelist","version":"1.1.0"},"text":"\n    ","tail":null,"_children":[{"_id":37,"tag":"name","attrib":{},"text":"Legacy Whitelist","tail":"\n    ","_children":[]},{"_id":38,"tag":"description","attrib":{},"text":"Cordova Legacy Whitelist Plugin","tail":"\n    ","_children":[]},{"_id":39,"tag":"license","attrib":{},"text":"Apache 2.0","tail":"\n    ","_children":[]},{"_id":40,"tag":"keywords","attrib":{},"text":"cordova,whitelist","tail":"\n\n    ","_children":[]},{"_id":41,"tag":"platform","attrib":{"name":"android"},"text":"\n        ","tail":"\n\n    \n","_children":[{"_id":42,"tag":"config-file","attrib":{"target":"res/xml/config.xml","parent":"/*"},"text":"\n            ","tail":"\n\n        ","_children":[{"_id":43,"tag":"feature","attrib":{"name":"Whitelist"},"text":"\n                ","tail":"\n        ","_children":[{"_id":44,"tag":"param","attrib":{"name":"android-package","value":"org.apache.cordova.whitelist.LegacyWhitelistPlugin"},"text":"","tail":"\n                ","_children":[]},{"_id":45,"tag":"param","attrib":{"name":"onload","value":"true"},"text":"","tail":"\n            ","_children":[]}]}]},{"_id":46,"tag":"source-file","attrib":{"src":"src/android/LegacyWhitelistPlugin.java","target-dir":"src/org/apache/cordova/whitelist"},"text":"","tail":"\n    ","_children":[]}]}]}},"id":"cordova-plugin-legacy-whitelist","version":"1.1.0","name":"Legacy Whitelist","description":"Cordova Legacy Whitelist Plugin","license":"Apache 2.0","keywords":["cordova","whitelist"]}},"_getAllCache":{}},"nohooks":["."]}"
Installing "cordova-plugin-legacy-whitelist" for android
Install start for "cordova-plugin-legacy-whitelist" on android.
  'cordova-plugin-gamecenter',
  'cordova-plugin-legacy-whitelist' ]
Install complete for cordova-plugin-legacy-whitelist on android.
Calling plugman.fetch on plugin ".../cachedPlugins.2tS1ac.tmp/cache.cxmDeg.pl/org.apache.cordova.inappbrowser"
Copying plugin ".../cachedPlugins.2tS1ac.tmp/cache.cxmDeg.pl/org.apache.cordova.inappbrowser" => ".../mygamename/plugins/org.apache.cordova.inappbrowser"
Calling plugman.install on plugin ".../mygamename/plugins/org.apache.cordova.inappbrowser" for platform "android" with options "{"cli_variables":{},"browserify":false,"link":false,"pluginInfoProvider":{"_cache":{".../cachedPlugins.2tS1ac.tmp/cache.cxmDeg.pl/org.apache.cordova.inappbrowser":{"filepath":".../cachedPlugins.2tS1ac.tmp/cache.cxmDeg.pl/org.apache.cordova.inappbrowser/plugin.xml","dir":".../cachedPlugins.2tS1ac.tmp/cache.cxmDeg.pl/org.apache.cordova.inappbrowser","_et":{"_root":{"_id":25,"tag":"plugin","attrib":{"xmlns":"http://apache.org/cordova/ns/plugins/1.0","id":"org.apache.cordova.inappbrowser","version":"0.6.0"},"text":"\n\n    ","tail":null,"_children":[{"_id":26,"tag":"name","attrib":{},"text":"InAppBrowser","tail":"\n    ","_children":[]},{"_id":27,"tag":"description","attrib":{},"text":"Cordova InAppBrowser Plugin","tail":"\n    ","_children":[]},{"_id":28,"tag":"license","attrib":{},"text":"Apache 2.0","tail":"\n    ","_children":[]},{"_id":29,"tag":"keywords","attrib":{},"text":"cordova,in,app,browser,inappbrowser","tail":"\n    ","_children":[]},{"_id":30,"tag":"repo","attrib":{},"text":"https://git-wip-us.apache.org/repos/asf/cordova-plugin-inappbrowser.git","tail":"\n    ","_children":[]},{"_id":31,"tag":"issue","attrib":{},"text":"https://issues.apache.org/jira/browse/CB/component/12320641","tail":"\n\n    ","_children":[]},{"_id":32,"tag":"engines","attrib":{},"text":"\n      ","tail":"\n\n    \n    ","_children":[{"_id":33,"tag":"engine","attrib":{"name":"cordova","version":">=3.1.0"},"text":"","tail":"\n    ","_children":[]}]},{"_id":34,"tag":"platform","attrib":{"name":"android"},"text":"\n        ","tail":"\n\n    \n    ","_children":[{"_id":35,"tag":"js-module","attrib":{"src":"www/inappbrowser.js","name":"inappbrowser"},"text":"\n            ","tail":"\n        ","_children":[{"_id":36,"tag":"clobbers","attrib":{"target":"window.open"},"text":"","tail":"\n        ","_children":[]}]},{"_id":37,"tag":"config-file","attrib":{"target":"res/xml/config.xml","parent":"/*"},"text":"\n            ","tail":"\n\n        ","_children":[{"_id":38,"tag":"feature","attrib":{"name":"InAppBrowser"},"text":" \n                ","tail":"\n        ","_children":[{"_id":39,"tag":"param","attrib":{"name":"android-package","value":"org.apache.cordova.inappbrowser.InAppBrowser"},"text":"","tail":"\n            ","_children":[]}]}]},{"_id":40,"tag":"source-file","attrib":{"src":"src/android/InAppBrowser.java","target-dir":"src/org/apache/cordova/inappbrowser"},"text":"","tail":"\n        ","_children":[]},{"_id":41,"tag":"source-file","attrib":{"src":"src/android/InAppBrowserDialog.java","target-dir":"src/org/apache/cordova/inappbrowser"},"text":"","tail":"\n        ","_children":[]},{"_id":42,"tag":"source-file","attrib":{"src":"src/android/InAppChromeClient.java","target-dir":"src/org/apache/cordova/inappbrowser"},"text":"","tail":"\n\n        \n        ","_children":[]},{"_id":43,"tag":"resource-file","attrib":{"src":"src/android/res/drawable-hdpi/ic_action_next_item.png","target":"res/drawable-hdpi/ic_action_next_item.png"},"text":"","tail":"\n        ","_children":[]},{"_id":44,"tag":"resource-file","attrib":{"src":"src/android/res/drawable-mdpi/ic_action_next_item.png","target":"res/drawable-mdpi/ic_action_next_item.png"},"text":"","tail":"\n        ","_children":[]},{"_id":45,"tag":"resource-file","attrib":{"src":"src/android/res/drawable-xhdpi/ic_action_next_item.png","target":"res/drawable-xhdpi/ic_action_next_item.png"},"text":"","tail":"\n        ","_children":[]},{"_id":46,"tag":"resource-file","attrib":{"src":"src/android/res/drawable-xxhdpi/ic_action_next_item.png","target":"res/drawable-xxhdpi/ic_action_next_item.png"},"text":"","tail":"\n\n        ","_children":[]},{"_id":47,"tag":"resource-file","attrib":{"src":"src/android/res/drawable-hdpi/ic_action_previous_item.png","target":"res/drawable-hdpi/ic_action_previous_item.png"},"text":"","tail":"\n        ","_children":[]},{"_id":48,"tag":"resource-file","attrib":{"src":"src/android/res/drawable-mdpi/ic_action_previous_item.png","target":"res/drawable-mdpi/ic_action_previous_item.png"},"text":"","tail":"\n        ","_children":[]},{"_id":49,"tag":"resource-file","attrib":{"src":"src/android/res/drawable-xhdpi/ic_action_previous_item.png","target":"res/drawable-xhdpi/ic_action_previous_item.png"},"text":"","tail":"\n        ","_children":[]},{"_id":50,"tag":"resource-file","attrib":{"src":"src/android/res/drawable-xxhdpi/ic_action_previous_item.png","target":"res/drawable-xxhdpi/ic_action_previous_item.png"},"text":"","tail":"\n\n        ","_children":[]},{"_id":51,"tag":"resource-file","attrib":{"src":"src/android/res/drawable-hdpi/ic_action_remove.png","target":"res/drawable-hdpi/ic_action_remove.png"},"text":"","tail":"\n        ","_children":[]},{"_id":52,"tag":"resource-file","attrib":{"src":"src/android/res/drawable-mdpi/ic_action_remove.png","target":"res/drawable-mdpi/ic_action_remove.png"},"text":"","tail":"\n        ","_children":[]},{"_id":53,"tag":"resource-file","attrib":{"src":"src/android/res/drawable-xhdpi/ic_action_remove.png","target":"res/drawable-xhdpi/ic_action_remove.png"},"text":"","tail":"\n        ","_children":[]},{"_id":54,"tag":"resource-file","attrib":{"src":"src/android/res/drawable-xxhdpi/ic_action_remove.png","target":"res/drawable-xxhdpi/ic_action_remove.png"},"text":"","tail":"\n\n    ","_children":[]}]},{"_id":55,"tag":"platform","attrib":{"name":"amazon-fireos"},"text":"\n        ","tail":"\n    \n    \n    ","_children":[{"_id":56,"tag":"js-module","attrib":{"src":"www/inappbrowser.js","name":"inappbrowser"},"text":"\n            ","tail":"\n        ","_children":[{"_id":57,"tag":"clobbers","attrib":{"target":"window.open"},"text":"","tail":"\n        ","_children":[]}]},{"_id":58,"tag":"config-file","attrib":{"target":"res/xml/config.xml","parent":"/*"},"text":"\n            ","tail":"\n\n        ","_children":[{"_id":59,"tag":"feature","attrib":{"name":"InAppBrowser"},"text":" \n                ","tail":"\n        ","_children":[{"_id":60,"tag":"param","attrib":{"name":"android-package","value":"org.apache.cordova.inappbrowser.InAppBrowser"},"text":"","tail":"\n            ","_children":[]}]}]},{"_id":61,"tag":"source-file","attrib":{"src":"src/amazon/InAppBrowser.java","target-dir":"src/org/apache/cordova/inappbrowser"},"text":"","tail":"\n        ","_children":[]},{"_id":62,"tag":"source-file","attrib":{"src":"src/android/InAppBrowserDialog.java","target-dir":"src/org/apache/cordova/inappbrowser"},"text":"","tail":"\n        ","_children":[]},{"_id":63,"tag":"source-file","attrib":{"src":"src/amazon/InAppChromeClient.java","target-dir":"src/org/apache/cordova/inappbrowser"},"text":"","tail":"\n        \n        \n        ","_children":[]},{"_id":64,"tag":"resource-file","attrib":{"src":"src/android/res/drawable-hdpi/ic_action_next_item.png","target":"res/drawable-hdpi/ic_action_next_item.png"},"text":"","tail":"\n        ","_children":[]},{"_id":65,"tag":"resource-file","attrib":{"src":"src/android/res/drawable-mdpi/ic_action_next_item.png","target":"res/drawable-mdpi/ic_action_next_item.png"},"text":"","tail":"\n        ","_children":[]},{"_id":66,"tag":"resource-file","attrib":{"src":"src/android/res/drawable-xhdpi/ic_action_next_item.png","target":"res/drawable-xhdpi/ic_action_next_item.png"},"text":"","tail":"\n        ","_children":[]},{"_id":67,"tag":"resource-file","attrib":{"src":"src/android/res/drawable-xxhdpi/ic_action_next_item.png","target":"res/drawable-xxhdpi/ic_action_next_item.png"},"text":"","tail":"\n        \n        ","_children":[]},{"_id":68,"tag":"resource-file","attrib":{"src":"src/android/res/drawable-hdpi/ic_action_previous_item.png","target":"res/drawable-hdpi/ic_action_previous_item.png"},"text":"","tail":"\n        ","_children":[]},{"_id":69,"tag":"resource-file","attrib":{"src":"src/android/res/drawable-mdpi/ic_action_previous_item.png","target":"res/drawable-mdpi/ic_action_previous_item.png"},"text":"","tail":"\n        ","_children":[]},{"_id":70,"tag":"resource-file","attrib":{"src":"src/android/res/drawable-xhdpi/ic_action_previous_item.png","target":"res/drawable-xhdpi/ic_action_previous_item.png"},"text":"","tail":"\n        ","_children":[]},{"_id":71,"tag":"resource-file","attrib":{"src":"src/android/res/drawable-xxhdpi/ic_action_previous_item.png","target":"res/drawable-xxhdpi/ic_action_previous_item.png"},"text":"","tail":"\n        \n        ","_children":[]},{"_id":72,"tag":"resource-file","attrib":{"src":"src/android/res/drawable-hdpi/ic_action_remove.png","target":"res/drawable-hdpi/ic_action_remove.png"},"text":"","tail":"\n        ","_children":[]},{"_id":73,"tag":"resource-file","attrib":{"src":"src/android/res/drawable-mdpi/ic_action_remove.png","target":"res/drawable-mdpi/ic_action_remove.png"},"text":"","tail":"\n        ","_children":[]},{"_id":74,"tag":"resource-file","attrib":{"src":"src/android/res/drawable-xhdpi/ic_action_remove.png","target":"res/drawable-xhdpi/ic_action_remove.png"},"text":"","tail":"\n        ","_children":[]},{"_id":75,"tag":"resource-file","attrib":{"src":"src/android/res/drawable-xxhdpi/ic_action_remove.png","target":"res/drawable-xxhdpi/ic_action_remove.png"},"text":"","tail":"\n    ","_children":[]}]},{"_id":76,"tag":"platform","attrib":{"name":"ubuntu"},"text":"\n        ","tail":"\n\n    \n    ","_children":[{"_id":77,"tag":"js-module","attrib":{"src":"www/inappbrowser.js","name":"inappbrowser"},"text":"\n            ","tail":"\n        ","_children":[{"_id":78,"tag":"clobbers","attrib":{"target":"window.open"},"text":"","tail":"\n        ","_children":[]}]},{"_id":79,"tag":"header-file","attrib":{"src":"src/ubuntu/inappbrowser.h"},"text":"","tail":"\n        ","_children":[]},{"_id":80,"tag":"source-file","attrib":{"src":"src/ubuntu/inappbrowser.cpp"},"text":"","tail":"\n        ","_children":[]},{"_id":81,"tag":"resource-file","attrib":{"src":"src/ubuntu/InAppBrowser.qml"},"text":"","tail":"\n        ","_children":[]},{"_id":82,"tag":"resource-file","attrib":{"src":"src/ubuntu/InAppBrowser_escapeScript.js"},"text":"","tail":"\n        ","_children":[]},{"_id":83,"tag":"resource-file","attrib":{"src":"src/ubuntu/close.png"},"text":"","tail":"\n    ","_children":[]}]},{"_id":84,"tag":"platform","attrib":{"name":"ios"},"text":"\n        ","tail":"\n\n    \n    ","_children":[{"_id":85,"tag":"js-module","attrib":{"src":"www/inappbrowser.js","name":"inappbrowser"},"text":"\n            ","tail":"  \n        ","_children":[{"_id":86,"tag":"clobbers","attrib":{"target":"window.open"},"text":"","tail":"\n        ","_children":[]}]},{"_id":87,"tag":"config-file","attrib":{"target":"config.xml","parent":"/*"},"text":"\n            ","tail":"\n\n        ","_children":[{"_id":88,"tag":"feature","attrib":{"name":"InAppBrowser"},"text":"\n                ","tail":"\n        ","_children":[{"_id":89,"tag":"param","attrib":{"name":"ios-package","value":"CDVInAppBrowser"},"text":"","tail":" \n            ","_children":[]}]}]},{"_id":90,"tag":"header-file","attrib":{"src":"src/ios/CDVInAppBrowser.h"},"text":"","tail":"\n\t    ","_children":[]},{"_id":91,"tag":"source-file","attrib":{"src":"src/ios/CDVInAppBrowser.m"},"text":"","tail":"\n\t    \n\t    ","_children":[]},{"_id":92,"tag":"framework","attrib":{"src":"CoreGraphics.framework"},"text":"","tail":"\n    ","_children":[]}]},{"_id":93,"tag":"platform","attrib":{"name":"wp7"},"text":"\n        ","tail":"\n\n    \n    ","_children":[{"_id":94,"tag":"config-file","attrib":{"target":"Properties/WMAppManifest.xml","parent":"/Deployment/App/Capabilities"},"text":"\n            ","tail":"\n\n        ","_children":[{"_id":95,"tag":"Capability","attrib":{"Name":"ID_CAP_NETWORKING"},"text":"","tail":"\n        ","_children":[]}]},{"_id":96,"tag":"js-module","attrib":{"src":"www/inappbrowser.js","name":"inappbrowser"},"text":"\n            ","tail":"\n        ","_children":[{"_id":97,"tag":"clobbers","attrib":{"target":"window.open"},"text":"","tail":"\n        ","_children":[]}]},{"_id":98,"tag":"config-file","attrib":{"target":"config.xml","parent":"/*"},"text":"\n            ","tail":"\n\n        ","_children":[{"_id":99,"tag":"feature","attrib":{"name":"InAppBrowser"},"text":"\n                ","tail":"\n        ","_children":[{"_id":100,"tag":"param","attrib":{"name":"wp-package","value":"InAppBrowser"},"text":"","tail":"\n            ","_children":[]}]}]},{"_id":101,"tag":"config-file","attrib":{"target":"Properties/WMAppManifest.xml","parent":"/Deployment/App/Capabilities"},"text":"\n            ","tail":"\n\n        ","_children":[{"_id":102,"tag":"Capability","attrib":{"Name":"ID_CAP_NETWORKING"},"text":"","tail":"\n        ","_children":[]}]},{"_id":103,"tag":"source-file","attrib":{"src":"src/wp/InAppBrowser.cs"},"text":"","tail":"\n    ","_children":[]}]},{"_id":104,"tag":"platform","attrib":{"name":"wp8"},"text":"\n        ","tail":"\n\n    \n    ","_children":[{"_id":105,"tag":"config-file","attrib":{"target":"Properties/WMAppManifest.xml","parent":"/Deployment/App/Capabilities"},"text":"\n            ","tail":"\n                \n        ","_children":[{"_id":106,"tag":"Capability","attrib":{"Name":"ID_CAP_NETWORKING"},"text":"","tail":"\n        ","_children":[]}]},{"_id":107,"tag":"js-module","attrib":{"src":"www/inappbrowser.js","name":"inappbrowser"},"text":"\n            ","tail":"\n        ","_children":[{"_id":108,"tag":"clobbers","attrib":{"target":"window.open"},"text":"","tail":"\n        ","_children":[]}]},{"_id":109,"tag":"config-file","attrib":{"target":"config.xml","parent":"/*"},"text":"\n            ","tail":"\n\n        ","_children":[{"_id":110,"tag":"feature","attrib":{"name":"InAppBrowser"},"text":"\n                ","tail":"\n        ","_children":[{"_id":111,"tag":"param","attrib":{"name":"wp-package","value":"InAppBrowser"},"text":"","tail":"\n            ","_children":[]}]}]},{"_id":112,"tag":"config-file","attrib":{"target":"Properties/WMAppManifest.xml","parent":"/Deployment/App/Capabilities"},"text":"\n            ","tail":"\n\n        ","_children":[{"_id":113,"tag":"Capability","attrib":{"Name":"ID_CAP_NETWORKING"},"text":"","tail":"\n        ","_children":[]}]},{"_id":114,"tag":"source-file","attrib":{"src":"src/wp/InAppBrowser.cs"},"text":"","tail":"\n    ","_children":[]}]},{"_id":115,"tag":"platform","attrib":{"name":"windows8"},"text":"\n        ","tail":"\n\n    \n    ","_children":[{"_id":116,"tag":"js-module","attrib":{"src":"www/inappbrowser.js","name":"inappbrowser"},"text":"\n            ","tail":"\n        ","_children":[{"_id":117,"tag":"clobbers","attrib":{"target":"window.open"},"text":"","tail":"\n        ","_children":[]}]},{"_id":118,"tag":"js-module","attrib":{"src":"www/windows8/InAppBrowserProxy.js","name":"InAppBrowserProxy"},"text":"\n            ","tail":"\n    ","_children":[{"_id":119,"tag":"merges","attrib":{"target":""},"text":"","tail":"\n        ","_children":[]}]}]},{"_id":120,"tag":"platform","attrib":{"name":"windows"},"text":"\n        ","tail":"\n  \n    \n    ","_children":[{"_id":121,"tag":"js-module","attrib":{"src":"www/inappbrowser.js","name":"inappbrowser"},"text":"\n            ","tail":"\n        ","_children":[{"_id":122,"tag":"clobbers","attrib":{"target":"window.open"},"text":"","tail":"\n        ","_children":[]}]},{"_id":123,"tag":"js-module","attrib":{"src":"src/windows/InAppBrowserProxy.js","name":"InAppBrowserProxy"},"text":"\n            ","tail":"\n    ","_children":[{"_id":124,"tag":"merges","attrib":{"target":""},"text":"","tail":"\n        ","_children":[]}]}]},{"_id":125,"tag":"platform","attrib":{"name":"firefoxos"},"text":"\n        ","tail":"\n\n","_children":[{"_id":126,"tag":"config-file","attrib":{"target":"config.xml","parent":"/*"},"text":"\n            ","tail":"\n        ","_children":[{"_id":127,"tag":"permission","attrib":{"name":"browser","description":"Enables the app to implement a browser in an iframe.","privileged":"true"},"text":"","tail":"\n        ","_children":[]}]},{"_id":128,"tag":"js-module","attrib":{"src":"www/inappbrowser.js","name":"inappbrowser"},"text":"\n            ","tail":"\n        ","_children":[{"_id":129,"tag":"clobbers","attrib":{"target":"window.open"},"text":"","tail":"\n        ","_children":[]}]},{"_id":130,"tag":"js-module","attrib":{"src":"src/firefoxos/InAppBrowserProxy.js","name":"InAppBrowserProxy"},"text":"\n            ","tail":"\n    ","_children":[{"_id":131,"tag":"merges","attrib":{"target":""},"text":"","tail":"\n        ","_children":[]}]}]}]}},"id":"org.apache.cordova.inappbrowser","version":"0.6.0","name":"InAppBrowser","description":"Cordova InAppBrowser Plugin","license":"Apache 2.0","repo":"https://git-wip-us.apache.org/repos/asf/cordova-plugin-inappbrowser.git","issue":"https://issues.apache.org/jira/browse/CB/component/12320641","keywords":["cordova","in","app","browser","inappbrowser"]},".../mygamename/plugins/org.apache.cordova.inappbrowser":{"filepath":".../mygamename/plugins/org.apache.cordova.inappbrowser/plugin.xml","dir":".../mygamename/plugins/org.apache.cordova.inappbrowser","_et":{"_root":{"_id":132,"tag":"plugin","attrib":{"xmlns":"http://apache.org/cordova/ns/plugins/1.0","id":"org.apache.cordova.inappbrowser","version":"0.6.0"},"text":"\n\n    ","tail":null,"_children":[{"_id":133,"tag":"name","attrib":{},"text":"InAppBrowser","tail":"\n    ","_children":[]},{"_id":134,"tag":"description","attrib":{},"text":"Cordova InAppBrowser Plugin","tail":"\n    ","_children":[]},{"_id":135,"tag":"license","attrib":{},"text":"Apache 2.0","tail":"\n    ","_children":[]},{"_id":136,"tag":"keywords","attrib":{},"text":"cordova,in,app,browser,inappbrowser","tail":"\n    ","_children":[]},{"_id":137,"tag":"repo","attrib":{},"text":"https://git-wip-us.apache.org/repos/asf/cordova-plugin-inappbrowser.git","tail":"\n    ","_children":[]},{"_id":138,"tag":"issue","attrib":{},"text":"https://issues.apache.org/jira/browse/CB/component/12320641","tail":"\n\n    ","_children":[]},{"_id":139,"tag":"engines","attrib":{},"text":"\n      ","tail":"\n\n    \n    ","_children":[{"_id":140,"tag":"engine","attrib":{"name":"cordova","version":">=3.1.0"},"text":"","tail":"\n    ","_children":[]}]},{"_id":141,"tag":"platform","attrib":{"name":"android"},"text":"\n        ","tail":"\n\n    \n    ","_children":[{"_id":142,"tag":"js-module","attrib":{"src":"www/inappbrowser.js","name":"inappbrowser"},"text":"\n            ","tail":"\n        ","_children":[{"_id":143,"tag":"clobbers","attrib":{"target":"window.open"},"text":"","tail":"\n        ","_children":[]}]},{"_id":144,"tag":"config-file","attrib":{"target":"res/xml/config.xml","parent":"/*"},"text":"\n            ","tail":"\n\n        ","_children":[{"_id":145,"tag":"feature","attrib":{"name":"InAppBrowser"},"text":" \n                ","tail":"\n        ","_children":[{"_id":146,"tag":"param","attrib":{"name":"android-package","value":"org.apache.cordova.inappbrowser.InAppBrowser"},"text":"","tail":"\n            ","_children":[]}]}]},{"_id":147,"tag":"source-file","attrib":{"src":"src/android/InAppBrowser.java","target-dir":"src/org/apache/cordova/inappbrowser"},"text":"","tail":"\n        ","_children":[]},{"_id":148,"tag":"source-file","attrib":{"src":"src/android/InAppBrowserDialog.java","target-dir":"src/org/apache/cordova/inappbrowser"},"text":"","tail":"\n        ","_children":[]},{"_id":149,"tag":"source-file","attrib":{"src":"src/android/InAppChromeClient.java","target-dir":"src/org/apache/cordova/inappbrowser"},"text":"","tail":"\n\n        \n        ","_children":[]},{"_id":150,"tag":"resource-file","attrib":{"src":"src/android/res/drawable-hdpi/ic_action_next_item.png","target":"res/drawable-hdpi/ic_action_next_item.png"},"text":"","tail":"\n        ","_children":[]},{"_id":151,"tag":"resource-file","attrib":{"src":"src/android/res/drawable-mdpi/ic_action_next_item.png","target":"res/drawable-mdpi/ic_action_next_item.png"},"text":"","tail":"\n        ","_children":[]},{"_id":152,"tag":"resource-file","attrib":{"src":"src/android/res/drawable-xhdpi/ic_action_next_item.png","target":"res/drawable-xhdpi/ic_action_next_item.png"},"text":"","tail":"\n        ","_children":[]},{"_id":153,"tag":"resource-file","attrib":{"src":"src/android/res/drawable-xxhdpi/ic_action_next_item.png","target":"res/drawable-xxhdpi/ic_action_next_item.png"},"text":"","tail":"\n\n        ","_children":[]},{"_id":154,"tag":"resource-file","attrib":{"src":"src/android/res/drawable-hdpi/ic_action_previous_item.png","target":"res/drawable-hdpi/ic_action_previous_item.png"},"text":"","tail":"\n        ","_children":[]},{"_id":155,"tag":"resource-file","attrib":{"src":"src/android/res/drawable-mdpi/ic_action_previous_item.png","target":"res/drawable-mdpi/ic_action_previous_item.png"},"text":"","tail":"\n        ","_children":[]},{"_id":156,"tag":"resource-file","attrib":{"src":"src/android/res/drawable-xhdpi/ic_action_previous_item.png","target":"res/drawable-xhdpi/ic_action_previous_item.png"},"text":"","tail":"\n        ","_children":[]},{"_id":157,"tag":"resource-file","attrib":{"src":"src/android/res/drawable-xxhdpi/ic_action_previous_item.png","target":"res/drawable-xxhdpi/ic_action_previous_item.png"},"text":"","tail":"\n\n        ","_children":[]},{"_id":158,"tag":"resource-file","attrib":{"src":"src/android/res/drawable-hdpi/ic_action_remove.png","target":"res/drawable-hdpi/ic_action_remove.png"},"text":"","tail":"\n        ","_children":[]},{"_id":159,"tag":"resource-file","attrib":{"src":"src/android/res/drawable-mdpi/ic_action_remove.png","target":"res/drawable-mdpi/ic_action_remove.png"},"text":"","tail":"\n        ","_children":[]},{"_id":160,"tag":"resource-file","attrib":{"src":"src/android/res/drawable-xhdpi/ic_action_remove.png","target":"res/drawable-xhdpi/ic_action_remove.png"},"text":"","tail":"\n        ","_children":[]},{"_id":161,"tag":"resource-file","attrib":{"src":"src/android/res/drawable-xxhdpi/ic_action_remove.png","target":"res/drawable-xxhdpi/ic_action_remove.png"},"text":"","tail":"\n\n    ","_children":[]}]},{"_id":162,"tag":"platform","attrib":{"name":"amazon-fireos"},"text":"\n        ","tail":"\n    \n    \n    ","_children":[{"_id":163,"tag":"js-module","attrib":{"src":"www/inappbrowser.js","name":"inappbrowser"},"text":"\n            ","tail":"\n        ","_children":[{"_id":164,"tag":"clobbers","attrib":{"target":"window.open"},"text":"","tail":"\n        ","_children":[]}]},{"_id":165,"tag":"config-file","attrib":{"target":"res/xml/config.xml","parent":"/*"},"text":"\n            ","tail":"\n\n        ","_children":[{"_id":166,"tag":"feature","attrib":{"name":"InAppBrowser"},"text":" \n                ","tail":"\n        ","_children":[{"_id":167,"tag":"param","attrib":{"name":"android-package","value":"org.apache.cordova.inappbrowser.InAppBrowser"},"text":"","tail":"\n            ","_children":[]}]}]},{"_id":168,"tag":"source-file","attrib":{"src":"src/amazon/InAppBrowser.java","target-dir":"src/org/apache/cordova/inappbrowser"},"text":"","tail":"\n        ","_children":[]},{"_id":169,"tag":"source-file","attrib":{"src":"src/android/InAppBrowserDialog.java","target-dir":"src/org/apache/cordova/inappbrowser"},"text":"","tail":"\n        ","_children":[]},{"_id":170,"tag":"source-file","attrib":{"src":"src/amazon/InAppChromeClient.java","target-dir":"src/org/apache/cordova/inappbrowser"},"text":"","tail":"\n        \n        \n        ","_children":[]},{"_id":171,"tag":"resource-file","attrib":{"src":"src/android/res/drawable-hdpi/ic_action_next_item.png","target":"res/drawable-hdpi/ic_action_next_item.png"},"text":"","tail":"\n        ","_children":[]},{"_id":172,"tag":"resource-file","attrib":{"src":"src/android/res/drawable-mdpi/ic_action_next_item.png","target":"res/drawable-mdpi/ic_action_next_item.png"},"text":"","tail":"\n        ","_children":[]},{"_id":173,"tag":"resource-file","attrib":{"src":"src/android/res/drawable-xhdpi/ic_action_next_item.png","target":"res/drawable-xhdpi/ic_action_next_item.png"},"text":"","tail":"\n        ","_children":[]},{"_id":174,"tag":"resource-file","attrib":{"src":"src/android/res/drawable-xxhdpi/ic_action_next_item.png","target":"res/drawable-xxhdpi/ic_action_next_item.png"},"text":"","tail":"\n        \n        ","_children":[]},{"_id":175,"tag":"resource-file","attrib":{"src":"src/android/res/drawable-hdpi/ic_action_previous_item.png","target":"res/drawable-hdpi/ic_action_previous_item.png"},"text":"","tail":"\n        ","_children":[]},{"_id":176,"tag":"resource-file","attrib":{"src":"src/android/res/drawable-mdpi/ic_action_previous_item.png","target":"res/drawable-mdpi/ic_action_previous_item.png"},"text":"","tail":"\n        ","_children":[]},{"_id":177,"tag":"resource-file","attrib":{"src":"src/android/res/drawable-xhdpi/ic_action_previous_item.png","target":"res/drawable-xhdpi/ic_action_previous_item.png"},"text":"","tail":"\n        ","_children":[]},{"_id":178,"tag":"resource-file","attrib":{"src":"src/android/res/drawable-xxhdpi/ic_action_previous_item.png","target":"res/drawable-xxhdpi/ic_action_previous_item.png"},"text":"","tail":"\n        \n        ","_children":[]},{"_id":179,"tag":"resource-file","attrib":{"src":"src/android/res/drawable-hdpi/ic_action_remove.png","target":"res/drawable-hdpi/ic_action_remove.png"},"text":"","tail":"\n        ","_children":[]},{"_id":180,"tag":"resource-file","attrib":{"src":"src/android/res/drawable-mdpi/ic_action_remove.png","target":"res/drawable-mdpi/ic_action_remove.png"},"text":"","tail":"\n        ","_children":[]},{"_id":181,"tag":"resource-file","attrib":{"src":"src/android/res/drawable-xhdpi/ic_action_remove.png","target":"res/drawable-xhdpi/ic_action_remove.png"},"text":"","tail":"\n        ","_children":[]},{"_id":182,"tag":"resource-file","attrib":{"src":"src/android/res/drawable-xxhdpi/ic_action_remove.png","target":"res/drawable-xxhdpi/ic_action_remove.png"},"text":"","tail":"\n    ","_children":[]}]},{"_id":183,"tag":"platform","attrib":{"name":"ubuntu"},"text":"\n        ","tail":"\n\n    \n    ","_children":[{"_id":184,"tag":"js-module","attrib":{"src":"www/inappbrowser.js","name":"inappbrowser"},"text":"\n            ","tail":"\n        ","_children":[{"_id":185,"tag":"clobbers","attrib":{"target":"window.open"},"text":"","tail":"\n        ","_children":[]}]},{"_id":186,"tag":"header-file","attrib":{"src":"src/ubuntu/inappbrowser.h"},"text":"","tail":"\n        ","_children":[]},{"_id":187,"tag":"source-file","attrib":{"src":"src/ubuntu/inappbrowser.cpp"},"text":"","tail":"\n        ","_children":[]},{"_id":188,"tag":"resource-file","attrib":{"src":"src/ubuntu/InAppBrowser.qml"},"text":"","tail":"\n        ","_children":[]},{"_id":189,"tag":"resource-file","attrib":{"src":"src/ubuntu/InAppBrowser_escapeScript.js"},"text":"","tail":"\n        ","_children":[]},{"_id":190,"tag":"resource-file","attrib":{"src":"src/ubuntu/close.png"},"text":"","tail":"\n    ","_children":[]}]},{"_id":191,"tag":"platform","attrib":{"name":"ios"},"text":"\n        ","tail":"\n\n    \n    ","_children":[{"_id":192,"tag":"js-module","attrib":{"src":"www/inappbrowser.js","name":"inappbrowser"},"text":"\n            ","tail":"  \n        ","_children":[{"_id":193,"tag":"clobbers","attrib":{"target":"window.open"},"text":"","tail":"\n        ","_children":[]}]},{"_id":194,"tag":"config-file","attrib":{"target":"config.xml","parent":"/*"},"text":"\n            ","tail":"\n\n        ","_children":[{"_id":195,"tag":"feature","attrib":{"name":"InAppBrowser"},"text":"\n                ","tail":"\n        ","_children":[{"_id":196,"tag":"param","attrib":{"name":"ios-package","value":"CDVInAppBrowser"},"text":"","tail":" \n            ","_children":[]}]}]},{"_id":197,"tag":"header-file","attrib":{"src":"src/ios/CDVInAppBrowser.h"},"text":"","tail":"\n\t    ","_children":[]},{"_id":198,"tag":"source-file","attrib":{"src":"src/ios/CDVInAppBrowser.m"},"text":"","tail":"\n\t    \n\t    ","_children":[]},{"_id":199,"tag":"framework","attrib":{"src":"CoreGraphics.framework"},"text":"","tail":"\n    ","_children":[]}]},{"_id":200,"tag":"platform","attrib":{"name":"wp7"},"text":"\n        ","tail":"\n\n    \n    ","_children":[{"_id":201,"tag":"config-file","attrib":{"target":"Properties/WMAppManifest.xml","parent":"/Deployment/App/Capabilities"},"text":"\n            ","tail":"\n\n        ","_children":[{"_id":202,"tag":"Capability","attrib":{"Name":"ID_CAP_NETWORKING"},"text":"","tail":"\n        ","_children":[]}]},{"_id":203,"tag":"js-module","attrib":{"src":"www/inappbrowser.js","name":"inappbrowser"},"text":"\n            ","tail":"\n        ","_children":[{"_id":204,"tag":"clobbers","attrib":{"target":"window.open"},"text":"","tail":"\n        ","_children":[]}]},{"_id":205,"tag":"config-file","attrib":{"target":"config.xml","parent":"/*"},"text":"\n            ","tail":"\n\n        ","_children":[{"_id":206,"tag":"feature","attrib":{"name":"InAppBrowser"},"text":"\n                ","tail":"\n        ","_children":[{"_id":207,"tag":"param","attrib":{"name":"wp-package","value":"InAppBrowser"},"text":"","tail":"\n            ","_children":[]}]}]},{"_id":208,"tag":"config-file","attrib":{"target":"Properties/WMAppManifest.xml","parent":"/Deployment/App/Capabilities"},"text":"\n            ","tail":"\n\n        ","_children":[{"_id":209,"tag":"Capability","attrib":{"Name":"ID_CAP_NETWORKING"},"text":"","tail":"\n        ","_children":[]}]},{"_id":210,"tag":"source-file","attrib":{"src":"src/wp/InAppBrowser.cs"},"text":"","tail":"\n    ","_children":[]}]},{"_id":211,"tag":"platform","attrib":{"name":"wp8"},"text":"\n        ","tail":"\n\n    \n    ","_children":[{"_id":212,"tag":"config-file","attrib":{"target":"Properties/WMAppManifest.xml","parent":"/Deployment/App/Capabilities"},"text":"\n            ","tail":"\n                \n        ","_children":[{"_id":213,"tag":"Capability","attrib":{"Name":"ID_CAP_NETWORKING"},"text":"","tail":"\n        ","_children":[]}]},{"_id":214,"tag":"js-module","attrib":{"src":"www/inappbrowser.js","name":"inappbrowser"},"text":"\n            ","tail":"\n        ","_children":[{"_id":215,"tag":"clobbers","attrib":{"target":"window.open"},"text":"","tail":"\n        ","_children":[]}]},{"_id":216,"tag":"config-file","attrib":{"target":"config.xml","parent":"/*"},"text":"\n            ","tail":"\n\n        ","_children":[{"_id":217,"tag":"feature","attrib":{"name":"InAppBrowser"},"text":"\n                ","tail":"\n        ","_children":[{"_id":218,"tag":"param","attrib":{"name":"wp-package","value":"InAppBrowser"},"text":"","tail":"\n            ","_children":[]}]}]},{"_id":219,"tag":"config-file","attrib":{"target":"Properties/WMAppManifest.xml","parent":"/Deployment/App/Capabilities"},"text":"\n            ","tail":"\n\n        ","_children":[{"_id":220,"tag":"Capability","attrib":{"Name":"ID_CAP_NETWORKING"},"text":"","tail":"\n        ","_children":[]}]},{"_id":221,"tag":"source-file","attrib":{"src":"src/wp/InAppBrowser.cs"},"text":"","tail":"\n    ","_children":[]}]},{"_id":222,"tag":"platform","attrib":{"name":"windows8"},"text":"\n        ","tail":"\n\n    \n    ","_children":[{"_id":223,"tag":"js-module","attrib":{"src":"www/inappbrowser.js","name":"inappbrowser"},"text":"\n            ","tail":"\n        ","_children":[{"_id":224,"tag":"clobbers","attrib":{"target":"window.open"},"text":"","tail":"\n        ","_children":[]}]},{"_id":225,"tag":"js-module","attrib":{"src":"www/windows8/InAppBrowserProxy.js","name":"InAppBrowserProxy"},"text":"\n            ","tail":"\n    ","_children":[{"_id":226,"tag":"merges","attrib":{"target":""},"text":"","tail":"\n        ","_children":[]}]}]},{"_id":227,"tag":"platform","attrib":{"name":"windows"},"text":"\n        ","tail":"\n  \n    \n    ","_children":[{"_id":228,"tag":"js-module","attrib":{"src":"www/inappbrowser.js","name":"inappbrowser"},"text":"\n            ","tail":"\n        ","_children":[{"_id":229,"tag":"clobbers","attrib":{"target":"window.open"},"text":"","tail":"\n        ","_children":[]}]},{"_id":230,"tag":"js-module","attrib":{"src":"src/windows/InAppBrowserProxy.js","name":"InAppBrowserProxy"},"text":"\n            ","tail":"\n    ","_children":[{"_id":231,"tag":"merges","attrib":{"target":""},"text":"","tail":"\n        ","_children":[]}]}]},{"_id":232,"tag":"platform","attrib":{"name":"firefoxos"},"text":"\n        ","tail":"\n\n","_children":[{"_id":233,"tag":"config-file","attrib":{"target":"config.xml","parent":"/*"},"text":"\n            ","tail":"\n        ","_children":[{"_id":234,"tag":"permission","attrib":{"name":"browser","description":"Enables the app to implement a browser in an iframe.","privileged":"true"},"text":"","tail":"\n        ","_children":[]}]},{"_id":235,"tag":"js-module","attrib":{"src":"www/inappbrowser.js","name":"inappbrowser"},"text":"\n            ","tail":"\n        ","_children":[{"_id":236,"tag":"clobbers","attrib":{"target":"window.open"},"text":"","tail":"\n        ","_children":[]}]},{"_id":237,"tag":"js-module","attrib":{"src":"src/firefoxos/InAppBrowserProxy.js","name":"InAppBrowserProxy"},"text":"\n            ","tail":"\n    ","_children":[{"_id":238,"tag":"merges","attrib":{"target":""},"text":"","tail":"\n        ","_children":[]}]}]}]}},"id":"org.apache.cordova.inappbrowser","version":"0.6.0","name":"InAppBrowser","description":"Cordova InAppBrowser Plugin","license":"Apache 2.0","repo":"https://git-wip-us.apache.org/repos/asf/cordova-plugin-inappbrowser.git","issue":"https://issues.apache.org/jira/browse/CB/component/12320641","keywords":["cordova","in","app","browser","inappbrowser"]}},"_getAllCache":{}},"nohooks":["."]}"
Installing "org.apache.cordova.inappbrowser" for android
Running command: .../mygamename/platforms/android/cordova/version
Command finished with error code 0: .../mygamename/platforms/android/cordova/version
Install start for "org.apache.cordova.inappbrowser" on android.
Beginning processing of action stack for android project...
Parsing android project files...
Copying resource file src/android/res/drawable-hdpi/ic_action_next_item.png to res/drawable-hdpi/ic_action_next_item.png
Copying resource file src/android/res/drawable-mdpi/ic_action_next_item.png to res/drawable-mdpi/ic_action_next_item.png
Copying resource file src/android/res/drawable-xhdpi/ic_action_next_item.png to res/drawable-xhdpi/ic_action_next_item.png
Copying resource file src/android/res/drawable-xxhdpi/ic_action_next_item.png to res/drawable-xxhdpi/ic_action_next_item.png
Copying resource file src/android/res/drawable-hdpi/ic_action_previous_item.png to res/drawable-hdpi/ic_action_previous_item.png
Copying resource file src/android/res/drawable-mdpi/ic_action_previous_item.png to res/drawable-mdpi/ic_action_previous_item.png
Copying resource file src/android/res/drawable-xhdpi/ic_action_previous_item.png to res/drawable-xhdpi/ic_action_previous_item.png
Copying resource file src/android/res/drawable-xxhdpi/ic_action_previous_item.png to res/drawable-xxhdpi/ic_action_previous_item.png
Copying resource file src/android/res/drawable-hdpi/ic_action_remove.png to res/drawable-hdpi/ic_action_remove.png
Copying resource file src/android/res/drawable-mdpi/ic_action_remove.png to res/drawable-mdpi/ic_action_remove.png
Copying resource file src/android/res/drawable-xhdpi/ic_action_remove.png to res/drawable-xhdpi/ic_action_remove.png
Copying resource file src/android/res/drawable-xxhdpi/ic_action_remove.png to res/drawable-xxhdpi/ic_action_remove.png
Action stack processing complete.
Writing out android project files...
Preparing android project
Processing configuration changes for plugins.
Iterating over installed plugins: [ 'com.phonegap.plugins.facebookconnect',
  'cordova-plugin-legacy-whitelist',
  'org.apache.cordova.inappbrowser' ]
Writing out cordova_plugins.js...
Install complete for org.apache.cordova.inappbrowser on android.
Calling plugman.fetch on plugin ".../cachedPlugins.2tS1ac.tmp/cache.4qycPl.pl/cordova-plugin-crosswalk-webview"
Copying plugin ".../cachedPlugins.2tS1ac.tmp/cache.4qycPl.pl/cordova-plugin-crosswalk-webview" => ".../mygamename/plugins/cordova-plugin-crosswalk-webview"
Calling plugman.install on plugin ".../mygamename/plugins/cordova-plugin-crosswalk-webview" for platform "android" with options "{"cli_variables":{},"browserify":false,"link":false,"pluginInfoProvider":{"_cache":{".../cachedPlugins.2tS1ac.tmp/cache.4qycPl.pl/cordova-plugin-crosswalk-webview":{"filepath":".../cachedPlugins.2tS1ac.tmp/cache.4qycPl.pl/cordova-plugin-crosswalk-webview/plugin.xml","dir":".../cachedPlugins.2tS1ac.tmp/cache.4qycPl.pl/cordova-plugin-crosswalk-webview","_et":{"_root":{"_id":25,"tag":"plugin","attrib":{"xmlns":"http://apache.org/cordova/ns/plugins/1.0","id":"cordova-plugin-crosswalk-webview","version":"1.3.1"},"text":"\n\n    ","tail":null,"_children":[{"_id":26,"tag":"name","attrib":{},"text":"Crosswalk WebView Engine","tail":"\n    ","_children":[]},{"_id":27,"tag":"description","attrib":{},"text":"Changes the default WebView to CrossWalk","tail":"\n    ","_children":[]},{"_id":28,"tag":"license","attrib":{},"text":"Apache 2.0","tail":"\n    ","_children":[]},{"_id":29,"tag":"keywords","attrib":{},"text":"cordova,chromium,crosswalk,webview","tail":"\n    ","_children":[]},{"_id":30,"tag":"repo","attrib":{},"text":"https://github.com/crosswalk-project/cordova-plugin-crosswalk-webview","tail":"\n    ","_children":[]},{"_id":31,"tag":"issue","attrib":{},"text":"https://crosswalk-project.org/jira","tail":"\n\n    ","_children":[]},{"_id":32,"tag":"engines","attrib":{},"text":"\n        ","tail":"\n\n    \n    ","_children":[{"_id":33,"tag":"engine","attrib":{"name":"cordova-android","version":">=4"},"text":"","tail":"\n        ","_children":[]},{"_id":34,"tag":"engine","attrib":{"name":"cordova-plugman","version":">=4.2.0"},"text":"","tail":"\n    ","_children":[]}]},{"_id":35,"tag":"platform","attrib":{"name":"android"},"text":"\n        ","tail":"\n","_children":[{"_id":36,"tag":"config-file","attrib":{"target":"res/xml/config.xml","parent":"/*"},"text":"\n            ","tail":"\n\n        ","_children":[{"_id":37,"tag":"preference","attrib":{"name":"webView","value":"org.crosswalk.engine.XWalkWebViewEngine"},"text":"","tail":"\n            ","_children":[]},{"_id":38,"tag":"preference","attrib":{"name":"xwalkVersion","default":"14+"},"text":"","tail":"\n            ","_children":[]},{"_id":39,"tag":"preference","attrib":{"name":"xwalkCommandLine","default":"--disable-pull-to-refresh-effect"},"text":"","tail":"\n            ","_children":[]},{"_id":40,"tag":"preference","attrib":{"name":"xwalkMode","default":"embedded"},"text":"","tail":"\n        ","_children":[]}]},{"_id":41,"tag":"config-file","attrib":{"target":"AndroidManifest.xml","parent":"/*"},"text":"\n            ","tail":"\n\n        ","_children":[{"_id":42,"tag":"uses-permission","attrib":{"android:name":"android.permission.ACCESS_NETWORK_STATE"},"text":"","tail":"\n            ","_children":[]},{"_id":43,"tag":"uses-permission","attrib":{"android:name":"android.permission.ACCESS_WIFI_STATE"},"text":"","tail":"\n        ","_children":[]}]},{"_id":44,"tag":"source-file","attrib":{"src":"platforms/android/src/org/crosswalk/engine/XWalkWebViewEngine.java","target-dir":"src/org/crosswalk/engine"},"text":"","tail":"\n        ","_children":[]},{"_id":45,"tag":"source-file","attrib":{"src":"platforms/android/src/org/crosswalk/engine/XWalkExposedJsApi.java","target-dir":"src/org/crosswalk/engine"},"text":"","tail":"\n        ","_children":[]},{"_id":46,"tag":"source-file","attrib":{"src":"platforms/android/src/org/crosswalk/engine/XWalkCordovaResourceClient.java","target-dir":"src/org/crosswalk/engine"},"text":"","tail":"\n        ","_children":[]},{"_id":47,"tag":"source-file","attrib":{"src":"platforms/android/src/org/crosswalk/engine/XWalkCordovaUiClient.java","target-dir":"src/org/crosswalk/engine"},"text":"","tail":"\n        ","_children":[]},{"_id":48,"tag":"source-file","attrib":{"src":"platforms/android/src/org/crosswalk/engine/XWalkCordovaView.java","target-dir":"src/org/crosswalk/engine"},"text":"","tail":"\n        ","_children":[]},{"_id":49,"tag":"source-file","attrib":{"src":"platforms/android/src/org/crosswalk/engine/XWalkCordovaCookieManager.java","target-dir":"src/org/crosswalk/engine"},"text":"","tail":"\n\n        ","_children":[]},{"_id":50,"tag":"framework","attrib":{"src":"platforms/android/xwalk.gradle","custom":"true","type":"gradleReference"},"text":"","tail":"\n\n        ","_children":[]},{"_id":51,"tag":"hook","attrib":{"type":"after_plugin_install","src":"hooks/after_plugin_install/000-shared_mode_special.js"},"text":"","tail":"\n        ","_children":[]},{"_id":52,"tag":"hook","attrib":{"type":"before_plugin_uninstall","src":"hooks/before_plugin_uninstall/000-shared_mode_special.js"},"text":"","tail":"\n    ","_children":[]}]}]}},"id":"cordova-plugin-crosswalk-webview","version":"1.3.1","name":"Crosswalk WebView Engine","description":"Changes the default WebView to CrossWalk","license":"Apache 2.0","repo":"https://github.com/crosswalk-project/cordova-plugin-crosswalk-webview","issue":"https://crosswalk-project.org/jira","keywords":["cordova","chromium","crosswalk","webview"]},".../mygamename/plugins/cordova-plugin-crosswalk-webview":{"filepath":".../mygamename/plugins/cordova-plugin-crosswalk-webview/plugin.xml","dir":".../mygamename/plugins/cordova-plugin-crosswalk-webview","_et":{"_root":{"_id":53,"tag":"plugin","attrib":{"xmlns":"http://apache.org/cordova/ns/plugins/1.0","id":"cordova-plugin-crosswalk-webview","version":"1.3.1"},"text":"\n\n    ","tail":null,"_children":[{"_id":54,"tag":"name","attrib":{},"text":"Crosswalk WebView Engine","tail":"\n    ","_children":[]},{"_id":55,"tag":"description","attrib":{},"text":"Changes the default WebView to CrossWalk","tail":"\n    ","_children":[]},{"_id":56,"tag":"license","attrib":{},"text":"Apache 2.0","tail":"\n    ","_children":[]},{"_id":57,"tag":"keywords","attrib":{},"text":"cordova,chromium,crosswalk,webview","tail":"\n    ","_children":[]},{"_id":58,"tag":"repo","attrib":{},"text":"https://github.com/crosswalk-project/cordova-plugin-crosswalk-webview","tail":"\n    ","_children":[]},{"_id":59,"tag":"issue","attrib":{},"text":"https://crosswalk-project.org/jira","tail":"\n\n    ","_children":[]},{"_id":60,"tag":"engines","attrib":{},"text":"\n        ","tail":"\n\n    \n    ","_children":[{"_id":61,"tag":"engine","attrib":{"name":"cordova-android","version":">=4"},"text":"","tail":"\n        ","_children":[]},{"_id":62,"tag":"engine","attrib":{"name":"cordova-plugman","version":">=4.2.0"},"text":"","tail":"\n    ","_children":[]}]},{"_id":63,"tag":"platform","attrib":{"name":"android"},"text":"\n        ","tail":"\n","_children":[{"_id":64,"tag":"config-file","attrib":{"target":"res/xml/config.xml","parent":"/*"},"text":"\n            ","tail":"\n\n        ","_children":[{"_id":65,"tag":"preference","attrib":{"name":"webView","value":"org.crosswalk.engine.XWalkWebViewEngine"},"text":"","tail":"\n            ","_children":[]},{"_id":66,"tag":"preference","attrib":{"name":"xwalkVersion","default":"14+"},"text":"","tail":"\n            ","_children":[]},{"_id":67,"tag":"preference","attrib":{"name":"xwalkCommandLine","default":"--disable-pull-to-refresh-effect"},"text":"","tail":"\n            ","_children":[]},{"_id":68,"tag":"preference","attrib":{"name":"xwalkMode","default":"embedded"},"text":"","tail":"\n        ","_children":[]}]},{"_id":69,"tag":"config-file","attrib":{"target":"AndroidManifest.xml","parent":"/*"},"text":"\n            ","tail":"\n\n        ","_children":[{"_id":70,"tag":"uses-permission","attrib":{"android:name":"android.permission.ACCESS_NETWORK_STATE"},"text":"","tail":"\n            ","_children":[]},{"_id":71,"tag":"uses-permission","attrib":{"android:name":"android.permission.ACCESS_WIFI_STATE"},"text":"","tail":"\n        ","_children":[]}]},{"_id":72,"tag":"source-file","attrib":{"src":"platforms/android/src/org/crosswalk/engine/XWalkWebViewEngine.java","target-dir":"src/org/crosswalk/engine"},"text":"","tail":"\n        ","_children":[]},{"_id":73,"tag":"source-file","attrib":{"src":"platforms/android/src/org/crosswalk/engine/XWalkExposedJsApi.java","target-dir":"src/org/crosswalk/engine"},"text":"","tail":"\n        ","_children":[]},{"_id":74,"tag":"source-file","attrib":{"src":"platforms/android/src/org/crosswalk/engine/XWalkCordovaResourceClient.java","target-dir":"src/org/crosswalk/engine"},"text":"","tail":"\n        ","_children":[]},{"_id":75,"tag":"source-file","attrib":{"src":"platforms/android/src/org/crosswalk/engine/XWalkCordovaUiClient.java","target-dir":"src/org/crosswalk/engine"},"text":"","tail":"\n        ","_children":[]},{"_id":76,"tag":"source-file","attrib":{"src":"platforms/android/src/org/crosswalk/engine/XWalkCordovaView.java","target-dir":"src/org/crosswalk/engine"},"text":"","tail":"\n        ","_children":[]},{"_id":77,"tag":"source-file","attrib":{"src":"platforms/android/src/org/crosswalk/engine/XWalkCordovaCookieManager.java","target-dir":"src/org/crosswalk/engine"},"text":"","tail":"\n\n        ","_children":[]},{"_id":78,"tag":"framework","attrib":{"src":"platforms/android/xwalk.gradle","custom":"true","type":"gradleReference"},"text":"","tail":"\n\n        ","_children":[]},{"_id":79,"tag":"hook","attrib":{"type":"after_plugin_install","src":"hooks/after_plugin_install/000-shared_mode_special.js"},"text":"","tail":"\n        ","_children":[]},{"_id":80,"tag":"hook","attrib":{"type":"before_plugin_uninstall","src":"hooks/before_plugin_uninstall/000-shared_mode_special.js"},"text":"","tail":"\n    ","_children":[]}]}]}},"id":"cordova-plugin-crosswalk-webview","version":"1.3.1","name":"Crosswalk WebView Engine","description":"Changes the default WebView to CrossWalk","license":"Apache 2.0","repo":"https://github.com/crosswalk-project/cordova-plugin-crosswalk-webview","issue":"https://crosswalk-project.org/jira","keywords":["cordova","chromium","crosswalk","webview"]}},"_getAllCache":{}},"nohooks":["."]}"
Installing "cordova-plugin-crosswalk-webview" for android
Install start for "cordova-plugin-crosswalk-webview" on android.
Installing Android library: platforms/android/xwalk.gradle
  'android.support.v4',
  'org.apache.cordova.inappbrowser',
  'cordova-plugin-crosswalk-webview' ]
Install complete for cordova-plugin-crosswalk-webview on android.
Updating build files since android plugin contained <framework>
Generating config.xml from defaults for platform "android"
Calling plugman.prepare for platform "android"
Wrote out Android application name to "Tipico Safe Hands"
This app does not have launcher icons defined
Wrote out Android package name to "org.root9.mygamename"
************* Processing the main config.xml file (after_prepare)  *****************
App Directory = [.../mygamename]
Will process and update the following config files:
    Config.xml = [.../mygamename/config.xml]
Namespaces:
    prefix/uri ''/'http://www.w3.org/ns/widgets'
    prefix/uri 'intelxdk'/'http://xdk.intel.com/ns/v1'
Android Manifest Namespaces:
    prefix/uri 'android'/'http://schemas.android.com/apk/res/android'
Name of the app is [Tipico Safe Hands]
Updating full app name to [Tipico Safe Hands]
Processing preference android-minSdkVersion [14]
Processing preference android-targetSdkVersion [19]
Processing preference android-installLocation [auto]
Processing preference Orientation [landscape]
    Added [{http://schemas.android.com/apk/res/android}screenOrientation] with [landscape]
Processing preference permissions
Updating the versionCode
Updating the versionName
Added [{http://schemas.android.com/apk/res/android}debuggable] with [false]
Processing config file values
Saving config.xml to [.../mygamename/config.xml]
************* Completed processing the main config.xml file (after_prepare)  *****************
Running command: .../mygamename/platforms/android/cordova/build --release
ANDROID_HOME=/Developer/android-sdk-linux
JAVA_HOME=/usr/lib/jvm/java-7-oracle
Running: .../mygamename/platforms/android/gradlew cdvBuildRelease -b .../mygamename/platforms/android/build.gradle -Dorg.gradle.daemon=true
embedded
WARNING [Project: :] Current NDK support is deprecated.  Alternative will be provided in the future.
org.xwalk:xwalk_core_library_beta:15+
:preBuild
:compileArmv7ReleaseNdk
:preArmv7ReleaseBuild
:checkArmv7ReleaseManifest
:preX86ReleaseBuild
:CordovaLib:compileLint
:CordovaLib:copyReleaseLint UP-TO-DATE
:CordovaLib:mergeReleaseProguardFiles
:CordovaLib:preBuild
:CordovaLib:preReleaseBuild
:CordovaLib:checkReleaseManifest
:CordovaLib:prepareReleaseDependencies
:CordovaLib:compileReleaseAidl
:CordovaLib:compileReleaseRenderscript
:CordovaLib:generateReleaseBuildConfig
:CordovaLib:generateReleaseAssets UP-TO-DATE
:CordovaLib:mergeReleaseAssets
:CordovaLib:generateReleaseResValues
:CordovaLib:generateReleaseResources
:CordovaLib:packageReleaseResources
:CordovaLib:processReleaseManifest
:CordovaLib:processReleaseResources
:CordovaLib:generateReleaseSources
:CordovaLib:compileReleaseJavaNote: Some input files use or override a deprecated API.
Note: Recompile with -Xlint:deprecation for details.
:CordovaLib:processReleaseJavaRes UP-TO-DATE
:CordovaLib:packageReleaseJar
:CordovaLib:compileReleaseNdk
:CordovaLib:packageReleaseJniLibs UP-TO-DATE
:CordovaLib:packageReleaseLocalJar UP-TO-DATE
:CordovaLib:packageReleaseRenderscript UP-TO-DATE
:CordovaLib:bundleRelease
:com.google.playservices:google-play-services_lib:compileLint
:com.google.playservices:google-play-services_lib:copyReleaseLint UP-TO-DATE
:com.google.playservices:google-play-services_lib:mergeReleaseProguardFiles
:com.google.playservices:google-play-services_lib:preBuild
:com.google.playservices:google-play-services_lib:preReleaseBuild
:com.google.playservices:google-play-services_lib:checkReleaseManifest
:com.google.playservices:google-play-services_lib:prepareAndroidCordovaLibUnspecifiedReleaseLibrary
:com.google.playservices:google-play-services_lib:prepareReleaseDependencies
:com.google.playservices:google-play-services_lib:compileReleaseAidl
:com.google.playservices:google-play-services_lib:compileReleaseRenderscript
:com.google.playservices:google-play-services_lib:generateReleaseBuildConfig
:com.google.playservices:google-play-services_lib:generateReleaseAssets UP-TO-DATE
:com.google.playservices:google-play-services_lib:mergeReleaseAssets
:com.google.playservices:google-play-services_lib:generateReleaseResValues
:com.google.playservices:google-play-services_lib:generateReleaseResources
:com.google.playservices:google-play-services_lib:mergeReleaseResources
:com.google.playservices:google-play-services_lib:processReleaseManifest
:com.google.playservices:google-play-services_lib:processReleaseResources
:com.google.playservices:google-play-services_lib:generateReleaseSources
:com.google.playservices:google-play-services_lib:compileReleaseJava
:com.google.playservices:google-play-services_lib:processReleaseJavaRes UP-TO-DATE
:com.google.playservices:google-play-services_lib:packageReleaseJar
:com.google.playservices:google-play-services_lib:compileReleaseNdk
:com.google.playservices:google-play-services_lib:packageReleaseJniLibs UP-TO-DATE
:com.google.playservices:google-play-services_lib:packageReleaseLocalJar
:com.google.playservices:google-play-services_lib:packageReleaseRenderscript UP-TO-DATE
:com.google.playservices:google-play-services_lib:packageReleaseResources
:com.google.playservices:google-play-services_lib:bundleRelease
:com.phonegap.plugins.facebookconnect:FacebookLib:compileLint
:com.phonegap.plugins.facebookconnect:FacebookLib:copyReleaseLint UP-TO-DATE
:com.phonegap.plugins.facebookconnect:FacebookLib:mergeReleaseProguardFiles
:com.phonegap.plugins.facebookconnect:FacebookLib:preBuild
:com.phonegap.plugins.facebookconnect:FacebookLib:preReleaseBuild
:com.phonegap.plugins.facebookconnect:FacebookLib:checkReleaseManifest
:com.phonegap.plugins.facebookconnect:FacebookLib:prepareAndroidCordovaLibUnspecifiedReleaseLibrary
:com.phonegap.plugins.facebookconnect:FacebookLib:prepareReleaseDependencies
:com.phonegap.plugins.facebookconnect:FacebookLib:compileReleaseAidl
:com.phonegap.plugins.facebookconnect:FacebookLib:compileReleaseRenderscript
:com.phonegap.plugins.facebookconnect:FacebookLib:generateReleaseBuildConfig
:com.phonegap.plugins.facebookconnect:FacebookLib:generateReleaseAssets UP-TO-DATE
:com.phonegap.plugins.facebookconnect:FacebookLib:mergeReleaseAssets
:com.phonegap.plugins.facebookconnect:FacebookLib:generateReleaseResValues
:com.phonegap.plugins.facebookconnect:FacebookLib:generateReleaseResources
:com.phonegap.plugins.facebookconnect:FacebookLib:mergeReleaseResources
:com.phonegap.plugins.facebookconnect:FacebookLib:processReleaseManifest
:com.phonegap.plugins.facebookconnect:FacebookLib:processReleaseResources
:com.phonegap.plugins.facebookconnect:FacebookLib:generateReleaseSources
:com.phonegap.plugins.facebookconnect:FacebookLib:compileReleaseJavaNote: Some input files use or override a deprecated API.
:com.phonegap.plugins.facebookconnect:FacebookLib:processReleaseJavaRes UP-TO-DATE
:com.phonegap.plugins.facebookconnect:FacebookLib:packageReleaseJar
:com.phonegap.plugins.facebookconnect:FacebookLib:compileReleaseNdk
:com.phonegap.plugins.facebookconnect:FacebookLib:packageReleaseJniLibs UP-TO-DATE
:com.phonegap.plugins.facebookconnect:FacebookLib:packageReleaseLocalJar
:com.phonegap.plugins.facebookconnect:FacebookLib:packageReleaseRenderscript UP-TO-DATE
:com.phonegap.plugins.facebookconnect:FacebookLib:packageReleaseResources
:com.phonegap.plugins.facebookconnect:FacebookLib:bundleRelease
:prepareAndroidComGooglePlayservicesGooglePlayServices_libUnspecifiedReleaseLibrary
:prepareAndroidComPhonegapPluginsFacebookconnectFacebookLibUnspecifiedReleaseLibrary
:preArmv7DebugBuild
:preX86DebugBuild
:CordovaLib:copyDebugLint UP-TO-DATE
:CordovaLib:mergeDebugProguardFiles
:CordovaLib:preDebugBuild
:CordovaLib:checkDebugManifest
:CordovaLib:prepareDebugDependencies
:CordovaLib:compileDebugAidl
:CordovaLib:compileDebugRenderscript
:CordovaLib:generateDebugBuildConfig
:CordovaLib:generateDebugAssets UP-TO-DATE
:CordovaLib:mergeDebugAssets
:CordovaLib:generateDebugResValues
:CordovaLib:generateDebugResources
:CordovaLib:packageDebugResources
:CordovaLib:processDebugManifest
:CordovaLib:processDebugResources
:CordovaLib:generateDebugSources
:CordovaLib:compileDebugJavaNote: Some input files use or override a deprecated API.
:CordovaLib:processDebugJavaRes UP-TO-DATE
:CordovaLib:packageDebugJar
:CordovaLib:compileDebugNdk
:CordovaLib:packageDebugJniLibs UP-TO-DATE
:CordovaLib:packageDebugLocalJar UP-TO-DATE
:CordovaLib:packageDebugRenderscript UP-TO-DATE
:CordovaLib:bundleDebug
:com.google.playservices:google-play-services_lib:copyDebugLint UP-TO-DATE
:com.google.playservices:google-play-services_lib:mergeDebugProguardFiles
:com.google.playservices:google-play-services_lib:preDebugBuild
:com.google.playservices:google-play-services_lib:checkDebugManifest
:com.google.playservices:google-play-services_lib:preDebugTestBuild
:com.google.playservices:google-play-services_lib:prepareAndroidCordovaLibUnspecifiedDebugLibrary
:com.google.playservices:google-play-services_lib:prepareDebugDependencies
:com.google.playservices:google-play-services_lib:compileDebugAidl
:com.google.playservices:google-play-services_lib:compileDebugRenderscript
:com.google.playservices:google-play-services_lib:generateDebugBuildConfig
:com.google.playservices:google-play-services_lib:generateDebugAssets UP-TO-DATE
:com.google.playservices:google-play-services_lib:mergeDebugAssets
:com.google.playservices:google-play-services_lib:generateDebugResValues
:com.google.playservices:google-play-services_lib:generateDebugResources
:com.google.playservices:google-play-services_lib:mergeDebugResources
:com.google.playservices:google-play-services_lib:processDebugManifest
:com.google.playservices:google-play-services_lib:processDebugResources
:com.google.playservices:google-play-services_lib:generateDebugSources
:com.google.playservices:google-play-services_lib:compileDebugJava
:com.google.playservices:google-play-services_lib:processDebugJavaRes UP-TO-DATE
:com.google.playservices:google-play-services_lib:packageDebugJar
:com.google.playservices:google-play-services_lib:compileDebugNdk
:com.google.playservices:google-play-services_lib:packageDebugJniLibs UP-TO-DATE
:com.google.playservices:google-play-services_lib:packageDebugLocalJar
:com.google.playservices:google-play-services_lib:packageDebugRenderscript UP-TO-DATE
:com.google.playservices:google-play-services_lib:packageDebugResources
:com.google.playservices:google-play-services_lib:bundleDebug
:com.phonegap.plugins.facebookconnect:FacebookLib:copyDebugLint UP-TO-DATE
:com.phonegap.plugins.facebookconnect:FacebookLib:mergeDebugProguardFiles
:com.phonegap.plugins.facebookconnect:FacebookLib:preDebugBuild
:com.phonegap.plugins.facebookconnect:FacebookLib:checkDebugManifest
:com.phonegap.plugins.facebookconnect:FacebookLib:preDebugTestBuild
:com.phonegap.plugins.facebookconnect:FacebookLib:prepareAndroidCordovaLibUnspecifiedDebugLibrary
:com.phonegap.plugins.facebookconnect:FacebookLib:prepareDebugDependencies
:com.phonegap.plugins.facebookconnect:FacebookLib:compileDebugAidl
:com.phonegap.plugins.facebookconnect:FacebookLib:compileDebugRenderscript
:com.phonegap.plugins.facebookconnect:FacebookLib:generateDebugBuildConfig
:com.phonegap.plugins.facebookconnect:FacebookLib:generateDebugAssets UP-TO-DATE
:com.phonegap.plugins.facebookconnect:FacebookLib:mergeDebugAssets
:com.phonegap.plugins.facebookconnect:FacebookLib:generateDebugResValues
:com.phonegap.plugins.facebookconnect:FacebookLib:generateDebugResources
:com.phonegap.plugins.facebookconnect:FacebookLib:mergeDebugResources
:com.phonegap.plugins.facebookconnect:FacebookLib:processDebugManifest
:com.phonegap.plugins.facebookconnect:FacebookLib:processDebugResources
:com.phonegap.plugins.facebookconnect:FacebookLib:generateDebugSources
:com.phonegap.plugins.facebookconnect:FacebookLib:compileDebugJavaNote: Some input files use or override a deprecated API.
:com.phonegap.plugins.facebookconnect:FacebookLib:processDebugJavaRes UP-TO-DATE
:com.phonegap.plugins.facebookconnect:FacebookLib:packageDebugJar
:com.phonegap.plugins.facebookconnect:FacebookLib:compileDebugNdk
:com.phonegap.plugins.facebookconnect:FacebookLib:packageDebugJniLibs UP-TO-DATE
:com.phonegap.plugins.facebookconnect:FacebookLib:packageDebugLocalJar
:com.phonegap.plugins.facebookconnect:FacebookLib:packageDebugRenderscript UP-TO-DATE
:com.phonegap.plugins.facebookconnect:FacebookLib:packageDebugResources
:com.phonegap.plugins.facebookconnect:FacebookLib:bundleDebug
:prepareOrgXwalkXwalk_core_library_beta154438412Library
:prepareArmv7ReleaseDependencies
:compileArmv7ReleaseAidl
:compileArmv7ReleaseRenderscript
:generateArmv7ReleaseBuildConfig
:generateArmv7ReleaseAssets UP-TO-DATE
:mergeArmv7ReleaseAssets
:createXwalkCommandLineFileArmv7Release
:generateArmv7ReleaseResValues
:generateArmv7ReleaseResources
:mergeArmv7ReleaseResources
:processArmv7ReleaseManifest
:processArmv7ReleaseResources
:generateArmv7ReleaseSources
:compileArmv7ReleaseJavaNote: Some input files use or override a deprecated API.
:preDexArmv7Release
:dexArmv7Release
UNEXPECTED TOP-LEVEL EXCEPTION:
com.android.dex.DexException: Multiple dex files define Landroid/support/annotation/AnimRes;
    at com.android.dx.merge.DexMerger.readSortableTypes(DexMerger.java:596)
    at com.android.dx.merge.DexMerger.getSortedTypes(DexMerger.java:554)
    at com.android.dx.merge.DexMerger.mergeClassDefs(DexMerger.java:535)
    at com.android.dx.merge.DexMerger.mergeDexes(DexMerger.java:171)
    at com.android.dx.merge.DexMerger.merge(DexMerger.java:189)
    at com.android.dx.command.dexer.Main.mergeLibraryDexBuffers(Main.java:454)
    at com.android.dx.command.dexer.Main.runMonoDex(Main.java:303)
    at com.android.dx.command.dexer.Main.run(Main.java:246)
    at com.android.dx.command.dexer.Main.main(Main.java:215)
    at com.android.dx.command.Main.main(Main.java:106)
 FAILED
FAILURE: Build failed with an exception.
* What went wrong:
Execution failed for task ':dexArmv7Release'.
> com.android.ide.common.internal.LoggedErrorException: Failed to run command:
      /Developer/android-sdk-linux/build-tools/22.0.1/dx --dex --output .../mygamename/platforms/android/build/intermediates/dex/armv7/release --input-list=.../mygamename/platforms/android/build/intermediates/tmp/dex/armv7/release/inputList.txt
  Error Code:
      2
  Output:
* Try:
Run with --stacktrace option to get the stack trace. Run with --info or --debug option to get more log output.
BUILD FAILED
Total time: 1 mins 21.839 secs
.../mygamename/platforms/android/cordova/node_modules/q/q.js:126
                    throw e;
Error code 1 for command: .../mygamename/platforms/android/gradlew with args: cdvBuildRelease,-b,.../mygamename/platforms/android/build.gradle,-Dorg.gradle.daemon=true
Command finished with error code 8: .../mygamename/platforms/android/cordova/build --release
ERROR building one of the platforms: Error: .../mygamename/platforms/android/cordova/build: Command failed with exit code 8
You may not have the required environment or OS to build this project
    at ChildProcess.whenDone (/Developer/cordova/5.1.1/node_modules/cordova/node_modules/cordova-lib/src/cordova/superspawn.js:134:23)
    at ChildProcess.EventEmitter.emit (events.js:98:17)
    at maybeClose (child_process.js:743:16)
    at Process.ChildProcess._handle.onexit (child_process.js:810:5)
PaulF_IntelCorp
Tina, can you provide a ZIP of the complete exported Cordova project you got from Construct2? Please attach it to this forum or provide a download link via a private message.
Please do not paste logs to the forum, attach them as files. It is very difficult to read through such posts and inspect the logs.
Tina_S_
I sent you the project via a private message. sorry for posting the log file (didn't know it's that long)
Felipe_M_
Im having the same problem, did you fix it?
PaulF_IntelCorp
Tina, I managed to figure out what is going on (or at least I think I know what is going on). I was able to get a successful build. There's a conflict between the Facebook plugin and the Google Play Games Services plugin in the featured plugins list. That Google Play Games Services plugin is now obsolete and should no longer be used. The build system has been upgraded so that this plugin is no longer needed. It will disappear from the list of featured plugins in the next release. Paul
Here's a summary of how to fix the issue:
  • remove the Google Play Games Services plugin (it is now obsolete, see image below)
  • remove the Facebook plugin you added with the featured list (it is out-of-date)
  • remove the reference to the "inAppBrowser" plugin in your intelxdk.config.additions.xml file
  • add the inAppBrowser plugin using the plugin manager (I'm assuming you need this, since it was in the additions file)
  • add the Facebook plugin but as a "Third-Party Plugin" by specifying "phonegap-facebook-plugin" (see image below)
  • confirm you have set your project to CLI 5.1.1 in the Build Settings section of the Projects tab
  • build your app using Crosswalk (do not use Android, this will not work well, especially for Construct2 games)
For others who are reading this message, one way to recognize the problem is a build log similar to the one shown below and the error messages in the abbreviated detailed build log below the image:
:phonegap-facebook-plugin:FacebookLib:processReleaseJavaRes UP-TO-DATE
:phonegap-facebook-plugin:FacebookLib:packageReleaseJar
:phonegap-facebook-plugin:FacebookLib:compileReleaseNdk
:phonegap-facebook-plugin:FacebookLib:packageReleaseJniLibs UP-TO-DATE
:phonegap-facebook-plugin:FacebookLib:packageReleaseLocalJar
:phonegap-facebook-plugin:FacebookLib:packageReleaseRenderscript UP-TO-DATE
:phonegap-facebook-plugin:FacebookLib:packageReleaseResources
:phonegap-facebook-plugin:FacebookLib:bundleRelease
:prepareAndroidPhonegapFacebookPluginFacebookLibUnspecifiedReleaseLibrary
:compileReleaseAidl
:mergeReleaseAssets
:preDexRelease
:dexRelease
 FAILED
* What went wrong:
Execution failed for task ':dexRelease'.
    /Developer/tools/adt-bundle/android-sdk/build-tools/21.1.2/dx --dex --output .../forum_599093/platforms/android/build/intermediates/dex/release --input-list=.../forum_599093/platforms/android/build/intermediates/tmp/dex/release/inputList.txt
  Error Code:
    2
  Output:
* Try:
BUILD FAILED
Total time: 1 mins 57.679 secs
.../forum_599093/platforms/android/cordova/node_modules/q/q.js:126
                    throw e;
Error code 1 for command: .../forum_599093/platforms/android/gradlew with args: cdvBuildRelease,-b,.../forum_599093/platforms/android/build.gradle,-Dorg.gradle.daemon=true
Command finished with error code 8: .../forum_599093/platforms/android/cordova/build --release
ERROR building one of the platforms: Error: .../forum_599093/platforms/android/cordova/build: Command failed with exit code 8
    at ChildProcess.whenDone (/Developer/cordova/cordova-cli/5.1.1/node_modules/cordova/node_modules/cordova-lib/src/cordova/superspawn.js:134:23)
