Software Archive
Read-only legacy content
17060 Discussions
Build for iOS stuck on processing
CAJazzer
I have been successful building under XDK 3088 until today.  The build now hangs on the PROCESSING step.   Anyone else experiencing this problem?  Apologies if there are other posts related to this, although I have not been able to find any.
Shai_D_
i'm facing just the same issue
Pamela_H_Intel
I will check if it is our iOS build machine.
Anna_R_
I have the same problem. I have been trying to build the iOS app and ...still waiting. I have try several times and doesn't work. It holds on "processing".
Android works fins, the problem seem to be just in iOS.
Walid_S_
I am having the same issue. I was able to successfully build for both Android and iOS yesterday. But today only Android builds succeed. iOS builds are stuck in "Processing" stage
giuseppe_s_
Good evening bad I Same Problem I can not fill LOCKS of processing ?? What can rate ??
edimuj
Hi! Any new info regarding the problem? I'm experiencing the same issue for iOS builds: stuck on processing.
Anna_R_
It seems that the problem has been fixed! I have been able to do it.
CAJazzer
Fixed for me also.  Thanks Intel for the fast response.
Pamela_H_Intel
Yes - thank you all for your patience. Our server was hung. Please try to build again. It should work now.
