Software Archive
Read-only legacy content
17060 Discussions
IOS Build stop in "Processing" status
André_V_
In this morning everything was normal in xdk, I updated 2 apps in android and ios, but now the ios build stop in "processing" and don't finish to build de app. Android is working fine but ios don't advence to "building" status. Something changed?
Elroy_A_Intel
Are you still experiencing this issue? If so, what version of XDK are you using? Can you post a screenshot with the message you are seeing?
Pamela_H_Intel
I will check if it is our iOS build machine.
André_V_
@Elroy the problems persists.
I'm using version 3088
Seems the same error as https://software.intel.com/pt-br/forums/intel-xdk/topic/623696
The build process stops in "processing" only in iOs build in all my projects.
André_V_
Now it's working, thanks
