Software Archive
Read-only legacy content
17060 Discussions
Build server UI not available.
İhsan_T_1
XDK ver. 1912.
Done my project settings and then at the build tab:
I try to build, it shows a dialogue saying: "Loading Build Server UI". The dialogue disappears and nothing happens.
The build tab contents go unresponsive until I press "Close Build Page" button.
Also I try to build from "Intel App Center", this is what I see:
John_H_Intel2
You should not be building from appCenter, instead you should be building from within the XDK.
İhsan_T_1
Have you read my post carefully? I do not think so.
Build does not work from XDK. This is the main problem as I have stated in my post.
I also pointed out that it does not work from appcenter. I do not know if you folks disabled builds from appcenter or not. But if there is an option in user interface of appcenter for building, I will try so. So if we should not, then take it out from appcenter page.
İhsan_T_1
Hello? Any one concerned?
Michael_O_
Dear Ihan Download the latest version of intel xdk from here
Build from there.
İhsan_T_1
The new version is as useless as the older one.
But thanks anyway...
John_H_Intel2
Define useless? What is the issue? Is it with all projects, or just 1? Can you attach screenshots?
Swati_S_Intel1
Hello Ihsan,
As I mentioned in the other thread you posted, this issue is due to language settings and we are looking into the it to find a fix. Thanks for your patience.
Swati
İhsan_T_1
Hi Swati and John,
In contrast to what you may think, all I depend is your patience and attention.
Thank you for that.
You did not fail me. Things happen with programs, it is the nature of our job.
Michael O. pointed me to the new version which you have told me about before, so I informed him that new version did not resolve the problems I have.
Thank you for all your efforts and goodwill.
İhsan T.
