Software Archive
Read-only legacy content
17061 Discussions
Building PAPI 3.5.2 and libpfm4 as native Phi libraries
drMikeT
Environment:
RHEL 6u4 nodes with Intel Phi adapters. MPSS 3.2.3 installed on the hosts.
Has anyone built PAPI 5.3.2 to run on Intel Phis with MPSS 3.2.3? Are there steps documented somewhere in more detail besides the README?
I have tried this configure command line :
$ PATH="/usr/linux-k1om-4.7/bin":$PATH
$ ./configure --with-mic --host=x86_64-k1om-linux --with-arch=k1om \
    --with-ffsll --with-walltimer=cycle --with-tls=__thread  \
    --with-virtualtimer=clock_thread_cputime_id \
    --prefix=$proot \
    CC=icc F77=ifort &&
    make all && make install-all
Any recommendations for --with-walltimer, --with-tls, --with-virtualtimer ?
Also and most importantly, can we build libpfm4 library for the Phis ? And how ?
A more general question concerns how to build native open source code for Phis.
Michael
JJK
New Contributor III
I just downloaded PAPI 5.3.2 and built it using the XE 2015 compiler; I then ran the tests on a Xeon Phi w/ mpss 3.3 installed. Some tests gave warnings, quite a few were skipped but a lot of them passed too.
Also, a libpfm4.so library was built although I cannot tell if it is actually functional.
What problems did you run into?
Frances_R_Intel
To answer the more general question, you might want to check out https://software.intel.com/en-us/forums/topic/401046#comment-1786509, where Evan has posted suggestions for using the Intel compilers and for using gcc.with configure.
drMikeT
Hi Jan,
thanks for the reply. Can you provide the PAPI "configure" command line you used? I was using Cluster Studio 14.0 (or 13.1-SP1) but I did have to go to src/libpfm4 and tweak the config.mk there so it builds (cross-compiles) for Phis.
regards
Michael
JJK
New Contributor III
Hi Michael,
I compiled the code using
CC=icc CXX=icpc ./configure --with-mic --host=x86_64-k1om-linux --with-arch=k1om \
make
which created the libpfm.so files for me; it did not build the test or example code but that also built just fine using
CC=icc CFLAGS=-mmic make
This was done on a CentOS 6.5 machine with mpss 3.3 and icc v15 installed
Perhaps the next step would be to generate RPMs.
drMikeT
Jan Just K. wrote:
Hi Michael,
make
Hi Jan Just,
Are you compiling as root or as a user? I am compiling as user and I still had to
$ cd ./libpfm4
set "PREFIX=." in config.mk and
$ make clean ; make all ; make install
in the libpfm4 directory, otherwise the linker could not link with -lpfm for PAPI.
Can you please run on the Phi side the papi_avail and the papi_component_avail commands? It seems it cannot initialize libpfm4 lib here:
$ ./papi_avail
Available events and hardware information.
PAPI Version             : 5.3.2.0
Vendor string and code   : GenuineIntel (1)
Model string and code    : 0b/01 (1)
CPU Revision             : 3.000000
CPUID Info               : Family: 11  Model: 1  Stepping: 3
CPU Max Megahertz        : 1052
CPU Min Megahertz        : 842
Hdw Threads per core     : 4
Cores per Socket         : 60
Sockets                  : 1
CPUs per Node            : 240
Total CPUs               : 240
Running in a VM          : no
Number Hardware Counters : 0
Max Multiplex Counters   : 64
    Name        Code    Avail Deriv Description (Note)
PAPI_L1_DCM  0x80000000  No    No   Level 1 data cache misses
PAPI_L1_ICM  0x80000001  No    No   Level 1 instruction cache misses
PAPI_L2_DCM  0x80000002  No    No   Level 2 data cache misses
PAPI_L2_ICM  0x80000003  No    No   Level 2 instruction cache misses
PAPI_L3_DCM  0x80000004  No    No   Level 3 data cache misses
PAPI_L3_ICM  0x80000005  No    No   Level 3 instruction cache misses
PAPI_L1_TCM  0x80000006  No    No   Level 1 cache misses
PAPI_L2_TCM  0x80000007  No    No   Level 2 cache misses
PAPI_L3_TCM  0x80000008  No    No   Level 3 cache misses
PAPI_CA_SNP  0x80000009  No    No   Requests for a snoop
PAPI_CA_SHR  0x8000000a  No    No   Requests for exclusive access to shared cache line
PAPI_CA_CLN  0x8000000b  No    No   Requests for exclusive access to clean cache line
PAPI_CA_INV  0x8000000c  No    No   Requests for cache line invalidation
PAPI_CA_ITV  0x8000000d  No    No   Requests for cache line intervention
PAPI_L3_LDM  0x8000000e  No    No   Level 3 load misses
PAPI_L3_STM  0x8000000f  No    No   Level 3 store misses
PAPI_BRU_IDL 0x80000010  No    No   Cycles branch units are idle
PAPI_FXU_IDL 0x80000011  No    No   Cycles integer units are idle
PAPI_FPU_IDL 0x80000012  No    No   Cycles floating point units are idle
PAPI_LSU_IDL 0x80000013  No    No   Cycles load/store units are idle
PAPI_TLB_DM  0x80000014  No    No   Data translation lookaside buffer misses
PAPI_TLB_IM  0x80000015  No    No   Instruction translation lookaside buffer misses
PAPI_TLB_TL  0x80000016  No    No   Total translation lookaside buffer misses
PAPI_L1_LDM  0x80000017  No    No   Level 1 load misses
PAPI_L1_STM  0x80000018  No    No   Level 1 store misses
PAPI_L2_LDM  0x80000019  No    No   Level 2 load misses
PAPI_L2_STM  0x8000001a  No    No   Level 2 store misses
PAPI_BTAC_M  0x8000001b  No    No   Branch target address cache misses
PAPI_PRF_DM  0x8000001c  No    No   Data prefetch cache misses
PAPI_L3_DCH  0x8000001d  No    No   Level 3 data cache hits
PAPI_TLB_SD  0x8000001e  No    No   Translation lookaside buffer shootdowns
PAPI_CSR_FAL 0x8000001f  No    No   Failed store conditional instructions
PAPI_CSR_SUC 0x80000020  No    No   Successful store conditional instructions
PAPI_CSR_TOT 0x80000021  No    No   Total store conditional instructions
PAPI_MEM_SCY 0x80000022  No    No   Cycles Stalled Waiting for memory accesses
PAPI_MEM_RCY 0x80000023  No    No   Cycles Stalled Waiting for memory Reads
PAPI_MEM_WCY 0x80000024  No    No   Cycles Stalled Waiting for memory writes
PAPI_STL_ICY 0x80000025  No    No   Cycles with no instruction issue
PAPI_FUL_ICY 0x80000026  No    No   Cycles with maximum instruction issue
PAPI_STL_CCY 0x80000027  No    No   Cycles with no instructions completed
PAPI_FUL_CCY 0x80000028  No    No   Cycles with maximum instructions completed
PAPI_HW_INT  0x80000029  No    No   Hardware interrupts
PAPI_BR_UCN  0x8000002a  No    No   Unconditional branch instructions
PAPI_BR_CN   0x8000002b  No    No   Conditional branch instructions
PAPI_BR_TKN  0x8000002c  No    No   Conditional branch instructions taken
PAPI_BR_NTK  0x8000002d  No    No   Conditional branch instructions not taken
PAPI_BR_MSP  0x8000002e  No    No   Conditional branch instructions mispredicted
PAPI_BR_PRC  0x8000002f  No    No   Conditional branch instructions correctly predicted
PAPI_FMA_INS 0x80000030  No    No   FMA instructions completed
PAPI_TOT_IIS 0x80000031  No    No   Instructions issued
PAPI_TOT_INS 0x80000032  No    No   Instructions completed
PAPI_INT_INS 0x80000033  No    No   Integer instructions
PAPI_FP_INS  0x80000034  No    No   Floating point instructions
PAPI_LD_INS  0x80000035  No    No   Load instructions
PAPI_SR_INS  0x80000036  No    No   Store instructions
PAPI_BR_INS  0x80000037  No    No   Branch instructions
PAPI_VEC_INS 0x80000038  No    No   Vector/SIMD instructions (could include integer)
PAPI_RES_STL 0x80000039  No    No   Cycles stalled on any resource
PAPI_FP_STAL 0x8000003a  No    No   Cycles the FP unit(s) are stalled
PAPI_TOT_CYC 0x8000003b  No    No   Total cycles
PAPI_LST_INS 0x8000003c  No    No   Load/store instructions completed
PAPI_SYC_INS 0x8000003d  No    No   Synchronization instructions completed
PAPI_L1_DCH  0x8000003e  No    No   Level 1 data cache hits
PAPI_L2_DCH  0x8000003f  No    No   Level 2 data cache hits
PAPI_L1_DCA  0x80000040  No    No   Level 1 data cache accesses
PAPI_L2_DCA  0x80000041  No    No   Level 2 data cache accesses
PAPI_L3_DCA  0x80000042  No    No   Level 3 data cache accesses
PAPI_L1_DCR  0x80000043  No    No   Level 1 data cache reads
PAPI_L2_DCR  0x80000044  No    No   Level 2 data cache reads
PAPI_L3_DCR  0x80000045  No    No   Level 3 data cache reads
PAPI_L1_DCW  0x80000046  No    No   Level 1 data cache writes
PAPI_L2_DCW  0x80000047  No    No   Level 2 data cache writes
PAPI_L3_DCW  0x80000048  No    No   Level 3 data cache writes
PAPI_L1_ICH  0x80000049  No    No   Level 1 instruction cache hits
PAPI_L2_ICH  0x8000004a  No    No   Level 2 instruction cache hits
PAPI_L3_ICH  0x8000004b  No    No   Level 3 instruction cache hits
PAPI_L1_ICA  0x8000004c  No    No   Level 1 instruction cache accesses
PAPI_L2_ICA  0x8000004d  No    No   Level 2 instruction cache accesses
PAPI_L3_ICA  0x8000004e  No    No   Level 3 instruction cache accesses
PAPI_L1_ICR  0x8000004f  No    No   Level 1 instruction cache reads
PAPI_L2_ICR  0x80000050  No    No   Level 2 instruction cache reads
PAPI_L3_ICR  0x80000051  No    No   Level 3 instruction cache reads
PAPI_L1_ICW  0x80000052  No    No   Level 1 instruction cache writes
PAPI_L2_ICW  0x80000053  No    No   Level 2 instruction cache writes
PAPI_L3_ICW  0x80000054  No    No   Level 3 instruction cache writes
PAPI_L1_TCH  0x80000055  No    No   Level 1 total cache hits
PAPI_L2_TCH  0x80000056  No    No   Level 2 total cache hits
PAPI_L3_TCH  0x80000057  No    No   Level 3 total cache hits
PAPI_L1_TCA  0x80000058  No    No   Level 1 total cache accesses
PAPI_L2_TCA  0x80000059  No    No   Level 2 total cache accesses
PAPI_L3_TCA  0x8000005a  No    No   Level 3 total cache accesses
PAPI_L1_TCR  0x8000005b  No    No   Level 1 total cache reads
PAPI_L2_TCR  0x8000005c  No    No   Level 2 total cache reads
PAPI_L3_TCR  0x8000005d  No    No   Level 3 total cache reads
PAPI_L1_TCW  0x8000005e  No    No   Level 1 total cache writes
PAPI_L2_TCW  0x8000005f  No    No   Level 2 total cache writes
PAPI_L3_TCW  0x80000060  No    No   Level 3 total cache writes
PAPI_FML_INS 0x80000061  No    No   Floating point multiply instructions
PAPI_FAD_INS 0x80000062  No    No   Floating point add instructions
PAPI_FDV_INS 0x80000063  No    No   Floating point divide instructions
PAPI_FSQ_INS 0x80000064  No    No   Floating point square root instructions
PAPI_FNV_INS 0x80000065  No    No   Floating point inverse instructions
PAPI_FP_OPS  0x80000066  No    No   Floating point operations
PAPI_SP_OPS  0x80000067  No    No   Floating point operations; optimized to count scaled single precision vector operations
PAPI_DP_OPS  0x80000068  No    No   Floating point operations; optimized to count scaled double precision vector operations
PAPI_VEC_SP  0x80000069  No    No   Single precision vector/SIMD instructions
PAPI_VEC_DP  0x8000006a  No    No   Double precision vector/SIMD instructions
PAPI_REF_CYC 0x8000006b  No    No   Reference clock cycles
Of 108 possible events, 0 are available, of which 0 are derived.
avail.c                                     PASSED
$ ./papi_component_avail
Available components and hardware information.
Sockets                  : 1
CPUs per Node            : 240
Total CPUs               : 240
Compiled-in components:
Name:   perf_event              Linux perf_event CPU counters
   \-> Disabled: Error initializing libpfm4
Name:   perf_event_uncore       Linux perf_event CPU uncore and northbridge
   \-> Disabled: No uncore PMUs or events found
Active components:
component.c                             PASSED
Michael
JJK
New Contributor III
I've compiled everything as a regular but I did not run 'make install' ; I've simply ran some of the examples straight out of the 'src' tree (which is nfs mounted on the Phi). Thus:
$ ldd papi_avail
	linux-vdso.so.1 =>  (0x00007fff42bf7000)
	libm.so.6 => /lib64/libm.so.6 (0x00007febdc5b5000)
	libgcc_s.so.1 => /lib64/libgcc_s.so.1 (0x00007febdc3a3000)
	libc.so.6 => /lib64/libc.so.6 (0x00007febdc04b000)
	/lib64/ld-linux-k1om.so.2 (0x00007febdc7e4000)
	libdl.so.2 => /lib64/libdl.so.2 (0x00007febdbe47000)
$ ./papi_avail
Sockets                  : 1
CPUs per Node            : 240
Total CPUs               : 240
Number Hardware Counters : 2
PAPI_L1_DCM  0x80000000  Yes   No   Level 1 data cache misses
PAPI_L1_ICM  0x80000001  Yes   No   Level 1 instruction cache misses
PAPI_TLB_DM  0x80000014  Yes   No   Data translation lookaside buffer misses
PAPI_TLB_IM  0x80000015  Yes   No   Instruction translation lookaside buffer misses
PAPI_L2_LDM  0x80000019  Yes   No   Level 2 load misses
PAPI_BR_MSP  0x8000002e  Yes   No   Conditional branch instructions mispredicted
PAPI_TOT_INS 0x80000032  Yes   No   Instructions completed
PAPI_LD_INS  0x80000035  Yes   No   Load instructions
PAPI_SR_INS  0x80000036  Yes   No   Store instructions
PAPI_BR_INS  0x80000037  Yes   No   Branch instructions
PAPI_VEC_INS 0x80000038  Yes   No   Vector/SIMD instructions (could include integer)
PAPI_TOT_CYC 0x8000003b  Yes   No   Total cycles
PAPI_L1_DCA  0x80000040  Yes   No   Level 1 data cache accesses
PAPI_L1_ICA  0x8000004c  Yes   No   Level 1 instruction cache accesses
ions
ions
Of 108 possible events, 14 are available, of which 0 are derived.
avail.c                                     PASSED
and
Sockets                  : 1
CPUs per Node            : 240
Total CPUs               : 240
Active components:
                                Native: 140, Preset: 14, Counters: 2
component.c                             PASSED
Now I'm not entirely familiar with the PAPI package but I am seeing different results from what you're seeing.
I did notice that the papi_avail and papi_components_avail commands were linked statically - is that also the case on your box?
