Software Archive
Read-only legacy content
17060 Discussions
Built In Intel XDK Barcode Plugin issue with iPhone 6 Plus (Code 128)
Rodrigo_M_1
New Contributor II
Hi there, It's just to report a bug on built in barcode scanner on Intel XDK.
I was perform some tests with Android device (Galaxy S4), and so far the plugin works as expected, but on iPhone 6 Plus with barcode Code 128, there is a problem on decode this kind of barcode...
Just to give an idea, on iphone looks like that takes more time to scan (the camera did not perform the focus adjust like on Android devices), and when you scan the barcode just to give you an idea, I was trying to scan the follow barcode code 128:
80247110
And I got this results:
17397821
802$''0
00262255
And some times I got the correct scan...
There is any way to fix it ?
Thanks in Advance,
Rodrigo.
Dale_S_Intel
Sorry to hear that.  Unfortunately, this plugin is not being actively maintained.  I would recommend trying another barcode scanner plugin. I haven't tried this one, but it claims to work on Code 128:
https://github.com/phonegap/phonegap-plugin-barcodescanner
Give it a try and let us know if that works for you.
Thanks!
Dale
Dale_S_Intel
Thanks!
Dale
Rodrigo_M_1
New Contributor II
Thanks Dale Schouten !
I'll give it a try as I fix my iOS license to be able to compile to iPhone!
I just was able to test the built in plugin just because it's works with the Intel App Preview!
Thanks for the tip!
Rodrigo.
